Previous in Forum: solar panel   Next in Forum: Hydroelectric Potential
89 comments
Direct Current Energy Sensitivity.
07/31/2010 11:37 AM
Hi Everyone: I need your help with a personal issue.
I just recently discovered that if I came in close contact with a Direct Current power source such a battery I would loose my balance. I also found that if I was exposed to a DC energy source that was positive (+) I would be pushed backwards. When I was exposed to a similar DC energy source that was negative (-) I would be pushed forwards.
I have developed a test that incorporated a known energy source such as an AA Battery. This test allowed me to determine which polarity pushed me forward or backwards.
This test goes like this.
The first part of the test is.
1) Hold an AA battery in your hand with the positive (+) end facing your body.
2) Point the positive (+) end of the battery towards the base of your chest bone.
3) Hold the positive (+) end of battery about 2 to 4 ins. Away from your body.
4) After about 1to 2 minutes take note as to how you feel and if you feel any problems with your balance.
The second part of the test can be performed about 5 minutes after completing the first part.
5) Hold the same AA battery in your hand with the negative (-) end facing your body.
6) Point the negative (-) end of the battery towards the base of your chest bone.
7) Hold the negative (-) end of battery about 2 to 4 ins. Away from your body.
8) After about 1to 2 minutes take note as to how you feel and if you feel any problems with your balance.
I am trying to determine if this sensitivity to Direct Current energy is common among the population or am I the only one.
If you could try the test as described above and send me your comments it would be very helpful to me. Thanks in advance. Howard
Re: Direct Current Energy Sensitivity.
07/31/2010 11:56 AM
Howard,
Have you ever tried tasting a 9 volt battery by licking the contacts? Yumm.
If you put on a pair of roller skates and then held the battery in front of you with the negative side facing you, would you roll forward?
I had a girlfriend in college who was AC/DC, but that may be off-topic.
07/31/2010 12:15 PM
Hi: Thanks for you comment.
A 9 volt battery does not work as an energy source. This is because the + and - terminals are close to to-gether on the same end of the battery. This why the 1.2 volt battery seems to work to best for this test. I would not recommend liking the terminals of any battery you just never know what was there before. Howard.
07/31/2010 12:34 PM
Do you wear a tin foil hat when performing this "experiment"?
If you detect a note of skepticism you should.
If you held a 4 cell flashlight close to your chest would it knock you over?
Now, just for you, after I get home from work I'm going to ingest a couple shots of tequila and try this experiment.
That is if I can get out of that damn box that I'm in in another thread. The cat didn't help, either.
Good Answers: 119
07/31/2010 12:41 PM
I also feel similar attractive and repulsive forces caused by psychological perceptions. I find myself initially attracted to interesting topics, then repulsed by bad scientific test methods.
You need to perform your testing with the assistance of another person and in a double-blind manner before you can properly conclude that you have the reaction you claim.
07/31/2010 3:39 PM
Hi Everyone: I to have a real problem with psychological perceptions, bad scientific test methods and the like. I am the True Engineer for the Show Me State of Missouri.
For many years I tried to declaim the test in every way possible But in the end the results were the same. If I ignored the test results I got sick. If I excepted what the test results were telling me I could enjoy selected foods and medications without fear of being Uncomfortably sick for 10 days or so.
For those of you who would like more info on similar test called the "sway test" please check out the following link.
http://www.google.ca/#hl=en&source=hp&q=applied+kinesiology+self+testing&aq=6sx&aqi=g-s1g-sx9&aql=&oq=Applied+Ken&gs_rfai=&fp=4f87f900b18d902b
The "sway test" is used by many Chiropactors and Naturalpathic Doctors and described in detail on one or more of the links. This particular "sway test" does not work as described for me at all.
Once again thanks for all your thoughts. Howard.
Canada - Member - New Member
Good Answers: 39
08/03/2010 12:05 PM
I think the "show me state" needs a new engineer.
"The "sway test" is used by many Chiropactors and Naturalpathic Doctors and described in detail on one or more of the links. This particular "sway test" does not work as described for me at all."
Neither chiropactors nor naturalpathic (doctors) have ever been able to "show" that any of their methods do anything for anybody consistantly. Their practices are more magic than science.
