Previous in Forum: Hydraulic Tappets   Next in Forum: 2004 Honda Civic - Gages Don't Work, But Carpet is Clean
37 comments
Hydraulic Lifters
11/01/2009 5:23 AM
Continuing from my earlier question.
My Volvo 960 is 1994 and done 80 thousand miles.
When my timing belt broke all 12 exaust valves were bent and 3 inlet valves.
The exaust vaves were like new but very dirty. A few weeks ago I put 2 cans of valve cleaner into the engine oil. There was a sticky tar like deposit on the exaust valves.
Some of the hydraulic lifters rattle when I shake them (the tappet inside moves up and down) and some seem pretty immovable.
How do i know if the Hydraulik Lifter needs changing. Could the failure of all 12 exaust valves be related to the hydralic tappets.
I tested the compression a few weeks ago and the readings were eratic. Reading 70+ psi one minute and 40 psi next minute. The fuel consumption is about 30% to high. I suspected the valves may be sticking (hence the cleaner)
Any suggestions will be appreciated.
Re: Hydraulic Lifters
11/01/2009 9:49 PM
Unfortunately, I would recommend replacing the lifters and the cams, because they are supposed to break in together. Most likely the lifters were damaged in the collision between the pistons and valves, and putting them back in the right place will not be enough. With the amount of work required to put the engine back together I would do it right the first time.
11/01/2009 10:57 PM
That was weird. I forgot this was two posts and didn't recieve emails for the other one, so I replied to this post figuring I never sent out the other one. I'm almost confused again.
Good Answers: 97
11/01/2009 11:23 PM
Good Answers: 97
11/01/2009 10:55 PM
I agree with post #1, replace the entire valve train.
Realize the amount of pressure at the point of contact of the cam lobe and the two degree spherical grind on the bottom of the lifter is exceedingly great.
Good Answers: 145
11/01/2009 11:27 PM
The bending of the valves was as a consequence of not replacing the timing belt at the appropriate service interval. Timing belts need to be done around 50,000Miles 80,000Km. Although early watercooled VW's and Audis are at 36,000Miles 60,000Km.
Your motor will have be of the interference type with reliefs in the tops of the pistons to allow for the close tolerances .
Usually when repairing the head after such an event the (good reputable)head shops replace the all valve guides as well as all the valves as the guides get fractured where the valves bend.
Other damage to the valve train and bottom end can be expected. There is no cheap fix, just doing it right.
You'll be better off pulling the motor out tearing it down and checking for bent conrods and galled cylinder bores while your there, as you have contaminated the engine oil with "valve cleaner" then you will need to inspect all the main and big end bearings as well for damage.
As you have found, saving $50 in maintenance has cost you around $2500.00 in repairs.
The Valve cleaner should have gone in the fuel tank, not in the engine oil. Most likely you will have thinned the lubricating properties of the oil. 70 psi is very low compression reading, it should be around 150psi. This engine would barely have started let alone run.
All good fun as they say...
11/02/2009 12:15 AM
A piston into the valves is like a bull in a china shop. Why is this head being rebuilt rather than looking for a replacement head?
Why are you doing the head work and not a machine shop? Lots of shade tree mechanics have the skills to do their own block work but few have the skills and tools needed to do good head work, particularly after a head crash. You have plenty of busted valves. Try bending one. You'll find it's not easy. Experienced eyes watching for crash damage is money well spent.
I had a piston crash in my 1984 Chevette Diesel and I repaired it all myself. The special conditions were that the valves were not angled to the pistons and the valve train fasteners were weak. The pistons drove the valves straight up without bending them. The bolts popped and saved the cam. A few parts from a spare engine and it was back on the road.
The lifters should be replaced. Other problems have been mentioned but the biggest problem is that each lifter wears to the valve movement distance which is consistent over the life of the lifter but different for each valve position. Swap two lifters. One will fall short of the previous wear mark and the other will go beyond the previous wear mark. With lifter tolerances up in the ten thousandths range it doesn't take much lifter wear to be unacceptable. Then again, I threw 8 random lifters into a GM 2.3L SOHC Quad 4 and it worked.
Any auto parts company can look your lifters up and tell you if they are all the same.
