Previous in Forum: How to Calculate Loads on Vehicle Jack Stands   Next in Forum: Finding datasheets on google.
27 comments
Christmas Lights on a Redwood Tree
11/18/2009 2:32 PM
There is an 80-foot high, cone-shaped redwood (metasequoia) tree in my back yard. Except for a pickup truck fitting through the back door of my detached garage, there is no access for larger vehicles.
I want to confuse my neighbors by permanently placing several hundred multi-colored LED Christmas lights on the top 20 feet of the tree. The branches are too brittle for tree climbing, especially the small branches of the top 30 feet of the tree.
I thought of linking the lights in a the shape of a right circular cone, and using tethered helium-filled balloons attached to the vertex of the cone, raise the lights and lower the cone on top of the tree.
Does anyone have one of those anti-gravity baskets that Dick Tracy used?
Any practical and inexpensive suggestions?
Origo
Hobbies - Musician - New Member APIX Pilot Plant Design Project - Member - New Member
Re: Putting lights on top of a redwood tree
11/18/2009 2:50 PM
Bow and arrow . . . like used for fishing . . . shoot an arrow over the tree . . . use the fishing line as a leader and pull the string of lights over the top of the tree . . . I have done this many times when setting up my remote ham rig out in the woods. If you don't like the first pull, then pull the whole shooting match back down and shoot a new arrow.
A government big enough to give you everything you want, is strong enough to take everything you have.
Good Answers: 46
Re: Christmas Lights on a Redwood Tree
11/18/2009 4:39 PM
Hello Origo, Have you though about a man lift/cherry picker ? It all depend on the size of your door to get one through. Even one that did not reach all the way up to the top, but with using something like a pool pole (some are more than 20ft long when extended). Or like the other poster using an bow & arrow. Your aim and placement would be better than on the ground.
Good luck Charles
Metal is the material, The forge is life, The anvil and hammer bring character and soul.
Good Answers: 93
11/18/2009 7:47 PM
Practical & Inexpensive I'd try the Bow and Arrow method.
I have worked out of Manlifts up into the 30 and 40 foot ranges, but don't think it is something to do for fun. Some will get high as hell, but issues of spread and reach, and ground level may make even reaching from as close as you can get with the arm, may mean diagonal reach would reduce height from ground, plus have it fall over.
You might try a boom truck with a jib arm and get it with a swiveling shiv and pull lines, but this is not going to be what I would call inexpensive.
Climbing the tree is out for decorating it even if it is a strong assed tree.
You are simply too much in the wrong place. I've fought up in the smaller trees wrapping them with lights but still had to get outside it to up down do a wrap from a series of A frame ladders.
I think the sets of lights I used ran 5 amps a string, so then only three strings are really reliably safe to run on one feed.
Your desire for a "right?cone" may need to be abandoned as even vertical strings will be hard to pull up and over, unless there is something about this tree different from trees I have fought to light.
How I came to have spent some of my working life putting lights into trees illustrates why it has been said, "God isn't a second class novelist."
On a nice day you might tether a hot air balloon over the tree through the use of a drop line, and tag lines and pulleys and whatever tackle needed to control all.
I have been up in tethered balloon once a long time ago. I'd have to consult with a balloonist to see if they would know how much they might have to burn and what variances of AGL would be expected.
That method would not likely be less than just hiring a large crane since your talking 5 guys at least, plus rigging.
Scaffolding is also possible, but would be very labor intensive.
Strictures I understand so far are 80 tree, no space to get a manlift into, and a set of horizontal cone lights around the first 20 feet of the top of the tree?
Somehow this project is likely to be expensive, regardless of the least inexpensive method or design, vertical or horizontal.
I'd nearly recommend just building on the ground a fake tree, and standing it up.
You don't get wise because you got old, you get old because you were wise.
Good Answers: 46
11/18/2009 9:15 PM
Hello Transcendian, I agree the man lifts are harry especially the taller ones.
