Previous in Blog: On A Forgotten Island: CR4 Challenge (03/18/08)   Next in Blog: Projectiles: Newsletter Challenge (04/01/08)
95 comments
Reverse Engineering Dinner: CR4 Challenge (03/25/08)
Posted March 23, 2008 5:01 PM
Tom is trying to reverse engineer a delicious dinner he recently had at a local restaurant. After listening to Tom describe the meal, John recommends that Tom dissolve sea salt in extra virgin olive oil, add basil and oregano, coat the chicken breasts with the oil seasoning, and cook in an oven at 400 F for 1 hour. Tom looks at John in disbelief and says "You don't cook much, do you?" What's wrong with John's recipe?
(Update: April 1, 10:42 PM EST) And the Answer is...
Tom knows that salt cannot be dissolved in oil, but that is not his biggest concern. The serious flaw in John's recipe is the extra virgin olive oil. Although the smoke point for extra virgin olive oil is about 400 degrees F and the oil may survive, oxidation of nourishing substances found in extra virgin olive oil, as well as acrylamide formation, can occur at cooking temperatures very closer to the 300F range. Regular olive oil should be used.
Source:
http://www.whfoods.com/genpage.php?tname=foodspice&dbid=132
http://answers.yahoo.com/question/index?qid=20070123100846AAe8Cl4&show=7
Re: Reverse Engineering Dinner: CR4 Challenge (03/25/08)
03/24/2008 6:25 PM
The salt won't dissolve in the oil very well. He's be better off to coat the chicken in oil then sprinkle the salt over the top.
03/25/2008 1:49 AM
You are absolutely right.
It is the basis for the old adage that served we well over the years (especially trying to get large amounts of Vaseline out of my hair...long story and embarrassing. You'll have to get me drunk to tell it)...
Like Dissolves Like.
Basically, salt is an ionic molecule, oil is a covalent molecule. I forget which one shares and which one transfers electrons but I will stake my reputation that that is the reason (not that it's a bet worth much)
03/25/2008 6:40 AM
Actually, you would rub the salt on the chicken, and then coat it with oil.
That allows the moisture on the chicken to dissolve the salt.
The oil helps to seal in the moisture and keep the skin of the chicken from drying out too much.
Good Answers: 7
03/25/2008 9:41 AM
Think in scientific terms. The salt will dehydrate the skin and so assist in the browning -= putting oil on first will waterproof the chicken skin and stop dehydration.
Note an unrefined oil contains lecithins, free fatty acids and other goodies (great for flavour when raw but tend to decompose and cause problems at high temperatures) better to use refined oil for high temperatures.
You can always tell the pioneers - they are the ones with arrows in their backs.
03/24/2008 10:20 PM
I assume Tom is well refined enough to be purchasing only the highest quality extra virgin olive oil. The high end products have a larger free fatty acid content and a much lower smoke point- 375Deg F and lower.
At 400 degF Tom's quality oil will be testing his smoke detector and possibly sprinkler system. Tom ignores Johns recipe to prevent the fire.
03/25/2008 6:53 AM
I believe you've hit the nail on the head.
I had to learn about oil flash points the hard way some years back. A bag of oil absorbent and 2 fire trucks later everything was under control. Luckily for me, the absorbent was able to get the fire out before the fire fighters got there and hosed down my kitchen.
Good Answers: 123
03/25/2008 12:09 PM
Even the fire department has these moments. The first time the crew was going to deep fry a turkey, they bought a complete frying set. They bought 5 gallons of peanut oil, Fired that mother up and waited for the New thermometer to reach the magic 325* number. Time slipped away and still not hot enough yet. The thermometer gets to 250* and the oil starts to smoke. By 275 the airport control tower wants to know if the fire station is on fire. When it reached 300 it was close enough. The amount of oil that shot out of the back end of the turkey was un believable. pulled the turkey out removed oil a little at a time till the oil stayed below the rim when the turkey went back in. ten minuets before the scheduled time for the turkey to come out his leg bone was so burnt that it fell off from the boiling action. That was it ,pulled the bird cut it open and threw it all out.
The thermometer later showed that in boiling water the gauge was still at 90*.
Bob
03/27/2008 4:49 PM
A good story, a good laugh and a good argument for calibration. Thanks Bob. TK
intellectuals solve problems, geniuses prevent them ~ Einstein
03/25/2008 7:18 AM
The oven may be at 400-DegF, but unless it's a fan oven there's little chance the oil that is actually on the chicken will reach more than about 300-DegF - which shouldn't be a problem. But as stated elsewhere the chicken will be drastically overcooked. Then, although salt does not dissolve in olive oil, I doubt this on its own would cause incredulity about John's level of cooking experience - more a mental query as to whether he properly understands his terminology.
If it were my meal, I would emulsify the salt and the oregano together with crushed garlic** and some other herbs and spices, using just sufficient olive oil to create a paste, and spread it over the chicken and cook for about twenty minutes. I would also only sprinkle the basil (or a basil paste) over the chicken immediately after removing the chicken from the oven.
