Previous in Blog: Reverse Engineering Dinner: CR4 Challenge (03/25/08)   Next in Blog: Fixing The Pump: CR4 Challenge (04/08/08)
Projectiles: Newsletter Challenge (04/01/08)
Posted March 30, 2008 5:01 PM
User-tagged by 1 user
Welcome to April edition of Monthly Challenge Question from Specs & Techs by GlobalSpec:
Two projectiles are launched vertically. Projectile A is launched with an initial velocity v. Projectile B is launched t seconds after the first. Projectile B passed Projectile A as the latter reached its highest point. Determine the initial velocity of projectile B.
(Update: May 22, 9:02 AM EST) And the Answer is...
Consider the following figure depicting the trajectories of the two projectiles. The two projectiles are launched vertically according to the statement of the problem, but in order to make the solution more clear the respect to the timing of the events, we drew the figure as shown. Thus, even if it looks like the angle of launch is less than 90°, it is in fact equal to 90°.
Let Vi1 and Vi2 be the initial velocities of the first and the second projectile, respectively; let V1 be the speed of the first projectile when it reaches its highest point. It is clear that V1=0. Let V2 be the speed of projectile 2 when it crosses projectile 1.
The height h as seen in the picture is given by the following equations for each projectile:
But V1 = 0 and by equating both equation we get (1)
Now, let T be the time for projectile 1 to reach its highest point, then (T - t) is the time for projectile 2 to reach the height h. To determine the value of T we notice that the acceleration of gravity, g, is constant. Thus we can write
Or (2)
We can derive an equivalent equation for projectile 2 in order to determine V2,
Substitute Eq.(2) into the last equation and rearrange to get (3),
Now substitute Eq. (3) into Eq. (1):
Notice that all the quantities in the above equation are known with the exception of Vi2. Now by squaring the parenthesis in the equation and solving for Vi2, we get
This is the solution!
Re: Projectiles: Newsletter Challenge (04/01/08)
04/23/2008 5:11 AM
First, we assume, as it does not state otherwise, that the rockets are launched veritcally. There is no cause to believe that there is a downrange component in the velocity.
Next, we need to find the time it takes rocket 1 to get to its maximum altitude. This will help us to know how long rocket 2 took to get there. We will call its maximum altitude (or height) h. We use the equation v = vo - gt where vo is its initial velocity. Since velocity at max is zero, this becomes 0 = vo - gt. Solving for t we get the time it takes to get to maximum altitude and therefore have zero velocity:
t = vo/g but the problem gives its initial velocity as v, so we will substitute that in.
t = v/g
This is how long it takes rocket 1 to get to height h. Rocket 2 arrives at height h at the same time, so rocket 2 takes time = v/g -t since it was launched at time t after rocket 1.
Now let's look at rocket 2s ascent. We will use the equation of the form
Δy = h = vot -½gt2
This time we solve for vo or rocket 2's initial velocity.
vo = (h + ½gt2)/t
In this case, t is really v/g - t, so let's make that substitution.
vo = (h + ½g(v/g - t)2)/(v/g - t)
This is a little messy, so we do some algebra which results in the simpler form:
vo = (gh + ½(v-gt)2)/(v-gt)
There, now everyone can get some rest.
#99
In reply to #98
04/23/2008 5:22 AM
C'mon Prof - not only does the challenge "not state otherwise" but the first sentence specifically states that the projectiles are launched vertically.
Then, we don't need the parameter 'h' in the answer - so finish the job.
I hope your instructions to students include at least the following:
1) RTFQ
2) So far as is possible, present the answer in terms of the variables given in the question.
04/23/2008 5:56 AM
Picky picky. Prejudiced against h are we? OK. If you insist, the equivalent equation is:
vo = (v2 + (v-gt)2)/(2(v-gt))
So go home and get some sleep. Tomorrow will be a better day.
PS. Some of the discussions were sounding rather sideways.
