Previous in Forum: Roswell Incident Dissected   Next in Forum: Tacky Silicone Rubber
27 comments
Cast Iron Soil Pipe Access Plate
06/06/2012 7:26 AM
I'm looking to break into a cast iron soil pipe to run in the condensate from a gas boiler (suitably neutrailsed).
There is a small access plate (a rounded parallelogram shape) held in with two bolts, these are brass and have sheared at the slightest torque.
Now I could just leave it alone as it is still soild, or I could open it it up and drill/tap the holes. So...
a) What is the thread, I think it's 5/16 UNC.
b) Why brass bolts?... they may not corrode, but they are as much use as a chocolate teapot. What material would be best (SS?)
c) Should I forget adapting to the access plate and use a strap boss on the side.
d) Why did the weather go cold and wet as soon as I started work dissmantling the central heating?
Re: Cast Iron Soil Pipe Access Plate
06/06/2012 7:40 AM
"Break" and "cast iron" in the same sentence. <sigh>.
06/06/2012 8:32 AM
Is that the san(m)e cast of the bath tube from a while back?
Sorry cant help with the material selection.
But
How about duck tape?
06/06/2012 9:05 AM
Blimey the quality of help around here has gone right down the soil pipe.
06/06/2012 10:20 AM
" d) Why did the weather go cold and wet as soon as I started work dissmantling the central heating?"
It's simple, really.
The first law of thermodynamics is you do NOT talk about thermodynamics.
06/06/2012 12:22 PM
06/06/2012 1:10 PM
Been there done that. I've cut into it at head height and above that it's plastic.
The bottom of the boiler is only about a foot above floor level and I can't cut low enough to join because of the weird shaped boss with the access plate which is only just above floor level. Pic below shows a similar type plate.
But thanks for a serious response at last.
06/06/2012 1:35 PM
Cut a hole in the plate with a hole saw thread the hole, and install an adapter....
06/06/2012 2:04 PM
That's what I intended to do, when the heads sheared as It's easier to drill and tap on the bench rather than in situ especially as the plate is shaped to conform with the inner bore of the pipe, mind I could replace it with a flat plate.
Gotta answer Qs a) to d) first.
06/06/2012 2:46 PM
You can perform this task in place, just glue the adapter in place....Make sure your hole saw has a guide bit....I would add a threaded coupling for disconnect....
06/07/2012 9:51 AM
Did I say coupling, well I meant union, anyway I'm sure something will work out...cheers
06/07/2012 10:03 AM
I've got an adaptor coming tomorrow which might do the job. I'm working on the flue at the moment... and yes it's raining and cold still.
February was warmer and drier than this
06/07/2012 10:41 AM
I sympathize with you, it seems the older I get, the stiffer I get, and the cold and rainy weather just makes it worse... Fortunately, you can bask in the warm friendships you have acquired here, and elsewhere, to help ease the pain....
06/06/2012 5:51 PM
Del,
I'd leave the plate alone and go for a separate hole tapped into the pipe wall.
The inspection plate is there to enable easy access to the inside of the pipe when something gets clogged. If you hard plumb it into another system then the complexity for a simple inspection gous up.
Just like your question d), I can predict (Through application of Murphy's law) that you will have a blockage that will require the complete removal of the inspection plate and associated modifications and your boiler will then be off line while that happens.
PS. I'd go for SS bolts and brass nuts. (That way in future if they do gall together, the nuts are the cheapest replacement item.)
06/07/2012 2:26 AM
Cheers, some good points.
If I bear them in mind I could re-furbish the inspection plate as it's NFG unuseable at the moment .
As it's just the condensate line I'll be plumbing in I could make it dissconnectable, that way I'd have a useable inspection plate and the condensate couls go into a bucket during any necessary work.
I like the idea of going in on the plate as the fitting won't then protrude into the main bore of the pipe with the associated risk of causing the predicted blockage.
I'm still thinking round the whole the thing... plenty to get on with in the mean time.
I've got the new boiler in, and I've just about re-done the pipe work to give me two zones separating upstairs from down. New pipework will take the heating to the far end of the house where it was previoulsy starved of flow.
I've added a gatevalve so I can choke down the upstairs flow to give an overall coarse balance.
