Hello everyone.
I would like to hook my household mains up to my oscilloscope so that I can observe "the quality of my power" and see what happens when I turn on different devices. Devices like my air-conditioner and compact-florescent-bulbs (which seem to cause feedback on their phase), and possibly the output side of my UPS.
Obviously, I want to do this in such a way that I don't kill myself, damage my scope, start a fire, etc.
So I'm looking for suggestions on how to build a cable for this that can be disconnected and reconnected as desired. I'm particularly interested in correct cable wire gauge, fuses, connectors, whatever should be used.
I live in the United States, so this will be connected to 120 VAC @ 60 Hz on a 10 to 20 Amp circuit.
My oscilloscope is a GOS-622G (all analog). The 2 inputs are BNC connectors labeled "CAT. II 400Vpk MAX" (Volts Peak) with the outsides marked ground and a separate ground lug and 100Vpk EXT for selectable trigger.
I should be able to connect my little probes directly to the mains, right?
It's been about 10 years since my electronics class, but as I recall there should be near infinite resistance across the signal/ground , so I'm thinking about taking a lamp or extension cord, figuring out the polarity, connecting/soldering neutral to the outside of a salvaged BNC connector and the "hot" to the inside. and wrapping the whole thing in a heat-shrink insulator. No fuse or switch. Initial tests will be using a GFI outlet.
Does this sound OK, or do you have any better ideas?
