Previous in Forum: Sub Distribution Board Types   Next in Forum: Problem in Stardelta Starting
Good Answers: 140
Use of Acronyms...
06/08/2011 9:03 AM
Often times perfectly good question are rendered completely unintelligible by the use of acronyms.
This is an international forum! Acronyms used in one geographic region often mean squat to readers in other locations of the world.
If you want a valid response to a question, please ensure that the first time you use an acronym, explain what the acronym refers to. Otherwise... a well known and understood rule of valuation systems applies... "Garbage in = Garbage Out".
India - Member - New Member
Good Answers: 164
Re: Use of Acronyms...
06/08/2011 9:16 AM
Amen to that. In fact, this post should be a part of the CR4 code of conduct.
In addition to ...
not using sms type texting language,
using proper punctuation,
using a reasonable form of address (not "Hay!" as one poster started) .....none at all is quite ok
..... well, this is too much.
Forget it.No acronyms is enough.
Good Answers: 181
06/08/2011 10:50 AM
Sorry kvsridhar, I couldn't resist it:
Amen 2 dat. n fact, DIS post shud b a pRt of d CR4 code of conduct.n aDitN 2 ...
not UzN sms typ txtN language,
UzN propR punctuation,
UzN a reasonable form of adR$ (not "Hay!" az 1 poster started) .....none @ aL iz quite k
..... well, DIS iz t% much.
4get it.No acronyms iz Enuf.
Good Answers: 164
06/08/2011 11:56 PM
06/10/2011 10:25 AM
I got everything execpt DIS:
J B
06/08/2011 11:46 PM
What do you mean by the acronym SMS in your anti-acronym post?
Good Answers: 164
06/09/2011 12:07 AM
Hah got me there.
06/11/2011 10:11 PM
Good Answers: 164
In reply to #67
06/11/2011 11:16 PM
06/08/2011 9:19 AM
I don't understand......................what is acronym?
How do you mean squat?
Good Answers: 164
06/08/2011 9:27 AM
Acronym : A synonym with acrobatic leanings.
Squat : We Indians understand the sense, since it happens here.....
06/08/2011 10:14 AM
I understand. Just trying to be funny.
Many people may not understand the term "squat" in that sentence.
I'm also guilty of greeting someone with Hey............
My brain kind of works in the regional dialect, so I tend to type that way.
I don't particularly like acronyms either, you will never catch me texting, tweeting, or anything that requires an understanding of them all. I don't get any of them.
Good Answers: 164
06/09/2011 12:04 AM
i know ..... it was funny of course...
That OP said "Hay" not Hey, Hi etc ... ok, English not his native language, but then it isn't mine either. Anyhow someone set him right, explaining that it is something that horses and cattle eat, etc.
Another poster addresses the forum as "Dear"...not Dear friends, dear CR4 members, anything... just Dear. Makes me itchy. Someone has tried unsuccessfully to reform him...
Good Answers: 119
06/08/2011 9:35 AM
If an acronym is known and common to experts in that field, why shouldn't it be used in a discussion forum? For those readers who are unfamiliar with a specific acronym, this acronym should help lmgtfy. For other common text shorthand acronyms, how about a quick look here netlingo ?
I realize I'm suggesting that the reader should put in a tiny bit of thought and effort to learn about what has been posted. Shame on me for suggesting such a horrific concept .
Good Answers: 140
06/08/2011 9:45 AM
I agree that when engineering acronyms are well known and used world wide and are easily understood in the context of a given message, then there is no issue.
But... What does "MSB-01" and "MSB-02", mean to you? Means not much to me. All I can ascertain for sure is that there are 2 units called "MSB" in a given facility.
What we do is an engineering discipline. Doing this properly requires proper information! "Blue Skying" and "Guessing" have no part in these process.
Assumption has killed many a fool...
06/08/2011 10:48 AM
When I write something on a public forum, I usually at least hope that more than one person will read it. So, I usually try to consider the overall minimization of expended time--that is, mine combined with the readers. That usually means that I try to spend more of my time (to write out or explain an acronym) rather than expecting multiple readers to look up the acronym.