All that is required for evil to succeed is for good men to do nothing.
Good Answers: 123
08/03/2010 11:59 PM
In an effort to eliminate the test subject from tilting the results, I am going to make a small change in the testing procedure. in stead of the subject standing on his feet, I am going to suspend the subject from a rope before exposing him to the battery. Does anyone think the results will be any different?
Bob
Good Answers: 114
08/04/2010 12:11 AM
or at least we'll know which sex the baby will be
Good Answers: 117
08/04/2010 11:42 AM
08/04/2010 3:22 PM
Hi: I can not do the sway test as described on this site either. For many years I did not trust the results that I was obtaining from the modified test that I use for checking for possible problem foods and chemicals. After checking my results against the results my Allergist received from his instruments and tests I became a believer.
My results were in the area of 90 to 95 % accurate while my allergist results were on the area 70 to 80 % accurate.
My allergist used a wide variety of tests ranging from chemical challenge tests, Electronic ( Vega instrument ) testing to Electronic medicine as practiced in China and East Europe. Over Several years of semi blind testing I did eventually become a believer. This is why I want to try and help others with similar conditions.
My plan is to go forward with Double Blind testing in mid September. The tests will be setup and viewed by a team of professional people who are mainly Professional Engineers.
I will be publishing the results ( Good or Bad ) on this group in a separate thread.
Thank you again for your time and comments. Howard From Oakville.
07/31/2010 3:40 PM
How long from when you first smoke the weed until the testing starts?
Also if a 1.5 volt battery does this to you how do you cope with the hundreds to even thousands of volts of static electricty that build up around you when you walk on carpet or anywhere else for that matter?
07/31/2010 4:00 PM
"How long from when you first smoke the weed"
07/31/2010 4:17 PM
Hi: All I can say is actually try the test and then coment. You might actually learn something.
Good Answers: 119
07/31/2010 5:15 PM
As an Engineer from the "show me" state you must realize your test is completely invalid.
Have someone else NOT in your presence:
> put a group of 10 batteries inside cardboard tubes and tape them closed so no one can SEE which end is which polarity.
> mix them up, randomly select, and randomly label the ends A,B,C,D,E,F ... until all the tube ends are marked.
Now NO ONE knows which end is which.
Perform your test and note which letter attracts and which letter repels. When the test is fully complete, open the tubes and record which polarity corresponds to which letter. Plot the correlation between the force you experienced and the actual polarity of the battery. IF there is statistically significant correlation, you can claim to be one of the few people on the planet with this sensitivity. I'd bet the outcome will be completely random, but we really need to see the results of a properly conducted test before we can accept your claims as anything other than an unusual psychosis.
Best Wishes
08/04/2010 3:36 PM
Hi: Thank you for the suggested format for the Blind Tests. I am putting together a team of professional people to setup, view and verify such a test in the manor that you describe. I expect to preform the Double Blind tests in Mid September. I then will post the results ( Good or Bad ) to the group on a separate thread.
As Always I take every comment very seriously. Howard from Oakville.
Good Answers: 39
In reply to #64
08/04/2010 3:42 PM
" am putting together a team of professional people "
That would be opposed to us amateur people?
Good Answers: 101
07/31/2010 8:53 PM
So what happens if you get exposed to AC? Do you just sway back and forth, or do you wriggle all over like John Travolta on the dance floor? If it's the latter, I suggest that you take full advantage of your unique "talent" to earn money by entering as many dance contests as possible.
Or maybe it isn't the battery at all. Maybe you were in the line of sight of my Force telekinetic exercises and were affected by them.
Or maybe you're simply still suffering from the residual effects of a Force telepathic mind control experiment I carried out some time ago.
Lord Vader out.
08/01/2010 3:12 PM
Good Answers: 119
08/01/2010 4:28 PM
Is that where they got the idea for the "Hypnotoad" ?
Good Answers: 123
08/02/2010 6:55 PM
The battery polarity had apparently caused the toad's hands to move as predicted by the OP.
