Previous in Forum: Is This Product a Scam?   Next in Forum: Solar Powered Light (LED) with Charge Capability
machine to drive 50hz to 60 hz
09/27/2009 4:46 PM
is there to anything to consider in control system if machine ooperates in 60 hz which used to be run at 50 hz
Re: machine to drive 50hz to 60 hz
09/27/2009 8:41 PM
If your control system is rated 50/60 Hz, everything is fine. Your equipment will operate at 6/5 the speed as before, and there will be power issues.........
Re: 50 Hz & 60 Hz from THREAD 50 Hz & 60 Hz
posted in Electrical Engineering
Pathfinder Tags: 50 Hz 60 Hz motors
03/08/2007 6:32 AM
by
ashelec
517
03/01/2007 10:52 PM
by Guest
517
50 Hz & 60 Hz posted in Electrical Engineering
02/14/2007 10:33 PM
by Guest
408
Re: POWER FACTOR. from THREAD POWER FACTOR.
05/19/2008 5:53 AM
by
chhotu1990
371
Re: transmission lines from THREAD transmission lines
06/27/2007 3:52 PM
by
Haajee
256
Re: difference of 50 hz and 60 hz machines from THREAD difference of 50 hz and 60 hz machines
Pathfinder Tags: electric machines frequency
03/16/2008 9:49 PM
by
biswanath.das
187
09/28/2009 3:25 AM
hello,
Will you please explain..regrading the control system equipment and power issuse.will the output will incearse as the speed will increse.
09/28/2009 12:03 PM
Please describe the equipment comprising the control system.
50Hz 3Ø induction motors running on 60Hz will run 60/50 times as fast, as indicated above. If this should be a problem then consider fitting an inverter on the supply to each motor, limiting its highest outgoing frequency to 50Hz.
09/29/2009 4:05 AM
these are all syn. gen.
Register to Reply 4 comments
lyn (1); PWSlack (1); saidussadat (2)
