Previous in Forum: Apple Virus?   Next in Forum: speed up torrent downloading
92 comments
Hobbies - Fishing - Popular Science - Paleontology - New Member
Good Answers: 27
Hard Drive Access X 2 - Without the Sledgehammer, Please
02/16/2009 11:00 AM
So……..I fixed the computer. New mobo, two hard drives, bells and whistles. It took me two weeks and cost me more had I purchased a new one…but I needed to recover the data.
The first order was to find the online timeshare software that could diagnose a failed hard drive. Second was to find the interface that connected the non functioning hd to the diagnostic software. Thirdly was to download the found data into a new hd. Sounds simple enough doesn't it? It isn't!
Of course one had to assume that the motherboard was still functioning. Mine was not. I didn't know that. This is where the term 'back to square one' does not apply. One actually goes further back in time to a more primitive state of being.
One week into the project and shunned by one's fellow workers, wife, dog, cat, children and civilized society while reduced to Australopithecine communication skills I persevered and fixed the damn thing.
The problem is….I have no idea what I did (well, actually I do, sort of) and could never remember if I had to do it again.
My question is: I now have two hd's…..one working, the other with my data but with a corrupted os. I have moved the data into the useable hd but would like to re-format the buggered one and use it as a backup storage drive.
So………When I turn off my useable hd I cannot access the buggered one. How do I get around that or do I, in fact, need to?
Free ticket to heaven for the individual(s) who can make sense of my quandary.
Prophet Freddy has the answer!
Good Answers: 97
Re: Hard drive access X 2 without sledgehammer please
02/16/2009 11:28 AM
Hi Duckinthepond
I had that problem also. The boot record or fat got corrupted and the disk than had a identity crises.
I installed the disk in an older machine (I throw noting away) and partitioned the drive into a small and big partition and formatted only the big one. It now sits in my backup computer as drive F&G and it is still going strong.
If the boot record is gone you may have to pull a virus trick on it.
Seagate also had some tools
Good Answers: 27
02/16/2009 12:47 PM
Thanks Hendrik............what I'd like to do is completely wipe it clean and then re-download my documents file and os. What I have now is something you have described.
It boots up but no program inside can be accessed, uninstalled or re-downloaded ie no control panel.
02/17/2009 4:25 AM
What you mean by 'it boots up'? If it boots up it means that your old HDD is OK and operate as before which is not consistent with your 'programs cannot be accessed from control panel window'.
Does 'it boots up' rather mean you can see your HDD when you boot up from the new HDD?
As indicated to be able to access your programs from the control panel window you need to boot from your old HDD: this can be done either in the BIOS -not very flexible- or by modifying the BOOT.INI file.
Now if you only want to use your old HDD as a 'data-only' drive you can format the drive from the context menu by right clicking the icon representing this drive.
Good Answers: 27
02/17/2009 5:48 AM
This is a new hdd with corrupted os downloaded into it from the buggered hdd. The old one is mechanically damaged and will not spin up.
Good Answers: 39
02/17/2009 12:05 AM
Hendrik is that Seagate stuf still available or is it now "legacy software"
Elnav
Good Answers: 97
02/17/2009 10:50 AM
elnav
You can download "SeaTools" from Seagate to run diagnostics on any make of drive.
If you downloaded corrupt files from the old HD it might not work and it is better to install a fresh copy of the OS.
Re: Hard Drive Access X 2 - Without the Sledgehammer, Please
02/16/2009 10:52 PM
"reduced to Australopithecine communication skills"?
Don't you mean "reduced to an Australopithecus's communication skills"?
Good Answers: 27
02/17/2009 5:50 AM
....well, I've never really met one and was merely assuming the cus to be Australian
Good Answers: 68
02/17/2009 3:26 AM
Hello Duckinthepond:
I have problems with my PC and have had to change the boot order of the drive
Can I assume you know where to go and how to adjust your BIOS? I will anyway!
This is from memory OK? So bear with me.>>>>>>>>>
You will need a PS/2 keyboard to navigate the screens. It will not work with a wireless keyboard.
As you reboot look out for a note on the second screen as it starts. It says "press Ctrl + H" to alter BIOS settings.
Once you are in BIOS you will see two lots of choices. 7 choices on the left, 6 choices on the right.
You are looking for a subsection of one of the left-hand choices:
>SoftMenu 111 setup .......... PC Health Status
>Standard CMOS Feature Load Fail Safe Default
>Advanced BIOS Features Load Optimized Defaults
>Advanced Chip Set Set Password
>Intergrated Peripherals Save & Exit Setup
>Power Management Setup Exit Without Saving
>PnP/PCI Configuration -------------------
Can you tell me if you want to try this? Because I will have to run through it on mine and see what to click.
Get back and let me know please?
Good Answers: 68
02/17/2009 4:01 AM
You may want to try using the cmd prompt to check the disks?
Go to start > run > and type this: chkdsk/r (You may have to use upper case I am not sure.
See what it brings back.
Good luck. I have the rest of my first post ready to send but am not sure that you will not be putting yourself in a position where you have the non working HDD as boot one and then can't operate the machine to come out if you are unable to get it to work? Hope you understand that?
Take care...........................
02/17/2009 4:49 AM
Download and burn a CD with Knoppix. Boot from that CD. Use Knoppix to erase the HD, remake the MBR into FAT16 or FAT32. This erases any possible viruses completely.
Put the Disk on an XP machine and reformat into NTF. Run an antivirus scanner over it like Dr Web (free download) and then use it like before......
In most modern hard disks (and on the mainboards as well I believe) there is a S.M.A.R.T. function, set this to on, it will give you warnings of any disk disaster before it happens.
Set the antivirs protection on in the MB for the boot sector as well....
Good Answers: 39
02/17/2009 4:53 AM
Hate to say it Andy but that is what I tried, and it didn't work. The latest malware running rampant over here can even clobber Linux formatted drives. I have several drives and two clobbered computers to prove it. What'e even worse, Linus cannot even reformat these drives. Shall I send you a copy?
Elnav
Good Answers: 68
02/17/2009 5:13 AM
Hello elnav,
Are you OK?....................You have me worried now!
I was about to get a Linux disk and install it onto my computer, because I can only work from safe mode on the win xp. It wont let me un-install and lots of other stuff. Thats why I wanted Linux. But you say the nasties can get into Linux as well?
I tell you I am having one hell of a time. I can view one email then I am cut off. I have to reconnect and thats how it is with my system at the moment.
02/17/2009 11:09 AM
He should try what I said first.
