Previous in Forum: what is the roe of QC inspector in eletrical engineeing   Next in Forum: Light Absorption in Solar Cell
48 comments
Photo Challenge: What's This Machine?
09/07/2009 8:14 PM
Hello:
Over the Labor Day weekend, my wife and I visited the New Glarus, Wisconsin area, the old-time cheese-making village long known as "Little Switzerland." During our visit we toured the Swiss Historical Village which contains all sorts of buildings and displays depicting what life was life in the years following the Swiss migration into Green County around 1850-1870.
In their Hall of History, they display a machine that measures about 6" wide, 9" long and 8" deep, with a vertical metal "handle," which reaches about 18" high. The entire thing weighs about eight (8) pounds. Next to this machine is a sign asking, "Do you know what this is?" I told the attendant I had no idea what it was and was waiting for her to tell me. Instead, she said, "we don't know what it is and we've had it on display for several years, hoping that our visitors could tell us what it is."
Attached are five pictures I took of it. I could not find any identification, stock or serial numbers, or the manufacturer's name. If you have any ideas, I'd really appreciate hearing from you. As an avid historian I'd like to be able to help them solve this mystery.
Thanks for your help,
Bill Hart
Re: Need Help Identifying Machine
09/07/2009 10:38 PM
Picture on the right seems to show three governer weights. So looks as if there is some sort of speed control. Input shaft I can see, but is there an output shaft?
Could it have anything to do with a timing mechanism - clock?
09/07/2009 10:59 PM
I think the shaft you see is for the output. I think the "input shaft" is the "handle" - I can't figure it out, but it looks like you may push up and down or rotate the handle, which is attached to the spiral gear and starts things in rotation.
And good call on the governor weights.
09/07/2009 11:23 PM
Looking/thinking a little more - it would seem that this may be a high speed - low torque gear box that takes a twist of the wrist to get the output shaft spinning with, perhaps, a torque converter in the middle.
It looks like you spin the handle, which goes the the "torque converter" and then through two sets of speed increasing gears to the output shaft. And then there is the governor, what/how does it trip?
Guest #2
Hobbies - HAM Radio - New Member Engineering Fields - Mechanical Engineering - New Member United States - Member - New Member
Good Answers: 22
09/07/2009 11:19 PM
From what the first two posters have said, I'm wondering if it is a hand-operated drive mechanism for a submersible pump. That would account for a long handle that move up and down.
I'm not saying that is what it is. I'm just speculatin'.
I wonder..... Would Schrödinger's cat play with a ball of string theory?
09/07/2009 11:29 PM
Low speed output to a churn?
09/07/2009 11:34 PM
I think the shaft is high speed (you can see two sets of large input to small output gears)
Guest #2
09/08/2009 12:52 AM
Agree - could there be a spring inside that there drum and the other shaft be a winding mechanism?
Good Answers: 120
09/08/2009 10:36 PM
this is a governed spring drive from an old gram-a-phone.
The ones in pre-metric days were called ounce-a-phones
Per Ardua Ad Astra
09/09/2009 12:05 AM
Ounce-a-phone, good one.
09/09/2009 3:00 PM
My money (and a GA) are on your idea!!!
I think its a clockwork mechanism too.....
09/09/2009 11:56 PM
Love the pre-metric version.
I like the gramophone idea but find the orientation of the winder handle and the output shaft don't fully support that idea as far as I can see.
I do not believe that it is a clock mechanism (though I can imagine fitting the hour and minute hands on the output shaft) as a governed drive is not accurate enough and there is no sign of fusee, verge and foliot, pendulum or any kind of escapement required for accurate speed control.
Could it be the governed speed mechanism for a music(al) box - plate or cylinder type. Other things that come to mind are barrel organs and other mechanical music machines.
Guest 1.
Re: Photo Challenge: What's This Machine?
09/08/2009 11:10 PM
It looks like the mechanism of an old wind-up Victorola-type 78 RPM record player. The large can with gear contains the large flat spring. I cannot see enough of the long handle, which would probably be the crank to wind up the spring.