There are a few reasons for this. I'm on this forum not only to contribute my expertise (assuming I have some), but also to learn from others. Hence, I do not expect that all readers of my posts are experts--presumably some, maybe many, are reading to learn something they are not expert about.
(Usually I think that is a good thing, but obviously there are risks--I would not someone who learned brain surgery by reading in a medical forum to operate on me. ;-)
Nevertheless, sometimes I will use acronyms without defining them, either by accident or when I'm quite confident that it is a very common acronym. If I'm wrong I have no trouble explaining.
Moving to comment on a different post in this thread, with respect to MSB-1 and MSB-2, I suspect those are not quite acronyms as we normally expect, but more a feeder designation for a particular plant, possibly meaningless outside that particular plant. Something like that definitely requires explanation.
On the other hand, in my early days as an electrician helper (and probably even my early days of engineering), I might have seen that on a set of drawings (or heard it from my (lead) electrician) and assumed (I know) that was a universal designation.)
06/10/2011 10:32 AM
GA.
Recently I have found myself doing more proposal work. The standard approach we use in our proposals is to introduce the acronym by initially using the phrase (or term) spelled out with the acronym in parenthesis.
For example, if I were to use ASME, I would initially write American Society of Mechanical Engineers (ASME). From that point on in the writing I would use ASME.
J B
In reply to #59
06/14/2011 8:40 PM
The use of acronyms has gotten out of hand.I want it stopped ASAP!!
American General
In reply to #70
06/14/2011 11:46 PM
I once had a chassis made for a project at work. I wasn't in a hurry, so I put the required date for completion at 3 weeks. The next day the man brought me the chassis. When I asked why it came so soon he replied "Yours was the only one that wasn't ASAP".
In reply to #72
06/15/2011 2:48 AM
I guess if you put out an RFQ (request for quotation) with an ASAP (as soon as possible) in it, you could also ask how S is P....
United Kingdom - Member - Hearts of Oak Popular Science - Paleontology - New Member Engineering Fields - Mechanical Engineering - New Member
Good Answers: 75
In reply to #73
06/15/2011 5:33 AM
I have to point out that RFQ is not an acronym...it's an abbreviation.
An acronym is an initialisation abbreviation that forms a new word. A.S.A.P. or ASAP od borderline - I believe it's pronounced Asap in the US (and possibly other places) but more usually A.S.A.P. in the U.K.
NATO is an acronym, USA an abbreviation.
Most TLAs are, in point of fact, Three Letter Abbreviations...
Abbreviation is, of course, a compound word; being formed from the Latin "Ab" to move towards and "breve" to shorten. Ironic, really, what?
Chaos always wins because it's better organised.
In reply to #72
06/15/2011 9:46 AM
Reminds me of an experience with the chief supply clerk at the first mine complex I worked at. I needed some parts (to be bought--not normally stocked), so I wrote up the necessary requisitions, asking for delivery ASAP.
When I handed them to him, he looked at them, then very carefully lifted up a 15" high pile of paperwork in his in basket and placed them underneath.
I got them back and put dates on each of those, and all I submitted in the future.
06/08/2011 11:30 AM
It does weed out the uninformed, which if it peaks their interests they would ask.
What is and can be confusing is when and acronym has two totally different meanings.
But texting acronym should be hung. IMHO
06/08/2011 10:01 AM
Aren't acronyms on the Red List?
06/08/2011 10:03 AM
Acronyms and contractions can both be confusing. I agree with you, GIGO!
Amp? Are we discussing an ampere, an audio or signal amplifier, or an ampoule?
As you say, there are many acronyms that are considered common, but may only be so in English, and may only be really valid in the USA (United States of America): PSI (pounds per square inch), MPH (miles per hour)...
A command of communication is one of the most valuable skills in an engineer's toolbox. I have always believed so. Are these skills of communication no longer sharpened and honed at institutions of higher learning? It sometimes appears they are not nurtured in public education.
06/08/2011 10:16 AM
Darn. I thought MPH was "mighty penguin hunter".
Good Answers: 48
06/08/2011 10:23 AM
Only in the southern hemisphere!
06/08/2011 10:43 PM
must be the sort of day I'm having but thats funny!
