Previous in Forum: Six-coil, Three-phase Star Delta Starter   Next in Forum: Over Voltage Condition on Grid
24 comments
Good Answers: 73
How Do You Know When Your Control Cabinet is Too Hot?
06/28/2017 1:05 PM
I'll bet there are some great stories on this topic so I thought I would start with mine and see what wisdom follows. This always seems to be a good way to share important design criteria for the people just getting into the art.
We had some motor control cabinets built by a panel builder per our request. We added fans later because we didn't specifically call them out and we trusted the vendor to know what he was doing. Ha! You get what you ask for, but it may not be what you need! Ain't it the truth!
Anyway, about 6 VFDs were installed in a cabinet about 3 feet wide, 5 feet tall, and about 12 inches deep with no ventilation. The incoming power was 480, 3 phase and the temperature rise was only "warm to the touch". But then one day about a year later, those motors were being worked pretty hard and a controller kicked out. I got called out to look at it because it wouldn't reset. (it was still too hot internally)
I noticed this oil or grease like coating on the surface of the VFD's and wondered to myself what that could be. Then it hit me that it was the re-condensed thermal grease between the VFD and its heatsink on the back. It had evaporated and settled on the front of the case. We immediately installed filtered air fans and exhaust vents in each of the cabinets. Haven't had a problem with them since.
Re: How do you know when your control cabinet is too hot?
06/28/2017 1:28 PM
How hot do you estimate it got to evaporate the grease?
Gotta remember to clean the fins out...
Good Answers: 804
06/28/2017 3:09 PM
In a class I teach to electricians on VFDs, I tell them that heat is the #1 killer of VFDs. Most VFDs are rated for 40C ambient, some are 50C, a few can be used at 60C with de-rating and one I know of can be used at 70C with de-rating and an aux. fan for the PCB, but that's not the norm. VFD life is cut in half for every 10 degrees C over rated ambient, so if you have an VFD rated for 40C and the internal enclosure gets to 60C, your VFD life is reduced to 1/4 of it's expected life.
It's not too difficult to figure out how hot an enclosure will get, most of the enclosure mfrs will provide a simple on-line too to calculate it for you. They provide the tool to sell air conditioners, but you can use it to see how to avoid them. The tricky part is that most people grossly under estimate the heat rejection by looking only at the efficiency of the obvious things like the VFDs. So if it says the VFD is 97% efficient, they assume 3% heat rejection into the enclosure, but that alone is actually not enough. Control transformers are 95-98% efficient, switch mode power supplies are rarely over 85% efficient, even thermal sensing devices like circuit breakers and OL relays reject about 3W per running load amp per phase. It all adds up quickly when an enclosure is sealed.
I've found this to be a good training tool to hand out.
06/28/2017 3:23 PM
Thermal calculations should always be done by a reputable panel builder, if they engineered the design. If not, and were building to your design, then what were your engineers thinking when they sent the design to the builder without doing the heat rise calculations??? Especially with 5 VFD's in one small cabinet!!! You might get away with that if they are for 1/2 HP motors. Larger and, well, I guess you saw the outcome.
I saw a lighting/power panel in a Mennonite nursing home in the early 1970's, where the maintenance man just ran what ever size wire he had from what ever breaker, even from different breakers to get the correct phase, to install new three phase appliances in this building. Now these were old order Mennonites and had no electricity in their homes, but had to have them in the nursing home, and of course, the maintenance man was a Mennonite. He "learned electricity" on the job. The insulation on some of the wires was so hot, if you touched one, the insulation stuck to your glove. Now that was not the panel heating, but overloaded wires heating, but still an interesting thermal effect.
Good Answers: 804
06/28/2017 3:40 PM
Heat + moisture is an issue too. This one was growing a little crop of tiny mushrooms on it...
It is still working by the way, at least for now...
06/28/2017 4:02 PM
I have a lot of bottom feeder customers who will not pay for an industrial Ethernet switch for the panel.
They use a consumer grade switch until that hot summer day when the network connection to the SCADA software fails.
They call me in a panic and I say, "I didn't supply the Ethernet components on that panel; you or someone else did. Call whoever it was that supplied the Ethernet switch and have them fix it."
06/29/2017 11:28 AM
I know you are "right", but the customer "is always right". If you tell them you will be right there, you have the opportunity to win them over right away, make the sale, and get them on the correct path, all in one fell swoop.
I do get your point that it is pay me now, or really pay me later.
06/28/2017 4:06 PM
I think at least half of us could write a book on electrical. electronics overheating issues we have worked on due largely to bonehead engineering issues we have seen.
