I was looking into the control wiring of the switchgear provided by the switchgear vendor and noticed that the 'Lockout relay coil' is connected in series with a signal lamp called 'Healthy Lockout Relay' signal. The trip contact of the relay is connected to the Lockout relay bypassing the signal lamp. In this case, because the control voltage is divided between the lamp and the relay coil, the Lockout relay is partly powered but not operated and the lamp ensures the lockout relay is not damaged. In case of fault, the full control voltage is applied to the Lockout relay and it is operated with fault.
Same design is also applies to the trip coil.
Can anybody share any adverse impact of this design. I need to approve it but I need your valuable input before approve.
Thanks in advance.
- MS