Dad is in the antique business and he and I have worked on numerous ones of those. Usually they have a broken spring from someone winding it too tight. Upon dissassembling it, one uses two pairs of vicegrips. One to lock onto the center end of the spring and pull it out a couple of inches and a second set to clamp it from pulling back inside. It is necessary to heat the end of the spring to anneal it, then redrill and file a square slot in ot so it can engage the end again. The springs are usually packed in a nasty black graphite greas to keep them quiet, and by the time the repair is done you have the stuff all over you, your clothes, the workbench etc.
Good Answers: 93
09/08/2009 11:26 PM
Detective skills are needed here.{p] OK, of these sets of people what did they make other than cheese?
OKay, if they could make cheese they had some goats and cows around, likely.
Are there associated products possible to make from the dead cows skins that may match evidence of the mechanism?
Where was this mechanism found, and what was near it? - Is that unknown?
My first thought was that it may have squashed leather in some part of the process of making a strap.
Then I wondered if it may have aided somehow in the making of leather shoelaces.
So far I don't have much in the way of useful clues.
Where exactly was this found? I mean as much as possible about where down to details of whom owned the property, and what was it they did.
Is there any part of it that a Swiss history museum could identify as common to the period?
Has it ever been taken apart and put back together?
Has it ever been tested for residues?
Has it ever been X rayed?
P.S. I do find it hard to believe that not one thing used to make this mechanism cannot be traced back to some factory when looking at the gears employed. It would seem that even the type of metals employed would provide some clues needed. There had to be a motive to make this thing, and that is likely to make some money from using it to process some material.
You don't get wise because you got old, you get old because you were wise.
Popular Science - Biology - life lover Hobbies - Musician - music lover Safety - Hazmat - better safe than sorry United Arab Emirates - Member - desert trek Technical Fields - Procurement - procurement
Good Answers: 58
09/09/2009 3:51 AM
"Has it ever been taken apart and put back together?"
oh, don't just the ever-exploring engineers' hands itch to open up the thing?
Now the darkness only stays the night-time, in the morning it will fade away. -- George Harrison (All Things Must Pass)
Good Answers: 50
09/08/2009 11:36 PM
It's the drive mechanism for a large ice cream maker.
Good Answers: 74
09/09/2009 1:10 AM
It looks like it could be used for making jewelery, like in cold pressing. Looks like it could handle a bit, Ky.
The Twain Has Met
09/09/2009 1:15 AM
It is definitely A wind up clock mechanism and I suspect for a rather large one. If you look clearly at the base of the handle you will notice a pawl to prevent reverse spin. The shaft continues through the body to the helical gear to wind the main spring. The second drum I would expect may contain another set of gears. There are two clearly visible shafts on the side of the drums which I'm sure the upper is the main shaft for the governing mechanism (with the transverse shaft and screw), but when you examine the photos closely on the output shaft you will notice that 1) there are two drive gears 2) From the end of the out put shaft you can just make out that there is a sleeve bearing creating a shaft within a shaft. Each turning at a different speed. Wound by a spring. Must be a clock.
Now, measuring the length of the handle (from where the paint stops to the out put shafts) (*2) will give you the bezel diameter. Making another guess I would have to say that this was probably A public clock (town square traffic intersection or possibly even an old train station) that could be wound by a town or city worker and was either replaced with an electrical unit or omitted completely. A nice find indeed. the condition looks to be good so it may have been an indoor unit. Are there no tags or stampings on it anywhere? It seems odd that any company would not leave an identifying mark serial # or some thing. Definitely I would not toss it out. I would put serious effort into finding out the who, what, where, when, etc... And then consider restoration or sale. You never know what history it may hold until you do the research.
Have a good day!
09/09/2009 3:32 AM
Just a few thoughts on the drive.
1. The machine is shown with the winder vertical, must be right as the governor will only work in this position.
2. Cannot be clock drive as not accurate enough but could be for driving a turntable like a beacon, maybe a lighthouse or similar.
If it was wound up how long would it take to run down ?
