Question: Why doesn't a one-cylinder, four-cycle, Diesel engine stall? Does the momentum of a flywheel keep it running? Intake air is compressed to 435-600 psi before diesel fuel is injected for the power stroke. Although initial power stroke pressures are 1100-1370 psi, the mean effective pressures are 109-174 psi. At the end of a power stroke with a mean effective pressure of 109-174 psi, where does the energy come from to complete an exhaust stroke, an intake stroke, and to compress air to 435-600 psi for the compression stroke prior to the next power stroke?
