Previous in Forum: Preventing Rust on Guns or Tools Stored Underground   Next in Forum: Welding Trailing Arms of a Frame Work
Does Bullet Burn with Friction in Air?
11/08/2011 2:08 AM
21 gun salute and shooting in air is not uncommon.
The bullet should travel upward under G Force till its velocity becomes zero and then start downword and should arrive at ground level with velocity of launching again.
If hit someone he will be killed but never heard something like this. Why? Is the bullet burns itself due to friction with air? Completely? Partially bun bullet shall reduce in mass and increase acceleration and hence velocity ? (conservation of momentum) which will keep the force of hitting same?
Location: Ground Zero of the Pompous and self important....Washington DC
In reply to #65
Find in discussion
Re: Does Bullet Burn with Friction in Air?
11/09/2011 2:52 PM
Roughly 30-45 degrees above horizontal through unscientic observation. I've been to several funerals of ex-service men that had the 12 gun salutes. Navy and Army.
In reply to #70
11/09/2011 3:08 PM
Dangit it....I meant 21 gun salute....not 12.
In reply to #72
11/09/2011 4:42 PM
I thought 12 must've been wrong, as it's tradition to have an odd number.
According to Wikipedia, you must've known some pretty high-ranking ex-service men.
Good Answers: 918
11/09/2011 7:20 PM
That is because they use blanks.
Good Answers: 15
11/09/2011 11:16 PM
A 21-gun salute is conducted with blanks. No bullets are launched.
Shooting in the air does kill people. A 9-year old girl was killed in Phoenix, AZ a few years ago by someone celebrating a holiday by shooting in the air.
At the velocities that a bullet is travelling, it does not reach temperatures required to even melt, much less burn up. Additionally, it is rapidly slowing due to drag and, in the case of being fired into the air, gravity. It will not reach it's initial velocity on the fall to earth due to atmospheric friction, but it will reach a velocity sufficient to be lethal.
Good Answers: 62
#85
11/11/2011 12:19 PM
WOW
Subscribed and Un Subscribed in under a minute!
New record for me
United States - US - Statue of Liberty - New Member Engineering Fields - Electrical Engineering - New Member Popular Science - Genetics - New Member
#86
11/11/2011 3:08 PM
Shooting in the air can usually only kill somebody if they shoot up and at an angle this allows the bullet to maintain forward velocity if it is fired straight up it usually will not kill you because on the way down it can only reach terminal velocity due to air friction this is usually enough to leave a nice knot on your head, possibly knock you out but usually you will survive here is how you calculate the ending speed of a bullet where Vt is terminal velocity of that specific bullet, Vo is starting velocity, and T is the starting angle of the bullet (theta) (Vo*cos(T)^2+Vt^2)^.5 at angle atan(Vt/Vo*cos(T)) (this assumes the bullet was fired high enough to reach Vt on the way down it also does not account for forward velocity loss due to friction) *this is not encouragement to try to fire a bullet straight up all the math and physics in the world can't overcome stupidity*
Popular Science - Cosmology - New Member Engineering Fields - Civil Engineering - New Member Engineering Fields - Nuclear Engineering - New Member United States - Member - New Member
Good Answers: 38
#88
11/15/2011 3:48 PM
Perhaps we need to take a more subjective view. Suppose the bullet has never bucked hay and is, for lack of vocabulary, "girly".... in which case maybe the slight heating it would experience could be described as "burning"!
Sometimes my thoughts are in a degree of order so high even I don't get it...
In reply to #88
11/15/2011 7:08 PM
Also....there are such things as tracer rounds and incendiary rounds....those actually burn....but not due to friction with the air however.
In reply to #89
11/15/2011 9:19 PM
Tracer bullets do not "burn per se" -- a small charge of pyrotechic compound in the base is ignited by the powder burn and provides the visible "trace" of the bullet path,
34point5 (3); 666 (1); Andy Germany (6); Anonymous Hero (1); Anonymous Poster (15); Bike Master (1); Chankley (2); ChaoticIntellect (1); cuba_pete (8); durtieduck (2); edignan (1); Envelope Guy (2); Epke (1); Grand Poobah (3); Graycav (1); Haajee (7); Hendrik (3); HiTekRedNek (3); hithuanand (1); JohnDG (3); johnfotl (1); Kalboon (4); LAA_Lucke (2); lyn (9); oilcan13 (3); Oldr&wiser (1); osborne83 (2); phph001 (1); PWSlack (1); redJohn75766 (1); robin.muir (1); ronseto (2); Sandman (2); Sanjayvt (2); Sapper (3); Smoothy (4); SolarEagle (2); Tornado (1); trgrcntrl (1); user-deleted-1105 (2)
