Previous in Forum: Conversion Unit for EU/mL to EU/pair of gloves   Next in Forum: What's Your Take on Energy Drinks?
Page 3 of 3: « First < Prev 1 2 3 Last »
Does the Human Body Store Electrical Charges?
07/06/2009 5:28 PM
I have an acquaintance how says he cannot wear a wrist watch, mechanical or electronic, because of "all the electricity stored in his body" from all the years he was a welder. He later became a medical equipment technician and somewhat of an electronics guru. I would have thought that as he developed his knowledge of electronics he would have abandoned that idea, but he sticks to it to this day. I, too, always had trouble with watches, but attributed it to the banging around I gave them in the work I do. I have never had a problem with digital watches. I asked him why the "charge" in his body could not be dissapated and he gave some techno-bable answer and then said it was a mistery. Am I missing something or is there something to this "stored charge" story? -- JHF
User-tagged by 1 user
This discussion was "closed" on 08/17/2009 12:47 PM. No new comments are allowed.
Message from admins:
Discussion comments are turning personal in nature. Closing before the become outright attacking and hostile.
Good Answers: 985
#127
In reply to #126
Find in discussion
Re: Does the Human Body Store Electrical Charges?
08/05/2009 9:06 AM
Nice explanation of why anecdotal observations are frequently meaningless. You get a GA from me for that alone. But I wish I could give it an "off topic good answer," but that's another thread.
In reply to #126
Find in discussion
08/06/2009 4:36 AM
Hi TVP45
Silvcrow has given an anecdotal example.
Your experience with the light is an excellent example of an anomaly that turned out to have a reasonable explanation.
For Silvcrow and others who seem to have that problem, the explanation may well turn out to be of a similar ilk to your light, they just haven't yet found that explanation.
I agree that normal charges are unlikely to damage a watch or any other piece of properly designed electronic equipment, and, as I have said earlier, I very much doubt that the body can generate a big enough charge as a steady state condition to do it.
At Mt Isa, our cat used to cringe when I went to pat her as accumulated static earthed nicely on the points of her ears! (Very dry climate, nylon carpet)
Most electronics have little resistance to even brief overvoltages, and static can generate quite large ones. However, normal enclosures provide adequate shielding to prevent this being a problem.
Static would not appear to be the explanation here, as Silvcrow has low resistance and would presumably be easily earthed most times.
I can't think of a satisfactory explanation so watch with interest as brighter people than me attempt to pinpoint the solution, which could turn out to have more in common with your light than we at first think.
A GA for your answer by the way.
In reply to #125
Find in discussion
08/07/2009 1:17 AM
You are absolutely right!
A thousand or more folks coming up with at least a thousand or more different anecdotal stories about a thousand different watches indeed points to a problem.
I just don't think it points to a problem with watches or human bodies storing electricity.
j.
Good Answers: 985
#142
In reply to #134
08/07/2009 3:33 PM
Jack,
You're falling into one of the subtle traps of anecdotal evidence. A thousand anecdotal incidents of people having failing watches shows nothing but that a thousand watches failed. The method that collected these incidents is the only thing that correlates these watches together. All machines will fail given enough time and a lack of timely maintenance. This magical and mysterious phenomena ( I'm getting scared now) has a name in Physics. It's called entropy. Getting back to my point, gathering a collection of unexplained failures together and saying that there must be a problem is false. There need not be a problem at all. The unexplained failures them selves can be in one of many categories:
  1. An explanation was not sought out.
  2. The explanation was obvious, possibly embarrassing but forgotten.
  3. The explanation was obvious only to a trained eye, and no trained eyes were available.
So to jump to the conclusion that a problem must exist is itself a false conclusion. Anecdotal evidence leads to avenues of investigation, but they do not prove anything themselves. With so many coincidences that naturally occur in all phenomena, to say any occurrence happens from a particular cause requires careful separate examination.
To paraphrase the scientific philosopher, Hume. Real knowledge requires the gathering of data to find a hidden trend. A theory must then be molded to explain that trend. Then separate testing of new data must reveal that same trend to make real knowledge. For data without theory is trivia. Theory without data is Bu!!$h!t. (I wonder if Penn & Teller ever used this in their show.)
In reply to #142
08/08/2009 2:20 AM
Redfred,
Was I really that obscure?