United Kingdom - Member - Hobbies - HAM Radio - G7TSP Engineering Fields - Electrical Engineering -
09/09/2009 3:49 AM
I'd prefer it to be a Gramaphone mechanism, the end of the shaft even looks like it fits the centre of an old 78... The handle however doesn't look as though it's original and somehow seems out of place.
09/09/2009 4:36 AM
My guess is a clock mechanism:-
09/09/2009 5:26 AM
Good Answers: 56
09/09/2009 7:46 AM
"Bloody good study Mr. Holmes!"
Dr Watson
(AKA, L.J.)
"Both the revolutionary and the creative individual are perpetual juveniles. The revolutionary does not grow up because he cannot grow, while the creative individual cannot grow up because he keeps growing." Eric Hoffer
09/09/2009 8:50 AM
rolling mill or printer or tumbler
Live in the moment, that's all you've got..
09/09/2009 9:14 AM
HAHA Havent seen one of these in a long time....it is indeed a clock mechanism. Since i used to work in a clock and watch shop i have seen many strange brews of clock workings and this is no exception. The shorter shaft is indeed the shaft for the hour and minute hand. the longer shaft with the bent end can move in or out and turn. depending wether the handle was in or out you could adjust the time then either push or pull the handle and wind the clock. pretty smart idea from way back when.
09/09/2009 10:28 AM
Only someone old enough to have seen one of these would know.
Its a Victrola motor. The shaft is tapered to accept the platten, there is a crank, the drum houses the mainspring.
09/09/2009 10:36 AM
Definitly a Victrola motor. The vertical shaft is the crank (not fully seen) and the sideways shaft is the vertical pin that the platen sits on with the rounded end so records are not broken.
It is sitting on it's side in the pictures. The crank would come out the right side of the Victrola and the tapered shaft would be vertical.
On a side note, there were electric conversions made for these so one could take out the wind-up motor and convert to an electric (no winding needed!) motor.
09/09/2009 10:48 AM
Gramophone = record player = Victrola
09/09/2009 11:27 AM
I should have read your post instead of just looking at the pitchers. I thought this was something you found in an attic or yard sale. I still say that I'm confident it's a clock mechanism . The handle is far to long for it to be from a Victrola but about the right length for a 3' dia clock. You said that this was in a swiss historical village. Where there any photos of those old buildings or public areas with a clock? say about 3' in diameter? It would probably be at a train station, village square, or some other public building.
09/09/2009 12:15 PM
The worm gear suggests the long rod is the input and the short rod the output. That being determined; the gear ratios suggest a low rpm in and a very high rpm out; Too fast for a clock or a Victrola. It appears the long rod is used to wind a spring inside the drum shaped object. The ball looking thing could be a speed regulator or adjuster. The mounting surface is the side with the three holes. There is a missing cover plate over the worm gear. It really doesn't look all that old. Other than that, I don't know what it is used for.
Mr.Ron from South Ms.
09/09/2009 1:28 PM
I am rapidly coming to the belief that some clock manufacturers used the same basic spring mechanism as the Victrola gramophones. Gnomehunter said that he was including five pictures but many people seem to have missed the long distance view:-
The handle looks much more like a clock adjust / winding tool than a gramophone wind up handle.
Also:-
09/10/2009 3:52 AM
I estimate that the spindle diameter is roughly 1/30th of the width of the motor which would make it about 1/4", which aint a million miles off.
09/10/2009 4:28 AM
Eh?
09/10/2009 4:57 AM
Hmm... Ok having had another look it could be a little bigger. Maybe its a reject? hence the rest of it is missing ;)
Good Answers: 109
09/09/2009 3:32 PM
Hi,
much too much elastic energy to be useful in a Gramophone.
Too high speed to drive the minutes and hours of a big clock. (The speed regulator will need some revs/sec to be functional).
May be a part of a clock: there was a mechanism (and is in working in mechanical examples) to operate the hours sounding mechanism (a hammer against a bell) to indicate the hours, sometimes also any quarter hours. This is requiring considerable energy for some short time, needs a speed regulator, required rewinding in pre-electric times (any 7 days was usual).