11/02/2009 7:15 AM
Careful inspection of the block assembly should tell you if it's even salvageable or not.
If not --->>get a used engine.
If it is-->> get a used head fully assembled.
Good luck...it's not a cheap experience however you go.
11/02/2009 8:56 AM
Engines with hydraulic lifters have cam chains or gears not belts. Belts drive overhead camchafts which drive the valves down by means of a rocker arm pusching the end of the valve or a shim/disc setup. There will be some clearance in the system unless a valve is being driven. Have the heads redone and check the pistons and connecting rods for damage.
Good Answers: 247
11/02/2009 11:12 AM
Actually, the Volvo has twin cams, hydraulic lifters directly over the valves, and belt drive.
If the car is in great shape otherwise, then the engine should be torn down and fully rebuilt (or replaced with a used engine in good condition). If the car is not in great shape, then a competent rebuild will cost more than the car is worth. A remanufactured engine is another possibility -- but again, does the rest of the car make that worthwhile? You could probably buy a pretty serviceable used Honda Civic or Toyota Corolla for the cost of repairs. Either of these will typically go for 200,000 miles without the need for opening up the engine.
The fact that the compression was so low is an indication that the rings may have been worn, particularly if the exhaust valves appeared to be in good shape (other than bent). If the exhaust valves have a tar-like deposit, it is likely that the engine has been burning some oil, although the cause could be worn rings or simply worn valve guides.
The valve guides should be replaced, in any case, and the tappets should certainly be replaced. The pistons should be carefully cleaned and checked for cracks, especially looking on the underside, which is in tension when the valves hit -- and therefore where the cracks open up. As the guest suggests, checking the rods is a good idea too. While the rods are off the engine, the crank journals and rod bearing clearances should be checked. Once you've gone to this much work, it makes sense to replace the piston rings, (after checking the cylinders for size, taper and roundness, and deglazing them) and to replace all gaskets and seals. In essence, once you've checked the pieces directly involved in the collision, you've torn the engine down to the point that a full rebuild is in order.
The Volvo has very direct valve actuation, so there is little flex available when valves and pistons collide. Thus, the forces can be very high. Also make sure that the cam bearing caps have not been forced up, stripping threads. Bedding in of new tappets to the old cams is somewhat iffy -- chances are that with 80,000 miles on the cams, things will go ok, if the car has been otherwise well-maintained. However, the low compression suggests that perhaps the maintenance was less than adequate -- so the cams may be more worn that they should be, and will then not bed into the new tappets as well as they otherwise would.
Before cleaning the cams, the wear pattern should be evaluated. Typically, the polished area will taper, being wide at the lobe side and narrow (or invisible) at the heel side. If the entire width of the lobe is polished, that can be an indication the the cam lobes are seriously worn -- although this is something to verify by a specialist in these engines. If there is any fretting (tiny cracks or little chunks of metal missing) on either lobes or the old tappet surfaces, then the cams should be replaced or (at least) reground.
On the other hand if the owner is a gambling man, he could throw together the top end, replacing only the valves, guides, and tappets (and grinding the seats to match). The engine might be fine thereafter.
11/02/2009 7:25 PM
Hi Blink, you seem to be the Volvo knowledgeable guy and my Volvo car knowledge ends about 1980.
This string caught my curiosity as back then, when a belt failed they usually just stopped, nothing hit anything, (unless there was 'other slack'), so you just replaced the belt, did a few checks and mostly were back motoring next day.
So I'm wondering when did Volvo engineers decide that things could hit in belted engines? Or if it all has to do with valve cleaner in the oil, say producing "pump-up" in stuck-up (semi-seized) followers? I imaging this 'rigidity' would take out a belt too?
Y/N? Educate me?
“Don’t worry, they usually don’t swim backwards.” Steve Irwin
Good Answers: 145
11/02/2009 11:19 PM
Around the 1989 year model 740 GLE, also known as 8+8 and 16V. The option of a twin cam motor designated B234E/F was available as a normally aspirated performance engine . Produces around 153 Hp. This motor has 4 valves per cylinder and two cams. Also has 2 timing belts one for the cams and oil pump, and the other for the two balance shafts.