Oversold and under built or just assembled and not maintained by those who have no clue.
I know I could.
In past jobs I have actually gotten a stern talking to by my superiors for taking it upon myself to clean out electrical cabinets and fix locked up fans.
Apparently I had 'better things to do' (like chase bonehead ghost issues on things that never existed outside of management's mind or deal with real issues that were so far outside of my area and capabilities is was stupid to have asked me or anyone else in the company do them) than mess with that stuff being, obviously, 'it was still working just fine' as is therefore didn't need any of my attention.
06/28/2017 4:22 PM
Easy. When the panel builder puts a 3hp line reactor going to a 5hp motor in the VFD cabinet. The cabinet gets so hot you can't hold your hand on it, and the wire insulation inside starts to melt.
And you have to prove it to the contractor, sub-contractor, and design engineer. That, by the way, was just 2 weeks ago.
06/28/2017 7:11 PM
You know when it's (a 6ft H x 8ft W, 480VAC panel) too hot when you have to leave the doors wide open so you can aim a large floor fan at the contents inside to keep the VFDs from tripping, so you can keep production going.
Good Answers: 804
06/28/2017 9:31 PM
I remember once someone wanted a 75HP VFD in a sealed NEMA 4 box, no ventilation, no exposed heat sinks, going outside but shaded from the sun. I used the Hoffman AC calculator software and kept increasing the enclosure dimensions until I no longer needed and air conditioner. The box size got to be 120" wide, 90" high, 30" deep for JUST that VFD... nothing else.
06/28/2017 11:05 PM
I would almost bet that was a request from an old boss of mine.
My first real job was as a maintenance technician for a pasta plant and they had a new processing line go online a month or so after I was hired on.
The main control panel was good sized ~( 20' x 8' x 3') but not for what power it was handling in the environment it was put in.
It has something like 6 racks PLC units plus ~ 200 HP in VFD's along with multiple variable power control units for ~ 50 KW of additional heater and other process line operation loads on top of the motor drives.
Beyond that it was mounted above the main pasta ovens in the main production area that ran at an ambient temperature of 100 - 105F at 90 - 100% humidity.
My bosses solution to the constant overheating issues was to add a 5000 BTU pneumatic vortex cooler at one end which did nothing of any measurable good other than take the plant's main air compressor to it's limit and beyond causing even more problems elsewhere due to other systems in the plant occasionally shutting down from low pneumatic system supply pressure issues.
06/29/2017 9:23 AM
Blow that.
06/29/2017 3:25 PM
"Blow that. "
They tried, it didn't work,
06/29/2017 5:12 PM
The problem was given the amount of organic powder in the air (semolina powder from pasta) plus the high humidity and ambient temperatures putting in air exchangers on the cabinets was not possible. Anywhere that stuff settled started to grow mold in a week.
They never did have a proper solution to the problem when I got out of there but plans for a water based chiller system were in the making base on an idea I had come up with given that the pasta ovens did have a cooling stage that circulated cool water through a heat exchanger at one stage so tapping into that was a viable source of adequate cooling capacity that could have been added.
Unfortunately it got shot down by my boss early on for being a stupid idea, like pretty much everyone's ideas, until he of course magically pulled near identical one's (right down the formating of the paper they were proposed on no less) out of his ass a few weeks after he thought everyone had forgotten about theirs. (I learned quickly about idea stealing bad bosses from him and to what countermeasures work best.)
06/30/2017 8:19 AM
Been there.
I've had bosses that didn't want me to contribute directly in group e-mail discussions I was supposed to be a part of, but instead to present my ideas to him for 'pre-approval.'
Guess who was claiming credit for those 'pre-approved' ideas.
I did find a counter, however. My ideas being submitted started containing critical, yet subtle flaws in the base concept that would make the solution either ineffective or overly expensive. Then after he'd submit the 'pre-approved' idea, I'd direct e-mail another department head with some 'corrections' he could recommend to my boss's idea.
Later I found that method to be overkill; the other department heads already knew my boss was stealing credit for my ideas. The grammar and vocabulary my boss was stealing was WAY above his normal communication style, so they all knew he was plagiarizing; they just weren't in a position where they could openly call him out on it.
06/30/2017 12:54 PM
Pretty much the same thing I went through. I was smart, young, ambitious and willing to learn which made me a perfect target for someone who was not much of any of that on his own.
Like you I figured out his game soon enough and started undermining him by leaving critical or correct details out of my ideas he was most likely to steal just to make him look bad by his own actions.
