Previous in Forum: CO2 Bulk Storage System   Next in Forum: MP3 Players in the Industrial Work Place
22 comments
Remove Bubbles Suspended In A Thick Edible Syrup
11/16/2010 12:25 AM
Recently I attempted to thicken a syrup based food product by using a hand blender to dissolve xanthum gum in water. The solution became very thick, goopy actually, which is how I wanted it. However, rather than being a clear syrup. as with sugar and water, this mixture is off-white and opaque the result of containing thousands of tiny bubbles which the blending action creates. Any slower blending action will not dissolve the xanthum gum. Is there an easy way to remove the bubbles? Would a vacuum chamber work?
User-tagged by 5 users
Re: Remove Bubbles Suspended In A Thick Edible Syrup
11/16/2010 3:57 AM
Depending on the viscosity, vacuum will remove the bubbles. The volume of material will increase considerably during the degassing process, so use a container with many times the volume of the amount of material to be degassed. Heating prior to degassing will reduce the viscosity and facilitate the process.
A centrifuge may be a more effective means of degassing a high viscosity material.
11/16/2010 9:19 AM
"A centrifuge may be a more effective means of degassing a high viscosity material."
I believe this to be a very good idea. A Honey Centrifuge can be built easily, or a small one purchased, not very expensive.
11/16/2010 9:28 AM
Did you try heating the mixture? Is there some reason why it can't or shouldn't be heated? With what you have now, it wouldn't have to come to a complete boil to drive out the air bubbles.
Is there any reason why simply doing a slow reduction, perhaps with some corn syrup added, wouldn't be practical instead of the xanthum gum? That's a typical method for thickening syrups, i.e., slowly heating them to reduce the water content. I've made blueberry syrup that way; using just a bit of corn syrup (which I otherwise never use) and slowly boiling the juice until it becomes the desired thickness.
Good Answers: 109
11/17/2010 9:26 AM
GA Usbport. As this is food processing, it is highly likely that the gases are CO2 from biological processes before the syrup is bottled. Heating slowly to the boiling point followed by cooling is a method used to de-aerate water or in this case remove the CO2 from syrup. If the user is bottling the syrup while the syrup is still hot, there may be gases still trapped in it. It would be much easier to remove the CO2 before the bottling rather than trying to remove the same gases as an added process. The maple syrup industry has similar issues but are avoided by the slow boil. If bacteria get into the syrup afterwards but prior to bottling, these CO2 gases appear.
As an aside, sometimes when you pour a glass of water that looks good, you may see bubbles that form around the meniscus. If these bubbles linger around more than a few seconds, I would suspect some bacteria contamination. The agitation of the water filling the glass will release CO2 created by bacteria. Hopefully, the syrup is not bacteria contaminated.
11/16/2010 12:20 PM
I have no idea if this would work and I would be interedted to hear comments from the rest of the community:
Perhaps you could put a blanket purge gas over the mixture - like Helium - that would displace the air from the mixing chamber.
Would Helium be less likley to become entraned in the mixture? or perhaps even release easier?
If you are going to go to the trouble of building a vacuum chamber, this idea, if it worked, seems like it would be easier to implement.
Just a thought.
Regards,
Paul
Some standards are like the North Pole and some are like Mecca. People use both to get their sense of direction, however, only one is a preferred destination. - P.E. Scheibmeir
11/16/2010 12:40 PM
My gut reaction is a gas is a gas. While I'm sure the act of mixing would entrap the same amount of gas, He might more easily rise to the surface, I don't know.
Hope this doesn't burst your bubble.
Good Answers: 140
11/16/2010 1:16 PM
You might try attaching a vibrator to the wall of the vessel holding the mixture. It may allow the bubbles to rise to the surface and pop. I have seen such vibrators (little air motors with offset counter weights on the driven shaft) used in the printing industry to allow ink tanks to be bubble free. Mind you the viscosity was much less, but the principal is the same and may meet your needs. Heating the mixture at the same time would also help.
11/16/2010 10:59 PM
GA from me. Years ago I saw a demonstration by a manufacturer of molded resin sinks and bathtubs. The mold full of **THICK** resin was put on a vibrator table to expel the air bubbles.
I cannot look at the leaf of a tree without being crushed by the universe. --Jules Renard
11/16/2010 9:03 PM
Can you make your stirring device submerged well below the surface so as to minimize entrained air?