This motor was an option up to 1991/2 in the 940. The heads are now fairly sought after items as the 2.3 litre ford motor in the SVO Mustang gains considerable performance increase by the use of this head. After some fiddling about.
I dare say the B234 was Volvo's customer "beta" test motor for future applications. As versions of this Hemi style head can be found in the B6304 and whatever they use in the 850 and V cars.
The belts (both of them) must be changed no later than 80,000km/50,000miles or else the gods will wreak their vengance and have no mercy on you.
Appropriate maintenance assures longevity, These motors also have hydraulic lifters instead of shims under the cam follower buckets, this a god send for those who have tried to match up shims when setting the valve lash in a B23/230 motor.
I own two 740's, with one of each motor so I know their peccadilloes.
Good Answers: 247
11/03/2009 1:54 AM
I'd say in the early eighties. All the twin cam Volvo engines are interference types, and the single cam engines are not.
Interesting thought. Usually pump up cannot occur at ordinary RPM, because the valve springs are so much stronger than the springs inside the lifters. If the valves are floating from over-revving then pump-up is possible: the lifter expands to take up the slop when the valve floats, and then cannot leak down fast enough to keep the valve fully seated. Then on the next opening, the valve floats again and the lifter extends even further, etc. I think this probably did not occur on this engine, but it is an interesting possibility.
Good Answers: 247
11/04/2009 12:21 AM
I poked around the web for 960 info. Turns out that your pump up theory is quite possible, because these engines are prone to valve sticking. That could leave a valve slightly off its seat, causing valve lash, which the lifters would quickly expand to fill.
One solution for the sticking valves that is recommended, in addition to using synthetic oil, is what we always called an "Italian tune-up" in which you run the engine at high rpm for a while (Volvo evidently recommends 12 minutes at 5000-6000 rpm.) This site has lots of info on sticking valves, timing belt tensioner problems, valve-piston collisions as a result of timing belt failures, etc.
I'd recommend that our OP study the site linked above, and get the factory repair manual. These engines seem to have all sorts of interesting issues and quirks. It could make one nostalgic for an old 122. I remember thinking that the 240 etc. were a step down from the 122, in terms of overall reliability.
Good Answers: 97
11/04/2009 12:51 AM
The 960 comes with a lifestyle eh? Great link 144's more my speed
Good Answers: 97
11/02/2009 11:52 AM
While the complications of some replies are possible the likelihood of major engine damage having occurred is questionable considering the information given.
Depending on the method used the compression figures given can be repeated on a fresh new engine
But an experienced mechanic (not parts changer) should inspect the parts including the tops of the pistons with the cylinder head removed to then determine if further inspection is required. Valve guides are not always broken when valve stems bend and 80,000 miles may not have incurred sufficient wear to require replacement unless skipping the suggested maintenance periods was the SOP for this car.
The advice of an experienced mechanic may cost a little and it can save you a bunch. Can you visually inspect the tops of the pistons and determine if one or two have merely been gouged by collision of valves or have they become cracked? Drop the oil pan and inspect for debris and have the oil analysed. Then reply with the result please
Good Answers: 247
11/02/2009 1:20 PM
But not if the person doing the testing is competent, and if the engine has run for a few minutes. Even a brand new engine (if properly lubed on assembly) will show normal compression after just a few minutes of running time. I've done several hundred (perhaps over 1,000) compression tests, and have never had a normal engine in good condition indicate anything like 40 psi or 70 psi.
If an 80,000 mile engine has low compression, is consuming 30% more fuel than normal, and there are heavy tar-like deposits in the back of the exhaust valves, something is wrong. Given that there is no longer the option of checking compression with oil, or by pressurizing cylinders, then it is probably worth pulling the pistons. (On a 960, this probably means pulling the engine, but with the intake and exhaust systems already disconnected, this is not as big a job as it otherwise would be.)
It would be a shame to bolt everything back together, only to find that compression is still low, because of a cracked/stuck/crystalized/relaxed/worn out ring(s).
And yes, the advice of an experienced 960 mechanic would be very worthwhile.