**For my portion I would omit the salt - and depending on my guests, I might include the salt and/or omit the garlic from some portions...
03/25/2008 7:59 AM
I must agree, the 400 Degree F setting is quite high here. The chicken will be burnt to a crisp.
03/24/2008 11:26 PM
I think it has something to do with the fact that oil and the sait will not mix. Eitehr that or that he's using reverse polish for the order of the recipe's steps.
03/25/2008 1:57 AM
You Countryist. I have relatives that are Polish (even though I am not...Polish logic).
er...I hope my Polish friends aren't reading this, but if they are...
...era yeht fi tub ,siht gnidaer t'nera sdneirf hsiloP ym epoh I...re .(cigol hsiloP...ton ma I hguoht neve) hsiloP era taht sevitaler evah I .tsiyrtnuoC uoY
(PS If you're lesdysic you understood the second half. Try typing something backward...it will cause you to re-evaluate your typing skills )
03/25/2008 6:43 AM
now i understand the comment about the vaseline
03/25/2008 7:10 AM
LOL, good, and a you're a quick study, cause it took me a bottle and a half of shampoo, 80 gallons of hot water, an hour's contemplation with a straight razor, all counterpointed by my father's poorly contained guffaws until I thought about lighter fluid.
And do you know how scary a head full of lighter fluid is to a kid in a house full of smokers?
And all of this just so my hair would stay slicked back like the stylized Vladimir Dracul on Halloween. There was black shoe polish involved as well. The only saving grace is that was long before cell phone or digital cameras, and my family had a lackadaisical approach to having film on hand.
03/25/2008 10:19 AM
I've used lighter fluid to 'rescue' some shirts that my wife thought were doomed to go into the trash can. My wife is well-endowed in the chest area (nice when she was young; a bit of a pain to her as she approaches middle-age), and she somehow manages to drip bits of oil, fats, sauces, etc., onto her shirts.
The usual stain remover products she was using for the laundry did no good whatsoever in removing these greasy spots. So one day whan she was lamenting that a brand-new blouse was ruined I suggested she try soaking the spot in lighter fluid, blotting it with paper towels, and then washing the blouse again. She was wary, so I said I'd do it. (Big mistake as now I'm stuck doing this every time she stains a shirt.) This worked, and after the blouse was washed it looked good as new.
03/26/2008 5:02 PM
Another, and possibly safer, option is to rub butter into the stain. Looks a real mess, but is a great way of getting dirty black motor-oil stains out of clothes. The butter disolves the motor oil, then hot water and soap/detergent cleans off the butter/oil mixture.
United States - Member - New Member Popular Science - Weaponology - New Member
Good Answers: 7
03/24/2008 11:29 PM
Extra virgin olive oil while very healthy cold, becomes unhealthy when heated to frying or baking temperatures. Put the olive oil in your dipping sauce or on your salad, and cook with canola oil.
Men are like steel, if they lose their temper they are worthless.
03/25/2008 1:52 AM
Sea Salts cannot be dissolved in Oil, even I know that
Good Answers: 7
03/25/2008 2:37 AM
"dissolve sea salt in extra virgin olive oil," come off it!!! Cannot be done!!!
03/25/2008 8:27 AM
Contrary to popular belief, it can. The only problem we now face is getting Zaphod Beeblebrox's Grandson to have a second accident with a prophylactic and a time machine <arcane reference alert! Either read Douglas Adams '"Hitchhikers Guide to the Galaxy" or listen to Ray Steven's version of "I'm My Own Grandpa" Either will get you to the appropriately twisted frame of mind.
The only thing I as is, that if it turns into a whale plummeting to the earth at 9.8 m/s2 down, you explain to it that it is really a bird and its name is based on it's landing sound. I always wanted to hear a whale, falling 30k meters to its death, would shout the name of "Squalshp" and the sound of his name would reverberate and echo throughout eternity.
That's definitely a Geek reference...but I'm betting that after all of that, there would be a carafe of molecularly salty EVO somewhere in the kitchen or bedroom.
Hobbies - Musician - New Member Engineering Fields - Manufacturing Engineering - New Member
03/25/2008 3:07 AM
Hmmmm...
The salt can't dissolve in the oil because salt is a hydrophilic (gets along well with water) and the oil is a hydrophobic (hates water with a passion) so the two can't mix.
As for cooking the chicken at 400 deg. F for 1 hour, well, if it doesn't catch on fire the end product might be useful as a new soles for your shoes (if you can slice it into slabs) but that's about it.
Courage is not the absence of fear, but the inner resolve to rise above it....or the inane lapse in judgement brought on by copious imbibitions....Egre Flagrus
03/25/2008 6:57 AM
While your use of Latin terminology was indeed chemical related and you had the hate and love thing going on in spades, I think you might have missed one, small point. There was never an aquatic element introduced into the problem. (unless it was tuna, or 'Chicken of the Sea').
Just sayin,...
