Previous in Blog: Britain Ordered to Destroy its Database of Innocents' DNA   Next in Blog: The Phone That Feels the Flu Before You Do
4 comments
SmartBolts Change Color When They're Tight Enough
Posted December 05, 2008 8:41 AM
From Boing Boing:
Smartbolts have little discs in their heads that change color as the right amount of tension is applied to them. I recently installed a child safety gate with a similar mechanism: a red, spongy washer between the bolt and the frame; once the right amount of tension was on the bolt, the washer was squished down so much it disappeared and you could stop tightening. Unfortunately, a torque-wrench does not measure bolt tension accurately, usually only about +/- 30%, because it does not take friction into account. The friction depends on bolt, nut, washer-material, plating, surface smoothness, machining accuracy, degree of lubrication and the number of times a bolt has been tightened. Fastener manufacturers often provide information for determining torque requirements for tightening various bolts, accounting for friction and other effects. However, in field applications, this information is often not available, practical or administered poorly. SmartBolts (via Red Ferret)
Re: SmartBolts Change Color When They're Tight Enough
12/05/2008 10:01 AM
Great Mother of Pearl - finally!
Hobbies - Fishing - Popular Science - Paleontology - New Member
Good Answers: 27
12/06/2008 3:01 PM
+/- 30%? oh dear...........not good.
Prophet Freddy has the answer!
Good Answers: 230
12/06/2008 10:05 PM
It is worthwhile to read the full article, just for the comments.
I cannot see these bolts being used in everyday situations.
One problem I see is if the clear window is damaged, then the bolt would need to be replaced, even though the metal tensile strength was perfectly OK.
Kind Regards....
12/08/2008 10:12 PM
Now all I need is a sight glass on my torque wrench.
bhankiii (1); Duckinthepond (1); Mevel123 (1); Sparkstation (1)