#101
In reply to #100
04/23/2008 8:18 AM
No prejudice against Planck's constant - it just wasn't relevant to the question
If you are going to spend any time in CR4, you will just have to get used to the ignorant dominating the space for long after a proper answer is presented, or you will go mad. As a corollary, there is no point expanding on existing answers unless you are prepared to be (even?) more meticulous than they were.
"Tomorrow will be a better day" Dubious
In reply to #101
04/23/2008 12:06 PM
It might be a better day... Would you consider registering as a member? That might help!
Good Answers: 15
#110
In reply to #100
04/29/2008 3:23 AM
You'd find that mostly people who are vertically challenged have a "Prejudice against h"
#103
04/23/2008 8:07 PM
Lovely elegant question.
Should have specified identical
projectiles re mass and air resistance.
#104
04/25/2008 7:53 PM
Solution neglecting wind resistance:
initial velocity of projectile B = Vbo
ta = time in seconds of A projectile to reach apex.
t = time in seconds B projectile launches after A launches.
Vbo = 16[ 2(ta)^2 - 2(ta)t + t^2] / ((ta)-t)
The above is the correct answer for this problem. Note t<ta.
#105
In reply to #104
04/26/2008 5:01 PM
Are you one of PhysicsProf's students? He didn't answer the question first time around either.
#109
In reply to #105
04/28/2008 9:38 PM
No sir, I'm just an instrument tech.
#112
In reply to #109
04/29/2008 5:19 AM
That was just meant to say that, accurate or not, the data used in your solution were not those in the challenge - so you haven't (yet) answered it. The prof did the same first time around - I'm not sure whether you would regard yourself as being in good company...
#120
In reply to #105
04/30/2008 11:39 PM
Solution to Projectile Problem: J
Earth's gravitational acceleration on surface of the planet at sea level = 32ft/s2.
Direction is considered downward, a negative value if positive values are upward. Therefore, acceleration of the g-field = -32ft/s2 = a = acceleration.
Projectile motion equations for single dimension shot in the vertical direction are as follows: at + V0 = V and 1/2at2 + V0 t + S0 = S. V0 = initial velocity. S0 = Distance reference at Starting Point. S = final distance. Distance spanned = (S - S0)
Set up equations of projectiles spanning the same distance meeting at the apex of projectile A: (½)a(tA) 2 + VA0 tA = S- S0 = (½)a(tB) 2 + VB0 tB .
Therefore, (½)a(tA) 2 + VA0 tA = (½)a(tB) 2 + VB0 tB
Note that the condition of the problem states that (S- S0) is equivalent to both projectile paths only when projectile A has reached its APEX. Another bit of valuable information.
When the APEX is reached the V=0 for the following equation: at + V0 = V = 0. Since a = -32ft/s2 , we substitute as follows: -32tA+ VA0 = V = 0. -32tA+ VA0 = 0 .
32tA = VA0 . Now that we have confirmed the initial velocity of projectile A, we substitute VA0 = 32tA into the top bold faced equation:
(½)a(tA) 2 + VA0 tA = (½)a(tB) 2 + VB0 tB becomes
(½)a(tA) 2 + (32tA) tA = (½)a(tB) 2 + VB0 tB
(½)a(tA) 2 + 32 tA2 = (½)a(tB) 2 + VB0 tB note a = -32ft/s2.
(½)(-32)(tA) 2 + 32 tA2 = (½)(-32)(tB) 2 + VB0 tB
(-16)(tA) 2 + 32 tA2 = (-16)(tB) 2 + VB0 tB Noting that tB = tA-t
(-16)(tA) 2 + 32 tA2 = (-16)( tA-t) 2 + VB0 (tA-t)
16 tA2 = (-16)( tA-t) 2 + VB0 (tA-t)
16 tA2 = (-16)( tA2-2tAt + t2) + VB0 (tA-t)
16 tA2 = (-16 tA2 + 32 tAt -16 t2) + VB0 (tA-t)
32 tA2 - 32 tAt + 16 t2 = VB0 (tA-t)
VB0 = (32 tA2 - 32 tAt + 16 t2) / (tA-t)
VB0 = 16 (2 tA2 - 2 tAt + t2) / (tA-t) This is the final answer such that {t < tA }.