'Nunc est bibendum'
06/08/2011 10:49 PM
point of order - psi, mph etc. (Names have capitals eg Volts V)
sorry for getting picky but (and I make mistakes to) accronyms can sometimes get confusing if capitals are used where they shouldn't.
'Nunc est bibendum'
Good Answers: 181
06/08/2011 10:17 AM
This thread has been a long time in starting. I fully back all you say, it's impossible to answer a question not fully understood.
Unfortunately some attempt the impossible.
Good Answers: 75
06/09/2011 3:32 AM
There have been at least 2 such threads before...I'd put links but that means having to search for them and ICBA.
06/09/2011 6:08 AM
06/08/2011 10:28 AM
Good Answers: 181
06/08/2011 10:43 AM
Another good one http://transl8it.com/
Good Answers: 140
06/08/2011 10:52 AM
Without a doubt there are many such excellent lists of acronyms available on the Internet. The problem here is... which one are we to "assume" the OP (OP = Original Poster - which should be clear to all. But I added the codicil after the fact.) meant?
Where the use of a given acronym is clearly, or should be clearly, understood by all who read a given post, then the intent is clear and offers no impediment to the communication process.
Notice the word "communication". For communication to work, frames of reference understood by all are a core part of the communication process, or should be a core component.
This is especially so when dealing with technologies that can have a life safety aspect to them. There is no room for "What I really meant is..." in our line of work.
06/08/2011 11:32 AM
"In Morse Code, never transmit faster than the other end can receive." - Anon
06/08/2011 11:34 AM
TLAs are NBG.
Good Answers: 804
06/08/2011 11:43 AM
I wholeheartedly agree Nof60, I try very hard NOT to use acronyms that I think will be local, but it is difficult. I was trained here in the US but went to work for a German company years ago where I discovered just how diverse and confusing acronyms can be, mostly because they are usually based upon words in the native language or at best, based on transliteration of words in a native language into English. But is it British English or American English? It just gets way too confusing.
As to lmgtfy, here is why that rarely works for acronyms, based on the thread that I think prompted this rant:
MSB
About 10,800,000 results (0.18 seconds)
For me it's a sign of disrespect to use acronyms and sms style text. I am volunteering my time to help others, who seem to not want to bother with making my assistance as easy as possible to render. Sometimes my response has been an unexpressed "FU"! Then it often happens that the poster gets even more rude by saying something like "What, no response??" Clueless...
06/08/2011 12:44 PM
I try to follow the convention of most government documents and specifications by identifying the acronym at its first use, then assume everybody is informed enough that explanation isn't needed again during that conversation.
I admit that I sometimes don't bother with PSI, MPH, etc.
What bothers me more than dealing with acronyms is having to convert everything from metric to "standard" terms.
06/08/2011 11:55 PM
trying going from a decimal system to non decimal system
'Nunc est bibendum'
Good Answers: 94
06/09/2011 5:24 AM
I can remember having a confusing conference call with an American customer where we were discussing how large a component should be. We were both talking in 'mils' & it took a while to realise that the American mils are thousandths of an inch whilst the UK mils are millimetres.
I agree with an earlier post, define the terms at the outset then feel free to use them as often as needed.
Good Answers: 75
06/09/2011 3:40 AM
Shouldn't that read: "from metric to Imperial terms." ?
Good Answers: 48
06/09/2011 3:52 AM
No. US gallons are neither metric nor Imperial. 'Standard' is certainly the wrong term. Do we need to come up with a new term?
06/09/2011 8:53 AM
I'm used to calling units using foot, pound, mile, ... as English units (or the English system). And then, if I'm speaking with someone in England, Canada, or such, qualifying gallons (or tons) with "US" (when appropriate).
06/09/2011 10:38 AM
Perhaps I should have said "having to convert everything from metric to units with which I am familiar."
ER, back on the farm, we didn't realize that they were, " Imperial terms".
Good Answers: 75
06/09/2011 10:57 AM
<huge grin> It's the term used in the UK to distinguish between our native units and the French ones we had to start using when they bred out the sixth finger.
