Previous in Forum: Why Isn't This Better Known Info?   Next in Forum: What is this?
57 comments
Engineering Fields - Manufacturing Engineering - Hobbies - Musician - Engineering Fields - Mechanical Engineering - Popular Science - Weaponology -
Good Answers: 39
What Is It?? Some Kind of Nozzle...?
12/15/2015 2:48 PM
I found this on our receptionist's desk a couple months ago. We are a manufacturing facility (machine shop) and have had various vendors in and out working on all utilities. This nozzle looks important, but no one here owns it, and nobody knows what it is.Overall length is 2-1/8". The small hole running through the "nozzle" is 3/16" dia. The knurled end in internally threaded with a 9/16" thread inside it. It's steel. It's a heavy precision machined piece.
If not a nozzle... possibly some kind of collet? Maybe a part of a pneumatic tool? Part of a hand tool? Any ideas?
Re: What Is It?? Some kind of nozzle...?
12/15/2015 3:15 PM
Looks like a low velocity hot air gun soldering tip.....
Good Answers: 94
Re: What Is It?? Some Kind of Nozzle...?
12/15/2015 3:26 PM
I've been looking for that.
12/17/2015 5:10 AM
So there's more than one of them lost? Damn!
12/15/2015 3:57 PM
I guess you would know if it were for coolant delivery?
It also looks like it would work well for blowing up animal balloons. Did you work with any clowns?
Good Answers: 39
12/15/2015 4:16 PM
Do I work with any clowns? Every day. But none of them have painted faces or rubber noses.
Coolant delivery... hmm...
The HVAC guy was in here, in that area, that day. How exactly might it have been used for coolant delivery?
12/17/2015 12:29 PM
Yes it looks like part of a manifold the HVAC guy uses when he hooks up to your system, but do not ask me which part, just vaguely familiar. Oops, I failed to read all the posts before weighing in with my drivel.
JHowdy is the first one to get it right, Kudos.
12/17/2015 1:16 PM
12/17/2015 1:28 PM
There you go with that shaking finger business again. Merry Christmas ol' fart.
12/17/2015 1:30 PM
Ho Ho Ho!
Merry Christmas to you, too.
Good Answers: 39
12/15/2015 9:21 PM
Ohhh... coolant delivery. Sorry, that didn't register. Long day.
Hm... I think we use plastic nozzles, but it is a possibility. I'll have to check that when I go back in tomorrow. It might be a coolant nozzle.
Good Answers: 122
12/15/2015 5:18 PM
It appears to be a knurling tool.
12/15/2015 10:22 PM
"It appears to be a knurling tool."
Nah, it's a meat tenderizer.
12/16/2015 2:16 AM
This item is clearly knurled, but the tool that does it looks quite different.
The knurling does suggest that this object is often manually operated (e.g., attach, detach, adjust). Maybe some kind of quick-disconnect, or part of a valve?
12/15/2015 10:23 PM
Possibly a Clean-In-Place nozzle?
Ashok Pillai
12/15/2015 10:52 PM
Which type of thread?Any internal machining to indicate a tube hose end fitting, or something else?
Good Answers: 39
12/16/2015 6:48 AM
I can't tell if it's for a tapered thread, as it's only about 2 1/2 turns of thread.
Given the short thread inside, and the heavy knurling outside, it does suggest, as Tornado pointed out, that it is often manually adjusted or quickly removed.
I'll take pic of inside the knurled end later this morning.
12/16/2015 12:23 AM
Does the hole go all the way through? Looks like a muffler for air or gas discharge, unless the hole goes all the way through in which case maybe a silencer but there are only a few calibers that small.
12/16/2015 1:33 AM
Did you ask your receptionist if it was hers?
Remember to be nice to your children, they may one day pick your place of retirement....
12/18/2015 11:05 PM
For all of those who may think the response was in jest, the information given in the original post stated "found on receptionist's desk", not given or brought in by the receptionist so it's entirely possible that it IS the receptionist's.
Good Answers: 39
12/21/2015 10:39 AM
Yes.
Good Answers: 109
12/16/2015 3:33 AM
Now I know what it reminds me off. It looks like a tyre valve cap.
Good Answers: 109
12/16/2015 8:40 PM
Haha OT! What a Kindergarden!
Nothing to do with tyres? See #30!
12/16/2015 3:57 AM
maybe a tire valve removal tool?
To Carve a lion from a block of stone just chop away the part thats not the lion
Good Answers: 39
12/21/2015 10:43 AM
I can't imagine why this comment would be twice marked as off topic. It was a guess at what my object is, just like most of the other guesses. I've removed one of the "off topics".
Anonymous Poster #2
12/16/2015 4:11 AM
It won't remove nose hairs, but it might push them up out of the way for a while.
