Previous in Forum: Suppliers of Desiccant Dehumidification Units   Next in Forum: Polishing Machine for Thin Films
12 comments
Canada - Member - Proud to be Canadian
DIY Windmill Design?
09/17/2009 4:40 PM
I would like to build my own windmill and have been looking on line for plans. Has anyone bought any plans on line that are really good? There are a number of web sites that promise their plans are the best but they are in the business of selling plans so one wonders if it is just a con. If I build one it would be more for the fun of building it and experimenting than trying to build the most efficent generator.
The other idea I have is to build a windmill to pump water in a pond with a right angle gearbox to drive a pump.
The old windmills had a mechanism to turn the windmill out of the wind to protect it in high wind. I have looked on line to find how these mechanisms work and have not been able to find anything that would be simple to make. The top of the windmill rotates 360° so I figure I need a ring near the top of the mast that is free to rotate with the windmill and by pushing the ring up a leaver or cable rotates the tail of the windmill.
If anyone has any ideas I would appreciate the help. I am located in Hamilton Ontario.
Good Answers: 58
Re: DIY Windmill Design?
09/17/2009 9:42 PM
check otherpower.com they seem to be ok.
mike k
India - Member - New Member Germany - Member - New Member France - Member - New Member Engineering Fields - Mechanical Engineering - New Member Popular Science - Weaponology - New Member Engineering Fields - Energy Engineering - New Member Hobbies - RC Aircraft - New Member
09/17/2009 11:16 PM
Just try this www.thekevdog.com/projects/wind_generator/ if u dont comfortable with it reply me i will give u another solution
Be an engineer not a degree holder!
Good Answers: 119
09/17/2009 11:39 PM
Another vote to try
http://www.otherpower.com/turbineplans.shtml
The basic plans showing mechanical and electrical construction of a home-built version appear to be very well done! The rest of the site offers good sound advice with realistic expectations regarding home wind power.
This is refreshing since ~80% of home wind power sites on the web show unrealistic advertising-driven junk science.
Good Answers: 97
09/18/2009 12:07 PM
09/18/2009 1:42 PM
Thanks all for the links. What I still don't know is how to turn the tail of the windmill when I am on the ground and the windmill is at the top of the mast.
The electrical cable is inside the mast so how do you know when the cabel is too twister and do you have to take the windmill down two or three times a year to untwist the cable?
Good Answers: 119
09/18/2009 8:05 PM
One solution to the potential wire twist problem is addressed about 1/3 down this page (from previous link).
http://www.otherpower.com/towers.shtml
If you spend some time reading only this site, I believe all your questions will be answered. For more options and ideas, the additional sites posted above appear to be excellent sources as well.
Good Answers: 93
09/22/2009 5:06 AM
Would a darrieus rotor type design avoid the need for pointing the blades into the wind?
Good Answers: 97
09/22/2009 11:07 AM
It is a case for noise I have with these...
09/24/2009 5:55 AM
vertical wind turbine are both efficient and quiet, making them more suitable for energy production in residential areas than previous wind-based renewable energy technologies. Many current VAWT models resemble eggbeaters, with two blades attached to a central shaft, which is in turn anchored in a power generator. Others have a number of large, flat blades protruding from the central axis; and still others have a helix of extremely light plastic surrounding the axis. They typically stand between two and five feet in height and the best ones are able to attain 30 – 60% efficiency, depending on where they are located.
horizontal wind turbine
Hobbies - Musician - Tube Amps Only Please!
10/12/2009 9:20 PM
I have a windmill power plant near me and it is a bunch of poles in the ground maybe 15' high with what looks like to be aircraft propellers that spin sideways on the poll. I think it is Palmdale, California. Google such plants and see what you can find out then call them up and as for a tour if you live nearby. They give tours at Hoover Dam!
Regards, Maveric Manic - 'Knowledge is Power and Wisdom is knowing how to use it'
10/24/2009 2:07 PM
hi, i am new to this site... i was looking at building my own windmill which would run a water pump (like the style of windmills used on farms in outback australia)
i am interested in this part of your post: "The other idea I have is to build a windmill to pump water in a pond with a right angle gearbox to drive a pump."
did you have any luck with this, and can you please share your info!?
(otherwise i could use some car batteries I have lying around and somehow store the power, but i don't know anything about alternators or coil packs or anything)
chris.
Register to Reply 12 comments
bwire (3); Christo (1); maveric_manic (1); mike k (1); mjb1962853 (2); Nigh (1); rajeshbhanushali123 (1); sindhu sati (1); Stan The Man (1)