Another idea would be to find an arborist/tree cutter that would be willing to do the job. They would have the knowledge of the trees and equipment to do the job to get into the top. It would just then be a matter of pulling the strings of lights up and the arborist guiding with a pole or two to place. Just an idea.
Charles
11/18/2009 8:51 PM
Just thinking of the problems causing the dillema that could be more easily overcome if the situation were modified slightly.
Firstly I would ensure that the lead for the lighting was as lightweight for the application as possible, 80 feet of extension chord is pretty heavy.
The geometry of the situation may also pose some hassles, if you cannot see the top of the tree from your backyard this could become quite difficult. How high is your house, how close is it to the tree, what are your boundaries, perhaps a sketch may be in order.
Perhaps some simple trickery could be in order to "confuse" your neighbours. A large number of laser lights slightly out of focus could be used to pretend that the tree has lights on top of it, and to add the final confusing touch, a series of unconnected power leads up the tree until they are out of sight.
Goodluck!
Good Answers: 58
11/18/2009 11:17 PM
Tethered helium balloons are ok, but expensive to lift that weight. If there are no power lines in your area, you might be able to use a box kite. Have two tethers or three, think about it, and hang a string of lites a good ways below the kite. When the bottom of the string of lites is high enough, start wrapping the lites just like you do on a regular Christmas tree. When you get the string to the top, do a wrap and pull the kite down. You will need it still attached to the top of the string of lites to take them down.
PS you are totally whacked.
mike k
Good Answers: 74
11/18/2009 11:30 PM
Hi Origo
I know of crop dusters and animal herders that use small choppers. They could fly circles around that tree and carry a bit too. Make sure you have the cameras switched on and put it on U tube. Your neighbor would not even have to leave his house to view the tree or the debacle. If there are no higher trees in the vicinity it should be a walk in the park. Fair weather would be required. I'm sure one of these blokes would like that one on their resume so you could agree on a fair price. I would not mention it to my insurance but it could be done here in Queensland.
These dare devils here would do it for a slab or a bottle of rum, just for the heck of it. Good luck and send us a shot if you ever get those lights up there, Ky.
The Twain Has Met
11/18/2009 11:37 PM
To confuse/surprise your neighbours: either bow and arrow, as suggested, or one of Del's crossbows.
Cheers
Vince
"There is nothing more difficult to plan, more doubtful of success, nor more dangerous to manage than the creation of a new order of things." - Niccolo' Machiavelli
11/19/2009 12:08 AM
just run an ad on craigslist looking for a climber to set up your lights. An expert tree climber can go anywhere a squirrel can go in a live tree.Usually when i show up to work for someone new, the first thing i do on a tree takedown is climb the tree and remove the very top foot or so of the tree by breaking it off and tossing it down to the boss.After they see i can do that, they usually go do somthing besides keep an eye on the new guy.If you dont or wont use craigslist,just listen for saws and chippers running. you will usually find a climber nearby.Some tree companies advertise light installs, but the company will charge more than just the climber,working on the side for you.A good competition climber can be at the top of that tree in less than one minuite after setting his climbing line with a throwline.Bow and arrow,please! someone good with a proper arborist throw weight and throwline can hang a limb at 70 ft up,with a hand toss and pull their climbing line up with that. I think the record for a 50ft footlock climb is around 13.9 seconds.
Good Answers: 97
11/19/2009 3:16 AM
The bow and arrow may not lift the wires but a potato cannon will
11/19/2009 4:08 AM
Trebuchet?
11/19/2009 5:54 AM
I hope this helps.
The frame needs to be sturdily built for the lower 40 ft, it can be lighter built above.
You only need to go to about 30 ft with the rope(s), that should help....pull the frame tight against the tree.....black or green painted to blend in......
Make it so that you can dismantle it and store it for next year....
I hope this helps in some way......
11/19/2009 9:45 AM
Sir:
Your solution is the best that I have received. Thank You
Origo
Engineering Fields - Systems Engineering - Member for some time now, see my profile.
