Previous in Forum: 60 Hz, 230 V Refrigerator for 50 Hz, 230V supply   Next in Forum: formula
SPEED DRIVE
05/13/2008 8:44 AM
MY OMRON SPEED DRIVE GOT BURNT AND WAS REPLACED, HOWEVER THE NEW ONE DOES NOT RESPOND TO START COMMAND
Re: SPEED DRIVE
05/13/2008 12:21 PM
Download or get a copy of the engineering manual and look up the section on "Start" ...
There are usually a number of options for how the starter wiring is connected and the newer drives have to be configured via the HMI (front panel) to understand how the system is wired....
Are you working for a company or is this a personal project?
Availalbe for short term contracts, by the hour, day or week to help you be successful.
Re: SPEED DRIVE
05/13/2008 9:01 PM
I'm not familiar with these drives--But most drives have an ENABLE terminal and also STOP that must have a signal before START will do anything(if it is programmed to run). We usually have enable and stop jumpered together after the E-stop or master control relay.
Re: SPEED DRIVE
05/15/2008 3:25 AM
did u get the supplier to install it or u just bought it?Best is to call the supplier
nesubra (1); tchapman_egr (1); user-deleted-7 (1)