Nothing to lose really.......its worked for me in the past...its no good being negative first with no accurate infos.....it has a chance to work or not work.....if he gives it a chance at all after what you said!!!
Good Answers: 27
02/17/2009 6:17 AM
Thanks.....but here's the problem. The download manager in the corrupted hdd with the corrupted os won't let me download anything.
It's very possible the anti-virus software is still running but I can't even see it on the program list.
Good Answers: 68
02/17/2009 6:49 AM
Now you describe it............that sounds like my problem! I cant load or unload anything to do with the OS. Including some 3rd party software like Norton 360. It wont let me get rid of that.
You could try typing services.msc into the cmd prompt. It will list all your programs and their status,-automatic-off-manual-, something like that. This is to check if your antivirus is still working.
Good luck. I have managed to get mine back to working sometimes on normal. But for the last few days it has been from the Configuration Utility safe mode. Have you tried to sort the problem using the configuration Utility?
You can also go into safe mode---
start>run>
(type: msconfig )>BOOT INI>safeboot>network>apply>OK>reboot
(If you are able to do that of course)!
This will allow you to update your anti virus, and similar apps. but it advises not to run anti virus in safe mode.
Good Answers: 27
02/17/2009 7:07 AM
Hmmm.......haven't tried that yet. Forgot all about safe mode.
Good Answers: 27
02/17/2009 10:24 AM
Hey man..........something kicked in here. Safe mode came up, blue screen, re-boot, safe mode. Norton showed up and prompted me to scan. Ctrl, Alt Delete stopped Norton in its tracks. Blue screen, re-boot and prompted to start in safe mode. Still no control panel but I think I can get at it through msconfig.
Good Answers: 68
02/17/2009 11:48 AM
I hope you get on OK. If you rebuilt your computer you must be half familiar with some of the things you see in BIOS and Config utility.
It was almost three days before I saw my desktop after crashing with zero notice!
Although I did not think so at the time, it sort of helped me really as, I have just the one computer, and had to find a way out. I have a spectacularly terrible memory, so wrote everything down as I did stuff. Listed what it was, changed it, and if something told me it should not be like that, I changed it back.
Because the computer was not booting hardly at all, it took only 15 seconds to reboot into BIOS or safe mode for instance. I worked out I rebooted hoping for inspiration and it slowly came. It just meant thinking and reading and, two nights with about an hours sleep. Writing it all down hour by hour and minute by minute so I did not get it in the wrong order when I came to do it again. I worked out I must have rebooted almost 430 times. It is not that I knew what I was doing all the time, I just had no choice.
Keep me informed pleased. Just a note: It took me so long because I did not realise for a day and a half I needed the sp/2 keyboard.
Good Answers: 68
02/17/2009 11:54 AM
some of those screen come up and you do not have much choice. But I am in safe mode and can get to control panel, so you should be close.
My chash was made worse by the whole graphics card software. Not the card but the software.
Good Answers: 68
02/17/2009 12:10 PM
Do not know about you but, this was the one time I was pleased to see the blue screen! I got tire tired and just left it. And it went right through all those windows like blue screen, BIOS choices and another couple in the same order for two hours. It was werid. It was then I know I did not have to 'try' so hard and be frustrated I did not catch the BIOS or safe mode, coz it was gona be round again in a couple of minutes anyway. It your like that?
Good Answers: 97
02/21/2009 2:59 PM
Okay let us look at the principles.
Inside the case is the new corrupted HD connected as master? Make it so.
You can perform another XP install concurrent to the corrupted but be sure to correct the boot sector as you go.
After this passes do regular backups to a DVR maybe ya think.
Good Answers: 27
02/17/2009 6:44 AM
Yep........I'm using SMART function Western drives. The failure was from a short circuit in my mobo and was an instant catastrophic failure....no warning.
Other than the problem I'm having what I'd like to know is what caused the short. I thought it was the video card but it's working fine....actually, it's the only thing that didn't get fried. There was a bit of dust that collected and I suspect this might have done it.
Have since replaced delicate Asus mobo with one that has more copper in it.
02/17/2009 5:37 AM
Can't you set the buggered HD as last boot device in BIOS ? Or how about connecting it as a slave drive ? I haven't a clue what I'm talking about (as usual), but it doesn't sound that drastic a problem. Do you have an o/s install disc ? What about leaving the crap HD connected on it's own, and booting off some crappy old DOS floppies to format it ? It sounds like the problem is your pooter only thinking one HD is hooked up, which isn't the good HD's fault if it's playing nice.
Good Answers: 27
02/17/2009 6:15 AM
That's the plan Stan but no bus to catch. I can switch on and off but I can't delete the software in the re-downloaded hdd. I can't get to the formatting stage cos of the corrupted os....which I canna get rid orf because I don't have a startup menu init. I thought of downloading the os into it again thereby having two......one corrupt.......one working. The thinking behind this is that the file system would automatically correct itself through fusion (desperation is the mother of invention) but the download manager won't let me in. reminds me of a girl I used to know and her fathers gun collection
All's I did was to get my documents out of the buggered one into a new one and then into a working hdd with a working os.
02/17/2009 11:12 AM
If he has the Knoppix boot CD, he can boot from the CD, without having any other HDs installed (other than the damaged one(s)......)
If he does what I said before, he has a good chance of recovering the HD for further use....
02/17/2009 12:33 PM
That's true, but I'm beginning to think Ducky doesn't have a boot CD. If he can boot into 'DOS' (not sure it's exactly right to call it that anymore) mode there might be a few options available, but it depends how screwed up the 'working' HD is. How does he know it's the mbr/MFT or whatever they call it ? He might be able to reach system restore from a C:\ prompt and find a good restore point. sf /scannow and all that stuff. I Dunno.
I'd better read all this again, 'cos I don't think Duck can get anything on the screen when he tries hitting F8 (or whatever). If we all mailed Duck a boot CD he'd probably be snowed under, but it would take ages to reach him.
02/17/2009 12:39 PM
He could boot from the Knoppix CD, repair/rewrite the MBR, reformat the hard disk, all from Knoppix......its really easy, even I can do it!!!!
02/17/2009 12:52 PM
"If he has the Knoppix boot CD"
Ten'll get you twenty, he ain't got one !
02/17/2009 1:01 PM
He needs someone to do the download and burn the CD.
For anyone without problems, make one for "just in case!"
