Previous in Forum: Transformer Oil   Next in Forum: Calculation Of Transmission Line Parameters.
23 comments
Auto Alternators Rated and Constant Output
08/08/2013 9:09 AM
I and I am sure I am not the only person with this problem. But the alternator on my car is does not put out enough power to handle the load I need to put on it. Well it does but it will not last long. I have to replace the thing evey few months. I have several cars that need more constant power without burning the thing up and leaving me stranded on a 100+ degree day. There are sites that sell high output alternators. However none of them will fit my car. I could get a differant car with more room and use a higher output alternator but would rather have this car as I like this car. But I need more power. I have to keep extra alternators with me as when it goes out it can take a while to get a new one to install and it is not an easy job even with a fully stoked shop. Most automobile alternators only put out about 40 to 60% of the rated output other than for a very short time. The Rating if it were 80 to 90% without damaging it and the diodes is what I am after. I know that better magnets and windings and diodes will do the trick but I do not have the equipment to do this to an alternator. Does anyone know of someone that can do this?? Use Better and top quality parts to make the thing take more heat and constantly put out power closer to what its rating is on a constant bases.
I know it is doeable. I just have no idea where to get it done. I have looked and searched for over a year. Again the idea is not to get more total output. But to make the thing in a way that it can put out near its rated output on a constant basis.
I also would not mind an extra .5 volts. This is a normal 12 V auto. But I have a lot of accessories I need to run. It is a smaller car else I would get a larger alternator or even a second one. But there is flat no room to do this in this car.
thanks to anyone that can do this for me or knows of a place that can.
Jim
Re: Auto Alternators Rated and constant output.
08/08/2013 9:47 AM
Alternators don't "just blow up". Short trips and city driving may not fully charge the battery, but it sounds like you've got other problems.
Maybe a smaller pulley on the alternator would help.
A typical alternator will put out between 13.5-14.5 volts.
08/08/2013 9:50 AM
You telling us what brand and model of vehicles and the types of alternators they use would be very helpful here.
It's highly unlikely that your vehicles are so unique that there is not a aftermarket high output alternator that wouldn't be a direct fit but supply far more continuous power.
Relating the the 12 volts the automotive systems actually run at around 13.8 - 14.6 volts when the engine is running.
BTW what are you powering that adds so much extra continuous load?
08/09/2013 9:20 AM
Correct!!!
GA
United States - Member - NE, USA Hobbies - Target Shooting - New Member Engineering Fields - Aerospace Engineering - Engineering Fields - Electromechanical Engineering - New Member
08/09/2013 9:56 AM
I agree TCM.
Also, more voltage won't help. The range TCM stated is correct and adequate. Additional power requirements are usually rated by the alternator's current output rating, in my experience - ex: 65A alternator vs. 120A.
So... get a larger capacity aftermarket alternator. The only downsides will be how it effects the engine; less gass mileage, running less efficient, etc.
Those will be trivial compared to regularly replacing alternators.
Re: Auto Alternators Rated And Constant Output.
08/08/2013 10:12 AM
...and can the existing wiring and protection arrangements cope without the vehicle catching fire?
Is the vehicle's insurance company up-to-speed with this modification?
Good Answers: 445
08/08/2013 10:56 AM
As others have said, you have not given us enough information to diagnose, let alone solve, your problem.
"...does not put out enough power to handle the load I need to put on it..." why type of load did you put on it, a 2kW audio amp or ham linear?
"...I have to replace the thing every few months..." This is not a "common problem", most people realize after a few replacements that something else is causing the problem, kind of like replacing a fuse repeatedly without checking why it keeps blowing.
"...But I need more power..." How much more and why?
"...The Rating if it were 80 to 90% without damaging it and the diodes..." How do you know it's not outputting its rating and/or the diodes are failing? The electrical portion (stator and rotor) of most alternators is fairly basic, it's the voltage regulator that tells the alternator what to put out. Is the regulator and/or the diodes internal or external? Are they working properly?
You need to do a lot of checking instead of replacing the alternator. Any poor connection from the alternator to the battery to the sensing point for the regulator and/or a poor ground will cause exactly the same symptoms. A slipping fan belt will also result in the output falling off as the load increases since the belt doesn't slip until the load reaches a certain point.
If you don't want to do the hard stuff, then just install another battery and isolator in the trunk, and charge it every night.
Re: Auto Alternators Rated and Constant Output
08/08/2013 2:50 PM
are you running a 5000 W stereo? why such a huge draw???
Good Answers: 203
08/08/2013 10:38 PM
When you say it burns up do you mean as in fire or in electrical "ka-put"?
To get a specific answer you should give a more specific answer. That would give you an answer more directed to you problem. GIGO = Garbage In, Garbage Out. Don't be personally offended by this, just a good rule of thumb to follow when posting a question. This is stated by some of the previous posters.
With fire engines and other heavy trucks that have heavy electrical loads it is common to determine what your heavy loads are and possibly repair the load item or tune it up. Check the wiring, is there any that needs to be larger? the usual next step is to replace the alternator with one having a larger output capacity, such as 300amps. There are numerous outlets that could probably have/get one with larger output for you model car.
Also have you considered using 2 alternators in parallel? If necessary here is a wiring diagram:
http://news.prestolite.com/drupaldocs/TSB-1035_Wiring_Diagram_4991-4992.pdf
These could be small enough to fit if you can make a modified bracket for them. Two standard 150amp alternators (a common size now) could provide 300amps this way. That should be enough to even power a 3,200 watt amp and have enough left over for some flashing LED's
Good Luck, Old Salt
08/09/2013 8:45 AM
It would be good to know the make, year and model of the vehicle, most manufacturers have optional high output alternators for unusual applications such as police, ambulance, options etc. My old Ford had a 125 amp. alternator where 85 was standard. Run it past us with more info..