11/20/2009 7:01 AM
Andy
sounds good to me,
thinking outside the box!
GA to you.
Sleepy
11/20/2009 1:14 PM
I thank you kind Sir!
Good Answers: 58
11/19/2009 9:28 AM
Many years ago I might have thought about how to get to the top of that tree to place the lights. At my age I think I would get a few lasers and illuminate apprpriate branches. If you were really clever about it, you could do it with a single laser and a programmable mirror.
11/19/2009 9:42 AM
Make sure you get LEDs connected in parallel each with its own series resistor. You don't want the whole string to go out because of one duff light.
11/20/2009 6:59 AM
Randall,
Yes, very important otherwise the first one to go will take out all.
Have given you a GA.
It may be slightly better to provide a constant current source for all (how many?) LEDS,
this would avoid a lot of power loss and hot resistors and burnt hands, the thing to remeber is that LEDs are constant current devices ( they are diodes, after all).
Good thinking
Sleepy
11/23/2009 3:01 AM
Unfortunately: the only way to provide a constant current source for all LEDs is to put them in series:-
If you try to provide enough current for all LEDs and put them in parallel: the LEDs with the smaller forward voltage drops will "hog" the current:-
So the only sensible way to do it (if you don't want a single failure to kill the whole string) is to have a constant voltage source and a series resistor with each LED in parallel:-
Clearly you want the voltage source to be just enough bigger than the forward voltage drop of the LEDs so that the differences in voltage drop don't cause too large differences in forward current. Assuming that the LEDs have a forward voltage drop of 3.5V then a 4.5V power supply (one of those switchable ones) seems reasonable, and, 62Ω resistors will give you about 16 mA per LED which will give a very good life expectancy for typical 20 mA LEDs. (adjust the resistor value for different voltage drops for different coloured LEDs)
Of course if you make the installation easily accessible as Andy has suggested then several fixed current "strings" is the way to go.
It's worth thinking about making custom lights with very high brightness LEDs for this application because the off the shelf ones will seem very dim when they're at the top of that tree.
Good Answers: 74
11/23/2009 5:38 PM
Hi Randall
Say, would those technicalities work on a REDNUNWOD tree as well?
The Twain Has Met
Good Answers: 12
11/23/2009 4:10 AM
Alternative to the bow and arrow is fishing line with a heavy sinker on the end, and a slingshot
Bill
11/25/2009 3:06 PM
Origo - You said you want to PERMANENTLY mount these lights? Be aware that the tree will grow above them at the top and you will soon have an unlit apex above the lights. Also, the branch tips will grow beyond the lights, so the lights will begin to have an "embedded" look to them - that will be kinda cool.
Good Answers: 97
11/25/2009 3:19 PM
google metasequoia then rethink
11/25/2009 3:28 PM
OK, I googled it. I learned that metasequoia can reach 200 feet, grows fast, and is deciduous. I don't understand what sort of "rethinking" you have in mind...
Good Answers: 97
11/25/2009 3:53 PM
meta-sequoia is a fast-growing tree to 40m tall (100' in 60 years) and can reach 200' but at about 9"-12" per year adjustments can be made.
I consider a fast growing tree to grow 8' - 12' per year.
11/26/2009 1:49 AM
If the top grows at 9" to 12" per year then after ~4 years the lights will be "embedded" in the envelope by a foot.
Good Answers: 12
11/27/2009 2:52 AM
Redwoods which we have in the Pacific Northwest are definitely NOT deciduous. They have needles rather than leaves and are green all year long. They definitely are fast growers though.
Bill
Register to Reply 27 comments
Andy Germany (2); Anonymous Poster (2); AstroNut (2); bwire (3); ky (2); metalSmiths (2); mike k (1); nukesub629 (1); Origo (1); PWSlack (1); Randall (3); Sciesis2 (2); Sleepy (2); Transcendian (1); Vince GEntile (1); welderman (1)