Bob
Good Answers: 32
08/01/2010 4:48 AM
No, he's not kidding. I have EXACTLY the same results except that in step 4 I have to stand still for about 16 hours before starting to sway. It's uncanny!
johny451
Good Answers: 83
08/01/2010 1:08 PM
This is the best thread I have ever read.
08/02/2010 1:02 AM
Try the bath breaking thread then.
Good Answers: 83
08/02/2010 1:13 AM
08/01/2010 1:25 PM
Can't use a flash light?
Thousands of other typical home and shop items?
Now if there was a taser involved I could understand the backing up
If there was a vibrator involved I suppose some would be attracted and some repelled
I remember some clown going on about the magnetic lines around the earth and how they affected us. He wanted everyone to buy his book in order to understand what he was talking about.
08/01/2010 2:51 PM
So, I just went to the store and bought a gross of AA batteries. I'm going to sew them into a back pack and use them for propulsion when I skate.
No, wait! Do I have to wear it on my chest? Please help me, I'm about to install the batteries and I need to know which way to point them.
I'll be stuck watching NASCAR till I find out. Hurry!
Good Answers: 123
08/02/2010 7:00 PM
If you allow yourself to think about it for a few hours, you may discover that there is a natural occurring place to put the batteries that will allow you to still have 2 hands free. As a plus, you will be propelled forward.
Bob
08/01/2010 5:18 PM
Good Answers: 74
08/01/2010 7:40 PM
Instead of pulling and pushing you should try what I did. It took a long while but worked as you can see.
Good luck.
The Twain Has Met
08/01/2010 10:43 PM
Ahnold on the right, Casper Milquetoast on the left....
Good Answers: 130
08/02/2010 4:41 AM
It's alright; it can be fixed....
08/02/2010 9:24 AM
How bad is the chaffing?
Nothing exceeds like excess.
Good Answers: 97
08/02/2010 9:32 AM
I had similar results from experimenting with charge-coupled steroids, It was difficult to keep from kicking sand in my own face!
CRTL-Z
Good Answers: 130
08/02/2010 10:44 AM
GA
08/02/2010 9:29 AM
Reduce your electrolyte consumption
08/02/2010 12:07 PM
Hi Everyone: Before you Totally Dump this thread into the Dumpster I would invite you to read the following Link.
ttp://journalinformationalmedicine.org/hbf.htm
I do want the Thank Everyone who took the time to comment on this thread.
The good part is the test is still working for me. I use a modified version almost ever day to determine if I will have problems with foods I eat or the medications that I take.
Most of us except the fact the people with peanut allergies and sensitivities can become very ill if exposed to a micro amount of a peanut or a trace of peanut oil in a food product. I am able to detect the presence of a micro amount of a peanut products in foods by using the modified version on this test. For the past several years the test has not let me done.
You do not need to use a battery to perform this test. You can just use your personal battery powered watch. When I use my watch as an energy source, I place the face of my watch facing my chest. The result is I am forced backwards. If I place the watch face facing away from my chest I will be forced forward.
This test is a very personal test. It is not a test that could be used in a clinical setting in its present state. Each personal is an individual. Some who people who experiment with this test may feel no reaction at all while others will experience their own special set of reactions.
Go Figure: Howard.
08/02/2010 12:19 PM
Howard,
I apologize for insulting you.
I have not read the link, yet. I am truly happy that these tests help you. Please continue to do what's best for you and if this test makes you better, that's great.
You have taken the ridicule well. I did to the thing with the battery, but, nothing.
Good luck to you, sorry I couldn't help.
Good Answers: 97
08/02/2010 12:43 PM
Howard,
After contemplating the fact that divining rods actually work, I feel compelled to apologize as well.
I am sorry.
CRTL-Z
Good Answers: 97
08/02/2010 12:48 PM
What the...wait a minute, Journal of Informational Medicine?
I retract my appology.......
No, I apologize, really this time.
CRTL-Z
08/02/2010 1:41 PM
The Journal of Informational Medicine seems to have a lot in common with my fantasy fiction books - except that I expect my books are more accurate.
Quote from the web site,'
The subject of scalar physics is fraught with all kinds of political, commercial and scientific controversy; some say a conspiracy by governments and corporations to keep scalar phenomena a secret because of its both helpful and harmful potential.'
