Sports, Fitness, and Nutrition Blog
The Sports, Fitness, and Nutrition Blog is the place for conversation and discussion about topics related to sports and sports fitness, general fitness, bodybuilding, nutrition, weight loss, and human health. Here, you'll find everything from nutritional information and advice about healthy eating to training and exercise tips for improving your overall well-being.
Previous in Blog: Are You Getting Enough Fat? (Part 3)   Next in Blog: Open Sesame!
8 comments
Eating to Grow
Posted February 16, 2009 12:00 AM by NaturalPro
Your body is only capable of absorbing so many nutrients in one meal. In order to continually supply your body with essential muscle-building nutrients, your goal should be to eat six to eight small meals that are evenly-spaced throughout the day. The basic rule of thumb is to take in proteins throughout the day at two to three hour intervals, along with a balance of healthy carbohydrates and fats. A meal one to two hours prior to training should have a balance of protein (chicken breast, for example) along with rice, sweet potatoes or oatmeal, and green vegetables.
Don't Make This Mistake
Avoid the mistake of equating sugar with energy. Don't load your body with these types of carbohydrates before your workouts. Otherwise, your blood sugar levels will drop during training, and you will fatigue more quickly and lose endurance. To power through your workout, eat slower-digesting carbohydrates (such as those mentioned above) prior to training.
After the Workout
A fast-absorbing post-workout shake is ideal for spurring muscle recovery and growth. Therefore, immediately after training, a simple carbohydrate and protein shake to raise insulin levels, force carbohydrates back into the muscle cells, and restore glycogen levels is optimal. A post-workout shake should consist of simple sugars and fast-digesting proteins. You can also follow this up about one hour later with another well-balanced meal of protein and carbohydrates.
Editor's Note: The author is a Natural Drug Free WNBF Pro Bodybuilder, 2x Amateur State Champion, Amateur National Champion, and Amateur World Champion.
Re: Eating to Grow
02/16/2009 4:09 AM
This first sentence appears to me be ambiguous and poorly writen.
There may be a limit to the quantity of stuff which can be absorbed, but surely not the number of nutrients??? Which is by my reading the implication.
Maybe I'm wrong but I'd have thought the body quite capable of absorbing every possible type of nutrient (unless there are two which react together in some way) at the same time, within the confines of a small but well balanced meal.
Otherwise it makes sense.
Del (pedantic moi?)
Re: Eating to Grow
02/16/2009 8:00 AM
Studies have shown that our ability to absorb nutrients from the food we eat and supplements we take may decrease as much as 70-90% between the ages of 40 to 60 years of age.
When you can't completely digest your food or nutritional supplements your body cannot absorb the nutrients they contain.
For example high protein foods require a highly acidic environment while starchy foods require a mildly alkaline environment for digestion to take place. An over abundance of nutrient loaded proteins and carbohydrates within one meal can wreak havoc on the digestion system. The acidic and alkaline environment that is needed for digestion to take place actually neutralizes and proper digestion cannot occur, thus valuable nutrients pass through the body unabsorbed.
Good Answers: 146
Re: Eating to Grow
02/16/2009 7:36 AM
Our biochem prof had done some research on endurance training: he recommended a high-carbohydrate meal - such as pasta - immediately after a workout. This combination of conditions would drive metabolic pathways in the direction of storing all that extra carb as glycogen in the muscles. Result = increased endurance on the next workout. This seemed to work well for me.
incus opella
Re: Eating to Grow
02/17/2009 10:06 AM
Wrong.
That is a big mistake a lot of people make after working out.
When you workout your body requires protein. If you eat pasta you are cheating your body of the protein that it craves for and will start digesting your own musle mass to obtain it. That is why you see people that workout and never seem to bulk up.
Good Answers: 146
Re: Eating to Grow
02/17/2009 2:40 PM
I must admit, I can't imagine eating pasta without some protein thrown on.. so I can't say pure carbs worked.
Still the points about carbohydrate metabolism are worth understanding. It's like a switch that gets thrown, where major metabolic pathways are not mutually exclusive but there are amplifying effects in an either/or kind of way: either burning fat or burning carbs is one that's easily tested. Have a high carb breakfast, you will be starving in a couple hours. That's because the major metabolism has been breakdown of carbs to burn sugars for direct use. When they run out, the transition to burning fat is not a quick switch. The carbs to glycogen trick seems perfectly reasonable to me. After a workout, the glycogen in your muscles is depleted. With sugars available to process, they will go to fill that need first, before anything is converted to fats because you 'don't need it just now'.... ??? As I say, it worked for me...
incus opella
Re: Eating to Grow
02/17/2009 2:53 PM
You can't cut out carbohydrates all together. Even if you're trying to loose weight.
If you were to try and eliminate it your body will crave that and you'll end up going on a high carbohydrate binge eating episode.
The body does some things that are interesting.
One is that if your workout is a long and extensive repetition like running, your body will shut down and store energy. It's part of the fight or flight mechanism of your body. This is why long distance runners have a higher body fat percentage then weightlifters, even if they do look skinnier.
Short burst exercises like weight lifting, will trigger your muscles to burn calories even after you've stopped working out. Eating carbohydrates after working out will defeat that purpose.
Good Answers: 146
Re: Eating to Grow
02/17/2009 4:18 PM
Yeh you can say the same for fat. I had to go on the low fat diet some years ago to bring down the cholesterol. I wasn't overweight and the amount of fat in that diet was definitely not enough for my needs. Whatever 'template' they have for height/weight and calories/grams of fat per day was not up to my metabolism. It was brutal and I learned my lesson (and the meaning of the word "devour").
ok I see where you're coming from with the short burst exercises. I didn't know about that.
the workout I was talking about is more like the long distance runner: working all day cutting down firewood with a bucksaw, hauling it back to the house on my shoulder etc etc. Plenty lifting but major workout with endurance required. Maybe that's why I like fat too (thank goodness, an excuse )
incus opella
Hobbies - Car Customizing - New Member
Good Answers: 11
Re: Eating to Grow
02/17/2009 12:35 AM
for recovery, try chocolate milk.
inexpensive and available.
http://www.medscape.com/viewarticle/524370
artsmith (3); Janissaries (2); NaturalPro (1); user-deleted-1105 (1); Yosemit3 (1)