Good Answers: 97
11/02/2009 3:40 PM
Score—B+ Though it seemed probable the OP may have not run the engine immediately prior to performing the compression test sequences because the timing belt was broken. I gave you a good answer.
There were no indication so lobbed that out hoping the OP would volunteer more pertinent info.
Could be the bent valves are contributing to this condition ya think?
It would be a shame to bolt everything back together, only to find that compression is still low, because of a cracked/stuck/crystallized/relaxed/worn out ring(s).
I agree do you have more information than that which has been divulged in this thread? Tough tarry goo does develop on the back of intake valves when the mixture is rich, possible causes abound.
If the cylinders are showing 40 psi though that figure is very low it maybe only a bent valve causing the low pressure reading, if the valve is not seating properly, etc.. Without eyes on by a competent mechanic or automotive machinist little conclusion can be determined.
Having been and automotive, marine and aircraft engine machinist I can express that the basics are nearly identical for all; specifications are specifications regardless of make, model and year.
We need more information on maintenance this engine has received, 80,000 miles is extremely low but not unheard of on a fifteen year old vehicle. I own a 1992 with 100,000 miles, the first ten years at about 3000 miles per year were a little old lady driving and she had the vehicle serviced every year even during a few years when the miles totaled less than 500 in case the oil etc got old too.
11/02/2009 4:23 PM
Maintenance...."A few weeks ago I put 2 cans of valve cleaner into the engine oil."
Good Answers: 247
11/03/2009 1:22 AM
There is also the thread immediately before this, named "Hydraulic Tappets." It sounds as if you think this engine has been running with bent valves, but I seriously doubt that it has. As the OP describes it, the engine was running fine but consuming more fuel than normal "prior to the engine failure." He says that the valve tappets were mixed up at the service area, and that he is now trying to reassemble the engine, but has some questions. It appears that the engine has not run since the timing belt failure/valve bending incident -- and it is reasonable to assume that it is incapable of being run with the bent valves. (And in general, only a nut case would throw a new timing belt on an interference engine and then try to run it.)
Bending valves would be a normal occurrence for this engine if it was running at highway speed when the belt broke (although bending all 12 exhaust valves suggests that the timing jumped just before the belt broke). At that point the engine would no longer run, and the engine was partially disassembled for inspection. An ordinary compression test would not be performed at this point because a normal compression test relies on valves opening and closing -- and that cannot happen in this engine. A leak down test could be performed (but with some difficulty); however, the values obtained would not be quoted in psi.
So a reasonable assumption would be that the engine was running OK but using a lot of fuel, and the goo on the back of the exhaust valve heads accumulated while the engine was running -- probably over many miles with relatively low compression, yielding low combustion and valve temperatures, perhaps with some oil leaking past the rings, and perhaps with some oil leaking down the valve guides.
I doubt it. I think the valves were bent as the result of the timing belt breaking, and the engine has not been run since.
Good Answers: 97
11/03/2009 7:02 AM
The compression test would have been performed before the failure and the resultant figures indicate running fine as a poor choice of words.
Much of what you've taken for granted doesn't make sense, all intake valves would not be bent under the conditions you've described. There is way too much turning resistance of the cams for them to continue rotation after the timing belt broke and all the intake valves would not be in a position to be bent. Some of the valve bending occurred prior to the timing belt breaking
Dents and gouges in the top of pistons don't necessarily produce detrimental conditions.
I don't presume to know the conditions before inspection.
Good Answers: 247
11/03/2009 2:31 PM
I don't either, but at least I'm willing to make something up!
True, although it was actually all the exhaust valves that were bent... but you are correct -- it seems odd that they all bent. It suggests (I'm making this up) that:
1. The the timing jumped immediately before the belt broke. Otherwise, if the engine were running before the incident with all the exhaust valves bent, then the engine would be unlikely to produce adequate power, would be very hard to start (if it could start at all), and the exhaust valves would quickly burn at the unsupported edge... but the owner describes them as looking good.
