I've been roped in repairing my grand kids toys, not that i mind..! anyway, I need to repair a nylon pinion gear, my question is, will araldite stick to nylon, and in turn, to steel shaft...?
These posts amuse me. You will get a "can't lose" adhesive selection with each response.
To me, "Araldite" is a company name and not the name of a specific adhesive. Could be any number of things, but let's assume it's a polyamide cured epoxy. Sure, go ahead and use it.
The real secret to successful adhesive bonding is surface preparation as much as the adhesive.
Back in my day, we used hexafluoroacetone sesquihydrate to prepare nylon for bonding. Really.
Unfortunately, it's hard to bond thremoplastics with most adhesives, but an epoxy is as good a choice as any. Clean everything after sanding it first.
There's a lot of torque on gears, so I'd not be surprised if it fails.
Give it a try.
If you have all the pieces, you might want to explore making a reproduction of the gear using silicone rubber tooling and epoxy to cast your own gears.
Most cyanocarylate-based adhesives will come in handy for such tasks. Any home hobbyist would do well to keep small quantities of the following handy:
General multi-purpose glue, like UHU (usual disclaimer)
2-pack quick-setting epoxy resin adhesive for jobs that need space-filling stuff that is also sticky
Cyanoacrylate (the "super" glues), which only works well on joints where the air can be excluded from the joint
PVA woodworking adhesive
Impact adhesive
Solid-stick-based paper adhesive
With that lot, one can mend most things.
