Previous in Forum: Boundary Layer Thickness Problem ?   Next in Forum: Cheap Trick to Connect a Regular LED to 120 VAC?
12 comments
3Phase AC Motor Controller Schematic Diagram
09/07/2012 9:13 PM
anyone can give me a schematic diagram,layouts and parts list of high wattage 3phase ac motor controller?thanks
Re: 3phase ac motor controller schematic diagram
09/07/2012 9:46 PM
You will never build one for less than what you can buy a good new or used one for.
Good Answers: 982
09/07/2012 11:41 PM
Could you give us any less information?
Good Answers: 34
09/08/2012 12:31 AM
Could you be more specific?
"high wattage"
How much high?
09/08/2012 10:35 AM
from 2kilowatts up hoping for someone can help me..
really appreciated...
Good Answers: 34
09/08/2012 11:12 AM
09/08/2012 11:28 AM
its like PWM (PULSE WIDTH MODULATOR) it can controll the 3phase ac motor its a varaiable controller..,,, anyone or anybody have an idea, knows a link or have a design for this?really appreciated,,,
Good Answers: 34
09/08/2012 12:33 PM
Please throw all your cards on the table first, for all to see what exactly you want to know.
Good Answers: 982
09/08/2012 12:44 PM
Most PWM controlling is done by a microcontroller today. The microcontroller then controls either an SCR or IGBT to actually steer the current to the motor. (I'll leave it to the student to identify the advantages and disadvantages of each of these component selections.) To copy somebodies hard work of a three phase motor controller design you will also need to have the source code of the microcontroller. This is typically written in C, C++ or assembly language.
I see a lot of homework in your future.
09/08/2012 4:10 AM
Yes, Guv. Anyone can do this when they have the details off the motor rating plate.
Good moaning!
Re: 3Phase AC Motor Controller Schematic Diagram
09/09/2012 3:43 PM
3 phase variable speed (or variable frequency) drives are common and very inexpensive for what they are, they are however ridiculously complex and expensive to build yourself, so just go and buy one.
You will NOT be able to build one cheaper than what you can buy one for, and it is not suitable or safe for a DIY project due to the complexity and amount of equipment required to build and program the microcontroller, switch mode power supply, DC energy storage systems, etc.
Jack - Actually services these things.
Good Answers: 982
09/09/2012 6:19 PM
Aw, now you spoiled some of my fun.
I was really going to enjoy the fantasy of this OP going through all of the learning curve of switch mode supply design, microcontroller programming, three phase inductor motor starter circuitry and the obligatory troubleshooting required to not just buy something off of the shelf.
09/09/2012 8:34 PM
.......and the few thousand dollars worth of necessary test and programming equipment.
It really is a most difficult and expensive project, and even the experts that manufacture the VFDs don't get it right all the time as I have found.
Register to Reply 12 comments
Crabtree (1); jack of all trades (2); Joshi (3); kakkoi (2); redfred (3); tcmtech (1)
