Aerospace Blog Blog
Aerospace Blog
Previous in Blog: Can Technology Avoid Air Crashes?   Next in Blog: Extraterrestrial Life in Our Solar System
13 comments
Learning to Fly: Getting Lost (Part 1)
Posted September 01, 2009 7:00 AM by tinypilot18
Getting lost in an airplane isn't like getting lost on the ground. There are no road signs to tell you where to turn. There are no places to pull over and ask for directions. There isn't even a GPS (at least in my plane) to determine your location.
Navigating comes down to a map and compass. This can get a little tricky, especially when you're flying to an unfamiliar place on long-distance trip. Plus, since the plane I fly is a 1979 Cessna, it's lacking in the high-technology department.
When you get lost in an airplane, it is considered an emergency procedure - and it should be treated as such. After all, there's only a certain amount of fuel on-board. If your fuel tanks are low, finding the nearest airport becomes critical.
How I Got Lost
To obtain a private pilot's license, you must complete a series of cross-country solos. This isn't as exciting as it sounds, however, because "cross-country" doesn't literally mean "across the country", Rather, it just means flying 50 miles.
My second cross-country solo took me from Danbury, Connecticut to Pittsfield, Massachusetts. I spent about an hour doing preflight preparations, plotting the course on a chart, picking checkpoints along the way, calculating the time to get to each checkpoint, and setting the compass heading to follow (given the wind speed and direction). I was also taught to use something called flight-following along the route. In my case, flight-following involved contacting an air traffic control (ATC) tower in New York and asking them to track my position – just in case something happened.
At first, everything went according to plan. I took off, followed my checkpoints, and remained in contact with ATC - no problems. As you go along in your flight, however, you may pass out of the control of that specific ATC tower. The ATC will then pass you onto another tower, and you're supposed to establish communications with them and continue your flight.
When I was told to break-off communications with the New York ATC and establish communication with another tower, I completed only half the steps. Just by looking at my chart, I figured I was close enough to Pittsfield to be fine on my own. My plan was to land the plane and get flight-following on the way back. That was my first mistake.
Next blog entry:
Learning to Fly: Getting Lost (Part 2)
Previous blog entries:
Learning to Fly: Take Your Seat
Learning to Fly: Going Solo
Learning to Fly: Choosing a Plane
Learning to Fly: Ground School
Learning to Fly: Meet Tinypilot18
Re: Learning to Fly: Getting Lost (Part 1)
09/01/2009 10:26 AM
Yeah..and...?...tell me tell me tell me...I hope you didn't have any cats on board.
Quick tell us...I'll be worrying all night now...
I've just been reading about the early RAF in WWI, and WWII, they often got lost after dog fights and landed at strange airfiels...or farmland.
Good Answers: 93
09/01/2009 1:53 PM
I one time rushed my preflight and somehow got on the wrong VOR radial on my way from FLL, (Fort Lauderdale) to FMY? (Fort Meyers), had a girlfriend over there.
Further I was signed off for the Cross Country, but decided to do it at night. Apparently I wasn't supposed to do it at night, but that's what I did.
Somewhere along the way I recognized I was further north than I was supposed to be.
If you've ever seen the movie 1941, you may recall John Belushi attempting to read his Sectional map and fly at the same time, and not doing too well at it.
I figured I could just keep flying West till I hit the Gulf, and then turn South, but this would add time that I really couldn't afford. Had to call Control and admit I was a "little lost".
In this sort of situation it is nice to have a working transponder, for Control asked me to squawk ident, and then gave me a heading. Awfully nice of them, I thought.
They didn't yell at me or anything.
Another time I got lost because for some reason I didn't believe my instruments, but it was daytime, and I worked that out on my own.
P.S. It probably is a good idea to keep a working flashlight in the plane, interior lighting for some of these little planes is not that great.
Good Answers: 196
09/01/2009 10:39 PM
I've never been an aviation type; my only flying experience has been in commercial passenger aircraft and a couple of helicopter rides. But I do have a reasonable sense of direction and can read and understand maps and charts pretty well.
My home town is a little suburb south of San Jose, CA,; so I know the city pretty well. I can't tell you how many times I've flown into or out of there, looked down from 2000 or 3000 feet thinking I knew exactly what road or area I was looking at and found I was completely wrong. Same with watching the landscape from 30K feet going cross country. Lately I've even gotten lost on Google Earth and had to dig out a roadmap and try to match the highway traces between the two.
Yup!! it sure looks different when you are looking down instead of out of a car window.
Ed Weldon
Good Answers: 15
09/01/2009 11:24 PM
Hi Ed,
Thank for the Bonneville briefing. Maybe I can give you a ride next year in the airplane and get an airborne view of Bonneville. Remind me when it is so that I can schedule it... Thanks again.
It is called "dead reckoning" and every pilot should be good at it. You make a moving map in you mind and check off points and triangulate to your position. As you fly you need to make the world match your map, and if it does not, then you need to find key points (two or more) and relocate where you are.
I enjoy it because it helps me remember what I am flying over. It puts it in context, and I can then see it on the map and go back.
The easy way is to use the VORs and tune into two you think you are near, center the needle on two and presto...you are on the cross of the vectors. Not that hard actually...
