Previous in Forum: Higher Continuous Operating Voltage, Lower Breaking Capacity of Circuit Breaker   Next in Forum: Hall Effect Current Sensor for AC Servo Driver
27 comments
How to Calculate for Energy? Newbie
03/11/2014 7:03 AM
Hi guys,
This is about power output of a solar power, specifically about the units Watts and Watt-hour. What's the difference?
How do you come up with the unit Watt-hour if I am recording power for 6 hours everyday (from 9am to 3pm) with 30 minutes interval.So what that means is I record power at 9am,9:30,10,10:30 and so on until 3pm. So that is 13 records in all.
Question: Find: Total Energy generated for that 6 hours.
Please guys I need your help.
Pathfinder Tags: panel power solar
Re: How to Calculate for Energy? Newbie
03/11/2014 7:23 AM
Imagine that at 9:00 you measure 60 watts, and assume that is true for 1/2 hour. That is 60 x 1/2 = 30 watt-hours. Then at 9:30 you measure 100 watts for the next 1/2-hour interval. That is 100 x 1/2 = 50 watt-hours, for a subtotal of 80 watt-hours. Just keep accumulating through the day.
03/11/2014 8:38 AM
what if it gets cloudy from 11:30 to 1?
03/11/2014 8:59 AM
Sir, I can't assume that the power is constant for every 30min.
Here's a snapshot, sir. If you could tell me exactly how to calculate for the total energy, sir. I would be so happy.
Good Answers: 97
03/11/2014 9:09 AM
Calculate the area below your curve. search for Simpsons rule .
You are assuming the consumption is steadily changing over the 30min why cant you assume it stays constant?
03/11/2014 1:52 PM
Watt-hours are a quantity of energy. Watts are a power, or in other words a rate of energy. To get watt- hours from watts simply integrate with respect to time. It is actually the area under your graph line, Auntie.
Good moaning!
Good Answers: 125
03/11/2014 3:21 PM
Your graph is drawn using straight lines to connect data points. This is at best an approximation, because the actual graph (as drawn by a continuously connected recorder) would look smooth.
Your question indicates that you can't do this using calculus, which is how we would do it.
That being said, there is a way to get a "close" approximation using your graph.
Using data point 1 and 2 (segment 1), average the two points then multiply by 1/2 hour (1+2=x.. ..x/2=average watts.. ..average watts x 1/2 = watt hours for segment 1).
The next average would be segment 2 using data points 2 and 3.
That is the closest you will get with your methods.
Good Answers: 137
03/11/2014 4:11 PM
Yes, see #8
Good Answers: 125
03/11/2014 4:18 PM
Didn't read down that far; stopped at the graph.
Good Answers: 137
03/11/2014 4:34 PM
No prob, just thought I'd mention it
Good Answers: 32
03/11/2014 11:51 PM
JohnAnthony:
Use a power usage integrator on continuous bases and look at its value in watts after 1 hour it will be exact watts.
CR4 Admin Modified Post: Changed "watts/hour" to "watts" per user request.
03/12/2014 12:08 AM
Sorry, but all of those units are wrong.
Good Answers: 32
03/15/2014 9:58 PM
You are right.
Good Answers: 25
03/15/2014 9:28 PM
Please see simple method - jt.
Good Answers: 137
03/11/2014 8:11 AM
Watt is a unit of power, energy per unit time, joule/sec in SI units. Watt-hour is a unit of energy, joule or watt-hour or kWh etc. That does seem to be going round in circles, but it works OK. Joule is small for many purposes and electric energy supplied is traditionally measured in kWh = 3.6*106 joule.
Are you really recording power (watt), at 30 min intervals, or energy on a watt-hour meter? If the latter you have the answer to your question. If the former, do as Tornado says, but to get an accurate figure need the average power over each 1/2 hour.
03/11/2014 9:03 AM
Thanks for the reply sir.
Yes sir I am recording power (watt) every 30min, not energy. That's what I want to get sir the energy. I attached a photo above sir but I don't how to calculate for energy given that graph.
I hope you can help me, sir. I really appreciate your time.
Good Answers: 151
03/11/2014 9:13 AM
The energy is the integral of power over time. In your graph it would be the area of your graph between the 0 line and the power line that you drew. If you never took calculus in school, check the definition of Integral on the web
Good Answers: 137
03/11/2014 10:24 AM
I think other posts have covered it, but if you need more detail, I would take the average power Pave in each 1/2 hour section of your graph, multiply by 1/2 hour, and that gives 1/2*Pave watt-hour. Add all the 1/2 hour sections to get total. This assumes the power varies linearly between the measurement points, which won't be exact, but it's all we have.