2. Another possibility is that the inertia of the cam and cam pulley was sufficient to keep the cam rotating for perhaps 1/4 second (may be 1/2 second), even against valve spring tension and collisions. If the owner was cruising along at 2000 rpm, then 1/4 second would be about 8 crankshaft revolutions, with the timing becoming progressively worse. It is a very rare multi-cylinder engine in which the cam pulley can not be turned by hand to align timing marks (with torque cause by closing valves roughly canceled by torque required to open valves, leaving mainly friction from the total spring load being the retarding force.) Guesstimating the torque required at 10 lb-ft would mean that inertia alone would keep the cam turning for a while, with energy absorbed in friction and pulses of valve bending.
All conjecture, of course. Perhaps the OP will come back to describe the sequence of events more clearly.
Good Answers: 97
11/03/2009 5:34 PM
Your correction of my comment about the valves caused me to re-read the OP's post.
Here's my make it up as I go routine. As I'm reading the description the lines are revealing hidden meaning of a distinct lack of attention to detail of a profitable schedule of preventative maintenance.
If professional mechanical service and inspection is not available, tow to an area with signage "Fill Wanted"
11/03/2009 9:38 PM
Hi Blink, thanks for the explanation. I had a look around for a drawing of the engine but found nothing, so am struggling a bit trying to follow the posts. I don't suppose you or Bwire know of a site where I can see a general assembly?
Good Answers: 97
11/03/2009 10:04 PM
11/04/2009 6:25 AM
Thanks bwire and thanks to Blinks link, I think I've got the layout/concept.
I'm assuming that belt path is to run the water pump and there is no cam advance.
But probably talking through my hat, I'm still inclined to think the valve stems foul, the valves get 'slow' then get hit, bent a touch, the followers pump up, valves get properly bent, breaking the belt. I think this is why all 8 are bent, whereas if the belt just failed, you'd expect a couple getting hit would stop the cam.
I'm still a bit puzzled why intakes are not bent. Do the exhausts open further? I.e. inlets are "non-interference"?
But curious as I am, I'm not $48 'books4cars' worth; which as things look, is about what a 960 is worth.
Good Answers: 97
11/04/2009 2:14 PM
Kyzine,
A part of discovery is the complication involved, a simple answer may not be quite right and a complicated answer not simple.
Of the many factors involved no measure of contribution can be realized beyond that knowledge of dirty oil having low lubricity contributing to sludgy goo in the presence of cylinder head heat. This lubricant condition and leaky valve stem seals may combine to produce gunk deposits on the back side of the valves. However this will not slow the valves, buildup of carbon on the piston top may interact with the valve though this type impact would not be expected to bend a valve stem. Dirty sludge producing oil can cause inadequate performance of the followers too.
Again of the many factors, heat, dirty oil having low lubricity and little attention to preventative maintenance overall and specific to the timing belt failure and had the timing belt skipped a notch causing poor performance over a period to then skip again which caused valve to piston interaction which may have culminated in the breakage of the timing belt. Such an order of progression could produce the result you've described.
The 960 is a valuable piece of equipment when maintained properly and if as Blink indicated the rest of the car is in serviceable condition you may be money ahead to rebuild this engine. If you have more time than money or are of the inclination attend some local adult classes pertaining to auto repair because with some knowledge, patience and a little helping direction you may succeed
Good Answers: 247
11/04/2009 3:59 PM
I like your theory.
The exhaust valves, as they close, are being chased by the upcoming piston. so with light valves, (and therefore light valve springs... compounded by the general trend to make valve springs lighter yet in the interests of less energy consumed in moving valves) and gooey valve stems, the valves could be unable to outrace the pistons. even if they don't get bent with the first hit, the lifter pumping up would make them get hit more firmly, a little later.
A few were bent apparently. Following the sticky valve theory: the intakes have a longer time to return to the seat before the piston gets close, because they are closing at a point closer to bottom center rather than top center. Also, the intakes are actively cleaned by gasoline detergents, and operate with a smaller temperature range than the exhausts. The intake valves also have larger heads (and therefore probably slightly heavier springs) so a given amount of goo would have less effect on closing rate. The exhaust valve stem clearance, when the engine is cold, could be quite tight, to allow for the greater expansion rate of the aluminum head and bronze guides. (Maybe -- although it is not unusual to have extra clearance on the exhaust valve stems because the stems are so hot, even though their expansion rate is low.)
