Previous in Forum: Gas Turbine Parts   Next in Forum: Hand Elevator And Dumbwaiter Question
41 comments
Shear Pins
06/19/2013 2:40 AM
The plant I work at has a direct drive coupling with a shear pin arrangement on the drive sprocket. The pin isn't exactly a shear pin, but a 4.5mm mild steel bolt.
The drive is running a linked chain with small wheel carriages running inside a formed rail structure. (Monoveyor is the trade name) we recently added another 30 metres of chain and relevant carriages and since this time, regularly break the shear pin. The corner sprockets for this chain are of alloy construction.
My boss wants to increase the pin dia to 5.5mm. is this wise.
5
Re: Shear Pins
06/19/2013 5:11 AM
In order to evaluate the wisdom, one must consider the function of the shear pin mild steel bolt. It is most likely there as the first line of defence against mechanical overload so that, in the event of a mehanical problem, the shear pin breaks first rather than some other part of the mechanism with attendant risks to life and limb.
The shear strength of the shear pin mild steel bolt needs to be evaluated in terms of its ability to shear and thereby to protect the rest of the plant from a greater faliure. If the rest of the plant can withstand the forces involved in the shearing of the larger shear pin mild steel bolt, then fine. If it cannot, then make sure that the boss is standing underneath the plant when the larger bolt fails to shear on mechanical overload so as to accurately evaluate the consequences of his/her actions.
Without doubt, the best plan is to contact the equipment manufacturer and change the mild steel bolt for a shear pin of the correct size without delay, and document that this has been done, and why.
Incorrect Shear Pin
06/19/2013 9:23 AM
I tend to agree with PWSlack on this.
Another possibility... the shear pin mild steel bolt is correctly sized, and your added 30 meters is too far beyond the design of the mechanism. Was there a constant issue of breaking the shear pin mild steel bolt before this modification?
Re: Shear Pins
06/19/2013 9:28 AM
Crystal ball broken? Can't quite see the chain from here?
Never mind, problem solved. See above. No more broken shear pin mild steel bolts.
Re: Shear Pins
06/19/2013 9:39 AM
Agreed!
The direct drive makes me think this isn't intended to tolerate a lot of torque.
[edit] Well, I read again and it says direct drive coupling... it would be useful if we knew more. However, if the advice of PWSlack is followed all will be revealed.
Re: Shear Pins
06/19/2013 9:23 AM
Use a plastic drive sprocket, instead of steel. That'll insure that the shear pin mild steel bolt will not break first.
Now if we only knew how long the conveyor was before the 30 meters of new chain were added, we MIGHT be able to help determine the added stress applied to the system by the additional 30 meters.
Nope, insufficient data for meaningful solution.
Do what Slack said.
Re: Shear Pins
06/19/2013 9:42 AM
Are you binding somewhere?
I went to Texas A&M, I am proud to be an Aggee. Proud to be an Aggey, Proud to be an Agie.............Proud to have gone to Texas A&M.
Re: Shear Pins
06/19/2013 10:43 AM
Yes, thank you.
But, I went to the doctor yesterday/last week (don't remember exactly, time traveling is not without its attendant hazards) and he gave me something to loosen me up. No time travel today, till I get this binding problem fixed.
Re: Shear Pins
06/19/2013 1:18 PM
LOL!
United States - Member - NE, USA Hobbies - Target Shooting - New Member Engineering Fields - Aerospace Engineering - Engineering Fields - Electromechanical Engineering - New Member
Re: Shear Pins
06/20/2013 7:57 AM
In the future, less cheese, more fruit.
If the binding is so bad that it shears the pin, you might have to return to the doctor. But for now it sounds like you have under control.
The strangest thing to me was that when your time machine returned, it was cold and the husband was dead.
United States - Member - New Member Engineering Fields - Instrumentation Engineering - Popular Science - Cosmology - Beam me up Scotty!
Re: Shear Pins
06/19/2013 5:48 PM
Just encase entire unit in Mil Spec. oil or grease (must be Mil spec) to reduce the binding due to friction. Take an 800 mg motrin and do as PW suggested "then make sure that the boss is standing underneath the plant when the larger bolt fails to shear on mechanical overload so as to accurately evaluate the consequences of his/her actions". **safety note- wear safety goggles, steel toed boots, flame retardent clothing and hard hat
"Experience: that most brutal of teachers. but you learn, my God do you learn." - C.S. Lewis
Re: Shear Pins
06/19/2013 9:44 AM
Just weld the f$£%&@ thing up solid, and be done with it.
Re: Shear Pins
06/19/2013 10:27 AM
To the naughty step with you!
Re: Shear Pins
06/19/2013 11:34 AM
<titter>
Re: Shear Pins
06/19/2013 12:06 PM
Careful! You don't want your brain to release the magic smoke out your ears.
Take a dram and relax for awhile. Saving the world is thankless, indeed. But, somebody's got to do it.
Re: Shear Pins
06/20/2013 2:16 AM
Put a buck in the jar.
