Previous in Forum: NGT and NGR   Next in Forum: Earth Rod Extension
Electrical - Overloaded Generator
07/16/2010 4:05 AM
what are indiaction and causes of overloaded generator?
Re: electrical
07/16/2010 4:09 AM
Slows down and trips. Load too high.
Re: electrical
07/16/2010 4:36 AM
The cause will be the connection of too much load for the equipment to supply.
The indications:
  • If it's been installed and commissioned correctly, operation of (a) circuit protective device(s).
  • If it hasn't, something like this:
Re: electrical
07/16/2010 7:34 AM
indication-change in sound
Re: Electrical - Overloaded Generator
07/16/2010 8:19 AM
Dear Sir,
Indications : Abnormal noise / drop in speed / drop in voltage / slows down
and grinds to a halt / heavy black smoke / AVR burnt out etc.
Causes :(1) Sudden heavy loads coming on set ( like failure of soft-start
mechanism used for heavy loads). (2) Bearing failure of the generator (3) Any piston
seizure on the engine side. (4) reduction or no supply of Diesel to the set. (5) less
air intake etc.
Manroop.Chennai.
07/26/2010 6:55 AM
Could you provide a few more details on what you are doing?
Your questions:
http://cr4.globalspec.com/thread/57744 ,
http://cr4.globalspec.com/thread/57745/electrical ,
http://cr4.globalspec.com/thread/57329 look a lot like homework is due soon.
Anonymous Poster (2); jignesh142 (1); manroop (1); PWSlack (1)