Good Answers: 39
02/17/2009 1:15 PM
Andy, Here in Canada the government controls internet use. We do not enjoy super fast data transfer in most regions. When I tried to download the Knoppix it took seven and a half hours and the copy was corrupted. It took three tries to get one copy downloaded that appeared to be in working order. And I am supposedly connected by "High Speed Internet" according to my provider. When I complain I am told the speed of access is controlled by regulation. This has been confirmed by several of my acquaintances. Unless you have a corporate account and pay $$$ every month, you simply do not get access to really fast intenet. In Canada we seem to have access speed at about one third what they get in the States.
Elnav
02/17/2009 1:44 PM
I am sorry for you, but that does not change the need!
May I recommend a good download manager that validates the data AND can resend bad data AND can restart a download in the middle.....there are plenty of free ones around.
For limited line speed, there are download managers that will only take a bit, letting you work in parallel......
Who cares how long it takes, that is what is needed!!!!
02/17/2009 2:18 PM
It's probably no consolation if someone is stuck in the wilderness, but most shops that sell magazines in the UK have about a dozen different computer ones. Almost all carry a free software disc, and in any given month it's a fair bet that one will feature a bootable o/s. Sorry, that's probably just rubbing sold into the crispy duck skin wounds.
Is Canada's slow BB just due to remote places, or is it in the cities as well ? Over here, BB speed is never as good as advertised, but still works fine.Having said that, I understand the the UK is way behind the rest of Europe.
Good Answers: 27
02/17/2009 4:13 PM
We're pretty far behind the eight ball here. At the office I have 250kmbps cable but at home I'm on dial up.....not by choice but by being remote. It's actually 30% faster if I connect my dial up to the computer in the office and use the cable.
Having a workplace in a government town certainly helps with connectivity speeds.
I pay $40C /month for high speed.
Elnav is in a remote part of BC. Some towns and villages there are on satnav communications.
02/18/2009 3:03 AM
250kmbps
......please, please tell me that was a typo !
On the bright side, you have nice scenery to look at while you're waiting. My 2Mbs is considered crap around here, though it serves me fine. If it were possible, I'd trade some of your pond for some of my bs.
Good Answers: 27
02/18/2009 5:37 AM
Oops...........258 kb/s.(on a sunny day) considered to be high speed cable.
Bloody sad compared to Europe.
I'm on dial-up at home (28kb/s). Nothing else available unless mortgage first born...so I dial into the computer at the office and connect into my high speed.
02/18/2009 6:32 AM
South of the border, CR4 visits are much more prolific during office hours........
Engineering Fields - Instrumentation Engineering - New Member Hobbies - Fishing - New Member
02/21/2009 11:53 AM
I've no any idea who controls internet here where I'm livin' in (seemed no one in terms of its quality to say the least) but internet connection speed is awfully and dully slow. Nonetheless I'd succeeded to download linux SuSE DVD (4.4 Gb). This ordeal took a week without any corruption of ISO image though. I'd suggest you use the Opera for both surfing and downloading.
At past could have downloaded Knoppix through dial-up for approximately the same time.
Good Answers: 68
02/17/2009 1:18 PM
Hello Andy,
How are you?.........I have been thinking a lot about Ducky's problem because it sounds so much like what happened to me a few weeks ago.
Thinking also, if one computer is totally screwed so he cannot get into control panel. He must be using another to type stuff for CR4? So he will be able to download stuff. But as (sorry I forgot his name), said, more than one person sending a CD would be overkill. I know exactly how he feels. I can only use my machine in safe mode now. But at least I can get on-line. Even if my connection is dropped every ten minutes. (Not my fault). It is my ISP.
Anyway, take care.................
02/17/2009 1:58 PM
You too Friend.
Good Answers: 27
02/26/2009 7:36 AM
Any luck with your system?
I've been away (still am actually)
Good Answers: 68
In reply to #74
02/26/2009 11:25 PM
Hello Ducky,
Thank you for the post! I hope your 'away' time is worth it? Of course you do not have to say, but better a hopeful wish than none at all? Wasn't that something the vicker said to the blond?..........Maybe not.
Short ans sweet.......NO. Meaning no change. Wire and Kris, and others have sent some potentially useful sites. But I had two hour kip last night because I had to go out today. Got back here about 23:00? And found 40 emails to be sorted and it is freezing on almost every send and or any click in that process. Takes a very long time to get anywhere.
I have put any potentially useful sites etc in folders listed with the persons name so I can if necessary , find the 'original' post, on a thread with often over a hundred posts! Just makes it easier, as with the freezing I loose any WIP (Work In Progress) and end up at the yahoo email page at the most recent emails, rather than the one/s I had been writing to, and so have to find it again.
I want to try out some things and sites wire has sent me. A couple of the sites and or apps are supposed to be 'wicked init?'. I clicked my fingers as I typed that. Not easy I can tell you, only a superbly experience BSh-ter can put it off. Which in itself also takes some doing whilst I am typing! Sorry, my mind is wondering a little now as tiredness pursues its deadly roll!....................
In reply to #75
02/27/2009 2:27 AM
If that's composing replies, you could try typing with something like ms Word (saving frequently), then when ready cut 'n' paste it. Not sure that's the situation, but seems worth mentioning.
Is Yahoo toolbar causing problems ?
If you haven't yet done so, and it's a problem, get on top of stopping unwanted cookies, and clear old garbage out frequently. Cookie blocking is discussed in one of these threads (here or the 'slow response' one), and CCleaner is the most reliable cleaner (some get over-enthusiastic, and can cause problems).
Good Answers: 68
In reply to #77
02/27/2009 8:50 PM
Hi Kris,
I often do type in Word ans save if it is a long piece. And then when it is edited and stuff I paste all and copy to the CR4. It is tedious but sometimes the only way.
Done all you mentioned, and clearing cookies etc is done regularly. I had kept cookies and history etc for a year. I found it more convenient with my own bad recall, it was often easier to go and search Temp' files to find a link or something?
I had Yahoo, google and CR4 tool-bar. But do not have any now and have not since well before my last major crash.
Take care OK?
In reply to #80
02/28/2009 2:10 AM
I can't recall which thread it's in now, but have you checked the boxes to block 3rd party cookies ? If you're on IE7 Right hand side of tool bar → tools>internet options>privacy>advanced> gets you to the settings box. Overide automatic cookie handling + Accept 1st party cookies(else CR4 won't fuly work) + block 3rd party cookies.
Good Answers: 27
In reply to #75
02/27/2009 7:50 AM
Like Kris suggests the Yahoo toolbar can cause problems. Having two or more toolbars open will also slow some systems to a crawl. Having too much junk on them eg shopping, news, feeds etc, will also slow down your system. Most toolbars have a tools pop-down menu where you can disable add-ons, turn off toolbars etc.
