Previous in Forum: Paradoxical Effect of Global Warming on Plants?   Next in Forum: Android Browser That /Doesn't/ Search From Address Bar
30 comments
Good Answers: 18
Reflectivity
06/07/2016 1:28 PM
I have a situation where I want to illuminate a flat, high-gloss surface which is about 8 feet in diameter The surface is located ~120 feet from a potential light source. The surface to be illuminated is inaccessible.
I think it might be possible to focus a directed light source on the selected surface using an optical system of some sort.
I would like to back-calculate the amount of light necessary at the source. I am assuming that light incident on the surface would be ~99% reflected. Is it reasonable to assume optical lens losses would be minor suggesting any light energy generated at the source is transmitted to the surface?
Re: Reflectivity
06/07/2016 2:57 PM
Extremely bright.. dual level brightness .. Excellent focusable optics. It will project a tight square that's about 8' across at ~120'
This is the best flashlight I've ever used. I use it to temporarily light up a room by reflecting the beam off of anything.
It's overkill for camping. Hardwired it will do the job you need, but it may be to simple and inexpensive for some people.
..This IS an and unpaid endorsement for the Duracell Durabeam 1300 lumen flashlight
Re: Reflectivity
06/07/2016 9:46 PM
I think I might need one of those!
Re: Reflectivity
06/09/2016 1:11 AM
I think I need one too.....not sure what for
Re: Reflectivity
06/09/2016 2:33 PM
You'll put your eye out!
I have one similar, so bright it beats headlights on my truck hands down, and can focus down to a clear image projected of the LED cluster.
Re: Reflectivity
06/07/2016 3:20 PM
Keep in mind that a high gloss surface will be mirror-like, so the reflection off of it will only be visible from a small angular region. If you want the 8-foot diameter surface to be see from any angle, it would need a matte finish.
Depending on what the surface is, the reflection will be more like 80 to 85 percent, or less. Even highly polished and coated mirrors used for telescopes barely achieve 95% reflectivity.
If the 'high gloss surface' is glossy white paint you'll actually have a combination of diffuse and mirror-like reflectivity. Near its surface you'll get 80 to 85 percent reflectivity. Farther from the surface the effective reflectivity will be much less and will depend on your position with respect to the surface.
And in addition to my comments above, the best illumination source would be a 'spot light' type lamp, with a lens.
Re: Reflectivity
06/07/2016 3:22 PM
You mount a few of these spotlights pointed in that general direction....
Is the object to light the surface, or something on the surface?
http://www.newklages.com/NKI_LumensForHumans-Part2.htm
http://www.archiexpo.com/cat/shows-events/stage-lighting-ellipsoidal-reflector-spotlights-ers-AI-1291.html
Re: Reflectivity
06/07/2016 5:17 PM
Re: Reflectivity
06/08/2016 9:05 AM
GA. The ellipsoidal spotlight can easily handle this distance.
Re: Reflectivity
06/08/2016 11:00 AM
Good Answers: 140
Re: Reflectivity
06/07/2016 4:56 PM
This sounds like a job for a "light pipe" (fibre optic). They are used to bring outside sunlight into buildings. One would expect that they could be and are routinely connected to light sources to do what you want.
Re: Reflectivity
06/07/2016 6:36 PM
How do you figure? Light 'pipe' is used to bring light from a source, through an opaque or thick surface (like a building) without power being consumed at the point of illumination.
He didn't mention not having power available the the point of illumination.
Good Answers: 140
Re: Reflectivity
06/08/2016 8:31 AM
If the surface to be illuminated is not accessible, then one would sure not want a powered device in that area as getting to it would be problematic. So a passive device is indicated.
Re: Reflectivity
06/08/2016 8:56 AM
My assumption is that inaccessible means you can't get a powered or un powered lighting source to the surface being illuminated.
It seems to me that 120' away there is no issue for power or access.
Re: Reflectivity
06/07/2016 10:43 PM
The surface is located ~120 feet from a potential light source.-That is very non-specific. The light source could be parallel with the plane of the surface for all we know, thereby giving the surface no illumination at all. Need more detail.You say that the surface is inaccessible. Is it in a ravine on the moon? An alternate universe?
I am assuming that light incident on the surface would be ~99% reflected.Why? You haven even mentioned the specific angle of incidence or range or ballpark,..... something! which I think would be rather important here.
You haven't even mentioned where viewers will be and a description of what you want them to be able to see.
"More details provide you can, better answer have you will!"Yoda
Re: Reflectivity
06/08/2016 2:57 AM
Laser?
Good Answers: 18
Re: Reflectivity
06/08/2016 10:46 AM
I agree. The use of a laser system was also among my first thoughts, but I have assumed (probably erroneously) that such systems are incredibly expensive.
Re: Reflectivity
06/08/2016 11:12 AM
This is a joke? Right?
Give me an example where lasers are used as a source of basic illumination?
