Previous in Forum: HVAC Question   Next in Forum: Gearing Puzzle
38 comments
Belt Speed
08/17/2015 9:01 AM
What is the belt speed of gear box ratio of 40:1, motor of 1450 revs per minute ,Pulley diameter of 110 mm for both motor and gear box and belt with of 500mm
Re: Belt Speed
08/17/2015 9:07 AM
208.8mms-1
Re: Belt Speed
08/17/2015 9:15 AM
John,
I got 949 mm/sec, I believe you forgot about the belt pulley diameter of 500 mm
but the OP post was a little unclear on this, so I could be wrong.
Good Answers: 122
Re: Belt Speed
08/17/2015 9:24 AM
The 500mm is the belt width not the pulley diameter.
Re: Belt Speed
08/17/2015 9:38 AM
it was a little confusing...... where belt width does have a play here. So I read it as Belt Drive roller.
Good Answers: 122
Re: Belt Speed
08/18/2015 6:59 PM
Me too. I had to re-read it to make sense out of the question.
Hobbies - CNC - New Member
Re: Belt Speed
08/17/2015 9:12 AM
36.25 RPM
Re: Belt Speed
08/17/2015 9:46 AM
I know this is the simplistic answer but the OP hasn't given us near enough information to make a calculation!
Re: Belt Speed
08/17/2015 9:14 AM
Use this formula
V = (R/T) (#RPM/60) m/s, you may use motor side pulley in computation and for T=1sec. Gear ratio does not matter. Cheers!!!
"When I thought I exceeded to be wise but wisdom was far from me" -King Solomon
Good Answers: 122
Re: Belt Speed
08/17/2015 9:31 AM
I think you missed a critical part of the equation.
Belt speed is dependent on how the gearbox is connected: (Reducing or Multiplying)
If the gearbox ratio is 40:1 either the belt speed will be 1/40 of motor speed multiplied by the circumference of the belt pulley or 40 times motor speed multiplied by the circumference of the belt pulley.
Re: Belt Speed
08/17/2015 9:41 AM
Yap, you're right, my bad. I thought about in between center "c". At the circumferential side of both pulleys, velocities varies.
In designing it is crucial to get the maximum velocity- this where the maximum radian acceleration to occur arad = v2/R, definitely at the high speed pulley- the smaller one.
Re: Belt Speed
08/17/2015 9:44 AM
I (maybe wrongly) assumed a reduction gearbox; if a multiplier the belt speed would be about 334ms-1, which sounds a bit swift for such small pulleys.
Re: Belt Speed
08/17/2015 10:21 AM
This would help what I meant- to see the actual. I mean driver and driven.
But, if you mean driver & driven at the same shaft, then its different thing.
Re: Belt Speed
08/17/2015 11:24 AM
I thought that the belt was between the motor and the gear box. This would make the gear ratio extraneous information. Then there is always the uncertainty of belt slippage. A V-belt adds the uncertainty of where the pulley diameter is measured. I'm mildly surprised that nobody used the constant Pi in their answer.
Good Answers: 76
Re: Belt Speed
08/17/2015 9:33 AM
This sounds a little like homework to me, since a real world application the desired belt speed would be an input into sizing the gearbox and motor rpm. Mind you, I could be wrong.
Re: Belt Speed
08/17/2015 11:02 AM
41.1 fpm or 12.53 meters/minute:
1450/40 =36.25 rpm
((110/25.4)/12)(PI)=1.13378 feet/rev
(1.13378)(36.25)=41.099 fpm
Good Answers: 140
Re: Belt Speed
08/17/2015 11:27 AM
Given the information supplied... The only possible "belt" speed that is discernable is the input to the gear box. As such the info on the gear box is a red herring. As critical thinking is required... this is clearly homework. OP... what is your answer?
Re: Belt Speed
08/17/2015 11:48 AM
Π x 110mm x 1450rev/min x 1min/60 sec = 8351.4 mm/sec = 8.3514 m/sec
Gearbox ratio is irrelevant.
Re: Belt Speed
08/17/2015 12:03 PM
That's the answer I calculated as well. Now, the width of the drive belt is 500 mm. That sounds more like a conveyor belt.
Re: Belt Speed
08/17/2015 12:20 PM
How can you say that the gearbox ratio is irrelevant? You do realize 110mm pulley or sheave is mounted on the gearbox output shaft which is rotating at 36.25 rpm??
Re: Belt Speed
08/17/2015 12:30 PM
It doesn't say that. Here's how it reads, "Pulley diameter of 110 mm for both motor and gear box"
I see a motor with a 110 mm diameter pulley, with a belt width width of 500 mm driving a 110 mm pulley mounted on the input shaft of the gear box.
Of course a 500 mm wide belt on a 110 mm diameter pulley seems rather absurd except in the case of a supermarket check out line. At 8.3 meters per second, the check out person had better be fast.