Also check from your START menu .....Programs -Accessories-System Tools-Internet Explorer (if IE has add-ons switch 'em off).
Disk Cleanup from System Tools
Delete cookies
Defragment (analyze first)
Good Answers: 68
In reply to #78
02/27/2009 8:22 PM
Hello Ducky,
Thanks for the post! Everything you have mentioned including defrag' has been done. I had google, yahoo, and CR4 tool-bar, but did find the CR4 one caused problems and the same for Yahoo. But I don't have any now.
I have run the browser with no add-ons for roughly 2 years. It is freezing like mad now though!.
Very much appreciate your post and help!
Good Answers: 27
#81
In reply to #79
02/27/2009 10:50 PM
Still freezing? Damn.
Back to the drawing board.
You must have some type of process running that is using up memory.
Good Answers: 68
#82
In reply to #81
02/28/2009 12:35 AM
Hi Ducky,
For sure! I have cut and continue to check and cut any background info running.
I know the memory is secure and locked in. I will wait and see how a new OS Linux on a completely different HDD works. I know there is several things that are listed as 'damaged'. But until I get the Linux CD I really can't do much.
wire has sent a couple of sites which are to scan and clean kind of thing. I will run those over the next week. It is not too bad surfing. But, locks every 20 clicks or so when I am trying to reply to posts.
As long as I can get on-line for the moment I have to accept the status quo.
Take care my friend.....................
Good Answers: 97
#84
In reply to #82
02/28/2009 11:04 AM
Your computer maybe fine but you are not controlling it. Have you run a port scan? Are you a botnet?
Good Answers: 97
#85
In reply to #79
02/28/2009 11:07 AM
Turn off java in Adobe reader it is a security hole at the moment.
Good Answers: 68
#86
In reply to #85
02/28/2009 6:22 PM
Hello wire,
How are you?..............
I would be obliged if you could remind how please?
I have done several network diag tests today all saying the wins servers are not working and the OE server out, is not working. Having said that, I can still send some mail from the OE so I am not sure if the info I get back changes between the different computer modes I use? I tried to remidy some things with regard to the network connection, which works fine in safe mode but not otherwise, but got a note saaying what I wanted to do could only be done out of safe mode. So I went back into normal mode tried to do the say thing but, could not get through to Microsoft. I feel like screaming but have to keep calm. AAAArrrrgggghhhh!
I keep getting a pop up saying 'threaatfire' is not updating. I think that is with ref' to the PC Tools Spyware Doctor + Anti Virus, so I may have to uninstall it and reinstall it again. Trying to turn some non Microsoft systems off today, I think it may have been one of the things I turned off, but, I did not keep a note so don't know.
Just to let you know how things are moving, .........or not!
Good Answers: 97
#87
In reply to #86
03/01/2009 10:36 AM
OPen Adobe reader / on the tool bar hover mouse over Edit / Preferences / on left panel find Java click it and disable
Quit beating yourself up, uninstall IE then install fresh
Manual steps to recover a corrupted registry that prevents Windows XP from starting
The procedure that this article describes uses Recovery Console and System Restore. This article also lists all the required steps in specific order to make sure that the process is fully completed. When you finish this procedure, the system returns to a state very close to the state before the problem occurred. If you have ever run NTBackup and completed a system state backup, you do not have to follow the procedures in parts two and three. You can go to part four.
Part one
In part one, you start the Recovery Console, create a temporary folder, back up the existing registry files to a new location, delete the registry files at their existing location, and then copy the registry files from the repair folder to the System32\Config folder. When you have finished this procedure, a registry is created that you can use to start Windows XP. This registry was created and saved during the initial setup of Windows XP. Therefore any changes and settings that occurred after the Setup program was finished are lost.
To complete part one, follow these steps:
  1. Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
    Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted to do so.
  2. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  3. If you have a dual-boot or multiple-boot computer, select the installation that you want to access from the Recovery Console.
  4. When you are prompted to do so, type the Administrator password. If the administrator password is blank, just press ENTER.
  5. At the Recovery Console command prompt, type the following lines, pressing ENTER after you type each line: md tmp
    copy c:\windows\system32\config\system c:\windows\tmp\system.bak
    copy c:\windows\system32\config\software c:\windows\tmp\software.bak
    copy c:\windows\system32\config\sam c:\windows\tmp\sam.bak
    copy c:\windows\system32\config\security c:\windows\tmp\security.bak
    copy c:\windows\system32\config\default c:\windows\tmp\default.bak
    delete c:\windows\system32\config\system
    delete c:\windows\system32\config\software
    delete c:\windows\system32\config\sam
    delete c:\windows\system32\config\security
    delete c:\windows\system32\config\default
    copy c:\windows\repair\system c:\windows\system32\config\system
    copy c:\windows\repair\software c:\windows\system32\config\software
    copy c:\windows\repair\sam c:\windows\system32\config\sam
    copy c:\windows\repair\security c:\windows\system32\config\security
    copy c:\windows\repair\default c:\windows\system32\config\default
  6. Type exit to quit Recovery Console. Your computer will restart.
Note This procedure assumes that Windows XP is installed to the C:\Windows folder. Make sure to change C:\Windows to the appropriate windows_folder if it is a different location.
If you have access to another computer, to save time, you can copy the text in step five, and then create a text file called "Regcopy1.txt" (for example). To use this file, run the following command when you start in Recovery Console:
batch regcopy1.txt
With the batch command in Recovery Console, you can process all the commands in a text file sequentially. When you use the batch command, you do not have to manually type as many commands.
Part two
To complete the procedure described in this section, you must be logged on as an administrator, or an administrative user (a user who has an account in the Administrators group). If you are using Windows XP Home Edition, you can log on as an administrative user. If you log on as an administrator, you must first start Windows XP Home Edition in Safe mode. To start the Windows XP Home Edition computer in Safe mode, follow these steps.
Note Print these instructions before you continue. You cannot view these instructions after you restart the computer in Safe Mode. If you use the NTFS file system, also print the instructions from Knowledge Base article KB309531. Step 7 contains a reference to the article.
  1. Click Start, click Shut Down (or click Turn Off Computer), click Restart, and then click OK (or click Restart).
  2. Press the F8 key.
    On a computer that is configured to start to multiple operating systems, you can press F8 when you see the Startup menu.
  3. Use the arrow keys to select the appropriate Safe mode option, and then press ENTER.
  4. If you have a dual-boot or multiple-boot system, use the arrow keys to select the installation that you want to access, and then press ENTER.
