I am generally inexperienced in how to
conduct "boundary layer" calculations and am unsure how to
approach the problem I will now describe:
I have a steel strip (x, ft. wide)
traveling in a closed looped fashion at a strip speed (speed, fpm) of
~1500 ft./min. In part of the loop, the strip is submerged in a
quiescent water bath and then exits vertically from the bath into ambient air
and travels vertically. I want to estimate the volume of water still
on the strip a vertical distance (say L, ft.) from the water surface.
I expect this is a "boundary layer thickness" calculation, but I
have no knowledge as to what assumptions can be made in the
calculation. Please provide any equations and assumptions made. FYI,
this is a real life situation, not a "Homework" problem.
Thanks