Moneywise, we talk about pre-decimal and decimal systems: Ah! the Old Money: 240 pennies to the pound, 12d to a bob, 4 crowns to a pound, 2 tanners to a shilling, 4 farthings to penny. And you should see my thre'p'ny bits...
I still use Imperial lengths and weights, but confess to being unfamiliar with units of heat - I've never managed to get a feel for BTU (British Thermal Units...). I read the back of a milkshake recently and worked out there were 25g or sugar in each bottle. That didn't sound much until I realised it's about an ounce - suddenly I'm not drinking so many of them!
One question: How many fluid ounces in a US pint? We've 20 fl.oz in a pint (UK) and 8 pints in gallon...I know US gallons are slightly smaller than UK ones, are the other units similarly different?
06/09/2011 11:04 AM
Forget units, have you Brits been able to make a car that doesn't leak oil yet?
Good Answers: 94
06/09/2011 11:55 AM
Of course we have, they're japanese cars manufactured in the UK.
Good Answers: 48
06/09/2011 12:22 PM
The good old British cars, now that was a clever design! You never had to drain or change the oil, just top it up. Plus good rust protection on the underside of the car! They don't make'em like that anymore!
Good Answers: 164
06/09/2011 12:31 PM
Amen !!! My neighbour had one which was pre-independance (Indian i mean). Never changed a single thing including the Champion spark plugs ! Used to smile when i changed my radiator every six months.
In my professional life, i have seen 40 year old BTH and English Electric Circuit Breakers, still happily in service. The customers can't understand why the company can't supply the same ones anymore. They can't swallow "Improved technology"
Good Answers: 48
06/09/2011 12:43 PM
You Indians have a habit of keeping good things going - like Royal Enfield!
Good Answers: 164
06/09/2011 11:14 AM
Pardon me, i could be wrong, but is it true that cars in England have speedo/odometers reading miles, but petrol is sold by the litre ?
No offence meant, just curious.
Miles per litre would look even more pathetic than kMpL that i get from my car
Good Answers: 48
06/09/2011 11:29 AM
Many countries that have officially gone metric have not gone entirely metric. Thus, in the UK, distance (especially on roadsigns) is usually expressed in miles and yards, but petrol/diesel is priced by the litre. Beer must (legally) be sold by the pint (imperial) but bananas must be sold by the kilogram.
It must be toughest for Canadians, torn between Imperial, metric and US units.
06/09/2011 11:35 AM
Here in the good ole US of A one needs both metric and SAE (Society of Automotive Engineers) wrenches to work on most vehicles. That may have changed over time, but I doubt it. Metric and SAE screwdrivers seem to interchange nicely.
Seaman to buddy near tool box, " hey throw me a wrench."
Buddy, 'What size?'
Seaman, "don't matter, I'm gonna used it as a hammer anyway".
Good Answers: 164
06/09/2011 11:44 AM
Canada...ahh ... don't remind me.
i was passing through Quebec a long time ago. Wanted to wash my hands, turned on the "C" tap (what else?)...got scalded !!!
Called reception furiously and questioned "what the f***?" .. the sweet young thing said ... 'but M'sieu, it is "C for chaud, means Hot in French you know"....'OK, sorry, my mistake' i said, and then looked at the other tap. You guessed it. It also said "C" !!! So i said 'Miss, the other tap also says "C" ... what the ... Ok sorry" ... "But M'sieu, that is COLD, we are a bilingual state n'est ce pas?"
Good Answers: 48
06/09/2011 12:05 PM
That's quite funny, and in some ways typically Quebecois. I lived there for a few years when Quebec was still bilingual. Interestingly, every province in Canada is now officially bilingual, except Quebec.
06/09/2011 11:48 AM
Great, In the US If we went metric, (think we started about 40 years ago) to be political correct. we'll have to put our roads signs in Standard, Metric and Spanish. We're going miss alot of turn offs. fortunately we all should have our GPS....to recalculate.