03/25/2008 12:00 PM
Hi tomkaighin
Actually, my reference to the aquatic was only to say that they are not "like dissolves like". (as in your post #5)
If you put the salt into the oil with the herbs the salt would just sink to the bottom as it is heavier than the oil. If you then used up all of the oil suspension on the chicken, most of the pieces would be mostly saltless and the last piece or 2 would get all of the salt like an old hunk of jerky.
If I were going to prepare the chicken with the stated ingredients, I would 1st rub the chicken with the salt,(the moisture in the skin would help it to dissolve and stay with the chicken), sprinkle on the herbs (dried type) and then drizzle the oil on top to help the skin crisp up, maintain some of its moisture and also partly protect the herbs from burning into dust. Bake at 350deg. F for 20-30 minutes or until just firm.
Juicy, crispy herb flavored chicken done just right. mmmm mmmm Loving it!
03/25/2008 12:13 PM
If you mix it in a pestle, the salt will absorb water from the herbs and form an emulsion with the oil. Even without that, most methods of spreading the oil distribute the salt at the same time as the oil.
03/25/2008 7:36 AM
You will not dissolve salt in olive oil....
03/25/2008 8:00 AM
The Colonel is going to be very upset with whoever blabbed, even if he doesn't use olive oil.
03/25/2008 8:20 AM
The smoke point for Olive Oil ranges from 320 F to 425 F depending on the free fatty acid percentage. A typical value for Extra Virgin Olive Oil is 410 F. Cooking at 400 F is very close to the smoke point and might burn the oil or at least produce a lot of smoke. 375 is a typical temp when cooking with oil.
Good Answers: 7
03/25/2008 10:04 AM
The moisture in the chicken will delay the tendency to catch fire but vegetable oils like olive can self ignite at high temperatures as many cooks have found.
Good Answers: 38
03/25/2008 8:26 AM
Along with the salt not dissolving in the oil, 1 hour at 400 degrees for chicken breast will probably dry out the breast to be inedible. The basil and oregano should probably be sitting in the oil for several weeks before it even starts to permeate the oil with an infusion. Yes! John does not cook very much!
03/25/2008 9:02 AM
Chicken $2.00/lb, other ingredients $0.5, fuel $0.5. Time 1 hour: You can't reverse engineering anything for $3.00 in an hour!
Reply Off Topic (Score 4)
03/25/2008 9:33 AM
Stuff the chicken with popcorn kernels--bake at 450 F. When it's
ass blows off it's done. Enjoy.. or give to the cats.
03/25/2008 12:00 PM
Oooooh, I like this much better than my beer can up the old cavity trick (and I get to drink the beer . Always a plus). And timer optional.
03/25/2008 9:50 AM
Where's the garlic? My mother taught me that garlic, Italian chesse and olive oil (first press - extra virgin) goes into everything, except tea and coffee.
03/25/2008 9:57 AM
Your mother must have had an original taste in desserts.
03/25/2008 9:53 AM
My mother was a professional caterer, and I grew up "borrowing" good recipes from many sources. The secret is to first be a good cook yourself. After that, a recipe is just a suggestion. Your trained palate will detect the essential ingredients. Your experience will dictate proportions, sensible procedures, including cooking temperature.
John is not unique, even cookbook recipes contain some strange suggestions and should be interpreted in the spirit of "good engineering practice".
Is there any knowledge in the world which is so certain that no reasonable man could doubt it? Bertrand Russell
03/25/2008 11:44 AM
The salt won't dissolve in the olive oil.
However, John does know what he's talking about because even though it won't dissolve in the oil (lipids inert to ionic combination with NaCl), the moisture from the chicken will absorb enough of the salt when cooking (it does combine with water ionically) to make a lovely difference in that recipe for herbed chicken. It's not whether John's cooking is frequent or not that's the point here, because the dissolution of the salt in the oil is completely unnecessary to achieve the desired effect. More like Tom is just a bit overbearing in his comments. I suspect the chicken breasts are covered with foil and at 400o for an hour will come out juicy and delicious.
Mark
(But, if the salt is dissolved in cider vinegar first, as in a vinaigrette salad dressing, and the oil is beaten in, it will "combine" with the sea salt in a miscible fluid enough to coat the chicken. The vinegar will boil off leaving behind a sweet taste.)
03/25/2008 12:28 PM
And maybe, just maybe, the lack of an instruction to enclose the chicken in foil is the what that is wrong with the recipe?...
03/25/2008 12:29 PM
I agree with Mark. If you want to season the meat with the sea salt, you need to dissolve it, preferably in some type of vinegar and water solution, and marinade it (let it soak in) for an hour or two before cooking. To speed up or amplify the process, perforate the meat repeatedly with a toothpick. The vinegar will also help tenderize the meat, as well as add flavor if it is a flavored vinegar (cider, malt, etc.).
After marinading the meat in the vinegary brine, poor it off and save to make a sauce. Then coat the meat in oil and sprinkle on your spices. Add spices to your saucepan as well if you want a strongly flavored sauce. Then heat the sauce to the point where it just simmers a little, without boiling away much liquid, stirring frequently so as not to scorch it. You want to be sure the sauce gets hot enough to kill any bacteria, especially since it was marinading raw chicken! If you want a thicker sauce, add a little cornstarch to the pan before heating.
