Previous in Forum: What Is It?? Some Kind of Nozzle...?   Next in Forum: Whatzit for Fredski
24 comments
What is this?
12/16/2015 4:43 PM
Re: What is this?
12/16/2015 5:03 PM
It's not a pipeline section, too flimsy. Judging by the background paintings,(or is that graffiti?) maybe some part of a circus act?
That crane looks too heavy for a traveling road show.
I don't know.
Good Answers: 918
Re: What is this?
12/16/2015 5:59 PM
Fred, you don't know what anything is, do you? ;-)
Register to Reply Good Answer (Score 10)
Re: What is this?
12/17/2015 5:08 AM
:-D
GA
Re: What is this?
12/17/2015 9:07 AM
If it wasn't for Fred, I would know nothing!
Good Answers: 918
Re: What is this?
12/17/2015 10:25 PM
But you wouldn't know that.
Re: What is this?
12/16/2015 6:13 PM
Re: What is this?
12/16/2015 6:41 PM
Beat me to it, I was going to guess that because what else would it be.
Good Answers: 918
Re: What is this?
12/16/2015 9:37 PM
Obviously a short test.
Re: What is this?
12/17/2015 11:37 AM
A train will go through that?
The internal lifting supports implies to me that this pipe is not strong enough to support its own weight, let alone the weight of a test train inside of it. Maybe the photographer snapped the image of a flash flood drainage pipe or some other operations support structure but that tube does not look adequate to me to put a train inside, let alone hold back the pressure differential of a vacuum to desert air pressure.
Re: What is this?
12/17/2015 12:39 PM
my understanding the section is for a "test track". I also read it will not be in a vac but a "low pressure" state of 0-+1 PSI
Re: What is this?
12/16/2015 7:36 PM
In a vacuum, nobody can hear you scream....
Re: What is this?
12/16/2015 8:24 PM
...what?
Re: What is this?
12/16/2015 10:05 PM
What if you thump the side of the tube really hard?
Re: What is this?
12/16/2015 10:19 PM
See #7. And then the internal train will be squeezed out like toothpaste.
Re: What is this?
12/16/2015 9:33 PM
A bigger version of "nightcrawler's" tubes, prior to external pressure collapse.
Re: What is this?
12/17/2015 5:07 AM
A piece of microbore pipe being installed for a KrisDelTM "Maxiconomy"R domestic central heating system? No? Oh well. Never mind.
Re: What is this?
12/17/2015 6:25 AM
...it's the cross-hairs eyepiece of a rifle designed by an engineer of the old school forced by company policy to use common core maths.
Good Answers: 26
Re: What is this?
12/17/2015 8:19 AM
Its called a "can". The roll direction is transverse to the length. Somewhere there is a long seam probably made by SAW. We make them here all the time. It is normally made by the 3 roll system. Yes a cold roll for that gage.
Re: What is this?
12/17/2015 8:26 AM
Looks similar to a rolled and welded tank cylinder that we fabricate here at work, then add top/bottom/legs/ports/and so on. Maybe a 4000 gallon process tank. Many smaller firms have them ordered, and trucked to them, as they can't roll a cylinder that large. Incoming tank cylinder for a small tank builder?
Re: What is this?
12/17/2015 9:08 AM
New Brigade Size MRE?
Good Answers: 122
Re: What is this?
12/17/2015 9:18 AM
Re-enforcement wall assembly for an underground duct?
Re: What is this?
12/17/2015 12:45 PM
It appears to be a short section of conrete lined pipe, typically used for water supply main lines. This one is probably going in near a curved section, or near a valving/pumping station.
Re: What is this?
12/17/2015 9:47 PM
Campbell soup test ? See what floats.
Good Answers: 34
Re: What is this?
12/18/2015 9:16 AM
Easy, is a CAN section for a deep water offshore Pile
Register to Reply 24 comments
Anonymous Hero (3); Fredski (2); horace40 (1); jack of all trades (2); James Stewart (1); lyn (1); Munster (1); Phys (1); PWSlack (2); redfred (1); SHOCKHISCAN (1); SolarEagle (1); texasron (1); Tom_Consulting (3); Tornado (2); Whitephone (1)
