Previous in Forum: Earthing of Weld Metal for CS,SS&AS   Next in Forum: Can We Use LTCS (P1 Through P11 Materials) Welders for SS (P8 Materials)?
Piping"0" Bar Pressure
07/22/2011 1:20 AM
Dear Sir,
Piping"0" bar pressure, is there any test required?if it is required what type of test is required?as per which code?
Re: Mechanical Engineering
07/22/2011 1:27 AM
Whatever test might be required, the piping is almost certain to pass the test.
Good Answers: 101
Re: Piping"0" Bar Pressure
07/22/2011 6:52 PM
"0" bar?
Um....
Did I miss something?
07/23/2011 10:57 AM
0 bar is the same as 15psi, only from the outside in. Test for 15psi leaks and you are good to go.
Good Answers: 299
07/25/2011 8:59 AM
"0 bar is the same as 15psi, only from the outside in."
Every time? Is this a vacuum line, and zero bara?
Register to Reply 4 comments
Deefburger (1); Doorman (1); RVZ717 (1); Tornado (1)
You might be interested in: Piping Services, Bar Code Software, Piping Systems
