I picked up an old push reel mower at a yard sale the other day. I hadn't used one for over 50 years and wondered if I still could (plus, now that I've managed to get part of my front lawn turned into an herb garden without getting knicked by the zoning folks, I might just mow the remainder with a push mower).
Anyway, it had been pretty neglected and misadjusted by some numby-nut garden shop, so it needed sharpened. The best way to do this, provided you don't have a $300 fixture, is to coat the blades with lapping compound (usually 80 grit), tighten up the cutter bar, and run the blades backwards.
This, of course, means I need lapping compound. Nobody sells it locally since the big box stores have bankrupted the local hardware stores, and McMaster requires two days and shipping charges (plus I don't want to pay $5 for the compound).
So, I took a piece of 80 grit aluminum oxide sandpaper (that because I got them for 10 cents a sheet), set fire to the paper, and then mixed all the residue with a little 90 weight gear oil. It seems to work, but takes a lot of work and is messy.
Does anybody have any other low cost solutions for lapping compound?