You may choose values for tA and t at your discretion such that {t < tA }. Plug the values that you wish to solve for the initial velocity of projectile B. This is the complete and accurate solution to the problem.
#122
In reply to #120
05/01/2008 8:18 AM
apart from 32ft/sec2 not necessarily being the appropriate units, and certainly not exact, the problem gives v (I would prefer vA) as the input data. I know substitution is 'trivial', but if you want to lay claim to providing the complete ... solution to the challenge, the answer really needs to be in a compatible format.
#106
04/28/2008 5:59 AM
Strangely, I get the initial velocity of B (when T = 0) as zero.
Too much lateral thinking?
#107
In reply to #106
04/28/2008 6:45 AM
Changing the question while thinking, perhaps?
The projectiles must pass when A is at its top point. Zero velocity would be a solution for them passing when projectile B is at its top point.
BTW, that could be regarded as a more 'interesting' case, as in general there are either two answers or none.
#108
In reply to #107
04/28/2008 9:36 PM
Projectile A will impact ground zero before B will impact the zero level. Therefore, only one answer exists for this problem. Note, both projectiles are subject to the same dominant gravitational force established by the GEOID. This problem assumes that neither projectile attains the escape velocity of the planet. I assumed planet earth's gravitational field and used a constant to serve as the local acceleration over a minimal trajectory. The published solution should verify this reasoning.
#111
In reply to #108
04/29/2008 5:12 AM
Perhaps I was not sufficiently clear - I was writing about the modified problem in which projectile B is launched so that the projectiles pass when projectile B is at the top of its trajectory. As shown by BobD and followers, the original question has a unique solution.
#117
In reply to #111
04/29/2008 2:34 PM
If A projectile passes B projectile, re-label "A" to "B" and "B" to "A" and the equation holds true, again.
#118
In reply to #117
04/29/2008 3:47 PM
Yes, the equations hold true (so long as we remember also to change the sign of TB).
But the equation is no longer explicit. We need to solve the quadratic to find VB. The result is that not all combinations of TB and VA give solutions. I think you will find that if you launch B before A there will either be two solutions (both with upwards velocity) or none.
In reply to #118
05/01/2008 12:23 PM
"...there will either be two solutions..."
OK, maybe it's so simple I just can't see it, so lend me some glasses before I make a spectacle of myself, please. But wouldn't one of those two solutions have to follow a negative timeline? <-blind...
#124
In reply to #123
05/01/2008 4:35 PM
This is for launching B before A, knowing when and how fast A will be launched - and requiring that A passes B when B is at its highest point (heavens knows why you would wish to do this, but it's taken from the implication of MadMike's comment).
The obvious case is when they are launched at the same time - B can be stationary or at the same velocity as A. The easiest way to see this might be to consider when B would need to be launched for A to pass it at a given height. One way to show the effect would be to draw a pair of identical parabolas (like MPM's), one on a sheet of paper (for projectile A) with a base-line representing the launch height, and one on a transparency (for projectile B). If you place the transparency with its parabola's highest point coincident with the launch of projectile A, and then slide the transparency up the parabola, you will see the launch point for projectile B starts coincident with projectile A, gets earlier for a while and then gets later. [There's only one valid solution if you launch B after A, unfortunately]
Alternatively, you could solve BobD's equation with the velocity variables swapped...
#121
In reply to #107
04/30/2008 11:41 PM
See message #120
#113
04/29/2008 12:07 PM
A couple of little things:
The objects are projectiles, not rockets. Energy profiles are different.
Objects thrown in air do not describe parabolic paths; hence, the need for an understanding of ballistics for weapons to be successful.
I think this "elementary" Challenge is quite good.