06/10/2011 4:22 PM
06/09/2011 11:22 AM
"bred out the sixth finger" ROFL
From Wiki:
US customary fluid ounce
1 US fluid ounce=
1⁄128
US gallon
1⁄32
US quart
1⁄16
US pint
1⁄8
US cup
1⁄4
US gill
=2tablespoons
=6teaspoons
=8US fluid drams
≈1.80468754cubic inches
[4]
≡29.5735295625millilitres (or the same number of cubic centimetres (cm³))
≈1.040842731imperial fluid ounces
≈1.041avoirdupois ounce (29.5 g) of water at 62 °F (16.7 °C)
Good Answers: 75
06/10/2011 10:51 AM
Aha! I got the impression there were 16 of your fluid ounces to one of your pints...I found somewhere selling 8 fl.oz and 16 fl. oz bottles, which seemed odd strange numbers to pick, to UK eyes. Looks like "Standard" and "Imperial" are different beasts...even the ratio of teaspoons to tablespoons is different (2 tspn = 1 tbspn here).
Yes, I could have looked it up, but, well, you know how it is ;o).
06/09/2011 11:34 AM
Re: One question: How many fluid ounces in a US pint? We've 20 fl.oz in a pint (UK) and 8 pints in gallon...I know US gallons are slightly smaller than UK ones, are the other units similarly different?
There are 16 fluid ounces in a US pint. As far as I know, US and UK ounces are the same, and the difference in the US and UK gallon is then 32 ounces--ahh, but I'm wrong:
From Wikipedia: Gallon:
Definitions
A one US gallon gas can purchased near the US-Canada border. It shows equivalences in imperial gallons and litres.
  • The imperial (UK) gallon was legally defined as 4.54609 L. This definition is used in some Commonwealth countries and Ireland, and is based on the volume of 10 pounds of water at 62 °F. (A US liquid gallon of water weighs about 8.33 pounds at the same temperature.) The imperial fluid ounce is defined as 1⁄160 of an imperial gallon. On 1 January 2000, it ceased to be a legal unit of measure within the United Kingdom for economic, health, safety or administrative purposes.[3]
  • The US liquid gallon is legally defined as 231 cubic inches,[4] and is equal to exactly 3.785411784 litres or about 0.133680555 cubic feet. This is the most common definition of a gallon in the United States. The US fluid ounce is defined as 1⁄128 of a US gallon.
  • The US dry gallon is one-eighth of a US Winchester bushel of 2150.42 cubic inches, thus it is equal to exactly 268.8025 cubic inches or 4.40488377086 L. The US dry gallon is less commonly used, and is not listed in the relevant statute, which jumps from the dry quart to the peck.[4]
Hmm, for some reason, I can't get those bulleted items to stay in italics.
06/10/2011 10:55 AM
<...And you should see my thre'p'ny bits...>
Do go and get a bath towel, ER! There are sensitive readers on here!!
06/10/2011 11:05 AM
Surely she was tought to keep her hand on her ha'penny too.
I've gone metric every inch of the way.
I always quote bow limb dimensions in mm taken at 6" intervals down the limb, 'cos mm is convenient for small dimensions and inches convenient for big ones.
(tee hee I said big ones)
Good Answers: 164
06/10/2011 11:32 AM
i am afraid the Americans have got you us all beat...
There was this ten-gallon hat guy in the loo at DC last time i passed thru there (Washington DC is a good place to pass through). He squatted. Some guys there giggled, so one braveheart asked the cowboy, "Excuse me, i thought you guys were really tough ?" .. Said the texan .. "Glad you asked podner...y'see, i had meself a hernia operation, and my doc tole me not to lift heavy things ya know"
Good Answers: 48
06/10/2011 12:06 PM
Small peristaltic pump tubing has also gone totally metric, eg 1.6mm, 2.4mm, 4.8mm, 6.3mm, 12.6mm, etc.
Good Answers: 75
06/13/2011 4:55 AM
I'll wrap them in the towel after I've soaked them in coca-cola to remove the patina and make them all shiny
Good Answers: 75
06/09/2011 10:44 AM
Good point, Colonial Cousin . Must remove these Imperial glasses...
Good Answers: 48
06/09/2011 11:07 AM
Yes, ditch them. I'm told metric specs are ten times better. (Or was that binary specs?)