RHABE
Good Answers: 11
09/09/2009 6:58 PM
It reminds me a lot of a hunting tooth limit switch. While I don't see switches I suggest it is possibly a position indicator for a winding engine.
When I get a chance to have a closer look I'll try and identify the parts and confirm or squash my first impression.
09/10/2009 1:22 AM
I may be off base here but as NOBODY knows exactly what this is, we are MOST unlikely to get the definitive answer.......so I guess we will never know for absolutely sure what it is.....other than its a clockwork mechanism, with speed regulator, for something (of that I am pretty sure).
Good Answers: 50
09/10/2009 3:17 AM
If you notice, the faceplate holding the output shaft is meant to be bolted against something. This obviously is the Worlds first attempt at "green energy." That's right, your looking at the wind-up motor for a spring-driven car...
I know, because I work on a similar principle.
09/10/2009 3:36 AM
...and there is stupid me thinking that you can only go up and down!!!!! Almost like Zebedee on the Magic Roundabout!! (Do the ladies like that better?)
09/10/2009 3:38 AM
250 miles to the gallon (of sweat!)
Good Answers: 18
09/10/2009 6:06 AM
HiGnomehunter,
I add my contribution on the side of it being a gramophone drive. The evidence suggests the machine has been used for some other purpose after it ceased to be used in the 'phonograph' box. Hence the extended winder shaft. The speed control friction device beneath the governor with the little rubbing pad are all in keeping with this being a 78 RPM drive. The output shaft appears to have a slow taper on it after the rounded tip which is where the platen would locate. What it was subsequently used for is the interesting challenge. There is so little power available from the spring drive and when combined with the short duration of the running time between winds makes it quite a puzzle.
Good antique hunting.
Massey
If it ain't broke,leave it well alone .........until it comes looking for you!
09/11/2009 12:13 PM
some kind of rolling mill
Good Answers: 88
09/12/2009 5:46 PM
It's a 78 rpm old gramophone hand winding mechanism. Please recycle
Good Answers: 114
09/13/2009 9:46 AM
It is a 78 RPM gramophone drive, its what we used to play records when I was a kid, I've cleaned and oiled a similar one many times. That governor works in any orientation. The winder, with the help of the pawl, loads up the spring while an external brake prevents the platen from turning. The record is put in position and the brake released and the arm moved onto the record. The spring holds more than the three or four minutes of one side, but then the torque reduces so you have to wind up for each record..
Good Answers: 50
09/13/2009 8:26 PM
It resembles a gramophone mechanism, but it looks too beefy. Also, look at the size of that output shaft! One more thing, gramophones had cranks - what the heck is that long pole doing where a smaller crank should be...
Possibly a spring drive for an old player piano???
Good Answers: 74
09/13/2009 8:42 PM
Maybe the long pole is there to crank some heavy metal (leverage), Ky.
The Twain Has Met
Good Answers: 50
09/13/2009 8:58 PM
I'm thinking the long handle is to reach the mechanism inside the piano case.
09/15/2009 4:30 PM
I'm convinced it's a winding mechanism for a "victrola". See the following link.
www.phonophan.com
09/19/2009 12:59 PM
Phonograph motor.
I've collected phonographs for over 30 years and I can say without a doubt this is a windup spring motor from a 1920's console style phonograph (gramophone). I don't know what brand. The pictures do not show the motor in the correct orientation. The short spindle should be vertical and is what the turntable would be seated upon. The long shaft is the crank (not fully shown) and is long because it had to go through the side of the console cabinet. Since most winding cranks are removable, this may or may not be the original crank handle.
Register to Reply 48 comments
3Doug (1); Andy Germany (3); Anonymous Poster (13); aurizon (1); crimich13 (2); don.ras (1); Emjay4119 (1); ky (2); langyaw (1); Laughing Jaguar (1); Lemmy70 (5); Massey 726 (1); passingtongreen (1); Princess (1); Randall (3); RHABE (1); ronseto (2); shriketexas (2); SimpleMind (1); Transcendian (1); vermin (4)