Also, as others have said, lower the oven temperature a little so as not to burn the olive oil and extend your cooking time a little. If you want a crispier outside on the chicken, use the higher temp oil as suggested and bake at the higher temperature, being careful not to burn the meat. Remove when brown and check for done-ness. If interior meat (especially near bone) is still raw, continue to bake at lower temperature.
That's the way my Mom taught me to cook.
Or....Just throw them on the George Foreman grill after marinading with the spices sprinkled on just before grilling: skip the oil to save calories. Save the juice run-off for the saucepan. Grilling will crisp up the outside nicely, while the inside stays nice and juicy!
03/25/2008 12:50 PM
I used to make a recipe that was functionally similar to this (until I discovered that it tasted better to me without the salt). I would grind herbs, spices garlic and salt together in a mortar and pestle, and continue grinding while adding enough olive oil to make a paste - so I didn't care whether the salt was 'dissolved' or not. I'd then rub it on to the chicken and pop it into the oven; it usually took somewhere between 20-minutes and half and hour to cook. I can't speak as to the exact temperature, as I use an uncalibrated (and variable) oven for this - but I think it would be in the region of 400-440F.
My recipe for this did not include basil, but my general experience when cooking with basil is that its flavour is rather fragile, and only survives if protected from the fiercer heat. So I believe you would either need to place anything containing basil under the skin or add it at the end of cooking.
03/25/2008 2:19 PM
With apologies to my fellow oven cooking kitchen types, with whom I share an appreciation of oven cooking:
Quarter chicken
Garlic powder & Pepper combination both sides. For herbed chicken add the oil, basil, etc. before the pepper/garlic powder
No salt necessary
Place in covered dish
Oven to serving dish in 9-12 minutes done in turntable microwave. (minutes=regular size to grand size)
Eat the best danged moist tender chicken you ever tasted.
Mark
Go on! String me up, all you benighted anti-microwave fanatics. I dare you to try this recipe.
03/26/2008 11:36 AM
stupid
03/26/2008 12:14 PM
Hi, Guest!
I especially appreciate the brevity of your comment. It shows that a lot of thought went into encapsulating what must surely have been a very long and well thought-out discussion as to your opposition to the ideas expressed in my blog above.
Your consideration in shortening your dissertation to just a single word regarding the lack of awareness of...ummm... -whatever- elements in my blog you were opposing is greatly appreciated, and, really, brilliant.
I'll bet your occupation has something to do with editing.
Mark
03/26/2008 12:19 PM
Clearly not nail-on-the 'ead-'itting? (But you could perhaps have marked the original comment "off topic")
Fyz
03/26/2008 2:29 PM
"Stupid is as Stupid does." - Forrest Gump
03/25/2008 12:58 PM
The sea salt should be added after cooking the chicken breasts, and the oil should be applied when the chicken has been at least half ciooked, not during the initial stages. Sea salt doesn't dissolve well in extra virgen olive oil (though it could be suspended) and the oil would burn off and char the seasoning at 400° for an hour. The temperature seems a bit high, although lesser quality ovens and altitude differences may come into play there. I would recommend 350° for 50 minures, and then 400° to brown the meat.
FRIENDS DON'T LET FRIENDS DRIVE HUMMERS
Good Answers: 266
03/25/2008 1:48 PM
Though the salt will not dissolve in the olive oil it's standard practice to mix the two for marinades. Then to be coated on the meat and set in the frig. for about 30 minutes. The oven temperature is a little low should be about 450 for first few minutes to sear in the moisture then dropped to 400 to 350. Chicken breast should be cooked about 35 to 45 minutes an hour seems a bit long.
Others have commented on the burning or smoking of the oil. Finish internal temperature for chicken is about 165 degrees.The surface temperature of the chicken will not get that hot unless too close to the heat source or you cook it over done.
I am not sure if the recipe is reverse engineering. But just trying to duplicate something.
03/25/2008 2:26 PM
You are correct, this is not "reverse engineering" any more than a garbage collector is a "Sanitation Engineer". Some folks just like to use fancy terminology. Cooking, baking, grilling, etc. all fall under the heading of Culinary Arts, and so this is truly more of an Artistic Reproduction, rather than Reverse Engineering.
Engineering can be a science or an application of technology, or both. Some people speak of The Art of Engineering, and once upon a time it was more of an Art, with practitioners acting more like skilled artisans. However, modern Engineering, although just as creative, is based much more in the Scientific Method. Reverse Engineering is applied by utilizing analytical instruments and measuring devices to de-construct an artifact or a process so that it can be replicated. There is usually very little or no guesswork involved, and so very little "artistic license" as there is in the art of cooking. That is not to say that Reverse Engineering will always "get it right" the first time. Iterative design approach, experimentation, and testing, may be necessary to approach 100% accuracy in replication.