Anonymous Poster #2
06/09/2011 11:11 AM
Binary is twice more better
06/14/2011 11:40 PM
According to former president Bush, they are twice more gooder.
06/09/2011 9:40 AM
IDK
Good Answers: 164
06/09/2011 9:48 AM
IYCLTJT
(If you can't lick them, join them)
06/09/2011 9:53 AM
Thats a new one on me!
Good Answers: 114
06/09/2011 10:02 AM
WTF [what the fuqk] I use acronyms
but only after defining them the 1st time I use one within a thread
the UM [unit of measure] question requires patience on everyone's part, I have a conversion program & am not afraid to use it. as long as we aren't getting too obscure these things tend to work themselves out...
OP's should return to their threads early & often to provide additional input or clarifications
ER is right this subject comes up from time to time
06/09/2011 10:41 AM
Now that I think about it I used to carry a press cutting from the Electronics Times (or something similar) from about 1979, which explained that "Plessey electronic network information systems" had decided to change its name.
06/10/2011 12:05 PM
This discussion has really gone into the crapper.
06/15/2011 6:56 AM
Government agencies and technical fields seem to be hooked on acronyms.Some have been used so much that they are often used without having to think about the origin.Such as SNAFU(situation normal, all fouled up),BOHICA (bend over, here it comes again),DILLIGAF (do I look like I give a flip).When an acronym is eventually accepted as a word proper, and there is no need to mentally decipher it, it has transcended into the public vocabulary.
Language is a living thing, and mutates over time.Someone once said that I did not speak the king's English.You are right, I replied, but neither do you.
I found an old recording of old English,where the narrator had studied the old text, and was considered an authority on the matter, and only an occasional word could be understood.If we went back to the 10th century, we could not understand the English of that era.
That is one reason the medical field chooses Latin, because it is a "dead" language, and the meaning does not mutate over time.
As acronyms become more frequently used, they become accepted without hesitation.Eventually, a separate language develops within certain groups that is sometimes unintelligible to others.
In reply to #75
06/15/2011 8:36 AM
Oh, you mean like the hip-hop culture?
J B
Engineering Fields - Control Engineering - Control Engineering Technical Fields - Education - Industrial Training Engineering Fields - Manufacturing Engineering - Manufacturing Training Engineering Fields - Electrical Engineering - Electrical engineering Training Engineering Fields - Instrumentation Engineering - Instrumentation Engineering United States - Member - New Member Engineering Fields - Energy Engineering - Become part of the larger group, change your world.
06/15/2011 8:35 AM
In the near future, more people will be using phones to access the internet and CR4 forums, than using computers. So often replies will be like tweets (140 characters), so how will one define acronyms with such limited text, screen area and typing functionality?
Maybe smart phones should have an acronym library built in that displays definition based on GPS indication of what country user is in.
GPS=Global Positioning System
And sorry, I could resest either, ha ha ....
GPSThe Gap, Inc.
(stock symbol)
GPSGreat Plains Software
GPSGeometrical Product Specifications
GPSGeneral Problem Solver
GPSGeneralized Processor Sharing
GPSGirls' Preparatory School
(Chattanooga, TN)
GPSGovernment Policy Statement
GPSGreat Public Schools
GPSGo Pound Sand
GPSGraphical Performance Series
GPSGigahertz Peaked Spectrum
(astronomical radio source)
GPSGerman Potato Salad
GPSGallons Per Second
GPSGod's Positioning System
GPSGray Platelet Syndrome
GPSGround Processing System
GPSGunner's Primary Sight
GPSGlobal Protection System
GPSGas Pressure Switch
GPSGraphical Programming Software
GPSGlobal Payment System
GPSGeophysical Processor System
GPSGlobal Product Support
GPSGhana Police Service
GPSGrams Per Second
GPSGladstone Power Station
(QLD, Australia)
GPSGod Positioning System
GPSGroundwater Protection Strategy
GPSGerman Philatelic Society
GPSGalapagos Islands, Ecuador - Baltra
(Airport Code)
GPSGround Processing Station
GPSGrand Parent Stock
(livestock breeding)
GPSGeneral Purpose Separator
(at CERN)
GPSGrange Primary School
(UK)
GPSGuelph Police Service
(Guelph, Ontario, Canada)
GPSGeneral Purpose Segment
GPSGlobal Priority Service
GPSGeneral Purpose Shelter
(temporary, military deployable shelter)
GPSGreenwood Primary School
(Singapore)
GPSGunbound Philippine Server
(gaming)
GPSGriffiths Primary School
(Singapore)
GPSGirault, Poupard & Stern
(public-key authentication scheme)
GPSGlobal Platinum Securities, LLC
GPSGeneralized Phase Shift
GPSGeophysical Products System
GPSGongshang Primary School
(Singapore)
GPSGuidance Power Supply
GPSGlobal Punchout Suite
GPSGuided Planning System
(financial planning)
GPSGreenridge Primary School
(Singapore)
GPSGerman Peace Society
GPSGot It, Played It, Sent It
(correspondence gaming)
GPSGuangyang Primary School
(Singapore)
GPSGross Pay Statement
GPSGlobal Precision Snipers
(gaming website)
AB PLC Training onsite, On-Line, training software and more. BIN95.com
Good Answers: 48
In reply to #76
06/15/2011 8:46 AM
How about predictive acronyms?