Good Answers: 22
11/16/2010 11:06 PM
Reverse the polarity on the blender connections & blend in the opposite direction for EXACTLY the same time as the first attempt?
11/16/2010 11:31 PM
Xanthum gum is very hard to disperse in water before it dissolves. I tried using it to thicken some home-made orange liquor and could not get it to work (just got lumps in my booze). I'm sure that's why you used the blender. I have not tried it, but I wonder if you might have better success by pre-mixing the xanthum powder with something like corn starch, which would allow you to use a slower mixer and not get those super fine bubbles.
11/17/2010 12:40 AM
Good morning, Curiosity killed the cat! What are you cookin'?
11/17/2010 1:03 AM
I recently did some molding with an implant grade silicon compound that is very thick. My first thought was vacuum but that created way too much expansion and foaming. I discovered that pouring it from one container to another worked fairly well. You have to pour it very slowly a fairly long fall so that the stream narrows so thin that it causes the bubbles to pop. It seems to work fairly well and you don't need any special equipment.
11/17/2010 3:54 AM
Yes, putting the mixture under vacuum will remove the bubbles, but make sure that you allow for the large increase in volume as the vacuum is being applied. The company I work for makes simmilar polymer based solution and that is the method that we always use to degas them.
Good Answers: 109
11/17/2010 4:34 AM
Mixing below inert gas will be a good idea to prevent oxidation if the stuff can react with oxygen from included air.
But bubble inclusion will take place nearly as much as with air.
If you can mix below steam then there will be no problem as with condensation this will be hot only at the surface and condense to water and thin the stuff again but not introduce bubbles.
RHABE
Good Answers: 123
11/17/2010 9:00 AM
I would also have to recommend keeping the mixing blades low enough and slow enough to not induce the air during mixing.
Another thought would to use a pump to circulate the mixture rather than using the mixer. I frequently have to pump large quantities of a liquid that foams up way too easily. We have found that we just never disturb the surface of the liquid. Pump and fill from the bottom and on foaming. If you were to have a pump with a flooded suction connected to your mixing "bowl", you could circulate the mixture as you add the Xanthum gum. As long as the pump does not suck any air, your mixture will blend, and be air free. As a bonus, you would be able to add a diverting valve you would be able to pump your mixture to the next location. Good luck.
Bob
11/17/2010 1:03 PM
Try making a paste from the gum, using a small amount of water.Then gradually add water to achieve the desired viscosity.Do not use a blender, as they are designed to introduce air into the mixture.Use a magnetic stirrer to incorporate more water, using a speed slow enough not to create an air induction vortex.Once this is thin enough,gradually add to the main mixture as required.If added too quickly, or if too thick when added,you may experience drop out when the product is stored, or on the store shelf.You may also use an eductor to inject the mix into the suction side of a recirculation pump,which pulls product form the bottom of the tank and returns it to the top side,preferrably above a mixing prop.
Good luck.
HiTek
Good Answers: 74
11/17/2010 7:10 PM
I agree:
Move slower and longer.
The Twain Has Met
11/18/2010 5:02 PM
X gum is very hard to work with if you want to avoid this problem. You might check with a company that produces thickeners for paints - some thickeners used in paint can be obtained as a food grade product. Hydrocellulose comes to mind. There is a short delay after mixing in water before it thickens. The initial mix is thin.
The only other way that comes to mind is to blend the X gum and water in a vacuum blender, which is neither cheap nor easy.
11/18/2010 5:04 PM
I should have said hydroxycellulose not hydrocellulose
11/22/2010 9:26 PM
microwave for 15 seconds
12/02/2010 7:33 AM
Hello Promethea2010
You mention a hand blender therefore I presume you wish a hand means of bubble extraction. Should this be so squeeze the mixture through a very woven fine cloth. Place mixture in middle of square cloth, gather the corners and start twisting downward. The air bubbles shall cling to the cloth syrup during passage through the cloth.
Register to Reply 22 comments
129CBRider (1); Anonymous Poster (3); bob c (1); corelite (1); DaS Energy (1); Doorman (1); HiTekRedNek (1); kevinm (1); ky (1); Leonf (1); lyn (2); MrGeneRall (1); North of 60 (1); OldTechNewToys (1); rcapper (1); RHABE (1); Tornado (1); Usbport (1); Zamaron (1)