In part two, you copy the registry files from their backed up location by using System Restore. This folder is not available in Recovery Console and is generally not visible during typical usage. Before you start this procedure, you must change several settings to make the folder visible:
  1. Start Windows Explorer.
  2. On the Tools menu, click Folder options.
  3. Click the View tab.
  4. Under Hidden files and folders, click to select Show hidden files and folders, and then click to clear the Hide protected operating system files (Recommended) check box.
  5. Click Yes when the dialog box that confirms that you want to display these files appears.
  6. Double-click the drive where you installed Windows XP to display a list of the folders. If is important to click the correct drive.
  7. Open the System Volume Information folder. This folder is unavailable and appears dimmed because it is set as a super-hidden folder.
    Note This folder contains one or more _restore {GUID} folders such as "_restore{87BD3667-3246-476B-923F-F86E30B3E7F8}".
    Note You may receive the following error message: C:\System Volume Information is not accessible. Access is denied. If you receive this message, see the following Microsoft Knowledge Base article to gain access to this folder and continue with the procedure: 309531 (http://support.microsoft.com/kb/309531/ ) How to gain access to the System Volume Information folder
  8. Open a folder that was not created at the current time. You may have to click Details on the View menu to see when these folders were created. There may be one or more folders starting with "RPx under this folder. These are restore points.
  9. Open one of these folders to locate a Snapshot subfolder. The following path is an example of a folder path to the Snapshot folder: C:\System Volume Information\_restore{D86480E3-73EF-47BC-A0EB-A81BE6EE3ED8}\RP1\Snapshot
  10. From the Snapshot folder, copy the following files to the C:\Windows\Tmp folder:
    • _REGISTRY_USER_.DEFAULT
    • _REGISTRY_MACHINE_SECURITY
    • _REGISTRY_MACHINE_SOFTWARE
    • _REGISTRY_MACHINE_SYSTEM
    • _REGISTRY_MACHINE_SAM
  11. Rename the files in the C:\Windows\Tmp folder as follows:
    • Rename _REGISTRY_USER_.DEFAULT to DEFAULT
    • Rename _REGISTRY_MACHINE_SECURITY to SECURITY
    • Rename _REGISTRY_MACHINE_SOFTWARE to SOFTWARE
    • Rename _REGISTRY_MACHINE_SYSTEM to SYSTEM
    • Rename _REGISTRY_MACHINE_SAM to SAM
These files are the backed up registry files from System Restore. Because you used the registry file that the Setup program created, this registry does not know that these restore points exist and are available. A new folder is created with a new GUID under System Volume Information and a restore point is created that includes a copy of the registry files that were copied during part one. Therefore, it is important not to use the most current folder, especially if the time stamp on the folder is the same as the current time.
The current system configuration is not aware of the previous restore points. You must have a previous copy of the registry from a previous restore point to make the previous restore points available again.
The registry files that were copied to the Tmp folder in the C:\Windows folder are moved to make sure that the files are available under Recovery Console. You must use these files to replace the registry files currently in the C:\Windows\System32\Config folder. By default, Recovery Console has limited folder access and cannot copy files from the System Volume folder.
Note The procedure described in this section assumes that you are running your computer with the FAT32 file system. For more information about how to access the System Volume Information Folder with the NTFS file system, click the following article number to view the article in the Microsoft Knowledge Base:
309531 (http://support.microsoft.com/kb/309531/ ) How to gain access to the System Volume Information folder Part Three
In part three, you delete the existing registry files, and then copy the System Restore Registry files to the C:\Windows\System32\Config folder:
  1. Start Recovery Console.
  2. At the command prompt, type the following lines, pressing ENTER after you type each line: del c:\windows\system32\config\sam
    del c:\windows\system32\config\security
    del c:\windows\system32\config\software
    del c:\windows\system32\config\default
    del c:\windows\system32\config\system
    copy c:\windows\tmp\software c:\windows\system32\config\software
    copy c:\windows\tmp\system c:\windows\system32\config\system
    copy c:\windows\tmp\sam c:\windows\system32\config\sam
    copy c:\windows\tmp\security c:\windows\system32\config\security
    copy c:\windows\tmp\default c:\windows\system32\config\default Note Some of these command lines may be wrapped for readability.
  3. Type exit to quit Recovery Console. Your computer restarts.
If you have access to another computer, to save time, you can copy the text in step two, and then create a text file called "Regcopy2.txt" (for example). To use this file, run the following command when you start in Recovery Console:
batch regcopy2.txt Part Four
  1. Click Start, and then click All Programs.
  2. Click Accessories, and then click System Tools.
  3. Click System Restore, and then click Restore to a previous RestorePoint.
Back to the top
REFERENCES For more information about using Recovery Console, click the following article n...
For more information about using Recovery Console, click the following article numbers to view the articles in the Microsoft Knowledge Base: 307654 (http://support.microsoft.com/kb/307654/ ) How to install and use the Recovery Console in Windows XP 216417 (http://support.microsoft.com/kb/216417/ ) How to install the Windows Recovery Console 240831 (http://support.microsoft.com/kb/240831/ ) How to copy files from Recovery Console to removable media 314058 (http://support.microsoft.com/kb/314058/ ) Description of the Windows XP Recovery Console For more information about System Restore, click the following article numbers to view the articles in the Microsoft Knowledge Base: 306084 (http://support.microsoft.com/kb/306084/ ) How to restore the operating system to a previous state in Windows XP 261716 (http://support.microsoft.com/kb/261716/ ) System Restore removes files during a restore procedure
Good Answers: 68
#88
In reply to #87
03/01/2009 12:05 PM
Hi wire,
I can't believe you have done all this work...........?! Thank you!
I can get out now so can get external memory etc. cheers my friend.
Oh, I am beating myself! But I need a 'good' day or few days to concentrate on the saving and reinstall. Can't thank you enuf!
I will run the scanner you sent a link to today to see what happens. Hope to reinstall over the next few days..............Depends if the 'things I have' let me.
If I can I will be keeping you updated as to how things are going. I know theres not much else I can do but reformat and reinstall, but I have a whole lot of stuff to save first.
Good Answers: 68
#89
In reply to #87
03/01/2009 12:19 PM
Hi wire,
GA to you sir. Thank you.
From a man who feels pretty bloody useless!
Take care my friend............, hopefully my normal healthy self will be back soon.
In reply to #89
03/02/2009 3:28 AM
"feels pretty bloody useless"
Totally NOT babybear ! Your perseverance is worthy of the highest respect. There's probably not a single person here who hasn't been left baffled by a computer fault at some time or other. Fighting through life's adversities makes us better people. There are helpful posts here, especially from bwire, but ultimately it will be you who conquers the infernal machine.
