Previous in Forum: Power Converting   Next in Forum: DC Load of 450KW DC Motor and 800HP AC Motor Load
18 comments
8000A Bus Bar Size
12/12/2011 12:04 AM
Hello,
I am going to design a synchronization panel for 3 genrater sets, the genrator set haveing the capacity of 1500KW each, on voltage rating is 415V, 3Phase, 50Hz.
I want to know the size of 8000A Bus Bar.
Re: 8000A Bus Bar Size
12/12/2011 2:54 AM
WAG 8 in2 cross-section.
12/12/2011 4:13 AM
What - from scratch?
Surely an earlier design can be cloned and altered to suit?
Good Answers: 58
12/12/2011 9:14 AM
OT???........Really???????
Not anymore.
12/13/2011 9:17 AM
Respect.
12/12/2011 1:16 PM
Follow the international and local standards and regulations relating to your specific application and country.
If you are not qualified to perform this type of design work, don't.
Australia - Member - New Member Hobbies - Target Shooting - New Member Popular Science - Weaponology - New Member
12/12/2011 10:00 PM
If you don't know what bus bar size to start with...you have no business designing a sync panel, or is this well disguised homework question ?? Regards, Sapper
It's all about the Boom! - MythBusters
12/12/2011 11:31 PM
Try www.storm copper.com
pnaban
Good Answers: 19
12/13/2011 1:18 PM
Or you can try the Copper Development site:
http://www.copper.org/applications/homepage.html
Lots of info on copper usage from electrical, plumbing, and architectural.
Good Answers: 19
12/12/2011 11:36 PM
In my opinion to operate the three 1500 kw DG sets in parallel, there is no need to have 8000 A Busbar in the Switch board
It is enough if we have bus bar capacity of 5000 A.
But you have to suitably locate the incomer and out going breakers in the switch board.
Ramesh,Freelance Electrical/automation Consultant
12/12/2011 11:47 PM
Good day.
Yes you are right no need the 8000A Bus Bar in the switch board, 5000A can works, but this is client requirments.
Regards.
12/13/2011 12:09 AM
For one DG at cos φ = 0.8, A = 1,500,000/(415 √3/0.8) ≈ 2609. Depending on switchboard topology, the bus bars might need to carry 2609, 5218, or 8427A; with possible further correction for continuous loading.
12/13/2011 12:37 AM
The previous 8427A should have been 7827A (arithmetic mistake),
12/13/2011 12:56 AM
When all 3 sets are feeding the common busbars,what should be the SC withstand capacity of the busbars,considering a fault in busbars or in outgoing feeder?.
pnaban
Good Answers: 102
12/13/2011 12:32 AM
If you have no idea how to determine conductor sizes then you are the wrong person for this job.
12/13/2011 1:26 AM
Sir, Please let me know you need in copper or aluminium and the outgoing capacity and numbers then only I can suggest the size of the panel.
12/13/2011 1:59 AM
Good day
Three Gen. set having the capacity is 1500KVA each and 4 out going with the full load capacity is 1800A each.
The Bus Bar we desier is copper.
Thanks & regards.
12/17/2011 8:45 PM
Just use a crowbar or something, it will work fine......i thynk...
guds777
Register to Reply 18 comments
Anonymous Poster (2); guds777 (1); jack of all trades (1); KJK/USA (1); mushdi545 (2); paulsonpal (1); pnaban (2); PWSlack (2); ramvinod (1); Ried (1); Sapper (1); Tornado (2); Wal (1)