Good Answers: 266
Re: Shear Pins
06/19/2013 12:12 PM
Did anyone in their decision to add the 30 meters of extra conveyor. Take into account the additional load?
Re: Shear Pins
06/19/2013 12:47 PM
No.
Re: Shear Pins
06/19/2013 5:53 PM
Is that a Rhetorical Question? I know you know the answer is obvious I think Lyn answered it for us.
Good Answers: 266
Re: Shear Pins
06/20/2013 7:31 AM
Rhetorical or not. We do not know whether they thought about it. Maybe Lyn is right. So the question points them in the right direction. Maybe they did think about it and don't have the skills to compute the additional load. Maybe they did and don't give a s*#t.
The shear pin is there to protect something. Since the 30 meter addition it appears to be doing it job. Now to increase the size of the shear pin it may cause damage to what ever it was to protect. Which could be personnel.
Re: Shear Pins
06/20/2013 11:35 AM
Agreed!
Good Answers: 11
Re: Shear Pins
06/19/2013 3:57 PM
The shear pin is there to protect your motor/gear reducer. Putting a larger shear "device" will put them at risk. If you're habitually breaking shear pins, the motor and gear box are probably already overloaded. One way or another, you need to find out how much practical torque you need to operate the conveyor and size your power components accordingly.
Additionally, if the conveyor is running not-so-smooth, or jerky, then you are probably introducing a shock load onto the coupling as well which will prematurely break the pin.
People Living in Competition, All I want is to have my peace of mind - Boston
Re: Shear Pins
06/19/2013 4:30 PM
We don't have sufficient information from the OP to make any intelligent recommendations.
We don't know how long the conveyor was before the 30 meters of new conveyor was added.
By the way, machine bolts should never be use as shear pins. They are not as strong as a smooth pin and may not fail consistently. I liken them to mechanical fuses.
Re: Shear Pins
06/20/2013 2:26 AM
And we dont know if 30 meters is the total length or is it the loop length. The loop could be 15m or the chain length could be 60m.
We don't know what is being conveyed, or if this is a ramp or level conveyer.
I don't know the same things you don't know. I just don't know.
Re: Shear Pins
06/20/2013 4:12 AM
Me too! Me too! I don't know nuffin, But it's my guess that a larger motor, coupling and gearbox are required. Next we know the chain will be breaking instead.
Re: Shear Pins
06/20/2013 4:40 AM
Maybe the motor fuse will blow?... But you can then use the 4.5mm bolt to replace it.
That sucker won't blow
(yes folks that's a joke I don't really advocte replacing mains fuses with 4.5mm bolts...a six inch nail usually does the trick)
No no, that's a joke too.... damn this could carry on all day....
Re: Shear Pins
06/20/2013 4:41 AM
Nah! Then the cable and the supply fuses would need uprating.
Re: Shear Pins
06/20/2013 4:48 AM
I thought I had the fuses covered
Re: Shear Pins
06/20/2013 5:23 AM
Maybe it should have a VFD on it?
Re: Shear Pins
06/20/2013 9:59 AM
Re: Shear Pins
06/21/2013 11:42 AM
Several.
Re: Shear Pins
06/20/2013 10:02 AM
No-one has mentioned the possibility of the motor overload device needing a bigger piece of Duck Tape to keep it from popping out, though...
Re: Shear Pins
06/20/2013 4:07 AM
After reading the replies to your question I have also come to the conclusion that there is insufficient information to give you a definitive answer.
What length is the overall conveyor now, what width is it, what material is the chain, did the original conveyor come with a shear pin or a mild steel bolt, is the motor man enough to handle the new loading an extra 30 metres of belt carries, also 30 metres of extra belt equates to an extra 15 metres worth of product.
I assume that the inserted part of conveyor is of the same construction as the original conveyor? All return guides/rollers correctly aligned?
I design conveyors here in the UK for the food and plastic moulding sectors, very rarely do we use shear pins but tend to use a direct drive with the motor/gearbox correctly specced with a torque limiter if necessary.
Ok Ignore all that above, I have just looked at the specs of your conveyor and it is an overhead rail arrangement. Are you working within the manufacturers guidelines for loading? Are the hangers correctly spaced for the lbs/foot loading?
http://www.conveyingsolutions.us/images/Series%202000_2007_rev.pdf
This document provides you with all this information assuming that is the correct series style of conveyor.
I still need to know if the manufacturer supplied a shear pin or a mild steel bolt when the system was originally installed. It could be that a mild steel bolt has a lower shear strength than a shear pin.
If i can help with anything just ask, i will try and help if i can.
Steve
Re: Shear Pins
06/20/2013 5:47 AM
maybe I need a shear pin here ?
