Previous in Forum: SEW Motors New DRS Motors   Next in Forum: Need Advice on Rebuilding the Niles Spindle
29 comments
United Kingdom - Member - British
Outboard Engine Cutting Out
10/27/2009 3:21 AM
At a place where I go, one of the engines keeps cutting out. It is a 40hp (mercury I think) attached to a RIB. When it is when it is idling it is fine, but when you try to drive it slowly, it cuts out. It is fine once you get it going faster. Do you think it could just be a case of rubbish in the carb? Its a 2 stroke.
bondy111
Re: Outboard engine cutting out
10/27/2009 6:40 AM
  • Rubbish in the carb?
  • Faulty magneto or LT leads?
  • Faulty HT lead?
  • Faulty spark plug or gap too wide or electrodes oily?
  • Spark plug not screwed in properly?
10/27/2009 7:34 AM
Rabbits foot degraded by exposure to excess moisture?
10/27/2009 8:14 AM
D'oh!
10/27/2009 1:57 PM
The spark plug is seated properly, the gap is too wide, and it is clean. I think the HT lead is ok, but have not had time to check. I will check the carb when I can, but am a bit run off my feet at the moment.
bondy111
10/28/2009 4:20 AM
"the gap is too wide" The gap is not too wide*
bondy111
10/27/2009 10:32 PM
I would say the low speed jets are plugged up a bit. either remove and clean the carburetor or run some carb cleaner with the fuel. These engines need to be run fast, the 2 cycle engines do not run well at low speed.
Also, check the fuel and see that it is fairly new, old fuel will gum up fuel lines, carburetor jets, and other items that are meant to be cleaned.
Al
Good Answers: 1693
Re: Outboard Engine Cutting Out
10/27/2009 9:17 AM
I'll go with rubbish in the carb/s. For us Yanks, what's a RIB?
Engineering Fields - Piping Design Engineering - New Member Engineering Fields - Mechanical Engineering - New Member
Good Answers: 27
10/27/2009 10:39 AM
"Rigid Inflatable Boat"
The hull has a solid bottom with inflatable sides
Best regards, HeviiGuy
Good Answers: 1693
10/27/2009 10:42 AM
What'll they think of next? Isn't that (Rigid Inflatable Boat) an oxymoron?
10/27/2009 10:39 PM
Sometimes referred to as a RHIB. Rigid Hull Inflatable Boat but it's pronounced 'rib'.
http://www.zodiaccz7.com/
Cheers!
10/27/2009 10:32 PM
The US military uses a lot of RIB's. They are almost unsinkable and can be stored in little space when deflated.
10/27/2009 11:51 PM
Are you using fresh fuel ?
Gas Mix Fuel setting on a boat for a long time is like desiel fuel takes a hot spark to burn it or a very warm motor.
10/28/2009 2:34 AM
Yes, the fuel is fresh, and yesterday after driving it for about 10 minutes, as I was driving in towards the jetty, and minimum rpm in forwards, it cut out again.
bondy111
10/28/2009 3:56 AM
Oil mixed in with the gas or oil injection? Too Much oil???
10/28/2009 4:19 AM
Oil mixed with the petrol. There isn't too much oil, the other 4 2stroke engines are working perfectly. They are 2 25hp, 15hp, 10hp.
bondy111
11/01/2009 12:47 PM
Different engines sometimes need different mix percentages.....I think that was what was implied.....
11/02/2009 1:37 AM
Oh ok. Thanks.
bondy111
10/28/2009 4:47 AM
Check the vent on the fuel tank - might be blocked
The Skin is mightier than the Banana
10/28/2009 4:56 AM
The vent is ok on the fuel tank; there are 2 fuel tanks for it, and the problem occurs with both. Also, the problem is not in the fuel line.
bondy111
10/28/2009 5:08 AM
Is the ignition timing adjustable?
10/28/2009 5:57 AM
Next time it happens, quick like a bunny rabit pull a spark plug and tell us exactly how it looks. Is it wet? Black? Brown? white and chalky? Do this the instant it dies not after you have cussed it, restarted it, and then blown the carbon out of it. OK, you can cuss it first but don't restart it.
10/28/2009 6:13 AM
Hey man, if your Bunny Rabbit can pull spark plugs he should join this forum. We need all the furry critter we can get.
United States - Member - New Member Engineering Fields - Biomedical Engineering - Radiation Oncology Engineering Hobbies - Fishing - New Member APIX Pilot Plant Design Project - Member - New Member Hobbies - Hunting - New Member Hobbies - DIY Welding - New Member Hobbies - Target Shooting - New Member Popular Science - Biology - New Member
10/28/2009 7:37 AM
I had a similar problem with an older 9.9 Yamaha engine. Only at slow idle. I put the fuel tank up on the seat and the engine ran better at slow speed. I think it the suction the engine imparts on the incoming fuel line is insufficent. Maybe a pin hole leak in the line or a clamp not tight enough.
Good luck
“Sometimes we don't even realize what we really care about, because we get so distracted by the symbols.” ? Tom Wolfe, The Electric Kool-Aid Acid Test
10/28/2009 10:17 AM
That one might also indicate a partially-blocked fuel filter, making it run lean at low revolutions. It's worth checking, anyway, and renewing it is a simple thing to do.
10/28/2009 1:01 PM
Besides the carburetor there is a little lever attached to a linkage on the throttle, it selects between fixed speed (i.e. for a lawn mower) or adjustable throttle (for a go-kart).
Hopefully you just switched it unadvertently. Otherwise try cleaning your carb.
Yahlasit
10/28/2009 2:29 PM
I had a thought, what if I turned the idle speed up, so if it is going slightly faster, it may not stall.
bondy111
10/28/2009 3:44 PM
On the Mercs I've worked on the ignition components move as the throttle is pushed until the max advance stop is reached. Check for frayed wires or wires broken under the insulation. -- JHF
10/28/2009 10:38 PM
And always remember 2 strokes are not happy unless you are wailing the snotskies out of them. They are not lazy 4 strokes that get cranky when you beat on them with the rpm stick.
10/30/2009 1:30 PM
If you have the older style mercury 40 hp 2 cylinder replace the stator if you have the newer 3 cylinder replace the CDI box
Knowing is half the battle
Register to Reply 29 comments
alonzo200 (1); Andy Germany (1); Anonymous Poster (6); BoltIntegrity (1); Bondy111 (7); Brave Sir Robin (1); Circuit Breaker (1); dadw5boys (1); lyn (2); moore (1); PWSlack (3); rlindey (1); user-deleted-1105 (3)
You might be interested in: Cutting Services