Depending on the goal in mind, Reverse Engineering can also lead to product innovation, as the process yields an analytical model that can be re-shaped and "tweaked" to make improvements upon the original. If the goal is to offer only an exact replacement, then no changes are allowed. However, if the goal is to create a product that will meet or exceed the original specifications, then the Design Engineer, like an artist, has some amount of freedom to modify the original, to improve performance, enhance aesthetics as well as manufacturability, reduce cost, or some combination of all of these.
I recently completed a project to Reverse Engineer a product line that my company is currently purchasing from another manufacturer. Since the manufacturer is not about to provide us with detailed engineering drawings or models, this is the only way that we could prepare to produce a replacement product ourselves. When that was completed my boss said, "OK, now we know we can make it the same. How can we make it BETTER and CHEAPER?" In other words, how would we design this product ourselves, using best engineering practices and best fit to our production processes? Thank goodness he didn't say just "CHEAPER"!
03/25/2008 3:07 PM
Salt does not dissolves in oil
03/25/2008 3:48 PM
Hi, jcbriant!
Glad to have you aboard. I think your post agrees with the general concensus in here. Enjoy the CR4 ride! It's quite a trip.
Looking forward to seeing more of you in here,
Mark
Good Answers: 74
03/25/2008 5:28 PM
You don't need herbs or any of the other ingredients to make charcoal. Even if a cooking container would have been mentioned! No hope for a tasty meal. The only way I would cook this is in foil so I could throw it out strait away with out having to clean the mess. Ky.
The Twain Has Met
Good Answers: 15
03/25/2008 10:31 PM
could it be that the Oven doesn't have F on it, only C, so he could have set the oven to 400 (or close enough) and over-crisped the chicken?
03/26/2008 3:14 AM
It get's even more minimal with an Aga ;
03/26/2008 1:21 AM
Traditionally, "seasoning" used for cooking, consisted of just salt and pepper.
ex chef.
If you don't laugh, you cry.
03/26/2008 4:56 AM
Hi, geomech!
Love pepper. Salt's OK. But no glamour? No excitement? No adventure? No appeal to the better taste buds?
Must've been like eating cardboard night after night. How terribly sad.
Mark
03/26/2008 5:13 PM
DON'T SAY THAT! One of my few childhood memories (about 8 yrs old) was of eating a cardboard pizza.
I was at the drive in with parents and got one of the drive in pizza's. No light so I just kinda ate by feel. The pizza was really chewy but heck, it was bought at the theater (yippee).
Anyway, at the break, Dad turned on the light to straighten up the car. I looked at the last slice of pizza in the box and noticed that the top layer of the cardboard had become adhered to the bottom of the pizza. I think I got my daily dose of fiber that day.
03/26/2008 5:16 PM
Gidday MarkTheHandyman,
Love herbs and spices. Just pointing out that the term 'seasoning' strictly refers to salt and pepper. I know everyone refers to different herbs and spices as seasoning but they are incorrect. I come from the old school of cooking and hate using salt and pepper while cooking and only use it as little as possible, as I prefer to let the ingredients supply the flavour. If you want to use salt and pepper use it at the table.
We get great fresh fruit and vegies in Australia and don't need extra flavour enhancer such as salt.
03/26/2008 5:43 PM
Please be even more careful not to propagate the myth that salt is a flavour enhancer.
Salt has its own flavour - 'salty' - but is more likely to hide other flavours that sensitise you to them. It does have some legitimate food uses - to extract excess moisture from other foodstuffs, and as a preservative. (Doubtless there are others, but I can't think of them just now).
03/26/2008 11:01 PM
Ok, Ok , mmmm terms.
Salt.
Barter: First used as currency in Roman times. (Salery)
Seasoning: C'mon, ya gotta say salt augments the flavour of food such as seafood and pasta. You might think its a myth but it works.
Colour enhancer: Throw it in your boiling water it will help keep the green colour in your green vegies (peas, beans broccoli).
With other ingredients it will enhance the golden colour in bread, and give a nicer colour to some processed meats.
Binding Agent: Helps bind meat together in processed goods.
Texture: Helps develop rind in cheese and strengthen gluten in bread dough.
Preservative: Where you you start. Meat, fish, chicken.
But wait there's more....
In reply to #60
03/27/2008 8:44 AM
Do you cohabit with a commercial food technologist, or what? With regard to the effects of salt:
Augment I can accept - it's not the same as enhance. It just happens that I believe the general liking for salt is the result either of its ability to hide 'off' flavours, or of its adictive qualities. Once the addiction is broken, you'll find many people actually dislike this particular form of 'enhancement'. For my personal taste, the only place I find added salt improves matters is on confections that I would otherwise find too sweet (hiding an 'off' flavour?), or where it is a necessary part of the production process (cheese rind, ham - see below).
Before you ask - I also use unsalted butter for cooking
Colour enhancer: no need, as your vegetables will retain their colour if you steam them (and they taste better as well). Even when I learned to cook, I was taught not to salt the water for cooking pulses until just before the end of the cooking time, as it wrecked the texture (or so I was told).
Colouring processed meats: so far as I can sea (sic), salt actually makes them go grey (fine by me). The other colours are due to saltpeter and other agents - and hide a multitude of sins.