Keep on keeping-on, and one bright day it will be
#91
In reply to #87
05/10/2016 11:03 PM
Thanks for your nice post to teach us more.
Good Answers: 27
02/17/2009 1:26 PM
Ok.......hey....good stuff. I just found a Knoppix guy will burn cd for me.
Nice to have a gov't lab in town. They got all the goodies.
Good Answers: 68
02/26/2009 11:31 PM
Hi Ducky,
You are such a Jammy git! No insult intended I have seen it on the Linux site for about $7.00 I think. Maybe a bit more. You obviously run in the right circles and know the correct people to get anything done!
Take care little Ducky.
Good Answers: 68
02/17/2009 4:33 PM
Hello Andy and all here,
I just wand to say sorry. I wasn't aware Ducky lived in BC and, are so isolated, and so don't have home broad band. I said earlier that he must have two computers because one is not working and Ducky is still on-line to us. But it will not be much good if he has land-line?
Sorry.
I was hoping that my last post would get him out of trouble because it worked for me! Clicking on VGA on the Advanced choices screen.
Must be beautiful in BC right now, well, round the year! Lucky man.
Good Answers: 39
02/17/2009 5:21 PM
Baby Bear, Ducky is a bit east of me over in Ontario - about 4000 kilometers away. Its only a few provinces away. I (elnav) am over on the west side of Canada in BC. Guess distances over her are a bit different. It took me three days of driving from Toronto just to get out of the province going west. It more like Australia in that respect.
I moved out of town from Vancouver. Just a short hop of around 700 or so kilometers to the north. People around here often drive down to Vancouver for major shopping.
I have a sort of high speed connection because I am tapped into the Emergency service network at the fire station hall, that is a short distance down the highway and still line of sight. No line of sight - no connectivity. Yes there is a satellite service at an up front cost of $500 and it costs $60 monthly. But the storms sometimes knock it out.
If I need really massive downloads like movies, the best option is to let a friend in town do it and then burn a CD. He can put on the bus express and it would get here within the week. Sometimes in only a couple of days.
Elnav
Good Answers: 27
02/17/2009 6:46 PM
I see things have vastly improved since I was last there.
He he......I was in Keno City, Yukon, when the first Anik tv broadcast came through...1971.
Place called Luigis'...... full of Indians, hard rock miners and the only TV within 1500 radial miles. For some it was the first time ever seeing a tv in action.....Guess what the show was?
Yep, you guessed it...........Liberace! in full flambuoyance! courtesy CBC.
They loved it!!!
02/17/2009 7:04 PM
Hi elnav
regarding remote area internet access, some friends live on a small sheep station (I think it is only about 400,000 acres). When I mentioned internet access, she said "O we have broadband".
It turns out that to have a phone, they needed a satellite dish, so when most of our cities in Australia only had dial up, she had broadband. As far as I know, her broadband is still faster than I can get.
Isolation seems to have some unexpected benefits - provided your isolation is extreme. (Nearest town of any sort is about 200km).
Good Answers: 39
02/17/2009 9:55 PM
Yep! sure beats city living.
Elnav
Good Answers: 27
02/17/2009 10:23 PM
I got you beat. I've already shovelled my roof!
Good Answers: 39
02/17/2009 10:36 PM
Awww! so sorry, no blue skies your way. I'll have to box some up to send you.
Elnav
Good Answers: 27
02/17/2009 10:52 PM
Funny you should say that. We got a blow coming off Georgian Bay that dumped a foot of snow while the sun was shining. Never seen that before.
Snow is something else this year. Damn cold too.
Good Answers: 68
02/18/2009 8:06 AM
Hello elnav,
That looks wonderful! Thanks for the pic.
Have just come on and some posts have yet to download. Has ducky got any further?
Take care.
PS. Still working in safe mode. Can't get on-line in normal mode. I think from various things I have seen in my trying to get this machine working again, I got a virus which has screwed the DNS and coms in normal mode. Not sure exactly whats going on but as long as I can get online thats fine!
Good Answers: 27
In reply to #60
02/18/2009 8:26 AM
Ya Bear.........all looks to be working just fine thanks much in part to your suggestions. I couldn't stop some programs from running which left the hdd unuseable. Eventually got into the windows control platform (in safe mode) and shut them all down. Next is to uninstall all the programs and just use the thing as a data storage backup device.
Thanks muchly for your assistance. Wish I could help with your demise but am still in learning curve as to what exactly I'm doing.
Good Answers: 68
02/18/2009 9:49 AM
I am pleased you have things sorted. These things are sent to try us right? And boy do we have to learn quick? I think you probably have the 'lead' on me because you have done a reinstall. I have yet to go there.
The Configuration Utility is a very useful tool and as you have proved, much can be done to sort problems out using it. I would not say I 'enjoy' doing so, but it is useful to know that you can reach the seemingly unreachable 'innards' in this way?
Take care anyway......................
11/03/2016 6:27 AM
What's the funny white stuff? We don't get it here, just rain (2m per year)
Good Answers: 27
02/17/2009 1:22 PM
Ok ok......I ain't got the Knoppix........
But I got boot menu etc..........what's a Knoppix?
02/17/2009 2:09 PM
Click on this link:-
http://www.knoppix.org/
Change language to English, read and inwardly digest.
Basically its a bootable floppy with a special linux that can read data on a windows disk, copy the data, format the disk, fix viruses, make a new MBR and and and etc.....
Good Answers: 27
02/17/2009 2:13 PM
Ya.....first I heard of it but definately a must have. Borrowing one from IT guy down the street. I suspect it was part of the data recovery software I was using.
Good info.
Good Answers: 27
02/17/2009 1:19 PM
Duck got boot and strap on floppy. Hdd das boot but no more than that. I haven't got a clue whats stopping the os from displaying on the screen.
Cautious about running scan or de-frag. If I can get download manager to work I'll re-install XP....or rather fuse it into the corrupted version.
By the way...thanks for that link. I've since lost it but it connected me to the lads who built the data recovery software....who connected me..... who connected me.... ad infinitum until IT discovered a lab here in my town that uses it that I do business with. Crazy man. It's been one hell of a roller coaster ride.
Good Answers: 68
02/17/2009 2:29 PM
Please try this if you have not already.........................!-!-!-!
As you say do not defrag'. How do you set up in safe mode? Coz if you clicked
>run>msconfig>BOOT INI>safeboot>network (radio button)>apply>OK> reboot
You should reboot back into safe mode and still have the ISP connection. And so should have your desktop back.
