Previous in Forum: Answer My Answer for My Question   Next in Forum: Spacing Between Equipment In Gas Processing Plants
32 comments
Looking for Suitable DC MicroVibrator Motor
09/22/2014 11:02 AM
I am looking for strong micro vibrator motor (DC, ideally 3V, diameter max 30mm, ideally 25 mm) for small prototyping project. I have spent several hours looking over many sources and not found what I wanted. I would like to find motor similar to these ones https://catalog.precisionmicrodrives.com/order-parts/product/912-101-12mm-brushless-vibration-motor-15mm-type (this is the closest type I have found, but it could be a bit larger with bigger weight and bit more powerful and not as expensive (no need for extra long life)) or http://www.kinmoremotor.com/product_disp.php?productid=106#.VCA3Qvl_ubF. My question is whether it is possible to find such motor or whether it is easy to use normal motor with weight attached. Since I not very good at mechanics I would prefer buying the whole vibration motor if it was possible because I have no idea how big the weight could be and what problems could by caused by attaching such asymmetric weight to a motor.
Any help would be really appreciated since it is not my usual area of expertise.
Also I am not sure whether this question is for Electrical Engineering or Mechanical Engineering forum, so please correct me if I put this into the wrong forum.
Pathfinder Tags: vibration vibrator motor
Re: Looking for suitable DC MicroVibrator Motor
09/22/2014 11:06 AM
A research visit to an adult products shop locally will yield examples of numerous personal appliances with similar size motors doing a similar job. One option is to dissect such an appliance and use the motor from it in the new project.
09/22/2014 11:13 AM
I have already thought about that but that wont really help because they use small and cheap motors in their accessories that are not that powerful (well, except for this http://en.wikipedia.org/wiki/Hitachi_Magic_Wand , but that is not DC motor but AC and too big to use. I already dissected one of the strongest ones (Palmpower from PowerBullet), but its motor is also very small (15 mm in diameter) and also the weight could be a bit bigger. Well, to be correct, I don't mind small motors but bigger one could give more power). Any other possibilites except for dissection? :)
09/22/2014 12:37 PM
So, what haven't you done yet?
09/23/2014 3:15 PM
Be careful ordering these online, especially on the office computer. You may find yourself on a lot of mailing lists.
Good Answers: 97
09/22/2014 11:35 AM
Rip one out of an old page or cellphone.
CRTL-Z
09/22/2014 11:42 AM
Well, I did that many times but they are very small vibrators and not usable, the examples I have provided are much bigger, cylindrical shape about 20-30 mm in diameter and thus are capable of much stronger vibrations (because the motors itself are more powerful and can have bigger weights) than small ones in cellphones (they are about 4-6 mm in diameter and usable only for alerting not for stronger vibrations). I am looking for vibrator motor which would be as strong as possible in set dimensions not necessarily the most cheapest ones (the limit is about $25-$30).
Good Answers: 104
09/22/2014 11:37 AM
tried eBay?
Where are you?
09/22/2014 11:47 AM
Yes, I have tried ebay, i have found some not so bad (like this one http://www.ebay.com/itm/4000RPM-Speed-Electric-Mini-Vibration-Vibrate-Motor-DC-3-12V/310904951555, but they are usually small or not very powerful or with small weight and they are usually without any specs so it is hard to guess their capabilities. I would not ask the question if I had not checked google, ebay, amazon etc, I tried but did not find many results, there must be more companies selling these than 3 or all factories must create vibrator motor from normal motor by attaching the weight - which is my second part of the question.
Good Answers: 104
09/22/2014 12:29 PM
I saw this one, supposedly for a massager. That may be as much power as you can expect from a motor that size. You may need to rig up a variable mass/variable eccentricity head. Are you after a known frequency?
Good Answers: 266
09/22/2014 11:58 AM
You look at industrial vibrators. They make them for parts bins. You may find one to meet the size requirements.
09/22/2014 12:03 PM
I already did that and the smallest ones of the industrial types are these ones http://www.tarylaite.fi/en/Products/Italvibras%20Electric%20Vibrators/The%20MICRO%20series%20electric%20vibrators/ and they are much larger than those I need and the weight is about 1 kg.
Good Answers: 97
09/22/2014 12:12 PM
If as you say there is "no need for long life" go with a brush type motor such as that on a cordless drill and fix an eccentric weight to the shaft.
These are easy to find due to the "increasing voltage syndrome" Makita started at 7.5.