AAAAAAAAAAARGH!!!
In reply to #76
06/15/2011 7:53 PM
Maybe smart phones should have an ...Like most things they'll be in the hands of (some) idiots so this discusion will rear its head again.
back to acronyms:- FYI to me meant 'for your information'. My wife has been using FYI when discussing her work and the distrubution of information there. She's been in the job for over 12 months and I've heard it a lot -and sometimes it didn't quite fit but ....any way the other day she said FYI 'Freedom of information' and suddnely a lot of discussions made a lot more sense.
My point along with many is that acronyms are not always as local as one would expect and should be clarrified at the onset.
'Nunc est bibendum'
Good Answers: 164
#81
06/15/2011 11:15 PM
Usual caveat !
Good Answers: 114
#82
In reply to #81
06/15/2011 11:28 PM
Good Answers: 130
#83
In reply to #81
06/16/2011 12:16 AM
"Usual caveat !"
More like 'Etymological naughtiness'
Good Answers: 164
#84
In reply to #83
06/16/2011 12:27 AM
Well, i guess now "Weiner" will become immortalised by generating its own family of associative words... wining, dining and wein(er)ing for example..
Good Answers: 130
#85
In reply to #84
06/16/2011 12:51 AM
I blame Andy Ky
But hauntingly accurate
Even associative careers, like Polish handball goalkeeper, playgirl photographer, Pulitzer Prize-winning author and naturally; psychologist
06/16/2011 6:05 AM
Sounds like some people have had SUPER HIGH INTENSIVE TRAINING in ACRONYM ETYMOLOGY. And of course, you are right...it doesn't mean squat to some people..
06/16/2011 6:15 AM
After seeing all the variations of wiener....
I wonder----is polish Polish?
Are pencils made in Pennsylvania?
Are finish nails made in Finland?
Are there turkeys in Turkey?
Is it cold in Chili?
Do ties come from Thailand?
Are people in Russia in a hurry?
Are Europeans?
Is there a hairy peen hammer?
Do Bald Eagles have a comb over?
Good Answers: 130
#88
In reply to #87
06/16/2011 7:50 AM
How odd - you spell it peen?
I wonder if it's cross
In reply to #88
06/16/2011 8:38 AM
http://search.yahoo.com/r/_ylt=A0oG7l449vlNzD8A14pXNyoA;_ylu=X3oDMTE1YW5oaGYyBHNlYwNzcgRwb3MDMQRjb2xvA2FjMgR2dGlkA1ZJUDAyNl8xNDg-/SIG=11pphmtkv/EXP=1308248728/**http%3a//www.thefreedictionary.com/peen
Even spellings vary by locality/nationality....(sigh)......
Genesis:11:1.5
5 But the LORD came down to see the city and the tower the people were building. 6 The LORD said, "If as one people speaking the same language they have begun to do this, then nothing they plan to do will be impossible for them. 7 Come, let us go down and confuse their language so they will not understand each other."
