Previous in Forum: cable schedule &cable block diagram   Next in Forum: Drum Level Deviation
Air Consumption Rate for Control and Shutdown Valves
04/27/2010 4:44 AM
How we can calculate the the air consumption rate for control valves and shutdown valves to help in determine the air compressor capacity?
Good Answers: 141
Re: air consumption rate for control valves and shutdown valve
04/27/2010 5:26 AM
Depends on: Size of valve, media to handle, frequency of use, type of valve. It is all about mass to handle: heavy things need more energy and use more air. Check the manufacturer's data.
Plenty of room here
You might be interested in: Gas Valves, Industrial Valves, Solenoid Valves