Some of these Volvos will apparently refuse to start when cold for this reason -- the exhaust valves do not firmly seat, so compression is too low to start. One poster on the Volvo site suggested that grinding the starter for as much as 3 minutes would often help get the thing started. Presuambly, so much fuel has gone past the valves by that point that they get washed off a little.
So you get the thing started, and then the block starts to leak, due to porosity -- yet another problem with these engines. I've helped launch new Volvo models, and like the people at Volvo, but sheesh... this kind of stuff drives people over to Honda or Toyota (but then Toyota has their floor mats, and now rusting frames on pickup trucks.) Maybe tuneups every 5000 miles with an old VW were not so bad after all -- there is a lot to be said for simplicity.
Good Answers: 97
11/04/2009 4:19 PM
Blink I can't get my mind around this.
If the lifters are not pumped up the the valve will not reach full design extension, then when the lifters are pumped up they will not exceed the design extension at that time if the cam orientation is correct.
Some of these Volvo's will apparently refuse to start when cold for this reason -- the exhaust valves do not firmly seat, so compression is too low to start. One poster on the Volvo site suggested that grinding the starter for as much as 3 minutes would often help get the thing started. Presumably, so much fuel has gone past the valves by that point that they get washed off a little.
Spinning the starter for three minutes would contribute to expansion of a tight valve guide by friction producing heat. Raw gas washing the cylinder walls may reduce compression.
Good Answers: 247
11/05/2009 1:09 AM
I'm using "lifter pump up" in the hot-rodding sense. (Lifters are always full of oil, and only have to extend or contract by a thousandth or two in normal operation.) In an ordinary hydraulic lifter, the small piston inside the lifter is set to be somewhere near the middle of its travel. If any valve lash develops, the lifter expands slightly (due to internal spring force), additional oil enters through a one-way path, and the oil, being non-compressible, makes the effective length of the lifter slightly longer. If the lifter has constant pressure on it (as from a valve being held slightly off its seat), it slowly leaks down, until the pressure is low (when the valve is back on its seat). In normal operation, the required expansion and contraction is very slight. (In cars with solid lifters, the difference between hot valve clearance and cold valve clearance is only .001" or so, depending on the metals used, relative location of the cam(s) etc.)
Where this system goes haywire is when the valves float from over-revving. Then there is lots of valve lash, which the lifters will take up. There is not enough time for leak down, so on the next cam revolution with the valves still floating, the lifters "pump up" a little more, and so forth. This leaves the lifter effective length too long, so that when the lifter is riding on the cam base circle, the valve is slightly open. Some people have reported engines being very hard to start for quite a while after valve float, until the lifters leak down -- even half an hour. (This is hard to believe, because the old standard method of setting lifters on V-8s was to crank the rocker arm pivots down 1/2 a turn after they were quiet with the engine running. If these lifters did not leak down fairly quickly -- in less than a minute, I'd guess, these cars would be hard to start after a tune-up -- but they weren't.) Isky makes lifters that are resistant to pump up from over revving.
The same sort of pump up can occur if the valves are sticking. Valves will only stick as they get close to the seat, where valve spring pressure is lowest. As the valve sticks and the cam backs away, valve lash occurs, and the lifters take it up, leaving the valve slightly off the seat when the lifter is on the base circle. Then, at full lift, (and everywhere else on the cam) the valve is being lifted too high, leading to the potential for bent valves. The average lifter probably has about 1/8 inch total travel, so depending on how it is initially set, the valve could be held significantly off its seat when it should be on its seat.
Good Answers: 97
11/05/2009 1:31 AM
Thank you for clarification and you very tactfully have made me aware how far off my range I've strayed
I would not have considered Volvo would produce such junk.
11/05/2009 9:15 AM
Hi Blink, nicely explained, may I add (for other readers) hydraulic lifters were 'invented' to deal with "manufacturing tolerances in valve trains" which resulted in "noisy tappets". Certainly not an aim of increased performance.
