Previous in Forum: Should Automatic Systems used in Public Transportation require HUMS?   Next in Forum: Best way to Lower output voltage from 2x3.6v Rechargable Battery
Tubing
06/27/2009 10:49 AM
I am trying to put together a device in which water runs through tubing? What tubing would be would be durable but I am able to shape and looking for cooling or more conductive to cool/ice? I am looking at 3/8' or 1/2' and I need to coil or shape it inside of a cooler in any shape needed.
Re: Tubing
06/27/2009 12:15 PM
If you are drinking, copper or a variety of plastics from your hardware store; copper coils are available from stock, as are various plastics. The length of tube will depend on rate of heat transference; look for some components for humidifiers, air conditioning or freezer units.
Pressure will be important, as will the coefficient of expansion if you are talking about a range of temperatures, as some materials will fracture or split.
Water is not the best coolant to use.
Re: Tubing
06/29/2009 8:24 AM
Aluminum should also work well and likely be less expensive but if it is for potable water, it may impart an undesirable metallic flavor to the water.
TT3
If the software can detect, compensate, avoid, or correct an anomalous condition in the system, it is, by definition, a software problem-regardless of the root cause. In the long run, for most classes of problems, it is cheaper to fix it in the SW
Re: Tubing
06/29/2009 5:08 PM
Aluminum is toxic, be careful what you are using the water for.
You might be interested in: Plastic Tubing, Rubber Tubing, Tubing