What I meant to imply was that the problem was in their heads not in reality as you said. "The method that collected these incidents is the only thing that correlates these watches together" i.e., their false mental conclusions.
A method that in some schools is called impressionism as you may well know.
You do an excellent and scholarly job of getting at that problem.
'With so many coincidences that naturally occur in all phenomena, to say any occurrence happens from a particular cause requires careful separate examination."
Let me take it a bit further. All events in real time are coincidental. It is only our minds, validly or not, that select out some of those coincidental events and give them a special attribution. Again, and we agree, all things are coincidental.
Who are Penn & Teller?
j.
Good Answers: 985
#151
In reply to #146
08/08/2009 11:16 AM
Ok, this is now an OT of an OT but an answer to a specific question.
Penn & Teller are an unusual pair of illusionist, magicians. What makes them unusual is that they explain some classic illusionist tricks like Sawing people, but like any quality magicians some illusions like catching a bullet will not be explained. They also have a show on Showtime called Bulls**t. Here they "discuss" Creationism.
08/09/2009 5:01 AM
Coming back to the original topic, I once read a book called "Electric UFO's". I don't remember the author.
His contention was that people who saw UFO's, at whatever level, be it sight or alien abduction, had all been sensitized to electric and magnetic fields by either being struck by lightning or suffering a severe electric shock, generally when they were young but not always.
When in the presence of strong fields (eg EHV transmission lines or close to TV transmission towers) then, if tired, the brain could flip and they would have a suitable experience.
An interesting comment made (and the purpose of this round about discourse) was that many of these people could upset electronic equipment by either being close to it or touching it.
Have any of the people who have this problem of stuffing up electronic gear by touch or proximity been sensitized as described above?
This may show someone a possible path to an explanation, although I'm not sure how.
I don't want to divert the discussion into UFO's. If you want to go there, please start a new thread.
(I am adept at stuffing up computers by my mere presence, but that has nothing to do with anything directly physical, predominantly it's due to my basic ineptitude)
Good Answers: 68
#162
In reply to #161
08/09/2009 5:22 AM
Hello scetic,[p]
Just to say I thank you for the second last paragraph. This thread has already gotten 'lost' several times with subjects not specific enough to be answered properly.
"I don't want to divert the discussion into UFO's. If you want to go there, please start a new thread".
Take care..
Good Answers: 68
#163
In reply to #161
08/09/2009 5:38 AM
Hello Sceptic,[p]
Is this book below the one?
I think this should continue in a new thread as it is interesting but the book itself it nothing to do with this current thread, OK?
Amazon.com: Begreadone "begreadone"'s review of Electric Ufos ... - 1:23amElectric Ufos: Fireballs, Electromagnetics and Abnormal States 0713726857 Albert Budden Sterling Pub Co Inc Electric Ufos: Fireballs, Electromagnetics and ...
www.amazon.com/review/RA4VNAHJFNJGD - Cached - Similar -
Take care
In reply to #163
08/09/2009 6:24 AM
I think so.
The cover of the one I read was slightly different.
The only reason I mentioned it was because he also mentioned that everyone he had examined who could alter the behaviour of electronics by their presence had been sensitized by a severe electric shock at some earlier time in their life.
If that is confirmed by our people who have this problem with electronics, it may give some one a clue to develop an explanation.
Regards
Good Answers: 68
#165
In reply to #164
08/09/2009 6:41 AM
To all................... This is definitely OFF TOPIC!
Hello sceptic,
Yes I fully understand what you say. And of course this book is published around the world so may have differing covers? As I say I do not believe in anything 'religious' or ghosts etc.
This book, from what I have read on the review seems to put things in some kind of order, and is not trying to 'sell' some weird new 'science'! It does not try to inform others and grab people so as to speak like a 'Cult". It would take the earth to move to change what I know about 'proper science' and the way the natural world works, including all the Elements in the Periodic Table.
I simply do not understand how a person cannot understand about a particular 'religion', right? Then they are 'converted'? It simply does not make sense to me. I think those kind of people 'need' something because they are scared of dying, or they are completely false. Take care. If you are interested in this book then why not start a thread? I am interested but only to read the book. As it is not an 'e' book if I decide to get it I will need to get the book, not a printed copy on-line, if you see what I mean? Take care.............
