Previous in Forum: Fault Current Calculation   Next in Forum: Facing Problem in CT Operated Over Load Relay
Neutral CT Insulation class
12/13/2013 6:20 AM
I have come across selecting the Neutral CT for transformer (132kV/33kV) for 33kV side. CT ratio has been finalised but its highest voltage level and insulation class are to be decided yet. Please help
Pathfinder Tags: insulation class NCT
Good Answers: 181
Re: Neutral CT Insulation class
12/13/2013 9:06 AM
I'm sorry but if you have to ask a bunch of random guys on the net, should you be anywhere near a transformer of that size?
Good Answers: 131
12/13/2013 12:34 PM
Think about it this way:
If the transformer's neutral connection to ground were somehow to become disconnected so that it is no longer at ground potential, you could under some conditions have full 33kV potential across the CT's insulation to its physically grounded base. It will need to withstand that voltage if you want to keep the "magic smoke" in it.
12/13/2013 12:35 PM
You can do it.
We have faith in you.
Go for it!
Do your best!
Give it your best shot!
Success comes to those who work for it.
We're all behind you.
We know you'll succeed.
That's about all the help I can give you. Let us know when you've figured it out.
Register to Reply 3 comments
lyn (1); PeterT (1); TonyS (1)
