Previous in Forum: Equivalent of Nichrome V Superalloy   Next in Forum: Will Nitrogen gas remove moisture?
Hydrotest Pressure
07/01/2009 8:12 AM
Please good guys, how does material specification of pipe affects hydrostatic pressure?. Do i just rely on the operating pressures in determining the test pressure?
Cheers
fhosyll
Good Answers: 51
Re: Hydrotest Pressure
07/01/2009 12:53 PM
You should rely on the piping code that the pipe has been designed to.
The hydrostatic test pressure relies on the design pressure/temperature and test temperature, which relies on the thickness of the pipe, which is dependent on the strength and material specification of the pipe.
Have a search through this site with the menu at the right (first try "hydrostatic test")
A little knowledge is a dangerous thing.
07/01/2009 3:41 PM
test at 125% of the operating pressure
Reply Score 1 for Off Topic
07/01/2009 9:31 PM
Listen to xMech - ignore Moore. Everyone will live longer.
07/06/2009 2:02 PM
As suggested, you need to look at the piping code you are using.
Some piping codes will require the hydrotest be done at 150% of design pressure (B31.3 for example), others have lower pressure requirements but may require you to hold those pressures for a specific period of time.
Anonymous Poster (1); BruceCH (1); moore (1); XMech (1)
