Previous in Forum: Is Scrap Steel Price Going Up or Down in August?   Next in Forum: The weight and surface area "per meter" of human hair.
16 comments
The Wrong Place?
08/02/2009 2:08 PM
I am not an Engineer (i.e. no degree). Am I in the wrong place?
Re: Wendell
08/02/2009 2:37 PM
Absolutely.......NOT!This is a great place for anyone who wants to learn and help people. We also tend to have fun in the process.
Welcome to the party. Come in and share your knowledge.
CARPE CRUSTULORUM!
Good Answers: 97
Re: Wendell
08/02/2009 3:07 PM
For job opportunities you can click Engineering Careers under
CR4 Sections at the right of the screen.
For sharing knowledge you are in the right place.
Re: Wendell
08/03/2009 1:31 PM
If I were a degreed Engineer, I would take your suggestion. Thanks for the feedback.
Good Answers: 93
Re: The Wrong Place?
08/02/2009 5:10 PM
No.
Ultimately it is up to you.
You don't get wise because you got old, you get old because you were wise.
08/02/2009 6:15 PM
Stick around. You'll figure it out. Just explore for a while.
Go to all the Sections on the right>
Anyone who is coherent is welcome. ( there are exceptions to this rule, but, I don't make them.)
Good Answers: 62
08/02/2009 9:29 PM
You are totally welcome, and many of us are not engineers.
But you are bound to know something, and if you'll share that knowledge when someone is in trouble, you are home.
But I am curious how you found our happy home, I personally was trying to answer a question about irrigation so many years ago (and lest you be intimidated - no one here could answer it either).
I think I hung around because they tried.
Good Answers: 93
08/02/2009 10:19 PM
I ended up here because I was doing research into batteries.
Ended up at Wikipedia and then Exide and then Global Spec, and registered.
The Forum is to me all I wanted from Shortwave Radio, but never got.
- got bottles with roofing tin, and roofing copper cut to 1" wide and three inches long in half liter carafes filled with White Vinegar to produce cell outputs of 1.8 volts for a couple of months.
Was a lot of fun. -got addicted to the forum.
Curious as well as Edignan how you ended up here?
Nice of you to register since the veterans get cranky with "Guests".
P.S. I was a Film Grip or Gaffer and there is probably a case to be made for me as a scholar of 20th Century literature. Around here my extensive reading of Nevil Shute is of more respect, than my understanding of Absolam Absolam by William Faulkner.
08/02/2009 10:56 PM
A thermometer has 100 degrees (at least where I come from) and is pretty darn useless as an Engineer. Many of us are not degreed engineers but still contribute to and learn from this forum.
Just a note: At present there are approximately 10 000 comedians out of work and I think that at least 10% of them are on CR4. (Not altogether surprising sometimes that they are out of work).
Good Answers: 103
08/02/2009 11:27 PM
It is the attitude that matters not the degree. In industries I have seen so many degree-ed non engineers and non-degreed Engineers (ana am still finding a new one every day- not in cyberspace- in actula 3D Model )
Welcome to the forum. Contribute and learn.
(Only don't ask to do your class/project/homework assignments)
Hobbies - HAM Radio - New Member Engineering Fields - Mechanical Engineering - New Member United States - Member - New Member
Good Answers: 22
08/02/2009 11:52 PM
I'm just a lowly drafter, but a lot of engineers and architects started out as drafters. I'm also a ham radio operator who had tinkered with antenna building and design, so I guess I'm an amateur engineer.
Actually, we're just a bunch of nuts. Most of us work in engineering or engineering related fields. Scan through the site, and you'll see discussions on everything from higher math to car repair to bathtubs.
I wonder..... Would Schrödinger's cat play with a ball of string theory?
08/03/2009 8:17 AM
Another one bringing up that rotten bath tub!
CARPE CRUSTULORUM!
Location: N.E. Alberta 55.6329 N Lat. 111.0729 W Long. Canada
08/02/2009 11:57 PM
And DO NOT ask why the voltage is 11 kV or multiples of it. Anything else goes.
Cheers
Could be worse, it could be me. :)
Good Answers: 53
08/03/2009 1:29 AM
A piece of paper is not good enough to be called an engineer, So don't worry about that, Just look inside and figure out if you have that basic instinct of an engineer?
If yes, then you are at right place.
08/03/2009 3:16 AM
Not at all.
Welcome.
Canada - Member - New Member
08/06/2009 3:02 PM
Hey Guest - get it on, man! This is a also great place to pick up chicks, as well as redesigning the multi universe as we @ CR4 plod on into the now, as we thinks we knows it.
By the way, some of the engineers and PHD's here, where I work, are too damn educated & smart to pitch in and make a new pot of coffee when they take the last drop. I guess it's beneath their station in life to do so.
Welcome - Loupy
Have a Happy! ;-)
08/07/2009 10:32 AM
Thanks for the encourgement, and words.
Register to Reply 16 comments
3Doug (1); Anonymous Poster (1); edignan (1); Hendrik (1); Loupy (1); lyn (1); mayt2u (1); not so smart (2); PWSlack (1); rakesh_semwal (1); return (2); sb (1); Transcendian (2)