Good Answers: 143
#166
In reply to #164
08/09/2009 8:14 AM
Yet...
I've known a number of people who experienced severe shocks, including me. Two were struck by lightning, one on seven separate occasions. None had difficulty with electronics, none had problems with watches. The guy who was hit seven times had trouble with a woman, but that's another story.
Good Answers: 68
#167
In reply to #166
08/09/2009 8:22 AM
Hello TVP45,
Oh come on, you tell us part of the story and leave us dangling! Only joking.
Take care my friend.
Good Answers: 143
#170
In reply to #167
08/09/2009 10:56 AM
Do you mean the story about the guy hit seven times? He was a park ranger. His story is here. My sister knew him fairly well, but I didn't run into him until after hit number 6. He was slightly eccentric, but I don't know if the lightning did that. But, after all that, he became obsessed and dejected over a woman and shot himself.
In reply to #161
08/09/2009 5:03 PM
Sceptic,
I suspect with a name like that you won't object to my scepticism as to your questions as to "...people who have this problem of stuffing up electronic gear by touch or proximity been sensitized as described above?"
If you are an engineer and have some sense of the science upon which engineering rests, you should know that simply raising such a question gives credence to such unfounded claims.
Science requires that before doing so there be material evidence, not simply unfounded anecdotal assertions by one or another nut case (Nut case because without hard evidence "nut case" is all that is left).
If you are not an engineer or scientist it is possible to see how you could so err.
Redfred has, in an earlier post, shown very well the mental traps that catch the unwary.
Are you an engineer or scientist?
j.
In reply to #172
08/10/2009 5:20 AM
Hi Jack Jersawitz
Retired mechanical engineer as shown under my name.
I was simply taking the claims made by others as honest and would like some explanation.
I find it hard to believe that there are mysterious, undetected, undescribed or mystical forces at work.
If enough info comes to light, perhaps a reasonable explanation can be arrived at, but I would need very solid evidence to even consider "little green men" or mystical forces. I find it hard to believe in either and have yet to see solid evidence of such things.
Good Answers: 68
#178
In reply to #177
08/10/2009 5:30 AM
Hello sceptic,
To post # 177............. In engineering there is ALWAYS a reason, and no mysteries.
Well put BTW!
If something cannot be explained, then the engineer is not experienced enough. Get another engineer.
08/09/2009 5:10 PM
It has nothing much to do with electricity as such but more to do with an energy field situation. Much like the aura that can be measured and photographed. We seem to be focusing on watches but this energy affects quite a few things and although I know of no scientific way to measure it it appears that it is detectable by many people and lots of animals. Some people claim that they can feel this particular energy level from quite a distance others from closeup. Any way it is time to end this program we will not solve this aberation in this form from what I have read. Cheers
In reply to #173
08/09/2009 8:23 PM
Roy,
You made the assertion.
Prove it!
Evidence!
Don't run away.
j.
Good Answers: 16
#194
In reply to #175
08/12/2009 4:20 PM
Prove your hypothisis that anything you havn't heard of, does not exist.
Prove it!
De gustibus non est dispudandum.
In reply to #194
08/13/2009 3:56 AM
That demand put that baldly proves everything I say about your notions.
j.
#179
08/10/2009 8:50 AM
"There is probably no God.... So stop worrying and get on with your Life!"
~Good Judgement comes from experience... and a lot of that comes from Bad Judgement! ~The Early bird may get the worm.. But the second mouse gets the cheese!
Register to Reply Page 3 of 3: « First < Prev 1 2 3 Last »
Anonymous Poster (6); artsmith (2); babybear (36); bwire (5); Campbell Lighting (1); DGCYS (1); garyceng (1); GordieGii (1); Jack Jersawitz (47); jack of all trades (2); Janissaries (2); JLMEALER (17); jrpeck (1); jurie sa (2); kramarat (1); ky (11); lighthasmass (4); lyn (1); Masyood (1); Neil Kwyrer (1); NotUrOrdinaryJoe (1); Part time thinker (2); PWSlack (3); redfred (18); roy hammy (4); RVZ717 (5); s.udhayamarthandan (3); sceptic (6); silvCrow (9); szwasta (2); tecmate (1); Tippycanoe (14); TVP45 (11)
You might be interested in: Charge Amplifiers and Charge Converters