Ultimately he screwed up bad enough that he tried to fire me to hide what had happened and that just blew up in his face for it when the people above him started to dig into his accusations/excuse for why he let me go to which none of them added up in his favor.
At the time I was young and just happy to be away from him but looking back now I probably could have lawyered up and lived a pretty comfortable life off it with very little trouble on my part. The whole situation and evidence to support what he had been doing was extremely stacked in my favor.
Good Answers: 804
06/29/2017 5:22 PM
I looked into the vortex coolers on a project once where I was putting VFDs on bridge cranes that were over the pot lines at an aluminum smelter. The ambient was upwards of 180F (82C) in the summer. The SMALLEST vortex cooler unit I could get required 100CFM at 40PSI of "instrument grade" air, meaning no oil or water vapor. When I ran that by a compressor supplier, that came out to a 10HP air compressor! A refrigerant based air conditioner was going to take a LOT less energy to keep that box cool...
06/30/2017 8:52 AM
Yeah, vortex coolers seem to be best for small applications, where you only need to drop the temperature to around -20F relative to ambient.
I personally don't even think of the problem as 'cabinet cooling,' but rather as 'heat venting.' You don't need to 'chill' the cabinet as get the heat OUT. If there is no external heat source (like a smelter underneath the control box) then typically, properly placed louvers and exhaust fans will do the job. If the enclosure is going someplace where external head will be applied, then a water-cooled system looks much more feasible, possibly even replacing existing 'finned' heat sinks on components with a 'heat transfer plate' so the heat-producing components are connected directly to the water-cool system(1).
Notes:
  1. Yes, I'm basically copying the same system that high-end water-cooled gaming PCs use. However, it is an Engineering Maxim: Don't Reinvent the Wheel. The Computer water-cooling system works, it is scalable to larger systems, as long as there's no patent issue involved, why NOT use the concept and safe the time that would have been spend designing something 'similar, but different'?
Re: How Do You Know When Your Control Cabinet is Too Hot?
06/29/2017 9:27 AM
When the OSHA guy shows up with marshmallows?
06/29/2017 11:21 AM
Your control cabinet is too hot when anything plastic related or connected to it, or included within it begins to resemble Salvador Dali art.
You know the cabinet is too hot also when you would not drink it if it was tea.
06/29/2017 11:32 AM
Not VFD but heat related.
I had a client call me because their CPU which I installed in their office had crashed and would not reboot without crashing again.
When I got there the CPU was not where I had placed it in the office (beside a desk in the open office area)..."It was making it too hot in here and it was noisy so we put it in the closet over there and shut the door".
We had a nice talk about air circulation and the need to keep the CPU where it would not overheat...I fixed it, put it back where it was, and closed out my contract with them.
Good Answers: 73
07/03/2017 8:00 AM
Great responses from everyone. I especially liked the reference to Salvador Dali. I've heard some great storied from machine shops as well. I was thinking to myself when I wrote the title that this sounds like the opening line of a joke. Sadly, it is not funny.
They say that experience is the best teacher. I think that is only true if it is able to bitch slap the person who made the stupid mistake. Unfortunately, that does not happen enough. My rule of thumb is this. If the cabinet is warmer than ambient (assuming it is not next to an oven) or perhaps any warmer than 85°F (30°C) it is just a matter if time before the next breakdown occurs. Of course, there are many environments where it never seems to cool down to that temperature. In those cases duplicate replacement parts really need to be available. Blessed are those who keep the plants running despite the morons. You all deserve a hearty show of appreciation but if you are like me, all you can do is dream about that. Ah, well. Pleasant dreams!
07/03/2017 9:30 AM
It rather depends upon whether there is a need to fry eggs on it because of hunger and the absence of a stove.
Good Answers: 11
07/07/2017 5:07 AM
IEC61439-2 could help you - the design should be compared with a tested unit to ensure compliance and temperature rise tests are a large part of that i.e. you will know before it is even installed.
This applies to switchgear, MCCs, control cabinets, call them what you like.
We have seen many folks rely on past experience alone (and a good reputation) but lets face it sooner or later you will get caught out. Follow the standard, do the tests, simples.
rogerggbr
Register to Reply 24 comments
adreasler (3); Carl_E (1); James Stewart (2); JRaef (4); Kilowatt0 (1); Mikerho (1); NotUrOrdinaryJoe (1); Phys (1); PWSlack (2); rogerggbr (1); SolarEagle (1); tcmtech (4); Tom_Consulting (1); Usbport (1)