Del (Shameless Del to you)
Re: Shear Pins
06/21/2013 1:45 PM
if you're the type of person that finds replacing blown fuses annoying so you wrap new fuses with foil to get them to last longer...you might want to keep going with steel. this is a designed feature to stop excessive loads from damaging your equipment. you would be foolish not to utilize the grade of material the OEM suggests (probably aluminum). the pin broke because you're asking too much of the system.......don't over-ride that, only tax the system to it;s designed limits, not beyond
Good Answers: 114
Re: Shear Pins
06/23/2013 9:21 AM
The questions, the questions.
Who made the decision to add the extra load? I suspect the manager.
Who decided not to clear it with the OEM first? I suspect...
If you don't take all the good advice above, try a high strength alloy bolt of the same size before you drill it out for a bigger one.
Re: Shear Pins
06/25/2013 12:12 PM
NOPE! Just going to a "Higher" grade or "Higher Strenght" alloy bolt, when you have NO IDEA of the shear strenght of the previously used "Mild" bolt is a sure way to find broken parts soon, guaranteed! I have seen people replacing bolts in various pieces of equipment, only to find the equipment now failed at a more critical place or was totally broken. Even changing the physical size (diameter) of the bolt can invite trouble since you cannot easily trace the bolt quality or material... A way to find out would be to devise a MEASURING jig of some kind. I would use an automotive torque wrench and then machine a supporting plate to hold the bolt to be tested, and then apply a shearing force by placing a second plate above, pivoted with a much stronger pin used as a shaft. By applying a torque to that jig, it can be used as an effective shear that can be used together with the torque wrench to quickly find the shearing force limit of the bolt, and then compare several bolts of "mild" vs "strong" materials. But as others have already said, without knowing the strenght and limits of the design, it can be easy to start breaking other things and not the intended "shear-pin". Amclaussen.
Murphy was overly optimistic
Re: Shear Pins
06/26/2013 3:04 AM
All comments are right,but the entering statement;..."using mild steel bolt" - instead of shear pin,is more than maintenance omitment....
Re: Shear Pins
06/27/2013 6:19 AM
Amarquez said he would use an automotive torque wrench to measure the shear strength of the bolt and that got me thinking. You could attach the auto torque wrench to the drive sprocket and measure the torque there, multiply by a factor of your choosing ( based on the overall setup ) and spec your motor, gearbox and coupling from that.
Re: Shear Pins
09/10/2013 10:49 PM
Well, not exactly. My idea was to implement a simple but effective way to get some reliable numbers, (remember the KISS Principle: Keep It Simple S....!).
The first problem is finding how strong the original shear pin needs to be... since we don't know its specs, material, grade, etc. Thus, we can resort to device a simple means to get some numbers. One way to do it, is by comparing the shearing strenght of a known (published) specification common steel bolt to get the number for the (unknown properties) original shear pin.
I was trying to get an easy, repeatable way to compare the shearing resistance of a similarly sized reliable, consistent, good quality bolt, to the shearing strenght of the original shear pin; by improvising a pivoting shear. (Imagine two rectangular steel plates with three holes each one; one hole is a large polished one that houses a short and robust shaft working as a pivot; and two smaller holes located at an identical short distance from the pivot; one hole is threaded and houses a known data common bolt to be sheared (Ouch!), then you can use a smooth hole to house a lengtht of the original pin, which is sheared (Ouch again!) to get a second torque wrench reading value. A simple way of applying a torque to one of the plates while firmly supporting the other, would be a simple square hole to house the square drive of the automotive torque wrench!) That would work as a reliable shearing device that can be used to find the torque value needed to cleanly shear a known strenght bolt, THEN we can use the device to easily and acurately measure the shearing torque needed to cleanly cut (shear) the original shearing pin. By comparing both values and taking into account any sectional area differences, we could establish what was the intended shearing action required in the original design. Amarquez.
Re: Shear Pins
09/11/2013 5:57 AM
Yes I agree. What you describe is a test rig to compare a known component with an unknown one. Given that the unknown component was driving the setup before then a replacement component that has the same shear will be required. Right? NO-wrong! The O.P. says he wants to extend the line and thereby add more load to the shear pin, which is why I suggested using the torque wrench to measure ACTUAL torque required to move the extended line. From that he can derive the REQUIREMENTS for the shear pin and indeed the whole drive train and also for the line itself.
Jim
Re: Shear Pins
09/11/2013 1:33 PM
Well, that would be the best way...
BUT, measuring actual actuating torque at electric motor speeds isn't going to be that easy, or the required instrument won't be cheap or easily available either!
Another indirect, but practical and inexpensive approach would be to measure electric motor running current, and compare the measured value against published data for that exact motor model. End of the problem! (unless the motor was oversized, or the transmission and rest of the mechanism is undersized, and something breaks!)... that perverse Murphy again and again!
Register to Reply 41 comments
1tech (3); amarquez (3); AverageJoe (1); Deefburger (2); Doorman (2); Fredski (1); Jacob Klepatch (1); JCase (2); JIMRAT (3); lyn (6); ozzb (2); passingtongreen (1); PWSlack (6); ronclarke (2); stevewicks (1); tcmtech (1); user-deleted-1105 (4)