Bread: I have neither heard nor observed salt to make bread go golden, other than possibly the crust of steamed white bread (yuck). In any case, I would mistrust a gold colour, unless the bread was based on maize. (Most of the bread I eat is some version of brown, ranging from dull to chocolate).
Preservative: I recommend cold as the main agent where possible. Otherwise, I soak out as much of the salts as possible to get an acceptable flavour.
Texture: generally this is a natural property of any foodstuff.
[Salt on cheese is legitimate as a preservative - mainly to form a rind to exclude air; unlike in meats and vegetables, it cannnot be soaked out. Salt seems almost unavoidable as a consequence, and I happily eat strong Cheddar and blue cheeses, most (all?) of which contain quite noticeable amounts of salt.]
On the subject of Salery, do you know why this vegetable intrinsically tastes slightly salty?
03/27/2008 9:50 AM
Hi, Physicist? !
Ever since I was a kid (which just shows you how long I've been bent!), I've enjoyed eating raw foods. Sashimi, steak tartar, raw liver are all favourites.
I've noticed that adding salt, pepper, and garlic to the above foods during/after cooking them tends to go far towards re-creating the taste of raw.
I'm well aware that many recipes call for spices and seasonings to create new taste sensations.
BUT, a question that has been in my mind for lo these many years is, "Is the basic purpose of seasoning to bring back the taste of the raw food after cooking?"
Mark
In reply to #66
03/28/2008 3:46 PM
We clearly need to know what each-other mean by seasoning. CR4's trained chef tells us it only refers to salt or pepper, but all the standard dictionaries (be it American or English) I have found say seasoning includes any herbs or spices that are used to add flavour. (On that basis, I sometimes have meals that consist exclusively of seasoning!)
For what it is worth, my view is that the main purpose of salt as a seasoning is to disguise "off flavours" that can arise because food needs to be kept (it's kind of hard to kill just 1-kg of wildebeest for a meal). Herbs and spices were used for the same purpose, but that needn't be their primary purpose.
Returning to the salt: in many parts salt was quite a luxury, but when a luxury becomes readily available it tends to become a must-have for a time, and the addictive aspect of salt means that its use has persisted. To my mind, salt does nothing to enhance meat**, whether cooked or raw (and many recipes for steak tartare have quite a lot of salt in them - typically around 0.3%, but I've seen some as high as 0.6%).
**or veg for that matter
Good plain food (raw or suitably cooked) is wonderful, but herbs and spices add variety and enhance the joy of eating.
But the trend of this thread raises another question: northern traditions seems to work on first selecting the meat and then finding accompanying vegetables as a secondary measure. Understandable, I suppose that we should give meat some priority when it is the most expensive item in the meal; but, when the cost of the raw materials ceases to be predominant, is that really an appropriate way to plan all meals?
In reply to #77
03/28/2008 3:57 PM
I've never heard of salt being used to disguise meat starting to turn, but I have heard that cloves and pepper were used for that purpose quite extensively. Salt was always used as a preservative. since not too many biologicals can live on it (except for motorheads on the Nevada Salt Flats, but a lot of them have died on that too)
#82
In reply to #78
03/29/2008 7:14 AM
Small quantities of salt have but little preservative effect, as there needs to be sufficient concentration to dehydrate the 'biologicals'. Salt being expensive, such large quantities would generally only be used for longer-term preservation.
For the short-term, only small quantities would have been used. Even though the salt would have been applied early (a touch of wishful thinking?) there would be no significant preservative effect; so presumably the disguise worked to some extent.
In reply to #77
03/28/2008 4:31 PM
Seasoning :
My take would be that it's meaning is not that different to its usage as applied to timber. It's a process of making a product more suited to purpose. That leaves it pretty open to mean anything you do to raw food ingredients, not just the added stuff, but how it is cooked (or not) !
Salt :
The dangers of excess are fairly widely known, and few Western people need salt added to food. I don't use much, but I love a bit of salt on my (soft) boiled eggs. As an aside, a TV documentary experimented with a 'stone-age' diet, in which all food was raw. It was mostly fruit and veg, with fish after some time adapting, but no salt. The guinea-pigs initially hated it, but after a few weeks began to enjoy it, and their measured health parameters increased astronomically. A not unrelated program detailed the survival of a guy marooned in a boat for several weeks. After a while, he stopped eating the tasty bits of the fish he caught, and began eating the more odd parts. It's thought that his brain responded to protein excess (which would lead to a malnutrition type starvation) and made the more nutritious bits more appetizing. His brain reacted to the absence of vital minerals etc, and suppressed taste induced like/avoidance until his eating habits arrived at a nutritionally viable part of the fish. That was the theory anyway.
#83
In reply to #79
03/29/2008 7:15 AM
Thanks for an interesting aside on this aside on ...