Seaplaneguy
09/02/2009 12:54 AM
Hi..
Getting lost, yes it's very difficult more so when you are flying low over water. My first trip over the sea at low level gave me my prangs. It was water water every where ! Just thanks to my stars as i was not at the controls.
Anil
Anil Tiwari
Good Answers: 247
09/02/2009 1:04 AM
I'll admit to having been lost (briefly) while flying, and it is not a good feeling. If you have nav radios, it is quite easy to find out where you are, but you shouldn't have to rely on them -- so it is disturbing when your dead reckoning skills fail you -- almost always the result of inattention, or focusing on one thing and ignoring another.
Incidentally, if you are told to contact another station, you should do it regardless of need... or explain why you are not doing so, if you have that option. If you are handed off, it causes confusion on the ground if you don't pick up the communication.
The rule is: if ATC says to do something, you darned well better do it, if you intend to get or retain your license.
Good Answers: 7
09/02/2009 6:32 AM
Every pilot needs to be able to fly IFR (I fly roads). If you were going from Danbury to Pittsfield, you should have had Rte 7 within sight. Unless you were at FL 25, (doubt it),Limerock Race Track, Haystack Mtn. with its stone tower in Norfolk, Canaan Airport (grass strip), Great Barrington Airport, and Butternut Basin Ski Area would have all been easily recognized way-points that can be seen from some distance. That is why these visual aids are listed on the maps.
Don't feel bad, this is half the fun of flying!
How can you be two places at once when you're actually nowhere at all?
09/02/2009 7:30 AM
FUN? Sounds like sheer terror, and a skivvy check, to me! But I don't fly. Always wanted to, until now. Maybe not so much, anymore. I'll just keep reading, and enjoying, TinyPilot18's chronicles.
Thank you, young lady, for being willing to let us in on your errors, too. And I'm SSOOOO glad you've survived to tell us.
Good Answers: 19
09/02/2009 8:33 AM
And then there was the time I was lost, found an airport, but did not know which one. Then I say the water that said NEOSHO, found the airport and radio frequency on the map, and announced my position and landed. After my knees stopped knocking, went to the pop machine, had a Coke, and plotted the rest of the way home to Illinois. Caught a great tailwind, and was able to get back. Dallas area to Chicago area in about 8 hours, total time, including being lost. In a trusty 1978 Cessna 172.
Boy, thanks for bringing back fun memories!
Good Answers: 247
09/02/2009 8:03 PM
This reminds me of probably my most embarrassing flying moment. I was lost without realizing it, and landed at the wrong airport. Both were the same distance from my departure point, and they were fairly close (I say as an excuse) to the same heading: on a 75 mile flight westward, they were perhaps 5 miles apart north-south. It was night, and minutes before I was pointing out to my passengers how easy it is to see airports from a long way away at night: "See there's our airport right over the nose." (Generally, I was yacking when I should have been flying.) Both airports were small and uncontrolled.
Oh! I just remembered. The unintended airport was off the edge of the sectional I had with me... (that close to the edge, I should have had the next sectional) so I actually had to get out of the airplane to find out what airport I'd landed at! My passengers seemed to take it all in good stride, I think not realizing that this was a very serious mistake with the potential for real danger.
Good Answers: 119
09/02/2009 3:53 PM
Can't wait to hear the end of this one.
Back in the day (60's) a highway map was standard carry along equipment, by demand of my CFI. As someone noted, IFR (my version, I Follow Roads) was imperative when everything else went wrong. Nowadays I would also include a hand held gps (with spare batteries). Inexpensive life insurance and imperative if you ever get caught on top.
Hooker
Good Answers: 93
09/02/2009 4:51 PM
I thought the phrase was really "I follow Railroads."
Well I guess you can figure its all the same difference, they go somewhere.
Guess the advantage with roads is that you can land on them if you really have to.
I was told that when flying at night over Florida, should the engine fail, head for the darkest spots, as they are likely to be water, and not trees.
I remember my hero pilot once joking about how a Controller had told him to turn right to an West heading for a left traffic landing on 9 left at FLL when he saw Sunrise Blvd.
"How'd he know I could tell Sunrise Blvd, from Powerline!
P.S. The addition of TinyPilots blog to this forum has been a bright spot for me, and I really really hope she gets to fly bigger, better, and faster planes. Nevil Shute once wrote there are two great things to do, fly and sail. - or something to that effect. Maybe it was just boats and planes. Anyway, I was pretty happy at the airport regardless, myself.
09/02/2009 4:55 PM
In almost 22 years of hang gliding I had to review a map enough to call it memorization when setting goals to fly past the horizon and kept an eye on the landmarks. I had a simple ball compass to use to semi-guide wobble and level me out of the white out of climbing too high into clouds. Now days one can buy a medium priced phone with GPS - what's the hubbub, Bub?
The apparent cycles of action are: Start, Change, Stop. The true cycle of action is: Create, create, create, etc.
aniltiwari (1); Blink (2); Ed Weldon (1); Hooker (1); Jerry New Hampshire (1); micahd02 (1); Ried (1); seaplaneguy (1); Tinker65 (1); Transcendian (2); user-deleted-1105 (1)