12/16/2015 4:14 AM
That would be called a schnozzle, of course.
Good Answers: 94
12/16/2015 5:23 AM
Made me laugh.
12/16/2015 5:32 AM
Laughter is always the best medicine! It made me laugh too, which cannot be bad.
Happy Christmas.
Good Answers: 39
12/16/2015 7:00 AM
The black oxide finish, and the heaviness of it reminds me of machining clamps and clamping hardware. I believe it's hardened. No it's not a tire valve, nor valve remover. The 3/16" dia hole goes all the way thru. Not a knurling tool. I'm pretty sure it's either for air or water consistency fluid.
12/16/2015 7:03 AM
That is just a knurled bit for removing material from a work piece be it wood, steel, plastic etc.
They are normally used in air powered tools:
12/16/2015 8:45 AM
No. Rotary files are never hollow and are never have internal threads.
12/16/2015 9:02 AM
I've used the wrong sized nut as a rotary file to remove treads on a bolt.
12/16/2015 9:10 AM
Using the "wrong sized nut" to remove threads DOES NOT make it a rotary file any more than something with knurled sections makes it a rotary file.
Knurling - Wikipedia, the free encyclopedia
"Knurling allows hands or fingers to get a better grip on the knurled object than would be provided by the originally smooth metal surface."
12/16/2015 2:07 PM
The knurled handle on my screwdriver filed down my finger prints after heavy use.
12/16/2015 2:11 PM
12/16/2015 4:17 PM
that's what i meant
12/16/2015 10:53 AM
oops, looks like I was wrong...gosh I don't think that has ever happened before????
12/16/2015 1:04 PM
It'll just be our little secret.
Good Answers: 39
12/16/2015 9:16 AM
A couple threads of 9/16 thread in the knurled end.
12/16/2015 9:26 AM
It looks like it may screw onto a air hose or some type of tubing/hose/hydraulic fitting.
Hand tightened only.
12/16/2015 4:10 PM
Looks like a nozzle that goes on an enema bottle, can work.
12/16/2015 4:15 PM
Looks like a nozzle that goes on an enema bottle, can work. To few threads for pressure applications, may be for suction purposes.
Good Answers: 122
12/16/2015 9:20 AM
Could it be the adjusting knob on a machinist micrometer?
12/16/2015 9:57 AM
Air brush or pin stripping nozzle
It is not a mistake if you learn something from it.
12/16/2015 10:25 AM
could it be an exchangeable tip for a gasket hole punch kit?
Kind of like this but with a longer throat? http://www.csosborne.com/NOK156T.HTM
12/16/2015 10:34 AM
Good Answers: 39
12/16/2015 10:44 AM
By George! I think you've got it! It sure looks the same! GA!!
Good Answers: 76
12/16/2015 11:13 AM
12/16/2015 5:54 PM
jhowdy: Thanks. I had the gun part, but didn't know what it was.
Lehman57
12/16/2015 10:43 AM
This is a tip for a tire plug repair tool.
http://www.amazon.com/Mushroom-Style-Emergency-Repair-Kit/dp/B00P2TQKM6/ref=sr_1_2?s=automotive&ie=UTF8&qid=1450279733&sr=1-2&keywords=tire+plug+gun
Note in this ad there are two tips above the "gun" type tool, one matches the item in the op's picture.
Good Answers: 39
12/16/2015 10:46 AM
9 minutes late and a dollar short.
jhowdy just beat you out. But good call!
Good Answers: 39
12/16/2015 11:10 AM
Since you arrived at it independently, GA for you too!
Good Answers: 266
12/16/2015 10:48 AM
Looks very simular to the dispencing tips on the glue guns they use here. The one you pictured the size is a bit larger. May be for dispencing oil.
12/16/2015 4:32 PM
Pressure from the thread side use a longer thread, can see it on the different photos.
Good Answers: 18
12/16/2015 12:46 PM
I have two sizes for a tire plugger,
For every great advancement in medicine there is an equal and opposite advancement in the denial of treatment.
Good Answers: 34
12/18/2015 9:38 AM
Dr Scholls toenails cutter model.
12/18/2015 11:09 PM
Cap for an automobile or bicycle tire vave?
Register to Reply 57 comments
andre pretorius (1); Andy Germany (1); Anonymous Poster (2); Ash55 (1); Casper71 (2); Harvey Patterson (1); IdeaSmith (2); James Stewart (2); JavaHead (1); JE in Chicago (4); Jerrell Conway (1); jhowdy (2); Lehman57 (1); lyn (8); Massey (2); New-user (1); Nigh (2); nsundberg (1); Oomborrie (3); Out of Box Experience (10); ozzb (1); PWSlack (1); rcapper (1); SHOCKHISCAN (2); SolarEagle (1); Tornado (2); Whitephone (1)