Might I also add, ref; being very hard to start for quite a while after valve float, until the lifters leak down -- even half an hour. (This is hard to believe, because the old standard method of setting lifters on V-8s was to crank the rocker arm pivots down 1/2 a turn after they were quiet with the engine running. If these lifters did not leak down fairly quickly -- in less than a minute, I'd guess, these cars would be hard to start after a tune-up -- but they weren't.)
Entirely true from "the old standard method...", I remember it as a quarter turn, but no, never had a starting problem - quite the opposite.
However, if you recall there was a spate of oil additives around in the 70's > 80's one of which contained some sort of shite that coated everything in a white deposit. The idea was it rebuilt 'white metal' type surfaces - (big ends, mains) and 'cured' piston slap.
The upside was it did for a bit. The downside was multiple treatments 'cured' all other fits like hydraulic lifter clearances, any little galleries (as in crankshaft feeds) and oil pressure relief seats.
When you add to this; the folk most likely to use this "miracle fix" had previously put grease or gear oil in the engine, and likely banana peal in the gearbox, to quell noise and smoke haze, that "half an hour" is not that "hard to believe".
By contrast, I have hands-on experience of a 21 year old - 4.1, 6 cyl petrol engine with 2nd time around 979,000 km and no wear you'd bother with, not even a bore lip worth honing, never-mind reaming. The only thing that separated it from all the same age and km basket cases was it was run from new on Castrol RX super - diesel spec oil. Not the recommended - either by Castrol or the vehicle maker - but in hindsight the right one. And no additives - ever
11/04/2009 5:27 PM
I like your theory. Damn, I was just about to enroll in adult classes.
Thanks for puzzle input. I missed that some intakes were bent.
The 'farmers' cure for this is a bit of ether, "get a bit of detonation happening - that 'll close 'em"
I so agree. This engine sounds like the love child of boy racer and marketing guy. About as suitable for the average commuter as the Jag V12.
Good Answers: 247
11/03/2009 11:46 PM
This article provides a drawing of the head assembly. You'll have to imagine the valves, (and the rest of the engine).
11/02/2009 5:21 PM
A timing belt will break if not changed within a reasonable time .
When a belt breaks your valve train will be damaged extensively.
Also , the aluminum pistons will now have gashes in the crowns that will cause detonation and pre-ignition problems.
As the other guys have advised , you need to completely rebuild your motor or find a replacement long block.
She is 15 years old , is she worth it .?
What dosent kill you makes you stronger , lifes a trip so sit back and try to enjoy the nice scenery.
Good Answers: 145
11/02/2009 6:09 PM
When it comes to 7 and 9 series Volvo's, they have to be in a really bad state not to be worth repairing. As the bodies are not known for rusting in odd hard to get at places most of the issues are usually poor mechanical maintenace or outright neglect.
Even the base poverty pack Volvos are nice enough to drive on the daily commute, the Upspec ones have all the "features" considered "essential" by todays standards.
I will fess up to owning two 740's (1 saloon, 1 Cammer 8+8 Wagon) they are equal to the current crop of repmobile and hair dressers cars only with more character and predictability.
Best of all I can let my teenagers at them knowing that they'll (the teenagers) come home alive and in pretty much the same condition they left. Not so sure about my cars though... Chances of surviving a high speed impact in a 7/9 Volvo is significantly greater than many other makes of vehicles.
Just my tupence worth..
Good Answers: 123
11/02/2009 11:48 PM
You have left us with a few questions.
1. Is the head still off?
2. Have you replaced all of the bent valves yet?
3. When did you put the valve cleaner into the oil? Before the belt failure or after the repair? Was the product designed to be put into the oil?
My best suggestion from the information you have provided is to have a competent cylinder head specialist examine your head, and tops of your pistons. Take his advice on how to proceed. Good luck.
Bob
11/06/2009 11:17 PM
Hello Gentlemen and Thank You very much for your information
1 The head is still off
2 Yes I have replaced the valves
3 Before the failure by 6 weeks
Register to Reply 37 comments
Anonymous Poster (1); Blink (9); bob c (1); bwire (11); Franksgarage (2); Kyzine (5); machine head (1); Planet of the Apes (1); severach (1); Tobugrynbak (3); Tom_Consulting (2)
You might be interested in: Vacuum Lifters, Gas Valves, Industrial Valves