Where are your project details?
Indoors or out? Temp? humidity? Power consumption? Cost?
cough overkill cough $1500 RGB (white) graphic projector.
Good Answers: 137
Re: Reflectivity
06/08/2016 5:19 AM
Depends how bright you want it illuminated. A car headlamp would pick it out at 120', but not focussed on your 8' diameter.
Good Answers: 120
Re: Reflectivity
06/08/2016 7:55 AM
Road sign makers use small clear glass beads as retroreflectors. They are embedded in a clear varnish. More details. Browse these and choose those that can tolerate the outdoor weather and UVYou can also buy stick on, or buy a used white movie projection screen with retro embedded already(outdoor survival???)
Retro reflective paints etc
Per Ardua Ad Astra
Re: Reflectivity
06/08/2016 9:11 AM
I have no idea from the information supplied as to whether price plays a role or not, but I feel that a secondhand Xenon (Spelling?) car headlight, especially one using the (I believe) Japanese system bulbs, as against the relatively expensive European system, might help.
You do need the in car Xenon High voltage unit and the wiring, don't forget!! Thats the bit that "hums" when the headlights are running!!
Xenon uses relatively little power at 12 volts nominal, as against conventional bulbs. But modern LED headlights probably use even less and may have a longer life.
The European system does have one possible advantage in that there is a large lense incorporated and if this was made adjustable, then the size of the illuminated area would be adjustable.
As both systems have been around some time, a scrap yard purchase, especially if one is found that has only been externally damaged, which no one would want to fit on their car, might be the cheapest alternative.
Spare bulbs from the same source should be pennies instead of around $100 each!!!
I hope this helps.
Let us know how you get on!!!
Good Answers: 18
Re: Reflectivity
06/08/2016 10:51 AM
Thanks Andy.
Re: Reflectivity
06/08/2016 11:17 AM
No problem, thats why we "meet" online to help each other......
Let us all know what you finally decide to do and do make some pictures as well....
Thanks back for a great idea in the first place, proper CR4 stuff!!
Re: Reflectivity
06/08/2016 10:50 AM
I do believe you are tackling the impossible. The only way to get that high a reflected power might be through total critical angle reflection. Instead of playing 20 questions (and no answers), could you elaborate a little bit more on the why and the situation of this disc? What is your present potential light source? Are you able to manipulate the disc to aim the sharply reflected light?
More details, otherwise we are just feeling up the elephant, once again.
Re: Reflectivity
06/08/2016 11:16 AM
Why provide details when he can provide frustration?
I know a thing or two about lighting, but I'm done
Re: Reflectivity
06/08/2016 11:40 AM
I don't see why you think this is impossible. The LBT has two 27 foot wide first surface mirrors. These mirrors are above 95% reflectance. The light source they view are much farther away than only 120 feet. And who hasn't started a design by first assuming ideal parts that cannot exist.
I agree that the OP has not posted anywhere near enough information for us to provide a definitive answer. We don't know if this is or is not limited to visible light. We also have no idea how bright this unreachable item is supposed to be illuminated. Bright enough for a person to admire Raphael's exquisite choices of pigment or only bright enough that the diffuse illumination on this cliff will be seen by aircraft flying by at night. We have no idea how bright any background illumination will be beyond or in front of this object so a clear contrast be easily discerned or is the goal to hide a change in depth by illuminating objects farther away just as bright as things much nearer.
Re: Reflectivity
06/08/2016 11:46 AM
Maybe it's an amphitheater for a flea circus, and the fleas like the heat from the lamp...
...or a rudder for a buck's dutt.
Re: Reflectivity
06/08/2016 11:19 AM
Question #20: Is it a drive-in movie theater? That has already been invented, gone (mostly) out of business except for a few notable exceptions, and been turned into white trash trailer parks in Kansas.
Re: Reflectivity
06/08/2016 11:26 AM
Good Answers: 120
Re: Reflectivity
06/08/2016 11:42 AM
Silver, the metal with the highest reflectivity, darkens in air. Aluminium is a little lower, but self protects with Al2O3 layer and is the reflector of choice.
If you want a mirror the beam follows optical laws. If you want broad spectrum emission, as from a white paint, that is about 70% in all directions.
What is the application?
Per Ardua Ad Astra
Good Answers: 137
Re: Reflectivity
06/08/2016 12:16 PM
But I don't suppose the material can be selected, it sounds like an existing (or proposed) object he wants to illuminate. I don't think he wants to project the reflection anywhere specific, just to make it visible. But until we know more detail, and how strongly he wants it illuminated etc, we're stuck.
Register to Reply 30 comments
agua_doc (2); Andy Germany (2); aurizon (2); Codemaster (2); James Stewart (4); JE in Chicago (5); Mikerho (1); North of 60 (2); PWSlack (1); redfred (2); Rixter (1); SolarEagle (5); Usbport (1)
