I have been looking for some information for the split case pump curve data's including the flow, the motor capacity and the dimension of the pump. But I would not find it in the internet. If anyone have these drawing or data's, please let me know. The following is the some of the pump data's that I can provide.
Flow rate Q= 95.4m3/hr (1.59 m3/min)
Head H = 120m (12bar)
I need to have the pump piping dimension for suction and discharge side, the height of the centerline of the pump, Motor dimension and the Motor HP. I need these information for designing water pump system for my Fire Hydrant system of my new plant.
Actually, the full capacity of the flow rate is 1260 USGPM but I split it to 3 pump so that I don't have the problem with the starting amps of the motor. The initial design was using one motor of 185KW to run the pump for the 1260 USGPM flow rate.
I am an Electrician and not a mechanical personal.