Good Answers: 131
08/09/2013 8:48 AM
If you look at the OP's previous thread on the same topic a few months ago, he stated that he drives a lot of stop & go in 90-100 degree temps with the AC going full-blast, plus has a refrigerator & 2 laptops running off the DC in his car. It's all that extra load that the alternator & battery were never designed to handle on a continual basis.
Car manufacturers design the electrical charging system to handle the typical max loads that might be put on the car, but not such extreme cases. If the OP wants to get that kind of service out of it, he needs to spring the big bucks for super heavy duty parts. Probably the best people to talk to are the ones who outfit cars with those gigantic stereo systems that ba-ba-boom down the road and vibrate your windows from a quarter mile away. They must deal with providing the additional power for the amps on a regular basis.
08/09/2013 11:02 AM
Oops didn't realize it was the same guy.
Well then the same advice holds true here as did in the other thread.
Talk to the high powered car audio guys. They make alternators that are 2 - 3 times the output capacity of his stock one that fit the same space.
08/09/2013 9:46 AM
Jimmyjoe, what are you running to draw that much power? I read one of these 'my alternator doesn't make enough power'. That person was running several desktop computers and a refrigerator. My suggestion was to replace desktops with laptops and replace the frig with an icebox or a propane powered frig. That is far cheaper than replacing your car with something that can deliver enough power. That guy needed to double his power and that is not a simple fix unless you just buy some kind of massive truck with a massive alternator.
08/09/2013 10:06 AM
I have the same issue with a 1998 Mustang Cobra.
The stock alternator is rated at 110 amps. On a hot day when the air conditioning is on with the fan on high, the voltage drops off considerably. The car has a serious power reduction at that time. Like there is not enough voltage to drive the injectors. I put on four rebuilt alternators from a auto parts store and the problem did not get any better. I purchased a new alternator from Ford and the situation improved, but it still exists somewhat. Could there be a grounding problem with it being a older car?
Is your car an older model, where as some of the connections through out the chassis may have a certain amount of resistance?
"Never mistake intelligence for wisdom"
08/09/2013 10:37 AM
So, there is a serious power reduction when the engine is turning the air conditioner compressor, compared to when it is not turning the compressor...
Five different alternators did not improve this situation satisfactorily...
Yeah, I'll bet too much resistance in the chassis is to blame.
08/09/2013 11:08 AM
Would that be one from some years back when they rebodied Ford tempos with the 2.3L I4 pinto engines and called them mustangs?
If so you had at best 90 Hp to work with so yes I can see where running the AC would pull the engine down.
08/09/2013 2:52 PM
It would be the 4.6 V8 32 valve cobra engine. It came from the factory with 305 hp.
Noe that there is a blower on top of it, it's a little more.
08/09/2013 8:04 PM
Odd. my wifes 94 Mercury grand marquis has the same engine with less hp even and it has no trouble running the AC and its 100 amp alternator at max high settings.
08/12/2013 9:31 AM
Lower horsepower is the key. The Cobra has larger injectors and run a longer duty cycle, to deliver more fuel. The issue was not present when the car was new. The volt meter reads lower with every tax that is put on it. Much like my pay check. I have checked it with a V meter to confirm.
Just sying, because he may have some sort of undue load because of + going to - somewhere on the car.
08/09/2013 11:19 AM
Why is the type of vehicle a secret?
08/09/2013 12:22 PM
Go down to your local auto sound dealer with the car and ask them what alternators they use for their high wattage audio installations. They already know the answers.
Good Answers: 88
08/10/2013 6:43 AM
If there is no room to install a bigger alternator, this is an obvious reason the small one overheats when stressed. The manufacturer will only solve issues of realistic worst case scenarios, e.g. recharging an almost empty battery at tropic climate, with all other installed electric loads on. (Actually this IS high stressing, especially if engine is at low rpm). But anything above that, is unrealistic use for a car alternator. Is there at least a possibility to improve flow and temp of the air it uses for cooling? Are there any modifications on car front? (ANY) S.M.
Good Answers: 54
08/10/2013 11:07 PM
Here's a cheap fix. Add a second battery to the car. At night, hook your car up to an automatic charger to get the batteries fully charged for the next day.
Either this or do some major work fitting two alternators or some propane run equipment.
Good luck!
Good Answers: 22
08/11/2013 7:47 PM
For 12V automobile alternators, the capacity output is primarily determined by the Stator (the stationary coil/windings within the case of the alternator).
Older vehicles commonly had outputs of around 55 - 60 Amps.
I was looking at this issue (albeit some years ago), & the auto-electrician advised that I could purchase a 100Amp stator to replace the original 55A one.
This involves removing the alteranator, dismantling it & reassembling it with the new higher capacity coil (stator) in place.
From memory this doesn't involve complicated tools, just basic home workshop eqpt & tools.
You can possibly get much higher than 100Amp stators. Check with your local auto-electrician.
They would obviously also be capable of fitting a larger coil to your alternator also.
Hope this helps.
Register to Reply 23 comments
aDIYguy (1); Andy Germany (1); Autobroker (1); Catmandu (3); Deefburger (1); Doorman (1); Fredski (1); JCase (1); lyn (2); old salt (1); OldTechNewToys (1); PeterT (1); PWSlack (1); RAMConsult (1); roy hammy (1); SimpleMind (1); tcmtech (4)
