Previous in Forum: Dinner Plate Washing Automation Process   Next in Forum: Two Hole Rule For Flange
Flange Fastening
08/07/2013 12:30 AM
why we cannot use nut and bolt arrangment on quadrants of a flange?why we keep offset from center line?
Pathfinder Tags: Bolting flange
Re: Flange Fastening
08/07/2013 1:05 AM
So that valve stems and other such items can be vertical or horizontal rather than goofy 22.5° angles.
Good Answers: 97
08/07/2013 2:12 AM
"why we keep offset from the center line?"
Do you mean why not use square flanges and only 4 bolts ?
Just yesterday I saw a flange (9 bar water) where the nut who installed it only used 4 bolts and a rectangular packing with width barely bigger than the pipe ID.
Of course it was leaking and had to be excavated and corrected.
08/08/2013 12:43 AM
In 1960s one of our engineers went to West Germany for training and on his return he introduced the material-saving method/technique in flange packing. The inner diameter of the packing obviously was inner diameter or bore of pipe but outer diameter was inner diameter of flange holes. While installing you first insert 2 bolts at the bottom most holes of the flange,keep the packing supported by 2 bolts, then put other bolts & tighten evenly.
pnaban
Good Answers: 203
08/13/2013 6:06 PM
For 4 bolt flange it should be done with 3 bolts. Better alignment of gasket.
Good Luck, Old Salt
03/12/2024 4:07 AM
Undefined: <...we...>.
Only one CR4 subscriber can answer the posed question. What happens at that particular facility stays at that facility...
Hendrik (1); old salt (1); pnaban (1); PWSlack (1); Tornado (1)
