Previous in Forum: Need freeware for 3D building design   Next in Forum: Spammer spammed!
Web Site Help Required
12/17/2007 7:00 AM
Hi All,
In my spare time I do work for an annimal charity, We have a web site that requires updating.
I have a log in for the site providor but can find no way to acces the site and amend, please help
Life is terminal, No One Gets Out Alive, It is therefore better to travel than arrive
Good Answers: 94
Re: Web Site Help Required
12/18/2007 4:41 AM
I'm no expert but I always thought that you would not amend the site on line. I believe that you would make the changes locally using whatever software was used to create the page & then upload the finished result. I'm sure someone will correct me if I'm wrong.
Canada - Member - Toronto, Ontario (South Parkdale On The Lakeshore) Engineering Fields - Marine Engineering - Great Lakes School Of Marine Technology (Owen Sound and Port Colbourne) Technical Fields - Architecture - Private Practice 1976-1990 Technical Fields - Education - Toronto Teachers' College 1971 Technical Fields - Marketing/Advertising - Founding Member Hobbies - Hunting - Founding Member Hobbies - Target Shooting - Founding Member
12/18/2007 11:24 AM
Hi, exemmet!
Have you tried using standard search engines with the name/some of the content you know is included in the web site. Search engine crawlers have probably listed it by now.
Mark
12/18/2007 11:50 AM
Many websites have a site provider but a different host. After looking at the website, can you find out who wrote the site for you? they may be able to tell you how to log on.
You may be able to get on by using:
ftp:rhodesianridgebackwelfaretrust.com
Some hosts will jump this to a login script. You may have to add a "www." in front of rhodesian
Technical Fields - Technical Writing - Validation Specialist-Medical Devices United States - Member - From the Big Apple! Hobbies - Model Rocketry - Rockets should go nuclear! Fans of Old Computers - PDP 11 - Studied computers at W.H.Taft H.S., Bronx, NY. Popular Science - Cosmology - Radio Science Observing
12/18/2007 7:41 PM
If yours is a FREEBEE site then the provider has tools you can use by accessing with your user and password. If on the other hand it's from your server, then you should be able to enter into it and make all the necessary adjustments. Otherwise call the webmaster and ask for directions.
WARNING! All suggestions are informative only. It is the prerogative of the user to implement under his sole responsibility. This commentator will not be liable for any damages or injuries incurred.
12/19/2007 9:38 AM
For all my web sites I use an FTP client and upload / download edit change whatever I like on-line...
It sounds like you are not using FTP perhaps? The FTP software is extremely cheap and easy to use.
John.
Electroman (1); MarkTheHandyman (1); Nigh (1); ronald (1); silvCrow (1)