Re: Belt Speed
08/17/2015 12:38 PM
Well, I see your point. But that would be goofy. Why not put a c-face adapter on the motor and mount the motor directly to the gearbox?
I still think it is final belt speed out of the reducer the OP is looking for but he does not say for sure.
I guess we need more input from the OP.
Re: Belt Speed
08/17/2015 12:47 PM
Hey, it's likely a homework problem with some extra numbers thrown in there to foil the student who doesn't have a clue and just adds, subtracts, multiplies, or divides numbers at random hoping to luck into the correct answer.
Good Answers: 140
Re: Belt Speed
08/17/2015 12:49 PM
Agreed...
Re: Belt Speed
08/17/2015 12:52 PM
You're probably right because who would include a belt width measurement when it is a completely unnecessary number. :-)
Re: Belt Speed
08/17/2015 12:19 PM
Dear Mr. lesley Marange,
It is very simple.
Gear Box output Speed = Motor Speed/ Gear Box Ratio i.e., 1450/40 = 40.277 rpm.
Linear Speed (of Belt) = Gear Box Speed x Perimetre of the Pulley ( 3.14 x 0.110) i.e.,
= 40.27 x 3.14 x 0.110 = 13.9119 Metres/Sec.
The Belt width has nothing to do with the Belt Speed. Belt Speed depends upon the gear box ratio and pulley ratio. In your case, both pulleys are same ratio, as stated by you.
DHAYANANDHAN.S
Re: Belt Speed
08/17/2015 12:22 PM
How do you get 1450/40 = 40.277 rpm.
My calculator renders 36.25 rpm and that is with low batteries.
Re: Belt Speed
08/17/2015 10:45 PM
Dear Mr. Massey,
You ARE ABSOLUTELY RIGHT.
Gear Box Output Speed is 36.25 as you have indicated. My typing as 40.27 is Totally Wrong.
I deeply regret for the error and I thank you for indicating this mistake, and will make me to be careful in typing.
Once again Thank you. VERY MUCH
DHAYANANDHAN.S
Re: Belt Speed
08/18/2015 12:42 AM
When will you ever learn to quit abusing the all-caps feature? Your excessive humility over some trivial arithmetic mistake does not compensate, although one might want to know just where the arithmetic mistake came from, in order not to repeat it in future.
Re: Belt Speed
08/17/2015 12:25 PM
Is anyone taking into account that the diameter of the drive roll may be a different size than the pulley so every calculation is incorrect unless the OP gives us all of the pertinent dimensions.
We're just flapping in the wind!
Re: Belt Speed
08/17/2015 12:50 PM
Yes, I did, I thought that was the 500 MM dia. but it was the belt width.....
Re: Belt Speed
08/17/2015 10:18 PM
Most of the time, motors are attached to gearboxes via direct drive (rigid flange mount or resilient coupling). Belt drive is possible, though. The OP states 1:1 ratio of belt drive; 40:1 gearbox reduction implies 1450/40 = 36.25 rpm output. If this is a conveyor belt with drive pulley diameter (rather than belt width) of 500mm, then the belt speed would be ~57 meters/minute. That's pretty fast.
I don't claim that this is a correct interpretation; the OP's info is unclear. In any event, the belt width does not matter.
Good Answers: 137
Re: Belt Speed
08/18/2015 9:00 AM
I'm amazed at so many posters taking the trouble to speculate what the OP might have meant, as it's totally unclear, and he hasn't come back to clarify, despite requests.
Re: Belt Speed
08/18/2015 9:23 AM
Good Answers: 137
Re: Belt Speed
08/18/2015 9:50 AM
I'm not with you. What are you saying?
Re: Belt Speed
08/18/2015 2:48 PM
It seems like we play 20 questions with a lot of new posters!
They also don't usually respond to the 20 questions either!
Re: Belt Speed
08/18/2015 3:00 PM
I'd be happy if they responded to any questions!!!!
Sorry, I was channeling Lewis Black for a minute.
Re: Belt Speed
08/18/2015 3:47 PM
Well, we can see where they modeled that emoticon.
Good Answers: 97
Re: Belt Speed
08/18/2015 2:44 PM
When I stand on the moving tread way at the airport, the belt does not appear to be moving, the people that are not on the belt, but walking alongside it in the same direction as myself are moving slowly. the people that are standing still even faster and the people running the other way, faster stil........dam! end of belt......
CRTL-Z
Register to Reply 38 comments
Brave Sir Robin (2); Codemaster (2); dhayanandhan (2); JavaHead (1); JohnDG (2); Kulas (3); Massey (4); North of 60 (2); Original_Macgyver (6); phoenix911 (3); redfred (2); Rixter (2); SHOCKHISCAN (3); Tornado (3); Unredundant (1)