I just love the governmental/corporate conspiracies that prevent the citizen from having access to xyz BS. There is no conspiracy!
That web site is for the 1st class loonies of wacky land!
Good Answers: 114
08/02/2010 1:10 PM
Well there is a lot of it
here's one bit that stuck out
In 2008, a research team led by Hynek Burda using the program "Google Earth" accidentally discovered that magnetic fields do affect the body orientation of cows and deer during grazing and/or resting. In a followup study in 2009, Hynek Burda and Sabine Begall observed that magnetic fields generated by AC power lines actively disrupted the orientation of cows to the magnetic field lines of the Earth. This is compelling evidence that this phenomenon is real and has a direct effect upon the HBF.
& a fun Picture
Good Answers: 97
08/02/2010 2:17 PM
What on earth is the red part? Effects of spicy foods?
Another study disclosed that the cows where suffering from M.A.D. (Magnetic Anomaly Detection) cow disease.
CRTL-Z
Good Answers: 114
08/02/2010 4:45 PM
Aren't most high voltage powerlines AC?
& aren't the various magnetic lines around the earth, closer to DC?
I like the pink parts myself
Good Answers: 97
08/02/2010 5:08 PM
I saw another thread about the re-introduction of HVDC distribution. so it must be that most are AC, for long distances at least.
Objects (coils) passing through at right angles to the earth's flux lines would produce AC. (this statement subject to further review by professionals). I wonder if snakes avoid coiling under high voltage wires?(subject for another discussion?)
As the cows pass through these flux lines, they become udderly disoriented, so there is no telling what sort of behavior Japanese cows would exhibit.
CRTL-Z
Good Answers: 74
08/02/2010 5:11 PM
We live at "ground zero" here. Even Captain Cook got his bearings wrong. It might explain why I am standing still although making progress. All in the mind. And all over matter. I feel sorry for .......???? It'll come to me, Ky.
The Twain Has Met
Good Answers: 97
08/02/2010 5:23 PM
ky,
looked up Magnetic Island, beautiful place! Wiki says Captain Cook is the only one that happened to. That is strange.
CRTL-Z
Good Answers: 74
08/02/2010 5:39 PM
Maybe Jdhautomation is just as lucky or unlucky, who knows? He should come here for a Holiday and get it out of his system once and for all, Ky.
The Twain Has Met
Good Answers: 119
08/02/2010 1:55 PM
There is no argument that everyone is different and that each of us have the potential for unique problems and/or abilities. However, a true impartial test is required to determine if the noted conditions are real or only imagined. The mind can have a powerful influence on the body, but the question is whether the stated effect is actually physiological or psychological. A double blind test can determine this.
IMO, the site link provided contains one of the most creative (and useless) collections of historical, scientific, mythical, and spiritual anecdotes I've ever seen. I have to give the site author credit for spinning such an enormous mix of plausible and implausible information that many readers will just acquiesce and accept all the information as fact.
Good Answers: 97
08/02/2010 2:11 PM
There is rumor that the paper was actually written by either Professor Irwin Corey, or a member of the Self Proclaimed Erudite League (SPEL).
CRTL-Z
Good Answers: 97
08/02/2010 12:26 PM
I have purchased a pair of electric socks and although quite warm for this time of year, I am able to levitate!
CRTL-Z
08/02/2010 12:29 PM
Don't they make gloves, too. Hell, maybe you can fly.
Good Answers: 39
08/03/2010 12:14 PM
Wait save your money, you don't need gloves.
To fly you simply have to throw yourself at the ground ............ and miss. (Douglas Adams)
Disclaimer: This can be quite painful until you get it just right.
08/03/2010 1:06 PM
There's too much ground to miss.
Anyway, this doesn't compare to: Omniscience, is The Origin of Conscience and Science!
Cheers.
Good Answers: 123
08/02/2010 6:48 PM
I had a similar thing happen to me. I was changing out batteries on a golf cart (48 volt). I removed the dead batteries with no problem. But when I went to attach the new batteries, I was amazed to find that it was harder to put the positive battery cable on the first battery than the negative post. As I worked my way through the batteries, it became more noticeable. The negative post would almost drag me to the battery, while the positive post became almost impossible to get my hand to.