In reply to #83
03/29/2008 10:02 AM
....a side dish. I once watched a programme about how Japanese households often keep a bucket of salt, in to which various vegetables are placed. The salt draws moisture and helps preserve them. Occasional chunks of cucumber of whatever can be withdrawn and washed, as accompaniment to the meal. Presumably this is done with relish. According to this article, genetics and dietary protein intake are major factors in a liking for salt.
03/27/2008 9:01 PM
I was a qualified Chef.
Augment: I hate using salt. Never have liked it. And you won't find it on my Dining room table. Food should not be enhanced except to maybe to cut down on sweetness. I agree unsalted butter is the best.
Colour enhancer: Yuck. Never use. If you cook your veggies that much that you lose the colour your not a cook. Pretty sure that the salt closes the pores of the vegetables so it makes sense that they will be more colourful but probably tougher.
Processed meats: Yuck. Sorry but i hate processed meats, too many colours and preservatives.
Bread: The salt is used commercially, to break down the sugars thus aiding in the caramelisation of the crust.
Preservative: Can't agree more with you.
Texture: Give you credit for eating blue cheese. Not my cup of tea.
Salary: Salery --- He He Ha Ha, Answer =No. Do you know why people put Celery in Bloody Mary's?
In reply to #72
03/28/2008 6:41 AM
Not tried blue tea with cheese. Project for lunchtime.
Salt + bread = unnecessary other than for pure financial reasons (a little extra time/heat would do the job).
I have yet to work out why anyone would wish to spoil tomato juice by adding salt or vodka, so... no.
You will find salt on my dining table - whenever I spill red wine.
In reply to #74
03/28/2008 1:27 PM
Hi, Physicist? !
I think you missed my query to you in blog #66.
Mark
03/27/2008 4:39 AM
Salt would increase the boiling temperature of boiling water for cooking , say, dried pasta. I don't know if that's significant temperature change, or even if it's desirable....
Here is some interesting discussion on the subject, it seems to be that it's effect on cooking time is more significant. It's horribly reminiscent of the add milk to tea first/last debate.
03/27/2008 8:53 AM
Dried pasta? Might it also reduce the rate of water absorption? Pasta cooks just fine without the salt (not sure if it takes longer, though).
I don't know, but it might be useful in some stews, to even out the cooking rates of the various constituents (but I like my veg al dente, so it's not an issue)
Good Answers: 123
In reply to #63
03/27/2008 9:14 AM
I was told that the added salt is to raise the temperature that the water would boil at. Similar to the effect of a pressure cooker. The higher temperature would cause the pasta to cook faster. What do you experts say to this. ( I still have to read the recipe for boiled eggs.)
Bob
#85
In reply to #64
03/31/2008 4:34 AM
This is a myth. If you make the calculations (I once made them... now I don't have the formulas handy) you will see that the raise of the boiling point of water with a logical amount of salt in it is in the order of one degree. Maybe much less. By far not similar to a pressure cooker effect! And certainly the speedup of the cooking time, is too small to be noticed.
BTW, there is an advice about boiling beans: You are supposed not to add the salt in the beginning. I'm sure it has nothing to do with cooking time or temperature, but rather with the fact that beens may get hardened by the salt (due to osmosis maybe), so you will need extra time to boil them. This is the opposite than what expected, had you taken the boiling point alone into account!
tkot
#86
In reply to #85
03/31/2008 5:59 AM
Geomech said much the same about hardening - but didn't restrict it to beans.
I'm not clear about the mechanism, so what follows is pure speculation: however, similar to the change in boiling temperature, the amount of salt involved seems rather small to rapidly extract moisture through osmosis**. I suspect the effect is to polymerise the skin; to my mind this possibility would be supported by the fact that long soaking in saline solution can be used to accelerate the cooking time of hardened beans (a bit like meat going hard with boiling, and then softening again).
**Although combined with the marginally higher cooking temperature I suppose it might encourage rapid boiling out of the surface moisture.
Good Answers: 123
#88
In reply to #85
04/02/2008 5:48 PM
Now you have done it! My wife, wife's sister, mother, mother in law, both of my grandmothers, and everyone in my family have always added salt to water used to cook pasta. And both families said it was to "make the pasta cook faster". Now my wife and sister in law want me to cook the pasta.
It was your darned knowledge that got me into this mess. I was happy in my stupidity. Now I am hungry and smarter. I hope you're happy now.
Bob
#89
In reply to #88
04/03/2008 9:19 AM
I'm always glad to cause yet another one share my misery .
Anyway, I think engineers - whether we like it or not - are more fit in doing the cooking business. It's applied science isn't it? Sometimes I wonder when my wife accuses me of becoming too "scientific" whenever I cook, when for myself, what I do is just application of common sense...
Anyway, cooking shares one of the most annoying characteristics of engineering: You cannot hide a bad result (unless you eat yourself what you cook), be it due to using ingredients gone bad, or using the wrong tools for the job, or stealing from cooking time to get fast to the table, or poorly supervising the process, or mixing up measurement units... Sooner or later you will be "caught".
tkot
#90
In reply to #88
04/03/2008 3:37 PM
Perhaps these recipes will solve your problem
Good Answers: 123
#91
In reply to #90
04/03/2008 10:10 PM
I,m afraid those recipes are too gourmet for my simple tastes. In my vast sampling of food over many years I have found that there are only five real ways to cook food. Because you were willing to share your recipes with me I now feel obligated to share my five with you. They are in no particular order.