So 1st bit Pave = 24 watt approx, giving 12 watt-hour, 2nd bit Pave = 38 watt, giving 19 watt-hour, and so on.
Good Answers: 181
03/11/2014 12:23 PM
I must have my stupid head on.
You're recording watts per half hour, what are you using to record this?
This may come as a silly idea, pulsed output KWHr meters are cheap. Just count the pulses over your recording period. Even cheaper, read the damn meter!
Good Answers: 137
03/11/2014 1:13 PM
As far as I can see, he's taking a power reading, presumably by reading a meter, every 1/2 hour. He then has to do some maths to find what he wants, energy over the 6 hours. It would be more accurate, but more work, to use shorter intervals.
As you say, easier (and more accurate) to use a kWh meter, assuming readily available for readings small by usual power supply standards. Only about 0.18 kWh over the 6 hours.
Good Answers: 61
03/11/2014 5:11 PM
Without using calculus or Simpson's Rule, you can get a fair estimate of the total energy by cutting out the area under the graph with scissors and weighing it on some very sensitive laboratory scales. You then compare the weight of the graph with that of a rectangle of known area (say 60 watts X 6 hours) and obtain your integrated energy quantity that way. You are, in effect, substituting weight of paper for area. Sounds crude, but it works.
Good Answers: 102
03/12/2014 2:44 AM
Ha!
03/12/2014 2:59 AM
Or draw it on a really big piece of paper, then cut it out and weigh it on your bathroom scale.
Good Answers: 73
03/14/2014 12:45 PM
Excellent idea! Ratiometrics without calculus. Sometimes you just have to use what is available!
03/11/2014 6:18 PM
Get one of these:
KILL A WATTRealtime pow...$19.00
03/12/2014 2:48 AM
Watt is a unit if power and watt hour is that of energy. Power in watt multiplied by perod in hours will get you watt hour, larger unit is kilowatt hour (KWH ) commonly known as unit in electrical terms. As suggested by others calculate area below your graph or why don't use kilowatt meters available in market which can get you the power straight without any calcs. For calculating from data mathematically you are bound to take the power constant between two consecutive readings. So more frequent readings mean better accuracy and continuous readings mean exactness to the extant of measuring accuracy and human errors..
Let us discuss the practical issues not the classroom.
Good Answers: 25
03/12/2014 10:11 PM
Haven't done this since I left school! (1953) So there well may be mistakes!
Total the vertical readings (which is approx. 538w) divide this number by the
total number of readings (13) taken, gives an average wattage of 41.38w
which, over 6 hours, gives a total of 248.38 wh.
Cannot get much simpler than this, or am I missing something?
jt.
Is it true that an apple a day keeps the doctor away?
Or is it just one of Granny's myths?
03/14/2014 12:46 PM
Power and energy for the calculus challenged. Analogy: Power is to speed in your car, as energy is to distance traveled. Since power is the rate, multiply the rate x time (interval, i.e. 30 mins = 0.5 hours), for each "30" minute interval, and add them up and you have total energy produced (and either consumed or stored less efficiency of storage battery). Power is Watts, Kilowatts, Megawatts, or Gigawatts in normal usage. Learn what the prefixes mean, i.e. 1000, 1000000, 1000000000.
Energy is measured in power-time: Watt-hour, kW-hr, MW-hr, and so on. 1000 watt-hr is equivalent to: 1 kW-hr (duh), and is also equivalent to 3412.141633 BTU (mechanical-thermal unit equivalency), and is also equivalent to 3,600,000 Joules.
1 Joule of energy is 1 Newton-meter, also 1 Kg-m2/sec2 , (thus energy is equivalent to mechanical (or other) force moving something through a distance. It is also equivalent to Pressure moving a boundary (piston for example) through a volume.
Register to Reply 27 comments
Brave Sir Robin (1); Codemaster (5); Crabtree (1); energyconversion (1); Fredski (1); gringogreg (1); Hendrik (1); James Stewart (1); JohnAnthony (2); jt (2); lyn (1); M.R.Iyengar (1); NotUrOrdinaryJoe (1); Shyam (2); TonyS (1); Tornado (2); Wal (1); WJMFIRE (2)