I am thankful that the voltage was not any higher. I could have been hurt.
Bob
Good Answers: 123
08/02/2010 7:18 PM
If likes repel, and opposites attract, then the OP must have some electrical energy available in his body. If I submerge him in a water tank in the back of a truck, can he generate hydrogen for free? If so, can I drive the truck on the hydrogen he produces alone?
Over (unity)? Did you say over (unity)? Nothing is over (unity) till we say it's over (unity),
Was it over (unity) when the Japs bombed Pearl Harbor..............................
Bob
08/03/2010 2:26 PM
I experienced this weird phenomenon yesterday while I was moving car battery's around. Every time I picked one up I just seem to feel this power wanting to bend me over or cause me to move forward but yet when I put the battery down I felt like I could stand up strait without difficulty.
I noticed this effect seems to work with other objects too! The heavier they are the more effort I need to put forth to keep standing up.
I think some physicists should look into this.
Good Answers: 97
08/03/2010 3:20 PM
I think I may suffer from "Direct Current Energy Induced Turrets Syndrome". This occurred when the battery hatch on my lantern opened and the six volt battery fell out on my toe.
CRTL-Z
Good Answers: 114
08/04/2010 12:00 AM
Splarf
Good Answers: 117
08/04/2010 1:25 AM
So, let me get this right then....you are like, deathly allergic to peanuts and you depend upon a battery to tell you whether the food has any peanuts in it.
Okay. Been nice knowing you.
So, what was the point of your post? You state that you need help with a personal issue. You want to see if you are not alone in your sensitivity? I can help with that!
So just to be a nice guy, I tried it. This was a serious test because you see, it seems I am deathly allergic to mosquitoes. No really, they can, and have killed me. (takes a lot of them, and thank goodness for paramedics when it happened. If there was an easy way to prevent such things with only a battery monitor, I would be on it like a chicken on a june bug.) I was distressed but not particularly surprised to note that there was nothing about my balance which would change if I was to be outside (where the mosquitoes are) to when I am inside. In fact, as I watched them land on me, I still got no results that I could detect. So, jdautomation, I did as you asked, and I might add, at some personal risk to myself. It doesn't work for me.
I fear what you have is an ideomotor reaction, and you have fixated on the use of a battery. If you ask enough people, you too will get anectdotal results which will tend to support your findings. Its very common, and is no reflection on your honesty, training, or even educational level. Even Mr. Randi feels that you should be treated with great respect but he points out that if you really can do this, he will hand you a million dollars. He explains the procedure in the above link.
ideomotor reactions are the force behind dowsing rods, and likely your swaying in your shoes by batteries. The above link also has Randi explaining amulet healing and double blind tests, and so forth. I read your link, and I ask you to please, please please please simply read the above links. It will take you about the same time as it took me to swat all those mosquitoes.
Actually, lets face it, I am the ultimate outside authority because in reality, I don't really care if you actually can do this or not. I proved to my own satisfaction that I personally can not so what you can do does not affect me. But if you really want your personal abilities to be proven to yourself, and the respected members of this forum, then please do the double blind test suggested on these pages, and then let me know when you are going to go for the million simoeons...you can share with me, after all, I gave you the idea right?
08/04/2010 2:22 PM
Hi: Thank-you for your interest and the results of your test. I personally do not have a peanut allergy as recognised in the Medical Community. My Grandson does have such a peanut allergy. I do have a peanut sensitivity. If I consume products containing micro amounts of peanuts or peanut oil I will become ill. I do not rely on the battery test for any of my sensitivity testing. I use a modified version of the battery test of this purpose. The only purpose of the battery test is to determine in an individual is sensitive to + or - DC power sources.
My purpose for posting this topic to the group was to see if there might be some interest and what the response from this community would be. I am truly amazed at the reaction to this topic. I was expecting 0 to NO reaction. That has not been the case.
The reaction has been such that I will be moving ahead with Double Blind Studies probably in mid to late September of this year. I am currently assembling a short list of professional personal namely P.Eng's. who will view and certify all aspects of these tests.