  1. Boil it in water, with a little bit of salt. (now the salt seems to be in question)
  2. Bake it in the oven at 350* till crisp on the outside.
  3. Saute it in a pan on the stove with onions till the onions turn clear.
  4. Grill it on a open flame till the outside turns dark brown.
  5. Nuke it in the microwave till it starts to smoke.
Bon appetite.
Bob
#92
In reply to #91
04/04/2008 5:17 AM
At last I understand your Avatar.
Good Answers: 22
#93
In reply to #90
04/04/2008 2:57 PM
They missed the one with great gooey gobs of greasy gopher guts, itty bitty birdie feet, and granulated monkey meat.
In reply to #93
04/04/2008 4:46 PM
One of my favourite recipes. Had to change the grease to canola oil for the gopher guts tho. Too much cholestrol.
In reply to #63
03/27/2008 9:45 AM
Dried pasta?
Yes indeed ! If that horrifies, you'd be scared rigid by some of the stand-by supplies I keep*. For reasons I know not, the packets always say to add salt. That link I gave previously presents some of the notions surrounding temperature and cooking time. Being dried must affect the water-absorption rate, as evidenced by the longer cooking time compared to fresh, but since all pasta has a small thickness it doesn't seem to matter. To mortify you further, I'm told that dried spaghetti can be cooked by simply putting it in a vacuum flask with boiling water for 10-15 minutes ! Maybe it's a 'save-energy' thing, but it could save resources in the event of a prolonged power cut. Dried pasta versus fresh probably holds the same arguments as fresh/instant coffee (although without so many chemical processes involved).
* I've heard many TV chefs extol the various virtues of canned tomatoes.
In reply to #65
03/27/2008 10:49 AM
Do tomatoes lose their inhibitions when canned?
In reply to #67
03/27/2008 5:38 PM
Only the red-faced ones. The green sort just get pickled.
In reply to #67
03/27/2008 9:17 PM
no, but the uninhibited ones sometimes like to be 'caned'
03/26/2008 9:38 PM
Hi, geomech!
Couple of months ago, a colleague got tons of BIG chicken breasts on sale. Put about 15 (no bone, no skin) into a ceramic dish -side by side, no overlapping-, a sheet of aluminum foil over the top, booted up the oven to preheat to about 425F and stuck em in for about 1/2 hour. No seasonings, herbs or spices at all --nothing. He just forgot! Best, moist, tender delicious chicken breasts I ever ate. Couldn't stop. Ate 3!
I never eat anything that isn't spiced up to be delicious...generally...but those chicken breasts were fantastic.
Ya never know...
Mark
#95
In reply to #59
04/09/2008 7:34 PM
Sorry it took so long to get back here.
Mmmmmm Coq Naturel.
When is Lunch?
03/26/2008 1:58 PM
After cooking for 1 hour @ 400 F the chicken breast either turned to charcoal or best case scenario...Chicken Jerky.
03/26/2008 2:31 PM
mmmmmmm.....Chicken Briquettes!
You know, we really don't get enough Carbon in our diets!
Good Answers: 15
03/27/2008 6:22 PM
What is this "Jerky" stuff?
03/27/2008 7:57 PM
400 for an hour???
sounds like a good recipe for chicken jerky. Especially with the salt leaching out all the available water, as well as the oil smoking at 375, plus the fact the herbs will be blackened, and bitter.
Mens Sana In Corpore Sano
03/28/2008 7:47 AM
Salt will not disolve in oil.
03/29/2008 12:01 AM
Wonder if sea salt will dissolve in oilive oil !!!!
#81
In reply to #80
03/29/2008 2:36 AM
A small amount of protein can be assimilated, if delivered by saline matrix. Temperature and timing is crucial.
#87
04/02/2008 7:32 AM
Another poor answer?
The source (whfoods.com) states that some of the beneficial properties of extra virgin olive oils may be degraded at temperatures as low as 300F - but there is no support there for using "regular" olive oil instead. In any case, by the time the surface temperature of chicken breasts in a 400-degree oven reaches 300-degrees, the chicken underneath will surely have gone hard? The real problem is the excessive cooking time.
Reply to Blog Entry 95 comments
3Doug (1); afabbricante (1); Anonymous Poster (11); ArcticZone (2); bob c (4); charsley99 (1); ckartson (1); cuznmonkey (1); dracosilv (1); fwes (1); garyceng (1); geomech (5); hazman (3); its me (1); jcbriant (1); Kris (7); ky (1); MarkTheHandyman (9); Mevel123 (1); misplayed (1); mpp (1); ozzb (1); Physicist? (15); razambuja (1); RickLee (1); Snaketails (2); snygolfgs (2); SPIJman (1); STL Engineer (4); taejonkwando (1); tkot (2); tomkaighin (9); wabuzaid (1)