My garage will have so much pipwork it will look like a submarine... Arrooogah Arooogah... DIVE DIVE
Canada - Member - New Member
06/07/2012 10:42 AM
I agree with Just An Engineer, leave the clean-out as a clean-out and use either a threadolet or a pipe saddle for the boiler drain.
It simplifies future blockage issues.
Elroy
Knowledge makes what was impossible, seem easy.
08/25/2015 11:42 PM
Hi Elroy,
Could you tell us where i can buy the saddle as shown
06/08/2012 8:11 PM
It looks like you have found a solution. But if you have to get into drill out and re-tap, I have a gadget that helps do that; I've had to use it only once, and it helped even though I had the most difficult breakage--bolt broken flush with the casting. If the break is above or below the surface, it is easier to use.
Website www.quikcenter.com.
Lehman57
06/09/2012 3:01 AM
Thanks for the input guys.
I managed to find a fitting at a local plumbing store and got ot fitted last night. Drilling that cast iron was real squirrel pig, The daft thing was, I found the cheapo drill bits cut better than the expensive ones. I had to push hard to get 'em to bite but if I pushed too hard they'd snap. I did a fair bit of re sharpening too and found the cutting angle needed to be quite steep. Got there in the end. As I had to drill an odd shaped hole (round but with a flat top and bottom) I went round the outline with a 4mm drill. Must've broke about 10 of the suckers.
Pic shows the fitting and the hole almost propared. I would have used a KrisDelTM stick on to save time , but they only come in 'round'.
Good Answers: 97
06/09/2012 2:04 PM
Well done though replacing the brass with brass studs will avoid galvanic corrosion from an SS combo. The brass may also be there in a case where one might intentionally break the brass fasteners when removing the access plate.
06/11/2012 11:32 PM
Del, there is another cautionary note for you.
You state this is the soil pipe. As such it will be connected to sewer and probably also to the property "stink pipe". This means that odours from that environment could be directed into your basement.
(I won't get alarmist about flamable concentrations of Methane, of noxious concentrations of Sulfur Dioxide.)
You need to include a "water trap" in your pipe. This could be done with a "U" shape or a single (vertical) loop in the pipe. From your pics it seems that you are using a large enough diameter pipe that it would not syphon. You need enough diameter that water dripping into one end can flow through and dribble away at the other. Both ends are open to atmospheric pressure.
In the months when you are not using your heater you might need to add a little water to make up for evaporation, otherwise you'll get stinky summers too.
I'd hate for Mrs cat to get unhappy with what's happening downstairs. (And if you did get odour from the pipes, it could take months to dissipate.)
I'm sure you're smart enough to take it from here.
06/12/2012 2:53 AM
Thanks.
There is a water trap in the boiler, I've added another, and a limestone neatraliser for the condensate.
The main thing is... we don't have a basement!
If you have a spare one, you could PM it to me and I could slide it under the front door, it would come in handy for some of our junk.
I got the heating up and running yesterday, took all day to get the air out odf it and sort out some minor probs.
06/12/2012 3:01 AM
No problem, how big do you need?
I'm building a small mound and need to find a hole to get the materials from. Would 200m by 50m by 3m deep be enough or will we have to subdivide?
06/12/2012 5:33 AM
That's a bit big, but if you divide it up I can use some for installing a rainwater tank.
06/12/2012 6:47 AM
Can you spare a bit for a replacement sceptic tank, please? The old one's leaking doubts all over the rosebed.
06/12/2012 2:22 PM
We had a leaking septic tank several years ago--the grass "downstream" sure grew good and was a beautiful shade of green. Doesn't it make roses grow better?
Lehman57
06/12/2012 5:46 PM
There is ample opportunity to subdivide the hole and Del's water tank would be more like a swimming pool. I'm sure he would allow you to share the space.
Just send the excess material to my PM and I'll look after it from there.
06/13/2012 3:56 AM
Just be careful opening the PM. A hole that size opened carelessly can wreak havoc.
Register to Reply 27 comments
Andrew VN (1); bwire (1); Elroy (1); IdeaSmith (1); JohnDG (2); Just an Engineer (4); Lehman57 (2); Mizuti (1); SolarEagle (5); user-deleted-1105 (9)