I would like input from all on how the group would like to see the Double Blind test setup and the type of Results Verification Documentation they would like to see.
When the tests are completed I will publish the results on this group for further peer review.
Thanks to All for your input: Howard from Oakville ON.
Good Answers: 117
#82
In reply to #60
08/05/2010 11:16 AM
It is a little remarkable that the professional skeptics, like Mr. James Randi and Jeff Wragg are so much more respectful than the members of this forum. Actually, in some ways, you should be proud that they gently mock you...if they thought you were truly mentally retarded, they would be much less nasty, and more understanding, but of course, no less dismissive. The fact that they mock you means that they feel you are totally sane but possibly holding a delusion. Don't let them get to you...many of them hold their own delusions, you should have seen how I got attacked by mocking the bull shit science of chiropracty a few months ago! (if that isn't a red flag to the bull I don't know what is....bring it on dudes! But use a private email like stag@cyberus.ca instead of clogging this forum with off topic claims and I'll send you links which will make you think instead of merely react.)
I admit to holding many delusions myself over the years....the delusion that all red lights were against me is actually a pretty strong and common one. I thought that my healing broken leg could predict the weather! And for awhile, I felt better when I ate more fiber but it turned out that was because I actually was eating breakfast instead of just tossing back a coffee! And that I was perhaps deficient in vitamins so I was multi dosing myself with multi-vitamins...but again, I have determined that there was no real benefit to myself unless I owned stock in the multi-vitamin company. A regular steak and eggs breakfast was superior to all the fibre vitamin self therapy I could come up with! ( And lets face it, for many years I held fast to the delusion that the Liberal Party of Canada had my best interests at heart! Boy was I deluded!) I bet many of the people that have mocked you here have bought "active-on" or "head-on", or hundreds of other nonsense remedies, so they are just as "delusional", and have no call to make fun of you.
I said "delusional" as if it was a bad thing. There is nothing bad about a delusion...any more than there is anything bad about an optical illusion. It is nothing more than a manifestation of the way our brains are wired. In fact, the "smarter" you are, the more likely you will be to seek an explanation for things that happen in the world around you. Any stage magician will tell you that the easiest audiences to fool are academics, and the most difficult to fool are children. So there is no shame in being fooled by a professional con man, none whatsoever in being fooled by an optical illusion, and no call to be mocked by people who don't know the mechanism by which your "sway" method tells you things that your subconscious feels you need to know.
My feeling is that the battery is a red herring. That the sway mechanism will work just fine with a dead battery, or a wand with plus or minus on it. The subconscious mind is a powerful thing, and it demands answers. I can think of a dozen ways that your subconscious mind could make patterns and the only way it could communicate with your conscious mind is by making you do some battery test. Mine communicates with me via dreams. All of us need to communicate with our subconscious mind in some way. Neither of us are crazy.
If your question was legitimate, and not just a troll to stir the pot, then I will take you seriously, and will give you some serious advice....and that is to study how con artists earn their money, study how the mind works, and you can start your studies by going through the articles on "quackwatch.com". There are a lot of them. Then see if you can refute the studies on "Science based medicine" . Have a copy of the sceptics encyclopedia at hand, and please don't think that sceptics are your enemy. (Actually, if you were to use your battery test to test foods for deadly allergens before feeding your grandson, they and I would suddenly become your enemy.....as would the CAS, the courts and his parents. I am glad you pointed out that you do not do so. A parlor trick which could have fatal consequences is no longer a parlour trick!)
If after all that information, you still feel that you can detect bad influences in food by using a magnet, then do a double blind test. Be warned however in the event of a negative result, that your subconsious mind will resist the results of that test...coming up with all sorts of reasons why it did not work "that day" or under "those conditions", that you were under too much stress or whatever. If you get a repeatable positive result, then we may well be on to something! And at that point, it will be time to research it further, and all the people on this forum who dismissed you will suddenly sit up and take notice. I am sure I can find some people in Oakville who can administer such a test, I know people there.
stag@cyberus.ca
(for anybody who wants to yell at me for anything I have said here. I can yell back just fine! With footnotes and references! grin!)