I remember, or rather I have just read nearly two shorthand pads of notes I took every time I did anything.
On the Advanced Options which is one of those screens which you can choose from reboot, there was these:
1)Safe mode
2)Safe mode with networking
3)safe mode with cmd prompt
4)Enable boot logging
5)Enable VGA mode < < < < < < < < Click this!!! Now!
I got to it from turning off and as it boots, immediately as you take your finger from the 'on' button, hold Ctrl down while clicking F8. You might have to wait for the various screens to roll round before you can stay on the Advanced Options.
6)Last known good configuration
7)Directory services restore mode
8)Debugging mode
9)Disable Auto Restart on System Failure.
Have you been rebooting via the reset button, coz that is a quick way and with no systems hardly it reboots in ten seconds or so. You can always interrupt the selection you have made, whether it be the one you want or, one you chose erroneously.
I know it makes know sense but, keep rebooting and something will click in there and it may decide to give you a multi choice screen so you can cmd.exe to allow you to choose safe mode with networking.
As I said I got too tired and had to rest and watched as mine was left on the blue screen. It then started going all by itself.......blue screen > multi choice > safe mode > windows LOGO > then blue screen..........round and round. But I knew I could reboot using the reset button at any time and just wait for the screen I wanted to come round and then choose it.
I had actually tried to restore it from safe mode, using the restore function two hours previously. And I guess it was just sorting itself out and then the screens stopped and the restore screen was on saying the restore was successful! It was then I went into safe mode with networking.
You realise you can choose 'Services' in safe mode? You can turn things on which should be on and there is one or two things which must be on. The one I can recall is something to do with 'comms' which is the connection to the ISP etc. DNS and all that. And that must be on and automatic (I think). Sorry I can't remember now. If you can always adjust it if you can't get on-line.
Have you tried that or have you have enough?
Can you tell me if you have seen your desktop yet?
Take care..........
Good Answers: 27
02/17/2009 4:35 PM
I've got a dual layer AMD processor that allows me to use both hdds separately....and yes....I have seen the safe mode screen. I can basically do four separate tasks on each of the processor layers.
I have a small screen playing of drive E (the corrupted) on my main screen. Safe mode comes on and the whole thing goes into boot again. I can switch drives very easily but I'll let E play out for a while yet.
Good Answers: 68
02/17/2009 4:42 PM
Thank for the post.
Did you try the VGA on the multi choice screen? It brought my icons back up and the desktop.
Take care. I am going to bed soon. Got stuck into your problem and never went to sleep. Not surprising I am tired. I did not sleep last night.
Take care.
Good Answers: 27
02/17/2009 4:56 PM
G'night.....thanks for helping..........
Good Answers: 68
02/17/2009 5:02 PM
No probs! I enjoyed it. Because it is so much like the way mine crashed. With regard to today, with your other friends helping '6' heads is better than 1?
02/17/2009 9:28 AM
I'm ignorant here so I brought in the expert (my daughter)
Hi. Back to basics, my friend. My best friend (computer technician) taught me how to put a computer together and how to fix it when it dies of various (odd, unexplained/unexplainable) causes, so here goes! Btw, congrats on putting your comp together well. (Note: Forgive the steps you probably already know - I'm writing everything just in case.)
Sorry for the screed - it took longer than I thought, and most of this you probably already know, so apologies in advance, and good luck!
1. Get into Windows. Which OS are you running? I'm assuming Windows XP but it could be anything. If you're running Mac, I can't help as I'm less familiar with the inner workings thereof. Back up your data if your disk drives (CD/DVD) are working. If they're not working, get new ones and backup before doing anything else - Please!?!
2. Open My Computer, note which drive letter has been given to the working HDD (usually C:), and if you can see the old HDD but not get in, at least note its drive letter. Take a note of these. Just to make sure, you have removed everything you want to keep off the old HDD, and it's only got copies + old OS? If so, try right-clicking on it and left-clicking Format ... . Keep all settings as they are and tick Quick Format box under Format Options near the bottom. Once that has gone through, choose Enable Compression but remove the tick from Quick Format - this will perform a deeper format. The final task here is to Quick Format again. You've just given the bung HDD three formatting sessions. Click on Close. Did that allow you to gain access to the HDD? If not, next step. NOTE: If you can't see the HDD in the first place, ignore everything in this step apart from discovering all available drive letters.
3. Once you've got the drive letter/s, and assuming you can't see the old HDD, turn your computer off. Do not restart at this point. You need to pull the power cord out from the back of the computer, unscrew all the screws, take the back/sides off, probably pull all other cables out from the computer as well, and then try frantically to remember exactly where each one goes into again .
4. Check the IDE cable which is the wide, flat, whitish cable with a red stripe down one side. Make sure you remember which way the stripe goes. It should be facing you as you look into the computer on its side, with the M/B farthest away from you. It doesn't matter which IDE cable each HDD is on, and it's often a good idea to keep each HDD on a separate cable, and the disk drives (CD and DVD) on different cables too. This is not usually practicable as they are often too far apart for the cable to reach both HDD and disk drive. The info you're looking for here is which part of the cable each HDD is connected to. There are two spots for connection: one at the end of the IDE cable and the other a little way back (kinda in the middle but closer to the end). Make sure each is plugged into the power supply with the yellow wire closest to you as you look at it. You're probably either holding the computer on its side on your lap while you sit on the floor, or on the table with you getting a bad back trying to look into it. Do yourself a favour and sit on the floor with computer on its side (M/B towards the floor) and don't let its weight rest on your legs - it hurts . Two cables must be firmly but not roughly connected to the HDD: power supply closest to you unless HDD is inserted upside down, and IDE cable with red stripe facing you (again unless upside down) - if HDD is upside down, reverse instructions, remove HDD and insert correct side up, which means circuit board should be facing the floor.
5. Well done - now remove cables and unscrew screws. Remove HDD from computer and turn on its top so the backend (HDD not comp ) where the cables go is facing you. There's a spot either between power supply and IDE cable or other side of IDE which should have a jumper slotted onto two of the pins. Turn HDD up or down. One of the sides will have a map of the selection panel (so to speak). You'll probably have to turn it around but you'll work out which way to read it. You want to put the jumper (little plastic bit which is absolutely necessary to give BIOS instructions) onto CS (cable select). Do the same for both HDDs then put them back. Make sure the new HDD is on the end of the IDE cable as that is Master position.