Good Answers: 130
#90
In reply to #89
06/16/2011 9:11 AM
And then ................... all that begat business started
In reply to #88
06/16/2011 9:13 AM
More of a surprise that he thinks the ball part is bald
http://en.wikipedia.org/wiki/Ball-peen_hammer
Good Answers: 130
#92
In reply to #91
06/16/2011 9:22 AM
I think ball pain is something different altogether and bald balls is a obviously a personal dilemma
In reply to #91
06/16/2011 9:58 AM
Thanks--I couldn't figure out where "hairy" came from--even with my mind in the gutter it didn't really fit...
In reply to #91
06/16/2011 11:28 AM
A little artistic license, please!
Good Answers: 164
#94
In reply to #87
06/16/2011 10:25 AM
Awesome !
Let me add my 2¢...
. You only need 4 correct to pass. Don't cheat!
1) How long did the Hundred Years' War last?
2) Which country makes Panama hats?
3) From which animal do we get cat gut?
4) In which month do Russians celebrate the October Revolution?
5) What is a camel's hair brush made of?
6) The Canary Islands in the Pacific are named after what animal?
7) What was King George VI's first name?
8) What colour is a purple finch?
9) Where are Chinese gooseberries from?
10) What is the colour of the black box in a commercial airplane?
Remember, you need only 4 correct answers to pass.
Check your answers below:
1) How long did the Hundred Years War last? 116 years
2) Which country makes Panama hats? Ecuador
3) From which animal do we get cat gut? Sheep and Horses
4) In which month do Russians celebrate the October Revolution? November
5)What is a camel's hair brush made of? Squirrel fur
6) The Canary Islands in the Pacific are named after what animal? Dogs
7) What was King George VI's first name? Albert
8) What colour is a purple finch ? Crimson
9) Where are Chinese gooseberries from? New Zealand
10) What is the colour of the black box in a commercial airplane? Orange (of course)
What do you mean, you failed? Me, too.
(And if you try to tell me you passed,you LIED!)
Good Answers: 130
#95
In reply to #94
06/16/2011 10:46 AM
I got #5 'wrong' - but I'm cheap
Soft hair brushes are made from Kolinsky sable or ox hair (sabeline); or more rarely, squirrel, pony, goat, mongoose or badger.
Cheaper hair is sometimes called camel hair, although it does not come from camels.
Good Answers: 164
#100
In reply to #95
06/16/2011 12:06 PM
IQ ≥ 200?
In reply to #94
06/16/2011 11:28 AM
And there's a perfectly logical explanation for each of those answers. Just not an obvious one.
J B
In reply to #94
06/16/2011 11:40 AM
http://www.urch.com/forums/english/9214-learned-vs-learnt.html
Which brings up a colloquial interpretation of an everyday word:
Naked,pronounced as it sounds, with a long A, and it means
"They ain't got no clothes on."
and Naked,same spelling, but pronounced NECK-ID.The definition of which is:
"They ain't got no clothes on, and they is up to somethin' "
Good Answers: 164
#99
In reply to #98
06/16/2011 12:03 PM
Wow. American folklore at its best ! As my friend Old Sitting Bull keeps telling me....(i am Indian you know)
Learnt is correct for me, since i live in India.
Nekkid is a good word. i will remember that one.
When i first landed in NYC and went to a breakfast joint, i was asked by the impatient waitress, "Up or over?" .. not having a clue, i said "Easy over" having read in some Perry Mason book... delicious eggs, bacon, toast, whatnot. Still don't know what the difference is between sunny-side-up and easy-over. i want to come to USA once more just to order "Neither. I want them hardboiled for 20 minutes"
34point5 (7); Anonymous Poster (2); BIN95 (1); crashcol (4); Doorman (1); English Rose (7); Fredski (3); Garthh (2); HiTekRedNek (8); Holzfeller (9); JBTardis (4); JRaef (1); kramarat (3); kvsridhar (17); lyn (5); mjb1962853 (1); Nigh (2); North of 60 (2); phoenix911 (3); PWSlack (4); Randall (3); rhkramer (5); rickwil (2); StandardsGuy (2); TonyS (3); Tornado (1); user-deleted-1105 (1)