#83
In reply to #82
08/05/2010 12:05 PM
Hi Thank very much for your encouragement. When I posted this tread I did not expect the path to be smooth. I was just hoping that I might find some who would actually do the test as described and experience similar results. The responses have been a way more that I ever expected. Thank You To All.
We must always keep in mind the battery has no part in the test that I use to identify my food and chemical sensitivities. The battery is used only to supply an identifiable (+)positive and (-) negative polarity energy source. I used the battery only to show what polarity actually pushes me forward or backwards no more or no less.
Once We have completed the Double Blind Study and posted the results (good or Bad) I will then describe in detail the test that I actually use to identify problem foods and chemicals. I am hoping this test will be of some benefit to the many who suffer from Electrical and Multiple Chemical Sensitives as I do.
You mentioned You Know people in Oakville. I would be pleased for them to come and view the blind test, hopefully in late September or early October. Could you send more info in a private CR-4 email so they can be included.
Once again Thanks to All the group for all your comments and questions. Howard.
Good Answers: 114
#85
In reply to #82
08/05/2010 1:41 PM
You probably are on to the actual mechanism.
the batteries are just a prop, the sub conscious mind being far more accurate in many of these matters than we can measure.
there is something to the power of positive thinking [not in the over the top delusional way]
I have experienced the results of extended concentration on a goal, what ever you would like to call it
You are what you think
everyone has their own way of defining their connection to source, which by it's nature is is impossible to define
it is always important to do your due diligence & this is not the best venue for this conversation in terms of the intangible aspects...
I certainly have not been as harsh as I would to someone in the realms of overunity
Good Answers: 97
08/04/2010 6:59 AM
I'm Very Interested In Hearing Some Half-Baked Theories
As an ill-informed pseudo-intellectual with a particular interest in the unverifiable, I'm always on the lookout for some partially thought out misinformation. So, if you have an uninformed solution to a dilemma that doesn't actually exist, don't bother double-checking your information. I'm all ears.
However, I must warn you: If you want to convince me of anything, you better be prepared to back up your claims with rumor, circumstantial evidence, or hard-to-make-out photographic proof. I may also need friend-of-a-friend corroboration or several signed testimonials all written in the same unmistakably spidery handwriting. I'm a quasi-critical-thinker. Things have to add up more or less in my head before I let myself be taken in by some baloney story.
read more...
08/04/2010 2:39 PM
Hi: Thank you for your interest and attached links.
As I mentioned in another reply I will be moving forward with Double Blind Tests probably in mid September. I will be publishing the results on separate thread for the group to provide a peer review of the findings ( Good or Bad ). If this research will help one person avoid the Electrical and/or Chemical sensivity issues that I have experienced for more that 30 years it will be worth the effort.
I am looking forward to reading your peer reviews of the test results ( Good or Bad )
Once again Thanks for your time and responses. Howard
Good Answers: 97
08/04/2010 1:03 PM
I have confirmed that my neighbor is sensitive to Indirect Direct Current.
How? you ask. My neighbor and I were in his Man-cave (Garage) admiring the engine in his car when I casually mentioned "You know, there is no way you can get a shock from your car's battery." "Huh, what if you wet your fingers?" he countered. "Nope" I said and demonstrated. Here you try, I offered.
He cautiously approached the battery and as he touched the terminals, I simultaneously honked the horn. After he recovered from the contact with the hood of his car and the back of his head, (it was obvious he was pushed backward) he strongly advised me to go home.
CRTL-Z
08/04/2010 1:13 PM
Love it!
08/04/2010 2:47 PM
Hi: Great Comment. Why not connect one end of a booster cable to one post on the battery and hold the other end near his chest bone. Please do not touch him with the cable. You may be surprised with the results. As Always: Howard.
Good Answers: 97
08/04/2010 3:54 PM
Howard,
As much as I would like to try the booster cable experiment, my neighbor has not quite recovered and is convinced he has been visited by Saint Elmo.
CRTL-Z
Good Answers: 39
In reply to #66
08/04/2010 4:10 PM
He is the patron saint of muppets....right?
Good Answers: 97
In reply to #67
08/04/2010 4:33 PM
I believe so.
Which begs the question, Who is the patron saint of patron saints?
