Previous in Forum: Information On Epoxy Putty Sought   Next in Forum: SPARE PARTS
18 comments
How to Remove Pine Tar/Sap from a Car?
11/30/2007 11:38 AM
Looking for a home remedy to remove pine tar/sap from my car without damaging the paint on my 2001 Toyota Avalon
The correct answer is not always YES!
Safety - Hazmat - Environmental, Safety & Health Manager Hobbies - Musician - Theremin (That about says it all...)
Good Answers: 19
Re: Sales
11/30/2007 11:54 AM
Try denatured alcohol or mineral spirits, applied with a soft cloth (like an old tee shirt). With minimal rubbing, the pine tar should wipe right off.
Just my $0.02
Good Answers: 918
Re: Sales
11/30/2007 12:27 PM
If you want to be more anal, use a microfiber cloth.
Start with dabbing to loosen the tar/sap, then wipe when it is dissolved.
Re: Sales
12/01/2007 10:37 PM
Mineral spirits is OK. I doubt the alcohol will do much. Toluene would be better than mineral spirits, but it may also attack the car finish. The OTC "tar remover" products for cars are primarily toluene, if I remember correctly. Read the labels or check the CAS number codes on the OTC tar remover bottles.
Re: How to Remove Pine Tar/Sap from a Car?
11/30/2007 12:38 PM
Just sell it (or give it away) and buy American. It's not worth the cost of mineral spirits!
I know that you believe that you understand what you think I said, but I'm not sure that you realize that what you heard is not what I meant
Good Answers: 230
11/30/2007 11:58 PM
You could use Eucalyptus oil, on a cloth, let tar/sap soften before buffing off.
Works for me just fine, on any resinous tree sap,on any car, including Toyotas....
12/01/2007 1:12 AM
DMSO has been said to work. Also, common vegetable oil should take it into solution and then remove the residue with a detergent wash.
12/01/2007 1:16 AM
WD 40 works great doesn hurt the paint or you could go to Autozone and get bug and tar remover at twice the price..
12/01/2007 1:29 AM
Yeah I forgot about that and it's a little faster than a heavier oil. Of course you could just as well use diesel fuel, which is not much different from WD40 and it's even cheaper though not in a convenient aerosol. You could put it in a pump sprayer.
12/01/2007 3:57 AM
Mineral oil / baby oil works well to get tar off hands have never tried it on a car though.
chazl
Good Answers: 18
12/01/2007 10:52 AM
Any one of a number of organic solvents will do the job. I believe the one most often packaged and sold in stores in primarily a kerosene base.
12/01/2007 6:14 PM
3M makes a product called:
General Purpose Adhesive Cleaner Part# 08984
I've used it since the test marketing (1975) with GREAT success on all surfaces (except cheap plastics) with the first use on a metallic copper paint on a Mazda to remove some enormous racing decals and 10 years later, there was NO sign of their existance.
I can't recomend this product any higher!!!
That that is, is. That that is not, is not. Is not that it? It is.
Fans of Old Computers - PDP 11 - New Member
Location: In a mushroom field somewhere in Canada. Kept in the dark and fed sh--, well you know.
12/03/2007 7:46 AM
This may sound ridiculous but I saw on an import/tuner car website that a quick and dirty fix for this is to use PEANUT BUTTER. YES, PEANUT BUTTER. I thought this was ridiculuous myself so I tried it on some nasty, old, hard tar and IT WORKED.
I also tried it on some tree sap and it worked as well but with a little more elbow grease.
Try it. You will be surprised. By the way I used Jiffy.
Good Luck
Dirt is for vegetables. Pavement is for racing.
07/27/2008 12:51 PM
chunky or smooth?
12/10/2007 6:29 AM
Paraffin to get it moving, followed by washing up liquid in water?
12/10/2007 2:31 PM
I think you still would need something to get the paraffin more fluid. I have had success using vegetable oil to get paraffin out of or off of something. Then you have to use strong detergent to get the resultant solution the rest of the way into solution with water.
11/05/2008 6:35 PM
I recommend using PowerGreens H2Pro Cleaner/Degreaser. It's a green cleaner that actually breaks down grease and oils into their base fatty acids and allows for a better cleaning with no residue. Place parts in aqueous solution, agitate or scrub, then rinse clean. I would also recommend blowing off the part to remove all excess water. This will get oils and grease off in a safe manner without the worry of solvents, voc's or other toxic chemicals in the mix. Check it out at www.thepowergreen.com
08/10/2009 3:45 PM
Canola oil and probably any cooking oil.
Good Answers: 97
10/06/2009 9:58 AM
Dissolves immediately upon application of distilled vinegar...
Register to Reply 18 comments
agua_doc (1); Anonymous Hero (1); Anonymous Poster (2); bwire (1); Cardio-2 (1); Chazl (1); Peahioi (1); PG1 (1); pilotcraig2001 (1); PWSlack (1); rcapper (3); Sparkstation (1); The JMAN (1); unclefastguy (1); wbsterritt (1)
