Previous in Forum: How To Connect 2 Laptops Via WI-FI (Without Router/Modem)   Next in Forum: Upcoming Engineering360 Webinar on HMI Market Outlook
Deflategate
01/21/2015 9:16 AM
If the balls used in the afc championship were filled and tested indoors at 70 degrees then brought out to the field at 35 degrees would there be any measurable pressure drop? and how much
Re: Deflategate
01/24/2015 5:22 PM
It can't be that important or the ump would be aware of inflating temperature and barometric pressure before and after as a minimum.
The other consideration would be the inflating gas which could be anything and no one would know. The leakage through the walls would change with the gas.
So the whole thing is an exercise and I think the questions put out by the Ravens probably turned everyone into a sleuth.
If you fail to follow through, you will fail.
Re: Deflategate
01/24/2015 7:15 PM
Just read this.
The Pats. scored 17 points in the first half, with soft balls and 28 in the second half with regulation balls.
Go figure.
Good Answers: 985
#92
In reply to #91
Re: Deflategate
01/24/2015 7:25 PM
I still like Rob Gronkowski's original response that he spikes the ball so hard that they lose air.
Re: Deflategate
01/24/2015 11:01 PM
Caption this? Found on the road.
In reply to #93
Re: Deflategate
01/24/2015 11:35 PM
OT. Not a football. Or even a futbol.
Good Answers: 58
#95
Re: Deflategate
01/25/2015 9:24 AM
If an person wanted to create a scenario for a football to lose pressure over a half period of play, all it would take is to fill it from a tank containing a partial pressure of hydrogen.
Re: Deflategate
01/25/2015 10:19 AM
If the balls used in the afc championship were provided by the match officials, without previously being tampered by the teams, there would never be an argument.
Good Answers: 985
#97
In reply to #96
Re: Deflategate
01/25/2015 10:58 AM
I agree that there would be less likely an argument but....
In reply to #97
Re: Deflategate
01/25/2015 3:38 PM
Argue with the umpire? Surely not
Re: Deflategate
01/25/2015 6:39 PM
In reply to #99
Re: Deflategate
01/25/2015 7:20 PM
What big balls they have.
In reply to #100
Re: Deflategate
01/25/2015 7:30 PM
I suppose a whale testicle is the wrong shape for football, but it might do for rugby or basketball, even if Greenpeace dumps a few bricks.
Re: Deflategate
01/27/2015 5:04 PM
Assuming the ideal gas law holds, about a 1 psi pressure drop would result. So if the balls were inflated to 11 psi at 70 F, out on the field they would be at 10 psi.
Good Answers: 985
#114
Re: Deflategate
02/11/2015 12:31 PM
Well at least kids will be held accountable for adults cheating. I wonder how hard Mr. Goodell will wag his finger this time.
Reply to Forum Thread Page 2 of 2: « First < Prev 1 2 Last »
adreasler (1); Anonymous Hero (5); Anonymous Poster (1); bluebelly (1); bullardrr (1); Charlie Greenwood (5); Fredski (5); gringogreg (4); harley (1); indel (1); James Stewart (12); JBTardis (9); JohnDG (2); JWthetech (1); lyn (18); nvirciglio (2); old salt (4); otha (1); ozzb (1); phoenix911 (6); phph001 (4); PWSlack (2); redfred (11); Rixter (2); SHOCKHISCAN (4); Tom_Consulting (1); Tornado (4); truth is not a compromise (1); wallermh (1); welderman (3)