Good Answers: 15
#119
In reply to #113
04/29/2008 11:28 PM
I beg to differ.
Each projectile thrown in the air will follow a parabolic course, height over time, or as it gets higher, the velocity decreases by a known constant until it hits the top of the parabola, then it accelerates back down the other side along the same accel constant.
so, the plotted path for height to time, will be a parabola
Good Answers: 22
#125
05/08/2008 2:12 PM
Two days after the Official Answer was supposed to be posted, and it hasn't shown up yet. No one else has even commented on the delay. Has anyone noticed? Or has everyone stopped caring?
Inquiring minds want to know! (At least one does, anyway.)
In reply to #125
05/08/2008 3:58 PM
Apparently no one else noticed. Or they all stopped caring. Maybe both... Why not just presume that YOUR answer was the most correct, and just get on with your bad self?
Good Answers: 22
#127
In reply to #126
05/08/2008 9:53 PM
Well, I haven't posted an answer on this one. I'm out of practice on deriving equations, and was hoping to catch a clue here.
Maybe we can get Skeeter to do some experiments, and then get Tee Square to comment on them! Of course, that will get Fyz involved, then Kris and you will interject some humor and/or poetry.
Good Answers: 15
#128
In reply to #127
05/09/2008 12:27 AM
I thought the post had gone so far off track, that all was lost, and the falling projectiles had landed on the people who fired them in the first place
In reply to #128
05/09/2008 7:32 AM
We should be so lucky! (Oooops, did I say that out loud?)
#129
In reply to #125
05/09/2008 5:50 AM
Personally, I don't care, as I can't see that it will add anything: BobD got his sums right, and PhysicsProf among others (eventually) provided a worked version.
In reply to #129
05/09/2008 7:35 AM
So you're saying "stick a fork in it"?
#132
In reply to #131
05/09/2008 8:19 AM
Non comprendo
In reply to #132
05/09/2008 8:28 AM
As in "stick a fork in it to see if it's done"! It's done?
#134
In reply to #133
05/09/2008 8:36 AM
Aha. But too late already (it's burnt to a frazzle).
In reply to #134
05/09/2008 9:05 AM
Flaming projectiles?!? OMG! ...tracer rounds, maybe...
#136
In reply to #135
05/09/2008 9:37 AM
I thought they were celebratory fireworks...
In reply to #136
05/09/2008 3:32 PM
Could have been. Hope it wasn't signal flares from someone in distress, they'd be in SORRY shape by now...
#138
In reply to #137
05/09/2008 4:50 PM
I reckoned the idea must have been to design the display so that the irresponsible party could walk around lighting the fireworks in turn, and still have the drama of pairs of fireworks meeting in mid air. [I'm running short of imagination here as to why would anyone try to do that with distress flairs - over to you]
In reply to #138
05/09/2008 4:58 PM
Flares with flair - perhaps a damsel in distress with an overactive fashion sense...
#140
05/12/2008 4:37 PM
Where is the answer?
Good Answers: 22
#141
In reply to #140
05/12/2008 11:35 PM
You tell me, and then we'll both know.
The answer my friend is blowin' in the wind, the answer is blowin' in the wind. - Bob Dylan.
#142
05/16/2008 11:16 AM
Where is the official answer?
Friend of CR4
05/22/2008 9:04 AM
The answer is posted.
3Doug (5); Anonymous Poster (25); bhasker (1); BobD (4); Cardio07 (1); Chris Leonard (1); dageng43 (2); Enrico Simone (1); EnviroMan (21); HUX (2); instrumenttech2001 (6); isloorkar (1); its me (1); jdretired (1); JohnAdriaan (1); Kris (12); madmikehooper (1); Maths_Physics_Maniac (3); miwukkid (1); ORDE (1); Physicist? (24); PhysicsProf (2); RickLee (3); Snaketails (7); TeeSquare (7); tkot (5); TurnerV (1); user-deleted-1105 (2); vik (1)
