Previous in Forum: Presents for An Engineering Wife   Next in Forum: Looking for Inexpensive Solenoid Valve
30 comments
United States - Member - Charter Member Engineering Fields - Instrumentation Engineering - Charter Member
Good Answers: 73
CR4 Challenge: What's This Device?
12/18/2008 2:14 PM
Here's an interesting device for you:
I go into every human encounter expecting to be framed for a crime I didn't commit. Dilbert, 2013
Re: CR4 Challenge, What is it?
12/18/2008 2:24 PM
Knee brace for a robot?
12/18/2008 3:48 PM
Two person rope slide carriage?
Good Answers: 101
12/18/2008 3:53 PM
A Torture Device?
From the looks of it, I'm guessing this is the "male" version.
Re: CR4 Challenge: What's This Device?
12/18/2008 4:30 PM
I think I saw one of those fall off a '73 Ford Pinto once.
Ok...I'm mostly stumped. Give us a hint. It looks a bit incomplete. Is it part of something larger or is this more or less the state in which it's used?
My current (and almost completely random) guess: It has to do with transformer assembly?
Hobbies - HAM Radio - New Member Engineering Fields - Mechanical Engineering - New Member United States - Member - New Member
Good Answers: 22
12/18/2008 5:19 PM
I know it's not a thistlewick.
It appears to have wires attached. The U-shaped opening probably goes around a shaft or pipe, but does not clamp to it.
I wonder..... Would Schrödinger's cat play with a ball of string theory?
Good Answers: 97
12/18/2008 6:01 PM
Sky clamp or ground clamp - for fine tuning the effective length of a transmitting areal.
Good Answers: 15
12/18/2008 10:08 PM
The long "Bolts" look like the tie-down bolts used on a mill or CNC machine, the heads are HEX shaped, not round as they appear in the pic?
Only having 1 view makes it difficult to imagine what it does in RL, I think the plug on the right could be part of it, but could also be a left over from some experiment you were doing previously
Qn, Whats the differance between a Snake and a Onion? Ans, No one cries when you chop up a Snake
Good Answers: 38
12/18/2008 11:04 PM
I think it is a P782655288V267/203 the 2008 model
Good Answers: 15
12/18/2008 11:46 PM
Nah, the part your specifying has straps that are used to tie down the "subject" the "203" section of the part number specifies that its a rotary oscillating member that would be attached on the other side of this "Appliance" and you'd have a connector that interfaces with the plug shown at the right for added stimulus.
This model is the 202.5 version
Good Answers: 38
12/19/2008 12:18 AM
You are still using the 202.5 version?
that one was recalled for leaving traceable lesions on the subject, the "203" vesrion is an updated version and the straps are for added "comfort"
12/19/2008 6:12 AM
I am guessing that it may be an electronic flow meter. It could be laid over a pipe, perhaps secured by the long bolts, and the flow measured by changes in the magnetic field of the two magnets on either side, Is this close?
Pete.
Having a farm is great provided you don't have to depend on it for a living.
Good Answers: 54
12/19/2008 6:44 AM
Could you remove the cardboard behind it please? I think it's part of whatever the cardboard's hiding from view.
12/19/2008 6:58 AM
Ah, yes, its obviously a cardboard thickness measuring instrument
12/19/2008 7:38 AM
I'm not saying, 'cos I didn't get points and slobbering adulation from everybody for knowing your ears. I've even sat on the things. No amount of begging will get me to reveal how I charge Del up at night.
Good Answers: 73
12/19/2008 8:12 AM
Here's the device without the mounting hardware:
Good Answers: 42
12/19/2008 9:29 AM
It can be possibly a pressure sensor
12/19/2008 3:23 PM
Motorized vise?
12/19/2008 11:07 AM
Have you put that sheet of cardboard there to hide something that would give it away?
Good Answers: 73
12/19/2008 11:40 AM
no. This is an older device, from the "back room". However, the modern updated devices look much the same. It is the actual sensor from a much larger testing machine, used in the aero-space forging industry.
Hobbies - Fishing - Popular Science - Paleontology - New Member
Good Answers: 27
12/19/2008 12:12 PM
Spar crack detector.
Prophet Freddy has the answer!
12/19/2008 12:47 PM
One question: Is this a production piece or custom built?
Good Answers: 73
12/19/2008 1:47 PM
This is a production device. In fact, there is an entire industry that provides this type instrumentation.
This testing is an absolute customer requirement. Almost every forging in every airplane and jet engine made in the free world would have been tested with a device such as this.
A hint: there is destructive and non-destructive testing required.
United Kingdom - Member - British
12/19/2008 2:49 PM
Spot welder?
bondy111
12/19/2008 2:50 PM
Part of a benchtop stiffness tester? (The remaining bits of which are cleverly concealed behind the cardboard)
Good Answers: 27
12/19/2008 3:03 PM
Multi-frequency structure or materials properties tester.......
12/19/2008 3:58 PM
Magnaflux ????
12/19/2008 4:14 PM
t looks as though this one is slightly damage; the looker's left front protrusion appears bent. I'm guessing the flat metal pieces coming out of either side are used to detect resonance. I am inclined to guess it is used to test for vibration in a high-speed shaft of some sort; the 4 protrusions set or establish balance... definitely a stumper.
12/19/2008 9:10 PM
Ultra sound sensor to look for stress cracks.
Good Answers: 73
12/21/2008 8:31 AM
Good Answers: 22
12/22/2008 12:55 AM
Link didn't work, but Wikipedia has this. Globalspec even has a page for them.
Register to Reply 30 comments
3Doug (2); Anonymous Poster (3); BigPete (1); Bondy111 (1); Bricktop (4); Duckinthepond (2); Epke (2); Hendrik (1); Kilowatt0 (1); Kris (1); Randall (1); RVZ717 (1); Shandy (2); Snaketails (2); StandardsGuy (1); U V (1); user-deleted-1105 (2); V.I.Abraham (1); Vulcan (1)