CRTL-Z
Good Answers: 123
In reply to #69
08/05/2010 12:11 AM
Is there a specific application form I would need to apply with, or is a standard resume acceptable? I am certain that appointment would help me avoid 1 ) Traffic tickets. 2) Long lines at better eating establishments. 3) getting stuck with ugly dates.
Please send whatever information on the position you can. Thank you.
Bob
Good Answers: 97
In reply to #70
08/05/2010 9:30 AM
Preliminary study:
CRTL-Z
08/04/2010 4:16 PM
I stuck a 1.5 volt battery in my ear, and it blow my brains out. dose that count.
Good Answers: 123
08/05/2010 12:19 AM
In dealing with a group of batteries, that are each 8 volts, and arranged in series to produce a combined voltage of 48, What would you expect the reaction to the individual connections of the batteries to be? the positive of the first battery is connected to the negative of the second battery. The positive of the second is connected to the negative of the third. And so on.
Would the reaction be different from one end of that connecting cable to the other?
Bob
#84
In reply to #71
08/05/2010 1:21 PM
Thank you for the questions: In regard to the expected reaction I would expect the result would be the same as described in test. When I first began experimenting with using a battery as an energy source reference I used a 9 volt battery. When I positioned the battery terminals near my chest I experienced no reaction at all. It appears that because the terminals were close together one polarity cancelled out the other. To get the 9 volt battery to work I attached about 3 ft of wire to one terminal and held the other end about 2 to 4 ins away from my lower chest bone. I experienced the same results as I do now with the AA battery or watch battery. It would appear that voltage has no effect on the results of the test. I have not worked recently with DC voltages in the 40 volt range so I really have no personal experience to share. I do know that if I was working near DC voltages in this range I would be very careful.
Thanks a gain for your question hope this helps. Howard
08/05/2010 1:46 AM
Put some batteries in your boxing gloves, and you'll be ready for Muhammad Ali.
In reply to #72
08/05/2010 2:08 AM
Which do you recommend for taking on a great boxer (in his prime)?
Lithium ion
Nıckel metal hydride
lead acid
AGM
NiCad
In reply to #73
08/05/2010 2:22 AM
Maybe Jdhautomation could add this to his impending experimental design, and include the results in his report? This would align well with his interests and investigations.
Good Answers: 130
In reply to #74
08/05/2010 5:57 AM
I feel obliged to point out that 'loading gloves' is illegal.
So you might only get away with those Polaroid flat foil ones. This then leaves the problem of creating polarised ends.
Good Answers: 83
In reply to #75
08/05/2010 8:58 AM
But that still leaves the problem of what shoes to wear...
Good Answers: 130
In reply to #76
08/05/2010 9:06 AM
Anything you wear is, by association, illegal.
Good Answers: 97
In reply to #76
08/05/2010 9:42 AM
Do these clash???
CRTL-Z
Good Answers: 114
#81
In reply to #80
08/05/2010 9:45 AM
Room for batteries too
In reply to #76
08/06/2010 10:40 AM
I left this thread for saner pastures, and just ran across this.
I vote for the lime/white. That'll go best with Unredundant's shoe selection.
Good Answers: 83
#87
In reply to #86
08/06/2010 10:59 AM
Perfect selection--it's my favoUrite coloUr! It matches my complexion.
In reply to #87
08/06/2010 11:52 AM
What? your complexion isn't peaches 'n cream?
Good Answers: 83
#89
In reply to #88
08/06/2010 12:07 PM
Good Answers: 97
In reply to #74
08/05/2010 9:35 AM
It is possible that Jdhautomation has already tried Lithium.
CRTL-Z
Register to Reply 89 comments
34point5 (4); Anonymous Poster (3); Apothicus (4); bob c (7); bwire (1); DVader1000 (1); Garthh (6); Jaguar (1); Jdhautomation (11); Johny451 (1); ky (3); lyn (8); mjb1962853 (4); PWSlack (1); russ123 (4); sue (5); szwasta (1); tcmtech (2); Tornado (3); Unredundant (15); Usbport (1); Yusef1 (3)
You might be interested in: Battery Holders, Sample-and-Hold Amplifiers