CRTL-Z
09/22/2014 12:17 PM
Thanks, that is a good idea, I will try to look at these motor whether they will fullfill the specifications. The only problem I can see now is that they probably will be 12V DC while I would like to something around 3V-6V and that they will drain a lots of energy but that is usually the price of powerfull motor (and they might be too big for the project) :)
Good Answers: 97
09/22/2014 12:24 PM
Google American science and surplus
CRTL-Z
09/22/2014 12:34 PM
Thanks for the tip for the page http://www.sciplus.com/. I have not known about that! Unfortunately they do not have many motor (like 6 for <6VDC and 7 for 6-12 VDC and not very suitable ones), but anyway it looks like a source that is very good to know.
09/22/2014 1:46 PM
Another one is "Nuts and Volts". I used to be on all the mailing lists.
Good Answers: 97
09/22/2014 2:08 PM
Now I have to look that one up. My only disappointment was the Sea Monkeys
CRTL-Z
09/22/2014 9:12 PM
The X-ray glasses I purchased didn't provide the view I was led to believe they would.
09/23/2014 4:05 AM
They didn't come with three lenses, either, making it impossible to inspect the latest in plastic surgery....
Good Answers: 97
09/23/2014 9:51 AM
Don't EVER put them on backwards!
CRTL-Z
Re: Looking for Suitable DC MicroVibrator Motor
09/22/2014 9:56 PM
You have failed to provide any real information on what the motor does.
Yes, it vibrates. But a narrative on what it is supposed to accomplish compared to some known vibrating device would be profound. Like a cell phone, which operates at 7 V.
3 V motors will require 2 batteries. The motors you reference indicate a need (and room, and need, for) for 3 AA batteries.
Tell us what you want to do.
Or, why you can't.
Good Answers: 97
09/23/2014 9:15 AM
Perhaps trying to disassemble a bridge using harmonics?
CRTL-Z
09/23/2014 3:42 PM
Why not just a few gallons of concrete remover/cleaner in all the wrong places? My mind is on use of concrete tool cleaner to remove this concrete-like scale in my condensers. I have found it to work on a test specimen, by the way.
Good Answers: 225
09/22/2014 10:43 PM
Try Precision Microdrives in the UK. They carry a range of micro vibration motors, one of which may fit your requirements. I have used their services in the past, they have been helpful, and postage (in my case to Australia) was not unreasonable.
09/23/2014 3:38 AM
Yes, Precision Microdrives are a good source, they are actually the first example I have provided in the first post. They have motor that would fit almost perfectly but they have it in the long-life version (I think that they are tested for 10k continuous running hours). This long-life version costs about 30£ which is pretty expensive. Something similar would be great.
Good Answers: 123
09/23/2014 12:29 AM
Look at some of the cheap smaller cordless screwdrivers There are some 6 volt drivers out there. Pull it apart and add your offset weight.
Bob
09/23/2014 1:10 AM
Cassette Walkman motor
09/23/2014 3:49 AM
Pick a normal motor that fits your requirements, either bend the shaft, the angle you achieve from straight will determine how strong it vibrates. Making it redhot at the point to the bend and rapid quenching can help as long as the heat cannot affect the bearings or other internals....
Or if the shaft is not conducive to bending, then have a tiny flywheel made, drill it off center and fix that onto the shaft - glue and or grub screws or both....that should be quick and also easy to adjust to your requirements...
DO NOT LET ANY FEMALES SEE IT!!!!
09/23/2014 8:04 AM
Off the shelf product at Drug Store is a throw away vibrating toothbrush. $7. runs on 1 AA bat. Mine last about 4 months . You'll need to remove it from the toothbrush. Maybe! Best Luck!
Canada - Member -  Member
Location: Hamburg NY (just south of buffalo) pre-Hamburg(1998) home was the Yukon territory of Canada
Good Answers: 27
09/23/2014 9:28 AM
try these guys too...
www.surpluscenter.com
Nothing is fool-proof to a talented fool
Good Answers: 97
09/23/2014 12:11 PM
Perhaps this could be accomplished with a shake light and cleverly installed contacts at the limits and current introduced to the coil.
Or an elliptical gerbil exercise wheel?
CRTL-Z
09/27/2014 10:46 PM
Did you find the motor you need? It must be there
You may try to find it on this website http://www.aliexpress.com
Register to Reply 32 comments
Andy Germany (1); Anonymous Poster (1); bigg (2); bob c (1); Brave Sir Robin (1); catman58 (1); gmphadte (1); James Stewart (1); lonster (1); lyn (1); Motor-machinery (1); Opice (7); ozzb (1); PWSlack (1); Rixter (2); spades (1); Tornado (1); Unredundant (7)