6. Press gently but firmly on every cable in the guts of the comp just to make sure nothing's worked loose as sometimes happens. Put everything back together, put cables back into back of comp and place power cord in. Turn power on and start computer - but make sure you're in front of the keyboard and as soon as the first screen pops up (BIOS starting and going through its paces), press and keep pressing (press, let go, press, let go, ad infinitum) either Delete or F1, or whichever other key your BIOS likes in order to open BIOS up. Once in BIOS, go to the first available choice. Usually it is Main, Advanced, whatever the screen says. Depending on M/B, the BIOS screen will show different possibilities but you're looking for the choice which lets you choose which HDD to locate and recognise. You'll have Master and Secondary or Slave choices of HDD and Disc Drive. You need to go into each one and encourage BIOS to locate it automatically (usually Auto is the command you need). Do that for all possibilities. Press Esc to get out of that menu and go looking for Boot Startup, Boot Configuration, whatever which is usually the next main menu or two. You need to make sure the Primary Boot Device is HDD and the Secondary is Disk Drive (or whichever words or title is used). Esc gets you to the main screen where you can press F10 and choose Y to close BIOS and save changes. Try not to make any other changes unless you know what you're doing as effects can be a little unpredictable at times , although if you have lots of time, you may want to experiment . Did BIOS recognise both HDDs? If so, move onto step 7. If not, try step 8.
7. Your comp will start up again. This time, let it run through and see what happens. HDD should be recognised by Windows Explorer (not to be confused as I do when I'm tired) with Internet Explorer . Do yourself a favour, remove everything off it that you can and format (see step 2 or 8).
8. In initial BIOS/comp startup screen, press and keep pressing (press, release, etc) F8 to open DOS menu. All these acronyms - what the? Techspeak. Out of the choices, hopefully there'll be one which lets you into DOS. Once there, display the directory (I can't remember the exact commands) of C: and of D: to make sure you're going to format the correct one. I believe the command is then [format d:], without square brackets of course, and putting the appropriate drive letter in place. Another way of doing it is to get back into BIOS, make the Primary Boot Device the Disk Drive and don't put the HDD on the list at all, or at the least, put it down the list. Remember to change them back again afterwards or the comp will forever be trying to open up your CDs instead of your OS. Put your Windows XP CD (or whichever OS you're running) into the drive and then restart. The system should want to repair or install. Try install. You'll get a chance later to choose which HDD to install on, or whether to actually install at all. Follow the prompts (each OS is different and I'll confuse the situation further if I give specifics here ) and stop when you reach the part where you can format a partition. Choose very carefully here. You will probably want to format the old HDD (here's where your drive letters are essential). Do so. If your OS on the new HDD is also corrupted, you may wish to re-intall your OS onto the new HDD. You can do so without losing most of your information. You shouldn't lose Program Files or My Documents, but at at least you've got your backup as per step 1. Putting a new OS onto the HDD removes functionality from the original OS but leaves it in place for you to delete later if space is a problem or you're a neat-freak (like me, of course).
9. If you've simply formatted the old HDD, restart comp and check to see whether drive is recognisable yet. If so, maybe give it another format (step 2) and then use it. It's a place to store data, not a place to run your OS from. Always treat it with caution as it can easily fail again without warning. If you've formatted old HDD and then reinstalled OS on new HDD, comp will restart as part of installation process, and will ask for appropriate details on the way through. Set up as per normal - set aside an hour or so (5 mins won't do it but you might get away with 15?) and read a book 'cause it's pretty boring watching the screen.
10. Have fun with your new computer!
If all else fails, take the HDD to a professional, have them recover all data and put it onto CD/DVD, throw the HDD away and buy a new, preferably larger, one.
Good luck.
PS: Do I get a free ticket to Heaven?
Good Answers: 27
02/17/2009 10:09 AM
No ticket.........but thanks for your time in compiling an otherwise excellent step-by-step setup.
The hdd is new. The recovered data was downloaded into it from an hdd that was damaged. I had to get yet another new hdd to download the os (XP) so that when I transferred the files they could be read by the program. This leaves me with one functioning new hdd and another non-functioning hdd which is also new. The hdd with the initial download doesn't allow access from the download manager leaving me stuck with a rather expensive and useless hdd.
My old hdd is in pieces because I wanted to see how the liquid bearings were made. Sealed unit.
Good Answers: 97
02/21/2009 10:59 PM
Subject that rather expensive corrupted useless HD to a powerful electromagnetic field and wipe it off
In reply to #67
02/22/2009 3:21 AM
Put it in a microwave oven. That should kick start it into spining again, though it might be worth checking insurance policies first. A kevlar beak protector might be a good idea too
Good Answers: 97
In reply to #68
02/22/2009 5:41 AM
Put disc in center of whirly-gig and collect hub caps
In reply to #69
02/22/2009 7:47 AM
I got an old stick that goes in hubs. It sucks, it honestly does suck. Probably because I didn't want to blow too much on it.
In reply to #67
02/22/2009 7:23 AM
If you do that, even a reformat will not be able to recover the drive as the "Di-Bits" would also be erased.......
One should never subject a disk drive to a magnet, unless one is junking a drive that has sensitive data on it, but there are still better methods than that even then!!
I guess you were just making a joke!!!
Good Answers: 97
In reply to #70
02/22/2009 11:14 AM
Yeah that's right, all is not lost some patience and fiddling will bring the data back.
Do ya think Norton Ghost could be useful in this endeavor, I had dismissed it but...
Good Answers: 27
02/17/2009 10:41 PM
Hey........that was some good info. It worked. I dismounted the screwed up os, cleared the drive and reloaded the data. I now have one functioning os and two functioning hdds....all done through bios.
In appreciation I'm sending you a catscan of my brain....or rather...what's left of it after two weeks of trying to figure out what I was doing.
02/18/2009 11:08 PM
That's great, Duck! happy to help.
Good Answers: 97
02/21/2009 3:36 PM
How have you configured the HD in BIOS?
Good Answers: 27
In reply to #66
02/26/2009 7:31 AM
I used auto detect and configured them manually.
Problem is I have some corrupted programs from the recovery that are on the second working backup hd (the original buggered one is in pieces). They mostly interfere with my display settings but otherwise work ok. The display settings have to be reset whenever the program is launched.
One thing I will mention..........under no circumstances go to the Microsoft help feature.
BTW.........Greetings to all from the lovely frozen community of Dorset, tip o' Hudsons Bay.
Register to Reply 92 comments
Andy Germany (9); Anonymous Poster (1); babybear (22); bwire (8); caramba (1); chanleen (1); Duckinthepond (26); elnav (6); Hendrik (2); Kris (11); lyn (1); sceptic (4)
Previous in Forum: Apple Virus?   Next in Forum: speed up torrent downloading
