Previous in Forum: Do air brake cylinders get hot, cold, or neither?   Next in Forum: how clearly can satellites seeeee?
Mysterious Press
01/13/2009 2:17 AM
Can anyone identify and relate just what it accomplishes? My wife came home with this press the other day, and we just can't figure out what it does. The spring tension is set by the small nut on the screw, which results in returning the cutting head to a pre-set height. The device was made in Portugal. Sorry, but this is the only way I can post photos... http://www.flickr.com/photos/iskeeter/?saved=1
Thanks.
This is it... so live it up!
In reply to #105
Find in discussion
Re: Mysterious Press
01/19/2009 5:12 AM
In reply to #106
01/19/2009 5:48 AM
Thanks, JohnDG. What would one do without friends?
In reply to #105
Find in discussion
01/19/2009 12:45 PM
Thanks Skeeter.....still scratching head.......
In reply to #108
01/19/2009 1:11 PM
I'm convinced it hasn't aught to do with any food of any sort. I'm also less than convinced it has to do with fabric or leather, most of what I've seen there are lever presses, this one is rather light duty insofar as application of downward pressure. Unless there's several pieces missing; I'm doing a lot of head scratching too.
In reply to #109
01/19/2009 6:32 PM
I'm still going for food. Gotta be something pretty soft - Skeeter's experiment with the tangerine (?memory) points to that (tho' clearly not for old oranges). There's no sign of any attachment point (fulcrum) for a lever, so all that could really be missing is a mushroom type actuator to make it gentler on the hands.
Also puzzled by the adjuster for the spring - a half decent spring wouldn't change its properties that much unless it got a hell of a lot of use - maybe a factory or commercial kitchen???
The wire adds even more to the mystery.
In reply to #110
01/20/2009 5:52 AM
I still feel that it might be for some relatively soft fruit of veg (could be totally off base, I would not bet on this!) and the spring allows the stone/unwanted center stem to slide up inside and only to be ejected, when the plunger is released.......maybe?
Long shot?
In reply to #96
Find in discussion
01/19/2009 4:22 AM
The hole in the vertical spindle doesn't seem to have a purpose (?)
It appears that the hole in the lower end of the spindle doe have a purpose. Otherwise, there is no need for the hole and no need for the tiny wire device, which moves up and down in the hole to eject whatever material enters the hole when the spindle returns to its upright position.
I'm waiting for the person to tell me exactly what it is by offering proof of their assertion. I still don't have the answer.
In reply to #98
01/19/2009 4:25 AM
Hi Skeeter,
Can you give any more detail on the wire bit (sorry if I missed it), and are you sure it's an integral part of the device ?
In reply to #100
01/19/2009 4:40 AM
Hi, Kris,
I'll post a url to the photo of the wire at Flickr, so you can see what I'm talking about. Give me a couple of minutes.
In reply to #103
01/19/2009 4:52 AM
Thanks Skeeter, much appreciated . Have to go now, but I'll be back for a look soon.
01/18/2009 10:37 PM
I would say there is a bottom piece that goes in the hole under the cutter.
No fruit I know of is short, wide and has a small pit or core.
It could be a folder or cut uncured rubber to make a round hole with flaps to be vulcanized afterwards. It does not look strong enough to cut cured rubber or leather for very long.
Could be some type of pastry maker but without the lower die it is hard to say.
Brad
In reply to #93
01/20/2009 2:00 AM
Given the new picture I don't think there is a bottom piece that fits on the press.
It could be as mentioned a hand held that aligns in the V cut in the, for lack of a better word, anvil.
I'm going with some sort of pastry press.
3Doug (2); Andy Germany (7); AnnafromA2 (1); Anonymous Poster (3); AussieBob (3); beriberi (2); Bricktop (2); bwire (4); cjhills1950 (1); Duckinthepond (11); Emjay4119 (1); EnviroMan (5); Epke (6); hazman (1); jdretired (7); JohnDG (10); jt (2); Kris (17); martywolf (1); OPEL Steven (1); qaqcpipeman (1); RobertOz (1); ronseto (1); Skeeter (17); Transcendian (2); U V (3)
